  3. stb analysis of a fully diff amp
  • Subscribers 136
  • Views 28903
Laoud
Laoud over 11 years ago
Hi there,
I have designed a fairly standard fully differential amplifier, with a capacitive common mode feedback (the standard one with transistors). This amplifier will be connected in closed loop as an integrator, so I have a capacitor in the feedback. I want to check the stability of both differential and common mode loops by using the diffstbprobe. My question is where exactly do I have to insert this module and what I can probe with that? Do I have to insert another stb probe in the common-mode feedback loop?
    You would use a diffstbprobe when you have a differential loop (i.e. two feedback paths). What you're doing is measuring the loop gain at that point - so it's usually fairly obvious where you place it - it needs to be a point where there is a single path (in each of the two halves) - if you have another path which is bypassing the route through this component, you're not analysing the loop in the right place.
    The diffstbprobe can be controlled from the stb analysis form - on the form you can choose whether it analyses the stability of the differential signal or the common-mode signal in that loop.
    If you have a separate common-mode loop, you'd place an iprobe in that loop too, and then use the stb analysis to separately analyse the stability of this second loop.
  • Laoud
    Thanks Andrew for your prompt response. I have tried diffstbprobe and it works fine. I have also placed the iprobe in the CMFB loop and checked the stability. Though, I am trying to find a way of checking the open loop gain-phase response of the amplifier from the same testbench. Any ideas?
    Kind Regards,
    Costas
    Costas,
    Can't you just plot the loop gain from the stb analysis (it's on the Direct Plot->Main Form)? That's generally what you really want, rather than trying to bias the circuit to actually function correctly open loop (given that I assume you're not going to actually use it open loop).
    Or maybe I've misunderstood your question...
  • Laoud
    Yes, I can plot the loop gain from the main form, but what I also want to do is to plot the open loop gain of the amplifier individually . This may not be feasible from the same testbench, since the amplifier is already connected in a feedback loop. Unless, I will remove the RC feedback and conect it as a unity-gain amplifier (but in this case I have modified my testbench).
    I hope my question is clear.
    I know that this is a more technical question but anyway thanks.
    Costas
    Costas,
    If you really want to simulate it open loop, then really you need a different testbench. Normally the loop gain is similar to the open loop gain (although that of course depends on your feedback loop, which from what you said is changing the loop response).
    You could use the spt1switch/spt2switch etc components from analogLib which allow you to configure connectivity differently for different analyses - although not sure that's quite what you want either.
    Or you could use the same testbench and have two different config views (created with the hierarchy editor), and use the "Bind to open" capability to omit certain components in different simulations - you'd have two ADE states (or two ADE XL tests) to do this.
