  3. pss simulation - saving currents
  • Views 6369
JorisLambrecht
JorisLambrecht over 11 years ago
when I do a PSS simulation (shooting) and try to plot the results in time
domain (via Results - Direct Plot - Main Form - Function: Current), the node voltages can all be plotted but
the only some of the node currents are saved.
For instance, the currents through the inductors are saved but the drain current though a transistor is not:
ERROR: "/M0/D is not a kept output".
I can't find where it is defined which currents will be saved and which will not.
I tried to add them to the "to be plotted" outputs manually, this doesn't work.
Then I tried pss - options - Output - save all, and outputtype "all", but the current still isn't saved.
Greetings,
Joris
    Joris,
    When you say "this doesn't work" for using outputs "to be plotted", then it won't plot the currents - because the auto-plot  in this way only works for DC, AC and Transient analyses. However, if the save checkbox is checked, it should save the currents. So I'd like to know what doesn't work...
    Look in the netlist to see if there are save statements having done this (or Outputs->To be Saved). Saving all device currents is a possibility (in the save options form) but if the models are subckt models, this won't work because saving device currents only saves the currents for the primitive devices.
    I don't know which version of spectre you're using, but you may also need to turn on the "useprobes" option on the save options form - this is called something like "save ac currents" (I haven't got access to Virtuoso at the moment to check).
  • JorisLambrecht
    I forgot to check the to be saved box . If only the "to be plotted" box is checked,
    it doesn't save them unless the "to be saved" box is checked as well. My mistake.
    Greetings,
    Joris
