  3. ERROR (VACOMP-1008): Cannot compile ahdlcmi module library...
  • Views 15401
zongya
zongya over 11 years ago
Hi all,
    I'm trying to simulate a voltage-controlled current source in veriloga. But spectre gave me the following errors:
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/2012_vlsix_fishy1_asl6_veriloga_veriloga.va.asl6.ahdlcmi/Linux2.6.18-402.el5+gcc/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (SFE-91): Error when elaborating the instance asl6. Simulation should be terminated.
The log file ahdlcmi.out shows:
ahdlcmicompile: Compiling ahdlcmi in input.ahdlSimDB/2012_vlsix_fishy1_asl6_veriloga_veriloga.va.asl6.ahdlcmi/Linux2.6.18-402.el5+gcc/ for Linux2.6.18-402.el5+gcc with optimize using gcc on Wed Mar 25 16:14:06 EDT 2015 [5.0]
ahdlcmicompile: Generating makefile
PATH:  /opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.1/install/bin:/opt/cadence/installs/ic/bin:/opt/cadence/installs/ic/tools/bin:/opt/cadence/installs/ic/share/oa/bin:/usr/synopsys/E-2010.12-SP5-2/bin:/opt/cadence/installs/EDI110/bin:/opt/cadence/installs/VIPCAT113/tools/bin:/opt/cadence/installs/VIPCAT113/bin:/opt/cadence/installs/incisiv/kits/VerificationKit/bin:/opt/cadence/installs/incisiv/bin:/opt/cadence/installs/incisiv/tools/bin:/opt/cadence/installs/incisiv/tools/cdsgcc/gcc/bin:/afs/eos/dist/cadence2008/edi/tools/bin:/afs/eos/dist/cadence2010/edi/bin:/opt/ciranova_new/ciranova_installer_linux_rhel40_gcc44x_32_4.7.1_Py262/install/bin:/opt/ciranova_new/ciranova_installer_linux_rhel40_gcc44x_32_4.7.1_Py262/install/plat_linux_gcc44x_32/bin:/opt/ciranova_new/ciranova_installer_linux_rhel40_gcc44x_32_4.7.1_Py262/install/plat_linux_gcc44x_32/3rd/oa/bin/linux_rhel30_gcc411_32/opt:/opt/ciranova_new/ciranova_installer_linux_rhel40_gcc44x_32_4.7.1_Py262/install/plat_linux_gcc44x_32/3rd/bin:/opt/Synopsys/CosmosScope/F-2011.09/ai_bin:/usr/synopsys/hspice/hspice/bin:/usr/synopsys/installer:/bin:/usr/bin:/usr/local/bin:/opt/sfw/bin:/usr/sfw/bin:/usr/ucb:/usr/openwin/bin:/etc:/home/somnathchakr/cni/bin:.:/opt/cadence/installs/ic/tools/dfII/bin:/opt/cadence/installs/ic/tools/dracula/bin:/opt/cadence/installs/ic/tools/gcf/bin:/opt/cadence/installs/ic/tools/jre/bin:/opt/cadence/installs/ic/tools/leapfrog/bin:/opt/cadence/installs/ic/tools/modelwriter/bin:/opt/cadence/installs/ic/tools/pearl/bin:/opt/cadence/installs/ic/tools/perl/bin:/opt/cadence/installs/ic/tools/plot/bin:/opt/cadence/installs/ic/tools/tlfUtil/bin:/opt/cadence/installs/mmsim/tools/bin:/opt/cadence/installs/mmsim/tools/spectre/bin:/opt/cadence/installs/ius/tools/verilog/bin:/opt/cadence/installs/ius/tools/simvision/bin:/opt/cadence/installs/ius/tools/nclaunch/bin:/opt/mentor/modelsim/modeltech/bin:/opt/mentor/calibre/cal/bin
LD_LIBRARY_PATH:  /opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.1/install/lib:/opt/cadence/installs/mmsim/tools/lib:/opt/cadence/installs/mmsim/tools.lnx86/mdl/lib:/opt/cadence/installs/mmsim/tools.lnx86/mmsim/lib:/opt/cadence/installs/mmsim/tools.lnx86/inca/lib:/opt/cadence/installs/mmsim/tools.lnx86/spectre/lib:/opt/cadence/installs/mmsim/tools.lnx86/lib/SuSE:/opt/cadence/installs/ic/tools/lib:/opt/cadence/installs/ic/tools/lib/SuSE/SLES11:/opt/cadence/installs/ic/share/oa/lib/linux_rhel40_gcc44x_32/opt:/opt/cadence/installs/ic/tools/Qt/32bit/lib:/opt/cadence/installs/ic/tools/dfII/lib:/opt/cadence/installs/ic/tools/sev/lib:/opt/cadence/installs/incisiv/tools.lnx86/lib:/opt/cadence/installs/ius/tools/bin:/opt/cadence/installs/ic/share/oa/lib:/opt/ciranova_new/ciranova_installer_linux_rhel40_gcc44x_32_4.7.1_Py262/install/plat_linux_gcc44x_32/3rd/lib:/opt/ciranova_new/ciranova_installer_linux_rhel40_gcc44x_32_4.7.1_Py262/install/plat_linux_gcc44x_32/lib
Can't exec "mpstat": No such file or directory at /opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/bin/getCPUnum.pl line 41.
/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/bin/gnumake -j2 -f GNUmakefile
Compiling C file asl6_func.c (optimize) with -O0
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O0 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/include -c asl6_func.c -o obj/optimize/5.0/asl6_func.o || rm -f -f obj/optimize/5.0/asl6_func.o
Compiling C file asl6_DcFuncDerLoad.c (optimize)
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/include -c asl6_DcFuncDerLoad.c -o obj/optimize/5.0/asl6_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/asl6_DcFuncDerLoad.o
rm -f -rf asl6_DcFuncDerLoad.c
Compiling C file asl6_DcFuncLoad.c (optimize)
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/include -c asl6_DcFuncLoad.c -o obj/optimize/5.0/asl6_DcFuncLoad.o || rm -f -f obj/optimize/5.0/asl6_DcFuncLoad.o
rm -f -rf asl6_func.c
Compiling C file asl6_TranFuncDerLoad.c (optimize)
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/include -c asl6_TranFuncDerLoad.c -o obj/optimize/5.0/asl6_TranFuncDerLoad.o || rm -f -f obj/optimize/5.0/asl6_TranFuncDerLoad.o
rm -f -rf asl6_DcFuncLoad.c
Compiling C file asl6_TranFuncLoad.c (optimize)
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/include -c asl6_TranFuncLoad.c -o obj/optimize/5.0/asl6_TranFuncLoad.o || rm -f -f obj/optimize/5.0/asl6_TranFuncLoad.o
rm -f -rf asl6_TranFuncDerLoad.c
Compiling C file asl6_CreateDevice.c (optimize)
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/include -c asl6_CreateDevice.c -o obj/optimize/5.0/asl6_CreateDevice.o || rm -f -f obj/optimize/5.0/asl6_CreateDevice.o
rm -f -rf asl6_TranFuncLoad.c
Compiling C file asl6_cmi_c.c (optimize)
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc  -march=i686 -m32 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/opt/cadence/installs/mmsim/tools.lnx86/spectre/ahdlcmi/include -I/opt/cadence/installs/mmsim/tools.lnx86/cmi/include -c asl6_cmi_c.c -o obj/optimize/5.0/asl6_cmi_c.o || rm -f -f obj/optimize/5.0/asl6_cmi_c.o
rm -f -rf asl6_CreateDevice.c
rm -f -rf asl6_cmi_c.c
/opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc -shared -O3 -fPIC -o obj/optimize/5.0/libahdlcmi.so ./obj/optimize/5.0/asl6_func.o ./obj/optimize/5.0/asl6_DcFuncDerLoad.o ./obj/optimize/5.0/asl6_DcFuncLoad.o ./obj/optimize/5.0/asl6_TranFuncDerLoad.o ./obj/optimize/5.0/asl6_TranFuncLoad.o ./obj/optimize/5.0/asl6_CreateDevice.o ./obj/optimize/5.0/asl6_cmi_c.o  -m32 -Wl,-rpath,/usr/lib -Wl,-rpath,/lib -s
ld: crti.o: No such file: No such file or directory
collect2: ld returned 1 exit status
gnumake: *** [obj/optimize/5.0/libahdlcmi.so] Error 1
Could anyone please help me to solve this problem?
Thank you in advance.
  • Quek
    Quek over 11 years ago
    Hi Zongya
    We can see the following error in the ahdlcmi log file:
    /opt/cadence/installs/mmsim/tools.lnx86/systemc/gcc/4.4/bin/gcc -shared ... -Wl,-rpath,/lib -s
    Would you please install glibc-devel rpm for your machine? I think it should resolve the problem.
    The alternative solution is to avoid verilogA compilation by including the following line in your .cshrc file:
    setenv CDS_AHDLCMI_ENABLE NO
    Best regards
    Quek
