  3. Change default bus name order
  • Views 17123
englishbear
englishbear over 11 years ago
How to change the defaut bus name oder from ascending to descending in ic615 with cdsenv or cdsinit?
Thanks.
    In what context are you talking about a default? Most of the time you explicitly enter a bus name so it would be useful to know which part of the application and what you are trying to do when such a default might be needed. Please mention the version you're using too. Kind Regards, Andrew
  • englishbear
    I'm using Schematic Editor IC6.1.5-64b.500.12.
    And in Options => Editor => Net Names, the default "Bus Range Order" is "ascending".
    For example, I am connection the top scheamtic with two block, blockA and blockB. In blockA, there's a pin AA<3:0>, and in blockB, there's a pin BB<3:0>. AA<3:0> and BB<3:0> are connected in top. If I do not explicitly enter the bus name, the default name would be net001<0:3>. It  causes cofusions sometimes...
    envSetVal("schematic" "netNameRangeDescend" 'boolean t)
    This will have impact next time you open a schematic. If you need to change it in the current cellView, you can use:
    dbSetNetNameDescend(geGetEditCellView() t) ; or nil
    There's also a function, dbIsNetNameDescend(geGetEditCellView()) which will tell you whether you're in descend mode.
    More details can be found in solution 11185586.
  • englishbear
    Thanks a lot.
