  3. "Direct plot" and tab management in IC 6.1.5
  • Views 1174
Aldo2
Aldo2 over 11 years ago
I use IC 6.1.5. When I simulate a schematic, I use to open different tabs containing the subcircuits I'm interested to.
If in ADE I choose "Direct plot" because I want to plot a waveform in a subcircuit shown in the currently open tab, the focus is moved to the top, and I must open again the tab I'm probing.
Is it possible to keep a tab always open, avoiding that virtuoso re-focuses the top view?
Thank you very much
Best regards
Aldo
    Aldo,
    This isn't a configurable setting - it shouldn't really happen. I think things are better in IC616, but still not completely cured...
  • Aldo2
    Thank you Andrew.
    Is this a known issue for which a 6.1.5 hot fix is forecast?
    BR
    Aldo
    Aldo,
    The last IC615 hotfix was in June 2013, so no - we are beyond fixes for IC615. It would be worth seeing if the problem still occurs in IC616 (I've not tested - I'm a bit swamped at the moment), and reporting it via the customer support channel.
