  3. Spectremdl - Equation for Capacitance calcualtion
  • Views 2210
hvemulac
hvemulac over 11 years ago
Here is the netlist I wrote it for capacitance calculation.
simulator lang=spectre insensitive=yes
parameters
+ f0 = 1M f1 = 5M f2 = 10M // keep same delta
+ vvp1 = 0
+ vvp2 = 0
include "./call_lib_spectre.scs" section=typical
X1 ( 1 2 ) cap_mim w=30u l=30u m = 108
Vp1 1 0 vsource dc=vvp1 mag=0.1
Vp2 2 0 vsource dc=vvp2
VoltSweep_p25 ac freq=100k dev=Vp1 param=dc start=0 stop=1 step=1
simulator lang=spice
.print ac Cap1=par('IM(Vp2)*IM(Vp2)/(2*100k*3.1415926*II(Vp2))*1e12')
saveOptions options save=all pwr=all currents=all
To print the output capacitance I used SPICE format.
But I wanted to do the same in SPECTREMDL and I wrote the following..
alias measurement acrun {
export cplx Cap1
run VoltSweep_p25
Cap1 = (mag(Vp2)*mag(Vp2)/(2*100k*3.1415926*im(Vp2))*1e12)@cross(sig=V(Vp1)-1)
But here is the warning
WARNING (MDL-1565): validate object failure -- parameter or terminal 'Vp2' not found in specified scope.
WARNING (MDL-1101): 11: MDL expression for identifier 'Cap1' can not be evaluated due to previous errors.
I am novice in using spectremdl and currently learning it. Anyone can help me where I am wrong in putting expression for Cap1 in spectremdl...
Hareesh
  • hvemulac
    Anyone can help me on my query on SPECTREMDL. I really didn't find an answer ..
    Urgent questions should go to customer support or to your normal support channel (e.g. Europractice if under that University program). this forum is a community resource - I aim to answer as much as I can, but at the moment my day job is taking up nearly all of my free time so am unable to answer everything I would like to.
    Wading through my email backlog. The mistake you made here was to do mag(Vp2) whereas it should have been mag(V(Vp2)) - you need to use the V function to reference a voltage.
