  3. To include Dim Major Dot ( dimMajorDots->value= t ) command...
  • Views 1266
To include Dim Major Dot ( dimMajorDots->value= t ) command enable at the start-up
RFStuff
RFStuff over 11 years ago
Dear All,
We usually set Dim Major Dot ( dimMajorDots->value= t ) command in Virtuoso Layout Editor manually.
Is it possible to add this in .cdsenv/.cdsinit  so that it is automatically enabled ?
Can anybody please tell the solution
Kind Regards,
    envSetVal("layout" "dotStyleMajorGrid" 'boolean t)
    This is in the documentation (searching for Dim Major Dots should find it - although I didn't try, but the manual also has those three words next to the env var information).
  • RFStuff
    Thanks a lot.
