  3. plotting from OCEAN script in ADEXL
  • Replies 7
  • Views 22372
Michele Ancis
Michele Ancis over 11 years ago
Hi all,
I am interested in learning how to issue plot commands from within an OCEAN script, basically extending the
already existing OCEAN measurement script. This is because in doing so I hope to get more control and uniformity
with respect to which windows get plotted, which curves on which graphs, colors, labels, what not.
I found that I keep tweaking and working at the way waveforms are plotted and could not really find a way of having this fixed once and for all.
[any suggestions appreciated, anyhow]
I have tried a simple plot( expression) from within the OCEAN measurement script, and that works fine.
However, the reason I am using XL is generally tied to
parametric/corner analyses. Here things change a bit and I probably do not understand the underlying concepts very well...
It may happen that the object I want to plot is a simple, single number, for each parameter point.
That is, the axlOutputResult() will return a single number per simulation point, and if I want to plot a curve vs. swept parameter
I have to RMB click on the name of the output and select "Plot All". This works OK.
Now, I would like to be able to have the same behavior, but use an OCEAN script.
The simple plot(my_result) function does not cut it, as the object passed (my expression) evaluates to a single number, not
something the software is keen on plotting.
Strangely enough, an ocnPrint(my_result) would return - on CIW - all the values!!
I have then tried to reproduce what happens when I "plot All" from the GUI
I can see a function _axlPlotAllOutput(...) - very promising - but I could not find any reference to it in the Help
Anybody knows where to search for it?
Anyhow, I am sure there are other, better ways to do that. But I am not aware of any ;-)
So, the issue at hand is how to "create" a waveform, maybe a set of (x,y) coordinates, from a set of outcomes from
parametric simulations ran by ADEXL
Another closely related topic would be, in case of multi-dimensional sweeps, how to slice the output results at will, similarly
to what happens with the YvsY and change sweep Var GUI buttons.
But more in general, I would like to gain understanding on how to access these data, what are these? arrays?
Some More Specific Data - and a pseudo-workaround
What I do
I run a simulation with no sweeps inside ADEXL
In the Global Variables area, I then set one single sweep up (but I would likely extend that to more variables)
In the OCEAN results definition script, I calculate something like:
my_res = db(ih('hb "my_node" '(2 -1))))
[ this is coming from the Calculator directly ]
What I get
As said, if I RMB click my_res in the Outputs Pane --> Plot All, then I get what I would expect, the value of my_res Vs. my swept variable
If i do
ocnPrint(my_res)
I also get a list of values printed out in the CIW
If I try
plot(my_res)
I get as many "not a waveform object...deleted" WARNINGS as the points of the sweep (luckily, not many yet).
Some sort of workaround
Now, after much searching I found a tricky way, but again it's clear I'm against Nature because the plot isn't nice...
Here is what I came up with:
Leveraging on the fact that - besides for plot() - the variable "my_res" DOES contain all the points, I create a vector:
my_xv = drCreateVec( 'double 0)
my_yv = drCreateVec( 'double 0)
foreach(val list(my_res)
    drAddElem(my_yv val)
    drAddElem(my_xv i)
    i++
my_wave = drCreateWave(my_xv my_yv)
plotStyle('joined)
plot(my_wave)
Weird Things
The first super frustrating thing is that now I get a plot, but it is all isolated points!! No way to get a line connecting them...
Also, I get N curves, it looks like, as many as the swept points. So despite my vector creation and all, still I am not really getting
the waveform the way I would like it.
Second weird thing, but this is because I do not know the language, you may have noticed that I do not declare i and set it to 0
before the foreach loop. This is because, if I do, then i stays identically zero.
A very dirty workaround I found is that I set it to zero from the CIW, then refresh the results. Otherwise, i keeps increasing
from a refresh to the next (while I am trying things out)
I also tried to write i = 0 after the foreach loop, but the outcome is the same.
Hope this wasn't uselessly too long and somebody can shed some light...
Thanks in advance,
Michele
  • Michele Ancis
    just a quick update. I have tried another way of plotting the data, this time instead of using an OCEAN script from within
    the ADEXL GUI, I go another route:
    1. Select the results (of course, the "top" psf directory, the one where data are collated)
    2. Apply *the exact same* set of calculations/manipulations
    ==> all of a sudden I have waves, as expected.
    So it looks like when accessing data from within the ADEXL I should specify something different...but what?
    Michele
    Michele,
    You shouldn't really use plot() or indeed any plotting from within an OCEAN measurement script. The primary reason for that is that normally these scripts get run in the "ICRP" (i.e. the background process) which is a non-graphical process. So you won't see the results. The cases where it might work is when you use the re-evaluate button in ADE XL because then the calculations are run in the foreground session (although this may change at some point, because it can be a bit of a bottleneck if you have lots of post-processing to do over many tests and corners and sweeps). Another case is if you're using the optimize single job run feature which was added in IC616 ISR9 - if you're running a single simulation, it uses the ADE XL session to do everything.
    The other things you are seeing are that you are getting family data for each point - and so it contains a single point waveform with the value you want, surrounding by the information about which variables were used. This could be unwrapped, but it's probably the wrong approach for the reasons in the first paragraph above.
    What you could do is use my code in Solution 11854778 (the solution was written by a colleague, but the code is mine, which you could probably guess from the prefix). This allows you to add an OCEAN script which runs across the entire set of data for a test, and then allows you to access all the information - it runs after simulations are complete - can also be re-triggered by hand. This also gives some info on getting the scalar results from ADE XL too.
    I think this approach would fit in with your last observations above.
  • Michele Ancis
    thanks for your reply. I think I start to understand. So my main take-aways are:
    1. OCEAN measurement scripts included in the Outputs Setup pane of ADEXL should not refer to anything graphical
    2. The way I "found" of tackling it from a pure post-processing perspective is indeed more correct (and, also, works right off the bat!)
    3. Using your code, it is possible to embed post-processing from within the ADEXL environment, which then integrates the whole thing
    A probably obvious question: at this point it would be probably more elegant/modular/maintainable to keep the measurement and display separated. One could then keep the measurement in the OCEAN script referenced in the Outputs Results, and use the post-processing only for displaying/formatting.
    I am assuming I can access any variable I have created in my OCEAN measurement, from my post-processing, right?
    I mean to say, the results of my OCEAN measurements are not available in the psf directory, are they? Under this perspective the operations, even with the OCEAN measurement, are always "post". So it may make sense to consider aggregating them into a single script, because then it would not have to rely - at display time - on a previously ran set of manipulations on the underlying psf data.
    Just thinking out loud...Any comment appreciated.
    thanks,
    Michele
    Michele,
    You can't access any SKILL variables that were created in your OCEAN measurement scripts in this "post run" script that the solution provides, because those SKILL variables would have been created in a different process (well, they might have been created in this process, but you can't rely on that, for the same re-evaluate/optimize single job reasons that I mentioned earlier).
    For any scalar outputs that your OCEAN measurement scripts creates, these are accessible from the "RDB" using the axlReadHistoryResDB API that I mentioned earlier and for which there is a small comment in the code about.
    Hope that helps...
  • Michele Ancis
    Andrew, thanks for this.
    I lost the part on "using the axlReadHistoryResDB API" you mentioned but I will look at the code and hopefully find my way through.
    It looks to me more and more like the "old way" of just pointing to whatever results set and crunching the data to display the features of interest, in a single OCEAN, is the way to go. Be it in an ADE L environment or - more sophisticated using your code - in the ADEXL environment where corners and different tests are available under a single roof.
    Thanks again and yes, your words help a lot!
    Michele
    Michele,
    You may find this other thread useful for examples on using axlReadHistoryResDB http://community.cadence.com/cadence_technology_forums/f/38/p/32425/1341416#1341416
  • Michele Ancis
    Wow that looks like a lot of useful stuff! Thanks will study it eagerly :-) M
