  3. IC616 some visual issues with local machines BUT no problem...
  • Views 1627
IC616 some visual issues with local machines BUT no problem when working through VNCViewer/Server
RFStuff
RFStuff over 11 years ago
Dear All,
I installed the latest ISR of IC616.
But
when I am using may machine through vncserver it is working fine. (NO visual issues)
But paradoxically on my local machine it is giving all types of visual issues with ADE & Layout editor.
So certainly, it is NOT a hardware issues rather the tool has some settings suitable for  VNCserver/viewer aplications.
Can anybody please tell how it can be fixed ?
    "All types of visual issues" is not very specific... without knowing what the issues are, it's pretty much impossible to advise you how to fix anything.
    Kind Regards,
  • RFStuff
    Dear Andrew,
    I basically face two types of visual issues ( but NOT when I use through  vncviewer )
    1:-
    Layout Zoom-IN and out is little bit sower in local machine than when I use my local machine in vncviewer remotely.
    It should be other way around. But .....
    2:-
    The Simulation log( progress report) output  on the prompt during simulations.
    When it gets updated the prompt becomes blank . It is not continuous unlike in VNC viewer.
    Sounds odd. Best if you contact customer support for this as we probably need to look into versions of drivers used, etc.
  • krawi992
    krawi992 over 11 years ago
    ehh :(
