  3. Editing the displayed floating Annotated DC Node Voltag...
  • Views 17759
Editing the displayed floating Annotated DC Node Voltages
dyanna
dyanna over 11 years ago
Does anyone know how do I change the display of a floating decimal points down to a a few (2 or 3) decimal points when I select Annotate DC node Voltages? I am using Virtuoso 6.1.6.
Thanks and regards,
Dyanna
  • Quek
    Quek over 11 years ago
    Hi Dyanna
    This can be done by including the following line in your .cdsinit file:
    envSetVal( "auCore.misc" "labelDigits" 'int 3)
    It will set the precision to 3 significant figures. It is not exactly the same as your request (3 decimal places) but I think it should be fine for you too. You can refer to COS article 11842658 for more details on changing the precision of numbers.
    Best regards
    Quek
  • dyanna
    Hi Quek,
    Thanks for helping me out. The suggestion to change .cdsinit  worked.
    I will also check out that article too.
    Best regards,
    Dyanna
