  3. Layout (??) - Constraint Group error
  • Replies 7
  • Views 8085
analogy
analogy over 11 years ago
Came across this error a while back :
    Looks like your library is not either attached or referencing the PDK library, but is attached to the default (cdsDefTechLib) library instead.
  • analogy
    Ok.How do I check that ?
  • analogy
    And Andrew, if I need gds of gpdk045 ind_A inductor (flattened), the approach should be:
    1.Copy ind_a from gpdk045 to working library
    2.open layout cell of ind_a
    3.Run DRC
    4.Go to View>Hiearchy>Flatten
    Is the right ?
    Use Tools->Technology File Manager, and then use the Graph button in the Utilities section of the toolbox to see what technology libraries are associated with your design library.
    I would not copy it, but place an instance of it with the appropriate parameters (since it's a pcell, I believe), and then use Edit->Hierarchy->Flatten, remembering to turn on the "flatten pcells" checkbox.
    I'm not sure flattening a copy of a pcell would stop it being a pcell (I didn't check).
  • Charanraj Mohan
    Charanraj Mohan over 9 years ago
    Hi Andrew, I too have the same issue. When I went Tools--> Technology, i can see cdsDefTechLib. How to solve this issue ?
    You probably just need to use the Attach on the Tools->Technology form to re-attach the library to the technology library. I don't know how that broke in your case (maybe the library it was attached to has been renamed, or is no longer in your cds.lib?)
