  3. Unsuccessful import using Verilogin
  • Subscribers 133
  • Views 14912
MoMiner1870
MoMiner1870 over 11 years ago
Hi all, I am trying to import a verilog netlist generated from Encounter RTL compiler.
I am using the verilogin gui and I get zero errors when importing.  The symbol and schematic views are created but have nothing in them.
Any ideas where I might have gone wrong.
I am using the gpdk045 technology library.
Thanks!
    Not enough info to start with really. You didn't even mention the version used. You probably need to contact customer support as we may need to see the netlist you're trying to import (although if you're using gpdk045, my guess is that you're from an academic institution, so you will either have to go through your university program contact within your organisation, or via Europractice if under their scheme).
