  3. Digital Pot: MOS as a logic switch
  • Subscribers 130
  • Views 16669
ctayers
ctayers over 10 years ago
Virtuoso IC6.1.5.500.9
For a class I need to build a digital potentiometer.  To do this Ive seen schematics where a MOSFET is used as a logic gate.  I attached an image really similar to my schematic.  I can get the gate control wires to see VDD, but Im not sure that I know what MOS to use (virtuoso symbol, then simulate), or how to size it.   When I apply VH=10 VDC, I would think if it was working correctly you would see a corresponding voltage on VW that works as if a voltage divider was activated at the MOS that is turned "on".  However VW seems stuck at 0.5V or so.
Can anyone help please?
    ShawnLogan over 10 years ago
    Dear Cyrus,
    > at 0.5V or so.
    The basic topology you provide is a viable means of providing a programmable resistive ladder. However, there are a number of potential issues to consider. The specific circuit details are not provided in your diagram - so I will need to rely on your knowledge as to which of these are or are not relevant - sorry!
    1. Is it possible that with the MOS device models you are using the 10V VH signal voltage exceeds the breakdown voltage of the MOS transfer gates or is causing excessive gate leakage? If it exceeds the breakdown voltage or the gate leakage is high, most likely all 100 transfer gates will present a finite resistance to node VW, and the resistance will not change significantly with the decoder output code. Have you examined the use of a lower voltage for VH - say something less than Vcc powering the decoder (I am assuming Vcc powers the decoder)? In essence, study the output voltage at VW as a function of code words for VH set to Vcc, 2V, 4 V, 10V to determine if you are observing a leakage or breakdown effect.
    A few other questions or thoughts...
    2. What is the impedance of node VW? Does it represent an infinite impedance or is there a finite resistance to ground?
    3. I am also assuming node VL is grounded - is this true? It sounds as if it as you are observing a voltage less than 10V (0.50 V) at node VW.
    4 Often in this topology the "transfer gates" are formed as a parallel combination of a pmos and nmos gate whose gates are driven by complementary signals. This minimizes the variation in their net drain source resistance as the voltage at their drain and sources vary. If the transfer gates are only nmos, the variation in their rds as VW varies will be significant. This is likely mot your issue, but it can be effective at improving robustness of the ladder.
    I hope these thoughts help you determine the issue!
    Shawn
    Dear Cyrus,
    > at 0.5V or so.
    Shawn
