  3. Warnings for Breakdowns, not suppressing.
  • Views 19390
MarkGr15
MarkGr15 over 11 years ago
Is there a way to make it so that in my spectre.out files (for Analog Simulation) does not suppress the warnings?
If so, what do I need to do?
In the ADE->Simulation->Options Analog->Annotation->  I changed the maxwarns to a large number, and have the "warn" box checked.  When I do this, I do not see a change.
Here is an example output:
Warning from spectre at time = 6.84728 s during transient analysis `tran'.
WARNING (CMI-2756): ILDO1.I50.M152: Vbs(=6.13091 V) has exceeded vbs_max (=6 V).
tran: time = 6.847 s (34.2 %), step = 400 ms (2 %)
Warning from spectre at time = 7.24728 s during transient analysis `tran'.
WARNING (CMI-2756): ILDO1.I50.M152: Vbs(=6.24858 V) has exceeded vbs_max (=6 V).
Warning from spectre at time = 7.64728 s during transient analysis `tran'.
WARNING (CMI-2756): ILDO1.I50.M152: Vbs(=6.36624 V) has exceeded vbs_max (=6 V).
tran: time = 7.647 s (38.2 %), step = 400 ms (2 %)
Warning from spectre at time = 8.04728 s during transient analysis `tran'.
WARNING (CMI-2756): ILDO1.I50.M152: Vbs(=6.48391 V) has exceeded vbs_max (=6 V).
Further occurrences of this warning will be suppressed.
tran: time = 8.847 s (44.2 %), step = 400 ms (2 %)
tran: time = 9.647 s (48.2 %), step = 400 ms (2 %)
If there are any setting in the ADE that I can play with and adjust, that would be helpful.
thanks
Mark
    ShawnLogan over 11 years ago
    HI Mark,
    I can only speak for the PDK I have used  - but it appears you are trying to observe all the warnings related to device parameters exceeding their respective voltage thresholds associated with a specific reliability target. If so, these warnings, I believe, are not generated by "spectre" - but rather by some code particular to a specific PDK. Hence, as is the case in the PDK I have used, the warnings (and supressions) are enabled by the use of the SKILL code that adds the voltage monitoring function.
    For example, I just ran a simulation using a 20V supply in a circuit where the maximum allowable MOS device voltage is about 1 V. No warnings were generated. However, when I invoked an feature that adds a reliability audit, the log file contains numerous warnings related to the obvious overvoltage conditions.
    Is there any chance you know anyone who supplies your PDK whom you might ask?
    Sorry I can't be more specific!
    Shawn
    I believe the clause you are refering to "Further occurrences of this warning with be supressed." only refers to the the
    Max, actually I think you just need to set the "maxwarnstologfile" option (on the Annotaton tab in Simulation->Options->Analog).
  • MarkGr15
    Thanks Andrew, that is what I wanted!
    Is there a way to make it so it is "infinite" or should I just set it to a really large number?
    Mark
    Mark,
    From a quick experiment, I believe setting it to -1 will do the job.
    That may actually set the limit to 2^32-1 - which is probably enough in practice... (or it may be handled specially).
