  3. ==create Netlist fail for modified av Extracted view==
  • Views 16212
tomchen
tomchen over 11 years ago
Hi
back ground:
for some reason , I need to change parameter of a device that on av Extracted view that QRC generated.
but it fails when I use modified av Extract View to create netlist.
And then I use dbSetConnCurrent(geGetEditCellView()) function to fix av Extracted view(open av Extracted and then execute this command).
I can use ADE to  create netlist successfully after I use this command .
But  when I revoke virtuoso, it will fail if I use ADE to create netlist again for av Extracted view . I need to use  dbSetConnCurrent(geGetEditCellView()) again before I create netlist.
is any skill function that can let ADE created netlist successfully for modified av Extracted view even if I revoke virtuoso??
  • Quek
    Quek over 11 years ago
    Hi tomchen
    The correct method is to use a callProc.il file as follows:
    a. Create a file named "callProc.il" in the Quantus technology directory with the following lines:
    procedure( avExtractedCellViewCallProc(cv)   let( (dev)
          printf("Modifying device parameter\n")
          dev=setof(x cv~>instances x~>cellName=="yourTargetCellName")
          dev~>yourParam=123
       ) ;let
    ) ;procedure
    b. Please replace "yourTargetCellName", "yourParam" and "123" with the actual values
    c. callProc.il will be automatically used by Quantus when generating extracted view
    Best regards
    Quek
    I'd also recommend Quek's suggestion, but what you're doing also ought to work - maybe you're just not saving the extracted view after marking the connectivity up to date?
