  3. Specifications problem
  • Views 17215
gonsays1
gonsays1 over 11 years ago
I've been designing a Two-stage CMOS OTA folded cascode amplifier.
The schematic for the simulation is presented below:
The schematic of the symbol Amplifier2 is presented below:
I must get the following specifications:
  • Small Signal Gain (Av) greater than 70dB;
  • Bandwidth (Bw) greater than 60kHz;
  • Phase Margin (PM) around the value of 60 degrees;
  • Slew-rate (SR) bigger than 200V/us;
  • Current Budget of 400uA (the current used on the circuit must be below 400uA)
I have used the following dimensions for the transistors and values for the DC current sources of the biasing circuits used on the simulation:
  • IBIAS2=125uA;
  • IBIAS=75uA;
  • L=0.55um (I’ve used the same length for all the transistors, I don’t know if this is a good method);
  • W12=11.25um (this value is for the width and width stripe of the transistor M12 – the same logic is applied for the other transistors);
  • W1=W2=50um;
  • W11=27um;
  • W3=W4=W5=W6=W7=W8=13.5um;
  • W9=W10=8.9um;
  • W13=11.25um;
  • W14=55um
Using the values presented before, the specifications of interest obtained by the calculator functions, are the following (and also, some comments of what need to be improved):
  • Av: 70.82dB -> I would need to increase the Small Signal Gain (Av), because it is near the minimum required value of 70dB;
  • SR: 201.5M -> I would need to increase the Slew-Rate (as it is near the minimum value of 200M);
  • Bw: 67.12kHz -> I think the Bandwidth is OK (above the minimum of 60kHz) and can be eventually reduced to increase the Small Signal Gain (Av);
  • PM: 56.83 degrees -> I would need to increase the Phase Margin to a value near 60 degrees;
  • GBW product: 234M -> This value is just to have an idea of the Gain-Bandwidth Product;
  • Current Budget of 400uA is being respected, because the total current used on the circuit is around 320uA (can eventually be increased if needed);
QUESTIONS:
Should I use the same length for all the transistors?
Can you give me a clue regarding the parameters that I should modify in order to get better values for the specifications?
In this case, what is the theoretical expression for the slew-rate?
Thank you very much in advance!
