  3. Automatic routing does not work
  • Views 15760
Majid Rafei
Majid Rafei over 11 years ago
I have added a PDK (tsmcN90nm), in layout when I run the automatic routing, nothing done! Do you know what is the reason and how can I overcome it?
thanks.
  • ColinSutlieff
    ColinSutlieff over 11 years ago
    Hi Majid,
    This is related to the same issues that you described in your other post.
    Your techfile needs a section called "functions" that contains all the routing layers to be used.
    In addition, you need a constraint group (default: virtuosoDefaultSetup) that is used to tell the router which vias and layers to use.
    Unless you want to rebuild your techfile I would suggest using a supported PDK from TSMC. Not a partially converted techlib.
    Colin
  • Majid Rafei
    Thanks a lot for your reply. I do what you say.
