  3. Probing bulk currents in Transistors
  • Views 14929
PhilipN
PhilipN over 11 years ago
I need to probe the current in a forward biased drain-diffusion diode of a NMOS device.
Spectre reports that the diode is forward-biased,  but I can't see how to probe the current ?
Phil
  • ALfrg
    ALfrg over 11 years ago
    Hi Philip,
    You have to probe it between the Drain and Bulk pins, this is the case when your transistor ( the model) contains a bulk pin of course. Else I don't have any other idea.
    Hope that will help you.
    Ayoub,
