  3. Get value points from a wave for every x in a vector
  • Views 18226
milind0y
milind0y over 11 years ago
        I have 2 waveforms. First I find the intersection of the 1st wave to some threshold to get a list of time points where it crosses like:
drGetWaveformXVec(cross(clip(VT("/IN") 199u 220u ) VAR("vdd")/2 1 "rising" t "time" ))
now from these time points vector I want to get a vector of all the y points of the 2nd waveform at the corresponding time points. Something like:
value(VT("/wave2") drGetWaveformXVec(cross(clip(VT("/IN") 199u 220u ) VAR("vdd")/2 1 "rising" t "time" )))
and then find the max and min of all the values. Value function as I wrote above does not work. How can I accomplish this?
Milind
    ShawnLogan over 11 years ago
    Dear milind0y,
    I do not think the value() function argument "g_value" works with a waveform. From the ocean reference manual:
    "Value (X value) at which to provide the Y value. If a string has
    been defined for a value or set of values, the string may be used
    instead of the value."
    How about the following? I am sure others can provide a more efficient solution, but I have used code similar to this.
    zcross_wave1 = cross(wave1 0 0 "rising" t "cycle")
    xvector = drGetWaveformXVec(zcross_wave1)
    xvector_length = drVectorLength(xvector)
    declare(y_values[xvector_length])
    ERR_VAL = 9e99
    min_y_value = 0.0 + ERR_VAL
    max_y_value = 0.0 - ERR_VAL
    for( i 1 xvector_length
    y_values[i] = value(wave1 zcross_wave1[i])
    min_y_value = if(y_value[i] < min_y_value y_value[i] min_y_value)
    max_y_value = if(y_value[i] > max_y_value y_value[i] max_y_value)
    Shawn
