  3. Instantiating Spectre/Spice module inside Systemverilog...
  • Views 1945
Instantiating Spectre/Spice module inside Systemverilog testbench for irun based flow
rrpat
rrpat over 11 years ago
Hi all
I was trying to  set up irun based test flow for one of our mixed signal design.Here I  have systemverilog testbench and my DUT can be either wreal model /spectre/verilog.So is it possible to have  systemverilog TOP module with wreal/spectre modules instantiated inside  for irun based AMS  flow ?
Btw  I am able to run the simulations using ADE based flow ,but I would like set a simulation flow without using hierarchy editor based net listing. Any leads will be very helpful.
  • rrpat
    I found the answer in AMS Designers user guide under section "Using SystemVerilog Modules". Let me try the flow !!! Thanks
