  3. Can I use a "not synthesized verilog file" in Cadence Virtuoso...
  • Views 1484
Can I use a "not synthesized verilog file" in Cadence Virtuoso?
aamn
aamn over 11 years ago
Can I import a verilog file that is not synthesized and use it as a block in my analog simulation?
    If you have a Verilog File that is an RTL or behavioural description, then you can't use it in a pure Analog simulation, because it's a digital representation. So that means you can't use it in spectre or other circuit simulators. Spectre understands structural Verilog, but that's just a netlist format which can be used to describe higher level connectivity with gate level transistor level descriptions underneath.
    Spectre also understands Verilog-A (an analog behavioural language).
    However, you can use AMS Designer - this is a mixed-signal simulator which can simulate Verilog, System Verilog, Verilog AMS, VHDL, VHDL AMS, SystemC, etc together with transistor level circuitry. There's no need for the Verilog to be synthesized.
