  3. Problem with simulating a circuit with spectre
  • Replies 8
  • Views 20981
dnelson
dnelson over 11 years ago
When attempting to simulate a simple circuit, I run into this error:
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
Possible cause could be an invalid command line option for the version of the simulator
you are running. Choose Setup->Environment and verify that the command line options
specified in the userCmdLineOption field are supported for the simulator.
Alternatively, run the simulator standalone using the runSimulation file in the netlist
directory to know the exact cause of the error.
I have not set any command line arguments in Setup->Environment.
Contents of runSimulation:
# runSimulation scripts generated for spectre interactive are not intended to be used for command line.
spectre  input.scs +escchars +log ../psf/spectre.out +inter=mpsc +mpssession=spectre1_13026_1  -format psfxl -rtsf -raw ../psf  +lqtimeout 900 -maxw 5 -maxn 5
And when I run this, I get the error:
ERROR (SPECTRE-129): Invalid command line argument `-rtsf'.
Type `spectre -help' in a terminal window for more information.
By everything I've found, this option is supposed to be "+rtsf" not "-rtsf". My question is, why would it be defaulting to that option, and how can I change it? Many users will be running this exact same simulation, and I need it to work through the GUI, without the need to modify that runSimulation file.
Also, how does this runSimulation file get generated? How does ADE L decide to use those command line options?
    Which IC version and which MMSIM version are you using (virtuoso -W and spectre -W will tell you at the UNIX prompt)? This was a command line option that was supported in spectre in MMSIM10.1 and there's a "feature file" in the installation which tells the tool it's safe to use it. So the only time it should get used is if using a spectre that supports this.
    Can you also do this at the UNIX prompt:
    env | grep -i feature
    and report back here.
    Kind Regards,
  • dnelson
    Virtuoso: sub-version IC6.1.6-64b.500.11
    Spectre: sub-version 14.1.0.576.isr7
    Nothing shows up for the grep.
    This is a problem we had last year, so we just decided to use the older version for simulations, because it worked just fine. Now that we are having the problem again, I'd like to get it fixed (without needing another wrapper script).
    dnelson
    Thanks for the info. Are you using ADE L or ADE XL?
  • dnelson
    ADE L
    I looked at the source code, and the only way this can appear is if a "feature" is found. With ADE up and running, what do you get from:
    _artCheckFeature('spectre_commandline_disable_rtsf)
    If this returns t, then what does:
    getShellEnvVar("SPECTRE_FEATURE_FILE")
    return (both of these are in the CIW)?
    I can only imagine that maybe something in your environment is setting this feature somehow. If you run "virtuoso -nocdsinit" - does the problem still occur?
    Probably this needs to go via customer support so that we can debug this properly...
  • dnelson
    Yes it returns t, and the feature file is:
    /cae/apps/data/cadence-2015/installs/MMSIM/tools/spectre/etc/files/spectre.dat
    Is there something in that file I can just add/change? Maybe this does need to go to customer support..
    So you are saying that the getShellEnvVar("SPECTRE_FEATURE_FILE") is pointing to that path? I guess so - and this means that something in your environment is setting this UNIX environment variable - and it really shouldn't do that. That env var should not be set and then ADE will pick up the feature file for spectre from the release that's in the path - what's happening here is that it's being pointed at some old feature file which has the:
    tag in the file. So you need to find out where it is being set and remove that. You can't just do unsetShellEnvVar("SPECTRE_FEATURE_FILE") in the CIW, because it will have been read by then - so I think you truly need to identify where this has been set. Maybe you have a wrapper around "virtuoso" which sets this?
  • dnelson
    Thanks Andrew. After I ran that command I realized that something had to be wrong there. I'll find the wrapper that's causing this and fix it.
    Thanks again!
