  3. [Layout QUESTION] Join Transistors shared drains
  • Views 20621
gonsays1
gonsays1 over 11 years ago
I would like to join, on the layout, the drain of two transistors that share the same drain. Here are the two transistors:
Can we join the drains this way?:
I mean, moving one of the transistors in order to allign the contacts of the drain of both transistors, as shown above.
Is the method used correct or should I create, for example, an unique substract for both (how can I do it?) of them?
Thank you very much in advance!
    If you are using Virtuoso Layout Suite XL, you should be able to just abut the two transistors. Most PDKs support auto-abutment, and based on the connectivity between the two devices (VLS XL is a connectivity-based layout tool, using the connectivity from the schematic), it will share the source/drain regions.
    Did you try that?
