  3. Current through subcircuit
  • Views 14730
vivekroy
vivekroy over 11 years ago
I have placed a subcircuit at every node in the circuit. (i.e I have defined a subcircuit with only one terminal and have connected it to every node in the netlist). After the simulation is complete, I want to access the current through all the subcircuit nodes. Is there any simple way to do that??
P.S. The design is of multiple hierarchy.
    I have no idea what you're trying to do here. Current doesn't flow through a "node" anyway, and I don't see what connecting a single terminal subckt to every node in the netlist would do for you.
    I think you may need to explain yourself better!
    Kind Regards,
