  3. Saving ADEXL Results automatically
  • Replies 13
  • Views 33262
Michele Ancis
Michele Ancis over 11 years ago
Hi all,
I often use ADE XL sweeps and corners not only when verifying but also when exploring designs.
Also, very often, I capture the features of interest in single-point measures, instead of curves. Of course, I have quite a few of them per simulation point.
I find sometimes easier to then export the "table" generated in the results pane of ADEXL and then slice and dice the results using other tools.
The "save as csv" is a wonderful button :-)
I was thinking what would be the flow if I wanted to make this operation automatic, i.e. after having run the sweeps/corners, save the results to file directly.
To this extent, of course, I would not need to have them in the results pane as well.
Probably:
1. create my sweeps and corners in ADEXL
2. create the output expressions in ADEXL (or ocn output script)
3. save the "ocean script" tied to this setup
4. modify it with some command to output the data to a file
If this is correct, what shall I use in 4? Are there other methods?
Michele
    Andrew Beckett over 11 years ago +3
    Hi Michele, I don't think this function will help you with the history recovery, but here's some code I just threw together to automatically save the results to a CSV file (in the documents folder in…
    Andrew Beckett over 7 years ago in reply to Nicolas Callens +1
    Nicolas, FYI - if you're using Matlab, we now have (with ADE Explorer and Assembler) a direct interface to Matlab which can read not only the scalar results but also the waveform data for the entire…
  • Nicolas Callens
    Nicolas Callens over 7 years ago in reply to Andrew Beckett
    Superb! Thanks for the information.
  • Nicolas Callens
    I watched the video, but I cannot add separate Matlab expressions nor can I find the Matlab toolbar button. I am using Virtuoso version 6.1.7.
    Kind regards,
    Nicolas
    Nicolas,
    Are you using ADE Explorer or Assembler, or ADE XL? This is only in ADE Explorer/Assembler (not XL) and requires you to be using IC6.1.7 ISR10 or later. It will also need a specific license - so you may need to speak to your account team for this.
