  3. Saving ADEXL Results automatically
  • Replies 13
  • Views 33260
Michele Ancis
Michele Ancis over 11 years ago
Hi all,
I often use ADE XL sweeps and corners not only when verifying but also when exploring designs.
Also, very often, I capture the features of interest in single-point measures, instead of curves. Of course, I have quite a few of them per simulation point.
I find sometimes easier to then export the "table" generated in the results pane of ADEXL and then slice and dice the results using other tools.
The "save as csv" is a wonderful button :-)
I was thinking what would be the flow if I wanted to make this operation automatic, i.e. after having run the sweeps/corners, save the results to file directly.
To this extent, of course, I would not need to have them in the results pane as well.
Probably:
1. create my sweeps and corners in ADEXL
2. create the output expressions in ADEXL (or ocn output script)
3. save the "ocean script" tied to this setup
4. modify it with some command to output the data to a file
If this is correct, what shall I use in 4? Are there other methods?
Michele
    Andrew Beckett over 11 years ago +3
    Hi Michele, I don't think this function will help you with the history recovery, but here's some code I just threw together to automatically save the results to a CSV file (in the documents folder in…
    Andrew Beckett over 7 years ago in reply to Nicolas Callens +1
    Nicolas, FYI - if you're using Matlab, we now have (with ADE Explorer and Assembler) a direct interface to Matlab which can read not only the scalar results but also the waveform data for the entire…
  • Michele Ancis
    ...I think I found a
    postExportResults()
    which should potentially do what I aim for.
    Any suggestions are anyhow very appreciated ;-)
    Michele
    Hi Michele,
    I'm not sure the postExportResults signal in ADE XL is what you want (note it's a signal, not a function). The idea is that you can register a trigger function on this signal which gets called when you export results. So actually the trigger would get called when you export results - it will not cause export results to be called when simulations are complete.
    Probably what you want is one of the runFinished signals (might be runFinished, runFinishedConclusion, runFinishedPostPlot, runFinishedPrePlot). This could then trigger a call to axlExportOutputView() to export the results.
    Kind Regards,
  • Michele Ancis
    thanks for your clarification. I am not sure under which "framework" I should be able to catch signals and react to them...I guess I'll need to read the manual ;-)
    On the layman side of things, however, I could probably use  axlExportOutputView() just after a simulation, basically adding this line to the run script generated by ADE XL automatically. Am I right?
    Also, I just posted about an issue I have at the moment, where I would like to recall results from the History but I cannot see them in the History pane as they were not saved with it. I could probably give this function a try, at least to save the different results to file and then access the csv data...
    Thanks!!
    Michele
    Hi Michele,
    I don't think this function will help you with the history recovery, but here's some code I just threw together to automatically save the results to a CSV file (in the documents folder in the ADE XL view) when simulations are complete.
    /* abExportCSVafterSim.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jun 10, 2015
    Modified
    By
    Call abInitExportCSV() - this will automatically export
    a CSV file to the documents directory after simulations are
    finished.
    SCCS Info: @(#) abExportCSVafterSim.il 06/10/15.10:41:38 1.1
    *           abExportCSVrunFinished(sess _runId hist)           *
    *    The trigger that gets called on runFinished (actually     *
    *     chose runFinishedPrePlot, but it's not too critical)     *
    procedure(abExportCSVrunFinished(sess _runId hist)
        let((sdb documentsDir histName CSVfile)
            sdb=axlGetMainSetupDB(sess)
            documentsDir=strcat(axlGetSetupDBDir(sdb) "/documents")
            histName=axlGetHistoryName(hist)
            CSVfile=strcat(documentsDir "/" histName ".csv")
            axlExportOutputView(sess
                "Detail-Transpose"
                ?history histName
            printf("INFO: Exported CSV file to %s\n" CSVfile)
    *            abRegExportCSVrunFinishedTrigger(sess)            *
    *           Add the trigger into the current session           *
    procedure(abRegExportCSVrunFinishedTrigger(sess)
        axlSessionConnect(sess "runFinishedPrePlot" 'abExportCSVrunFinished)
    *                       abInitExportCSV()                       *
    * Ensure that the trigger gets added whenever ADE XL is opened. *
    procedure(abInitExportCSV()
        axlSessionRegisterCreationCallback('abRegExportCSVrunFinishedTrigger)
    • Vote Up +3 Vote Down
  • Nicolas Callens
    Nicolas Callens over 7 years ago in reply to Andrew Beckett
    I was looking into this topic to find a script of automating the export of the ADE XL results. I have loaded the function (from you) in the CIW and ran a simulation, but I do not see a CSV file in the specified directory. Probably I am doing something wrong (still in the beginning of the SKILL learning curve). Therefore, I have a question:
    Are the arguments of the procedure abExportCSVrunFinished getting filled in automatically when ADEXL gives a signal that the simulation is executed? If so, how is this done?
    Kind regards,
    Nicolas
    Hi Nicolas,
    First of all, are you loading the code (e.g. in the .cdsinit) and calling abInitExportCSV() (ideally also in the .cdsinit) before starting ADE XL - calling the function in the CIW after starting ADE XL will not work.
    It works by registering a trigger upon ADE XL initialisation, which in turn registers a trigger when the simulation run is finished. The runFinishedPrePlot trigger defines what arguments the function abExportCSVrunFinished will receive - and it supplies them when called (so there's nothing you have to do).
    Are you seeing any message in the CIW at the end of the simulation indicating that the file was exported?
  • Nicolas Callens
    Thanks Andrew. It works now and can see the message in the CIW.
    However, is it actually possible to save plots with this scripts? I have tried to simulate and output only plots and the only thing that I am getting was black field in the CSV file (e.g. , , , ,).
    Kind regards,
    Nicolas
    Hi Nicolas,
    No, it's not. It's using the same capability to export CSV from the ADE XL UI - which just saves the scalar values. I'm not sure how you would expect to have waveform data in a row-based CSV file where each row is one output in the ADE XL output table.
  • Nicolas Callens
    Indeed, you are right. In case of a row-based CSV it will be impossible.
    Though, I also would like to export for example my transient simulations to a csv file in an automated way, since I am postprocessing the waveforms in Matlab or Python.
    KR
    Nicolas
    Nicolas,
    FYI - if you're using Matlab, we now have (with ADE Explorer and Assembler) a direct interface to Matlab which can read not only the scalar results but also the waveform data for the entire results. See this video: Making the most of using MathWorks MATLAB and Virtuoso ADE Product Suite together (yes, it's me doing the talking).
    Even before that we have a low level interface that can directly read waveform data into Matlab using the "Spectre Toolbox" which is provided in the MMSIM/SPECTRE streams (search for Matlab in <MMSIMinstDir>/bin/cdnshelp ). No real need to go via a text intermediate format.
