  3. unable to open config()
  • Views 16282
MarkGr15
MarkGr15 over 11 years ago
this is a snippet of my  output log. Notice the simulator does find an ADEXL license.  Next it errors out because it cannot open the config() which is set by the design() function.  Sometimes this script Errors out as shown, other times it runs fine. I do not have any idea why.  I will try and add more detail tomorow, but its late.
"dg_sw_erramp_Sim1WC"
\p >
\i createDir(strcat(resultsPath "/" simDirName) ) ; top level simulation directory
\t nil
\p >
\i simulator( 'spectre )
\o Loading oasis.cxt
\o Loading awv.cxt
\w *WARNING* (icLic-3) Could not get license Analog_Design_Environment_L
\w *WARNING* (icLic-21) License Analog_Design_Environment_L ("95200") is not available to run ADE L.
\w Trying to check out the license Analog_Design_Environment_XL ("95210") instead.
\o *INFO* (icLic-25) License Analog_Design_Environment_XL ("95210") was used to run ADE L.
\o Loading analog.cxt
\o Loading asimenv.cxt
\o Loading spectrei.cxt
\# Memory report: using 200 MB, process size 888 MB at UTC 2015.06.05 03:17:29.200
\o Loading devCheck.cxt
\o Loading relXpert.cxt
\o Loading par.cxt
\o Loading socket.cxt
\o Loading alvs.cxt
\o Loading adexl.cxt
\o Loading te.cxt
\t spectre
\p >
\i design( workingLib testBenchName view_2_use) ;
\o ERROR (ADE-5726): Unable to open config (_testbenches_regress dg_sw_erramp_Sim1 schematic).
\t nil
\p >
    That error means that it was unable to find the lib/cell/view passed to the design() function. It's essentially doing just a ddGetObj(lib cell view "*" nil "r") (to check the master.tag file) to determine this - and if this is working sometimes but not others, my assumption is that you have some kind of network/automount type problem which means that sometimes the data can't be found (or maybe there is something else wrong with your environment which means that the data isn't set up correctly).
    Probably if you can't figure it out, you'd be best talking to customer support - it's far from obvious what might be causing this (it could be some silly mistake, who knows?).
