  3. Cadence Virtuoso try to compile every layout to pcell
  • Subscribers 133
  • Views 6358
mad monster
mad monster over 11 years ago
Virtuoso try to do this during design saving.
But it occur not for all libraries. In what there can be a problem?
    That's rather surprising. Generally speaking this would only happen if somebody has done Launch->Plugins->PCell (in IC616 at least - you didn't provide the rather important information as to which version you're using) and then once compiled to pcell. Once that's been done, the viewSubType property gets stored which tells it to keep adding the PCell menus each time and compile each time you save.
    If you open the affected layout and do geGetEditCellView()~>viewSubType what does it return?
    The SKILL code below can be used to reset the viewSubType - but I would expect this to be on certain cellViews, not on everything in an entire library. You might want to talk to customer support so that we can look at your data together.
    /* abResetViewType.il
    Author     A.D.Beckett
    Group      Structured Custom, Cadence Design Systems Ltd.
    Machine    SUN
    Date       Jan 14, 1997
    Modified
    By
    Main entry points are abResetViewType or abHiResetViewType
    These allow easy removal of the viewSubType cellView property
    which controls which application is used (e.g. cell3 or virtuoso).
    This code is for 4.4 and onwards
    SCCS Info: @(#) abResetViewType.il 11/20/08.15:26:19 1.2
    *         (abResetViewType libName cellName viewName)          *
    *  Reset the viewType by removing the viewSubType property on  *
    *                         a cellView.                          *
    (procedure (abResetViewType libName cellName viewName)
      (let (cv)
           (setq cv (dbOpenCellViewByType libName cellName viewName "" "a"))
           (when cv
                 (dbDeletePropByName cv "viewSubType")
                 (dbSave cv)
                 (dbClose cv)
    *                 (abCreateResetViewTypeForm)                  *
    *    Create the form for the HI version of abResetViewType     *
    (procedure (abCreateResetViewTypeForm)
      (let (libName cellName viewName browse)
           (setq libName
                 (hiCreateStringField
                  ?name 'libName
                  ?prompt "Library Name"
                  ?callback "ddsUpdateSyncWithForm()"))
           (setq cellName
                  ?name 'cellName
                  ?prompt "Cell Name"
           (setq viewName
                  ?name 'viewName
                  ?prompt "View Name"
           /* create browser button */
           (setq browse
                 (hiCreateButton
                  ?name 'browse
                  ?buttonText "Browse"
                  ?callback "abResetViewTypeSyncWithForm()"))
           /* build the form */
           (setq abResetViewTypeForm
                 (hiCreateAppForm
                  ?name 'abResetViewTypeForm
                  ?fields (list
                           (list libName 0:0 400:35 105)
                           (list cellName 0:35 400:35 105)
                           (list viewName 0:70 400:35 105)
                           (list browse 105:105 90:30)
                  ?formTitle "Reset View Type"
                  /* cancel callback is to break the link with the browser */
                  ?callback '(abResetViewTypeCB "ddsEndSyncWithForm()")))
    *                (abResetViewTypeSyncWithForm)                 *
    *            Sync the form with the library browser            *
    (procedure (abResetViewTypeSyncWithForm)
      (ddsSyncWithForm abResetViewTypeForm
                       'browse
                       'libName 'cellName 'viewName))
    *                   (abResetViewTypeCB form)                   *
    *      OK callback for the form. This resets the viewType      *
    *                  on the specified cellView.                  *
    (procedure (abResetViewTypeCB form)
      /* break the link to the browser */
      (ddsEndSyncWithForm)
      (abResetViewType
       (getq (getq form libName) value)
       (getq (getq form cellName) value)
       (getq (getq form viewName) value)
    *                     (abHiResetViewType)                      *
    *            Main entry point - brings up the form             *
    (procedure (abHiResetViewType)
      (unless (boundp 'abResetViewTypeForm)
              (abCreateResetViewTypeForm))
      (hiDisplayForm abResetViewTypeForm))
  • mad monster
    Hello, Andrew!Thank you for your reply.
    geGetEditCellView() partially helps to resolve my problem (for certain cellViews, not for entire library).
    When I typed geGetEditCellView()~>viewSubType it returned its value (not nil, I forgot value).
    Then I typed geGetEditCellView()~>viewSubType = nil and exited from Virtuoso (with saving).
    In the next time this layout was repaired and there were no Pells properties.
    Good day to you,Yuriy.
