  3. .cdsenv
  • Views 14872
.cdsenv
Bryan71
Bryan71 over 11 years ago
Hi all:
I have two Questions:
1) when I am probing in schemaitcs the ProbeOptionForm appears when I hit the bindkey, the command that pops up in CIW winde is (geProbeOptionsForm)can I add this as a line in my .cdsenv file to make it stop popping up?
ie; schematic ProbeOptionsForm boolean nil
2) When I am in the layout window and I am making stretches or moving pieces of my layout, I have the form set to appear when the bindkey is pressed. is there a way to make them appear where I wan them to on my screen like when I use;
layout leWindowBBox string "((1680 10) (3350 1050))"
Thank you in advance for all and any comments!
  • skillUser
    skillUser over 11 years ago
    Hi Bryan,
    For the first item, it might be that you have "expert mode" turned off (CIW Options->User Preferences -> Options Displayed When Commands Start", you can turn it off using that form, or with SKILL:
    hiGetCIWindow()->expertMode = t
    If you can access the Cadence Customer Support site, take a look at this code for recalling form locations automatically
    Hopefully this helps you?
    Lawrence.
