  3. How to un-load and load a skill script in OCEAN
  • Views 18628
RFStuff
RFStuff over 11 years ago
Dear All,
I have a skill script ( the job of it is to delete psf folder after I close my ADE) which gets loaded at the start-up.
But while I run ocean script for multiple simulation it creates problem so I want to UN-load it at the beginning and then load it at the start.
Could anybody please tell how to achieve that ?
Kind Regards,
    There's no such thing as "unloading a script". What you presumably need to do us reverse whatever operation that script did, so without knowing what the script actually does, I can't really advise you. It may mean unregistering some trigger that was registered in the script, or maybe undefining a defined function. Without seeing the code that is doing this special task, I can't really say what the approach that should be taken would be.
    Kind Regards,
  • RFStuff
    Dear Andrew,
    It is a .ile file.
    I have attached here.CCSDeletePsf.ile.zip
    The code appears to have been sent to a customer (maybe you or somebody at your site) in the middle of March 2015, from case 45758268. The code itself appears to be an encrypted version of code I wrote a number of years ago. Probably it would have made more sense to contact customer support about the code that had been provided, rather than asking here - the reason it was encrypted was that it uses some private functions.
    You can stop it doing the deletion by doing:
    sstatus(debugMode t)
    procedure(abDeletePsfCloseProc(session) t)
    sstatus(debugMode nil)
  • RFStuff
    Dear Andrew,
    Yes, it was given by cadence people for the case 45758268.  In fact I have filed a SR for this.
    Will the commands ( you have mentioned ) will do the both i.e. delete and invoke ?
    If you log something as an SR then please do not also ask here. Otherwise people like me (I try to cover a lot of the forum questions in addition to my actual job with Cadence - this is not part of my job) end up replicating the effort of others in the support team. We simply do not have the resources to do that. The forum guidelines ask you not to contact customer support and ask the same question in the forums.
    If you want to enable and disable it, maybe a better solution is this:
    (sstatus debugMode t)
    (setq abDeletePsfEnabled t)
    (defun abDeletePsfCloseProc (session)
      (when abDeletePsfEnabled
       (hiDisplayAppDBox
        ?name 'abDeletePsfConfirm
        ?dboxBanner "Delete Simulation Results"
        ?dboxText "Delete Simulation Results?"
        ?dialogType hicQuestionDialog
        ?dialogStyle 'modal
        ?buttonLayout 'YesNo
        ?callback (sprintf nil "(abDeletePsfCB %L)"
                   (asiGetPsfDir session))
    (sstatus debugMode nil)
    Then you can turn it on or off by setting abDeletePsfEnabled=t or =nil. If this works for you, please provide this to the customer support AE so they don't waste their time on it too...
    (note, this part of the code is not the sensitive part that doesn't need to be encrypted)
  • RFStuff
    Dear Andrew,
    Sorry for the violations.
    It is working fine indeed.
    I have informed the same to customer support.
    Kind Regards,
