  3. Ocean script creating corners
  • Views 14591
samgll
samgll over 11 years ago
I need to run an ocean script where I sweep corners and temperature to create N different corners, and then read a noise file in each corner and find jitter numbers for each corner. Can you please tell me how I can sweep corners and temperature?
samgll
    Which version are you using? How are you reading the noise file? If using IC61X, do you have access to ADE XL?
