  3. Ocean Script: How to Get the Result with Respect to Each...
  • Views 14612
Ocean Script: How to Get the Result with Respect to Each Corner After Corner Analysis
Teem
Teem over 11 years ago
Dear All:
I run transient analysis to check the average voltage of a node, say avgVout=average(VT("/vout")), for each corner by using ocean command cornerRun() and cornerMeas().
Are there commands that I can use to retrieve the value of avgVout with respect to each corner?
Spectre version I used: 5.10.41_USR5.90.69
Thank you all for your help.
Best regards,
