  3. how to set custom display resource file as default
  • Views 18718
apple419
apple419 over 11 years ago
   How to set the custom display resource file as the default file which is used every time a layout is opened in Virtuoso layout editor?
   Now I have to load it every time. It is annoying...
many thanks!
  • apple419
    After some research I found one solution: put "graphic drfPath string "path/display.drf" in .cdsenv
