  3. Re: Simulating subcircuit within ADE with view other than...
  • Views 15978
Re: Simulating subcircuit within ADE with view other than spectre
slim5
slim5 over 11 years ago
Following the steps listed in this URL, community.cadence.com/cadence_blogs_8/b/rf/archive/2009/01/07/tip-of-the-week-how-to-simulate-a-subcircuit-netlist-with-spectre-in-ade I was able to instantiate a spice netlist and run simulations within ADE.
For the step, "Make a copy of this symbol view and call the new view "spectre.", is it possible to create the steps for a view name to something else other than spectre? For example, is it possible to create a view call "LocalSimViews" instead of "spectre"?
S Lim
  • Tom Volden
    Tom Volden over 11 years ago
    Yes.  You can give it any view name that you want, but then you also need to include that view name in the switch and stop view lists.  The advantage of using spectre as the view name is that it is already defined as a stopping view, assuming you are using the viewlist templates for spectre.
    TOM
  • slim5
    I tried with different names such as SpectreSims and picked this view in my hierarchy config view, but ADE totally ignore this view and I do not see the instance being used in the generated netlist (input.scs). For reference, I am using IC6.1.6
    S Lim
    Did you add "SpectreSims" into the stop list in the hierarchy editor? If you don't do that, it won't see the view as a stop view and so will try to traverse its hierarchy (of which there is no hierarchy, and so there's nothing to be netlisted).
    As Tom said, you need it in the stop list. Picking it as the view to use is one part, but defining it as a stopping view is also necessary.
