  3. CDL import with SpiceIn: W + L wrong!
  • Views 22612
bdjones1
bdjones1 over 11 years ago
I'm attempting to import a TSMC 65nm standard cell CDL netist using IC616 StreamIn.  I've created a device_map that imports devices, but their sizes are off by 1000x.
For example, the first device call in the cdl file is this:
mXI0_MXNA1 nin A XI0_n1 VPW nch L=6e-08 W=3.3e-07
When imported, the device ends up with l=60m and 330m, instead of 60n and 330n.  Here's the chunk of the log file showing that happening:
Created instance 'mXI0_MXNA1'.
Instance Terminal: Created net nin
Created connection between net 'nin' and term 'D'
Instance Terminal: Found net A
Created connection between net 'A' and term 'G'
Instance Terminal: Created net XI0_n1
Created connection between net 'XI0_n1' and term 'S'
Instance Terminal: Found net VPW
Created connection between net 'VPW' and term 'B'
CDF parameter not found for 'subtype'. User property will be cretated
Created propName='subtype'; propType='string'; propVal='nch'.
In CDF... Created propName='model'; propType='string'; propVal='nch'.
CDF Type is 'string' and the value given in netlist is 'float' - hence converting to 'string'
In CDF... Created propName='l'; propType='string'; propVal='0.06'.
In CDF... Created propName='w'; propType='string'; propVal='0.33'.
Clearly the Device Mapping is not handling the units on the conversion from the CDL float to the CDF string correclty:
L=6e-8 -> 0.06u -> 60m (!)
W=3.3e-7 -> 0.33u -> 330m (!)
For reference, here's what I have in the device_map file:
devSelect := nfet nch
propMap := W w L l
devSelect := pfet pch
propMap := W w L l
devSelect := diode ndio
propMap := AREA area PJ pj
I've looked through the transferOA.pdf help file but don't see anything addressing this.
Anyone have any ideas how to get this to run smoothly?
Brian
  • Marc Heise
    Marc Heise over 11 years ago
    Hi Brian,
    do you have a ".SCALE" line in your input file? If yes, what is the value?
    Set it to "meter" :  .SCALE METER  , or even try to run without it at all.
    Marc
  • bdjones1
    Thanks Marc!
    I gave that a shot, and now the netlist fails to parse.  When I have the ".SCALE METER" line commented it out, it imports fine, but with the wrong size.  When I uncomment that line, I get the error in the log file below.  Am I missing something?
    Spice In Log File
    Parameter file: /tmp/spiceInPuje188
    Import Parameters:
    Netlist file name: /.........../sc9_cln65lp_base_rvt.cdl
    Output library name: sc9_cln65lp_base_rvt
    Output View Type: schematic
    Schematic view name: schematic
    Netlist view name: netlist_tmp
    Reference Library List: tsmcN65 sc9_cln65lp_base_rvt_bdj
    Device-mapping file name: /............../device_map
    Master Cell for Ground: gnd
    Cells to be Overwritten: <all>
    Schematic Generation parameter file: /tmp/schOpts_spiceInPuje188
    Simulator: spectre
    Output Simulator: spectre
    paramCaseValue: default
    Parser: ASSURA
    Language: CDL
    WARNING (SPICEIN-99): 'Import Subcircuit List' is not found in the specification, hence setting it to
    default empty value and importing all sub-circuits in the netlist.
    ERROR (SPICEIN-102): SpiceIn failed to parse the cdl netlist file '/............./sc9_cln65lp_base_rvt.cdl'. You may read logfile 'lvsrpt.wrn'
    for details.
  • bdjones1
    bdjones1 over 8 years ago in reply to bdjones1
    3 years after posting this question, I found myself asking it again and finding my original post.  After some fumbling around, I was able to fix a CDL import scale issue with this syntax:
    .OPTION SCALE 1e-6
    The syntax of ".SCALE METER" or ".SCALE 1e-6" caused import errors.
    Andrew Beckett over 8 years ago in reply to bdjones1
    I just did some testing with a netlist that looked like this:
    .GLOBAL VDD VSS
    .SUBCKT myCdlInv Y A
    M1 Y A VDD VDD P L=6e-08 W=6.6e-07
    M2 Y A VSS VSS N L=6e-08 W=3.3e-07
    .ENDS myCdlInv
    This imports with the dimensions as specified untouched (apologies for the typo in the messages!):
    CDF parameter not found for 'L'. User property will be cretated
    Created propName='L'; propType='float'; propVal='6e-08'.
    CDF parameter not found for 'W'. User property will be cretated
    Created propName='W'; propType='float'; propVal='3.3e-07'
    If the netlist has the CDL directive *.SCALE (note that it has a * before it because it is not SPICE - CDL often uses a single star for such "pragma"):
    .GLOBAL VDD VSS
    *.SCALE METER
    .ENDS myCdlInv
    Then they are indeed scaled:
    Created propName='L'; propType='float'; propVal='0.06'.
    Created propName='W'; propType='float'; propVal='0.33'
    If you then add:
    .GLOBAL VDD VSS
    *.SCALE METER
    .OPTION SCALE 1e-6
    .ENDS myCdlInv
    then that undoes the effects of the *.SCALE METER. Obviously just removing the *.SCALE METER or putting an additional * in front (so **.SCALE METER) does the same thing.
    Note that .SCALE METER will not work because that's not a valid CDL command - it is *.SCALE METER.
    So overall, my guess is that your netlist (somewhere) has a *.SCALE METER in it, and that's what was causing the original problem. Adding the .OPTION SCALE 1e-6 just reverses the effect of that.
    • Vote Up -1 Vote Down
