  3. Can you change what corners are run, in OCEANXL, and then...
  • Views 14498
Can you change what corners are run, in OCEANXL, and then run other trimmed tests?
MarkGr15
MarkGr15 over 11 years ago
I want to simulate a reference that is trimmed.
Algorithm for testing:
Only Define 27C corners (process corner, mismatch corner)
run test to Get Trim setting
run other tests at 27C at the same corners, trimmed, using calcVal()
define other corners
      -40C & 150C (process corner, mismatch corner)
run several tests, Post Trim @ All Temps
- using the calcVal (trimmed settings)
just disable 27C corners (mismatch, mcproc)
run other trimmed tests at just -40C, and 150C.
A key issue, is how do I also not overwrite any data from previous runs?  Currently, if I use another  ocnxlRun() command in the same script, I believe it will overwrite the data of the previous run.
Maybe I just define all the corners at once, then disable certain ones later..... but the above issue (over-writing previous data) is one that I do not know how to resolve. Also, I am not sure if I can even do this algorithm.  I am trying this algorithm, to prevent unnecessary simulations for tests at corners that are needed.
    Probably the best way to solve this is using "pre-run scripts". It's covered in the documentation, but you may want to contact customer support to get hold of a workshop which shows various examples. If the AE can't locate it, ask them to get in touch with me internally.
