  3. Delete all wires and vias
  • Views 17790
Majid Rafei
Majid Rafei over 11 years ago
Hi.
I have done the layout rooting by means of autorouting VCAR (ICC) (global and detail options). I want to delete all wires and vias. I tried the option in: Edit -> Delete Wires -> All, but it doesn't work. In addition to wires, I want to delete vias.
How can I do this?
Hint: my icfb version is 5.41
    Try typing in:
    unprot all wire
    del all wire
    at the VCAR command prompt. The issue is probably that all existing routing has come in as being protected.
  • Majid Rafei
    Dear Andrew, Thanks for your reply.
    Do these commands delete all via(s) too?
    Edited: The codes are checked and they work. Thanks a lot Andrew!
