  3. How to remove Nets (guide lines) by wires (paths) in layout...
  • Views 19292
How to remove Nets (guide lines) by wires (paths) in layout (virtuoso)?
Majid Rafei
Majid Rafei over 11 years ago
Hi.
I am using IC5141 virtuoso. In layout page, there is a Display option named "Nets". When I tick it, nets and connection guides (guide lines) appear; but when I start to draw wires and paths (tracks), these nets (guide lines) are not disappeared!
Is there any option that when I draw wires (paths) then these guide lines disappear?
By this means, I will be able to find out which connection is not completed or connected.
    Use Show Incomplete Nets in Virtuoso Layout XL rather than just showing the rats nest display of nets as you've been doing it.
  • Majid Rafei
    Dear Andrew.
    Thanks for the reply. Checked and worked.
