  3. set axis limits in ADE plot
  • Views 17602
RobinCommander
RobinCommander over 11 years ago
Is there a way to set the X & Y axis limits on a plot instead of auto-scaling to fit, maybe with some skill? In ocean there is xlimit & ylimit, is there any other way to do this?
Robin
    Robin,
    What's wrong with using xLimit() and yLimit()? There are also awvSetXLimit and awvSetYLimit, but xLimit/yLimit should be fine too.
    Maybe I don't understand your question properly?
  • RobinCommander
    Andrew,
    I thought xLimit & yLimit being ocean commands I would then have to put all the run into a script (probably revealing my ignorance here).
    I'll investigate awvSetXLimit/awvSetYLimit. These didn't appear in the IC6.1.6 Skill Artist Reference document but are described in the 6.1 document.
    Robin
    Hi Robin,
    OCEAN functions are just SKILL. They aren't limited to being used in an OCEAN script. OCEAN is really just a set of SKILL functions with a simple interface designed for controlling simulation and post-processing, but they can be used in Virtuoso too.
    The awvSetXLimit function is documented in the Virtuoso Visualization and Analysis XL SKILL Reference manual.
