  3. ocnPrint() - output waveform names instead of full expr...
  • Views 3424
ocnPrint() - output waveform names instead of full expression
Michele Ancis
Michele Ancis over 11 years ago
I have a script looking like this:
openResults("/mypath/to/schematic/psf")
f= outfile("my_results.ocnp")
IM3L_Dph = phase((vh('hb "/VONAC" '(2 -1)) / vh('hb "/VONAC" '(1 0))))
ocnPrint(?output f ?numberNotation ' engineering ?width 30 IM3L_Dph)
close(f)
The issue I have with this, is that instead of using IM3L_Dph as the label for my output file,
the routine prints out the full expression phase(...). This becomes even worse if the results I am trying to save are from a swept simulation...
Any way to change this behaviour? I would like to avoid resorting to to low-level fprintf commands if possible.
Michele
  • Michele Ancis
    Nevermind...I will try to use these functions provided by Andrew here:
    http://community.cadence.com/cadence_technology_forums/f/38/t/19646
    Let's see how far I can get with that.
    M
    Michele,
    No need to use those functions here. This can be done with ocnPrint with a bit of adjustment of the input waveforms. See my solution
    In your case, you could do:
    drGetWaveformYVec(IM3L_Dph)->expression="IM3L_Dph"
    before calling ocnPrint.
  • Michele Ancis
    Great Andrew!!
    I was already on the verge of despair as the functions you provided back then would have needed some tweaking in the case at hand, since I am writing swept simulation data and I wanted to have them all in a single file.
    This solution allows to use the high-level ocnPrint() so I'm pretty happy to leverage on that.
    EDIT: tried...works perfectly :)
    Cheers,
    Michele
