  3. Is it possible to run Assura LVS under Ubuntu 14.04?
  • Views 15150
R Wodnicki
R Wodnicki over 11 years ago
I am using Ubuntu 14.04 and running IC616.
Virtuoso runs great expect for ASSURA LVS. ASSURA DRC is able to run but LVS fails.
I receive an error related to the 'sysname' command (please see listing further below this text).
I am fully aware that Ubuntu is unsupported by Cadence.
I have searched online forums and there is some indication that modifying the sysname
script can solve this problem. However I have not had any success with this.
If there is a more up to date forum page on this topic that could help, I would really appreciate
someone pointing me in the right direction.
Thanks so much for your assistance,
Robert
Starting dfIIToVdb...
avlck: ERROR: The command /home/robertw/cadence/installs/IC616/oa_v22.43.018/bin/sysname returned an error status:
unknown
avlck: INFO: Note that OpenAccess (OA) requires running the Configure phase.
avlck: See the "OpenAccess Installation and Configuration Guide" before
avlck: you complete the configuration step. This manual is included with
avlck: the Cadence product documentation.
/home/robertw/cadence/installs/ASSURA41/tools/assura/bin/64bit/dfIIToVdb: symbol lookup error: /home/robertw/cadence/installs/ASSURA41/tools/assura/bin/64bit/dfIIToVdb: undefined symbol: _ZTIN12OpenAccess_431oaExceptionFromObserverObserverE
*WARNING* Translation abnormally terminated!
*WARNING* aveng exit with bad status
*WARNING* Status 256
  • Quek
    Quek over 10 years ago
    Hi R Wodnicki
    I think modifying sysname file in $ASSURAHOME/oa_*/bin is most probably the best approach. I got my packages to work in RHEL7 by modifying sysname file too. : )
    Here are my modifications:
    check_linux() {
    version=2.6.32-431.11.2.el6.x86_64 #`uname -r`
    longVersion="Red Hat Enterprise Linux Workstation release 6.5 (Santiago)" #`cat /etc/redhat-release`
    Best regards
    Quek
