  3. CDL Import 5-terminal MOS transistor (deep nwell)
  • Views 17453
pauloau
pauloau over 11 years ago
I am trying to import a CDL netlist using spiceIn (both command line and through CIW).
My problem is that the netlist includes a deep-nwell NMOS transistor (model nrf_dnw) and this transistor has 5 terminals.
When running spiceIn, I get the error below:
Instance: M61
Instance has master: 'mos' model/subtype: 'vss'
Master Cell: 'mos'.
Did not find 'silterraC18G.mos:symbol'.
ERROR (SPICEIN-24): Spice In did not find the symbol view of the master cell 'mos' of the instance
'M61' in the subcircuit 'afe_rf5'. Specify the reference library that has the symbol
view of the master cell, or use device-mapping to map 'mos' to a different
cell.
The line in the cdl netlist that generates this error is:
M61 net11 net4 vss vss net12 nrf_dnw w=1e-05 l=1.8e-07 m=1 finger=1
My device map file includes the following device:
devSelect := nfet nrf_dnw
propMatch := subtype nrf_dnw
propMap := w w l l m m finger finger
addProp := model nrf_dnw
I can successfully import CDL netlists with "normal" NMOS transistors (4 terminals).
I am using Virtuoso IC6.1.6-64b.500.11.
My questions are:
1) Is it possible to use spiceIn to import this 5-terminal NMOS transistor?
2) If yes, what settings should I use?
Thanks and best regards,
Paulo A. Dal Fabbro
  • pauloau
    I found the solution in the Cadence Support website, topic "Does SpiceIn support import of five terminal mos device".
    The solution uses a sub circuit definition so the SpiceIn is able to import a 5-terminal MOS device.
    In my case I added to the cdl netlist:
    .SUBCKT nrf_dnw D G S B T
    .ENDS
    And replaced in the CDL netlist the line
    with
    XM61 net11 net4 vss vss net12 nrf_dnw w=1e-05 l=1.8e-07 m=1 finger=1
    This solved the problem and the CDL netlist import was successful.
    Thanks and regards,
    Paulo
