  3. How to Plot the Outputs in Ocean
  • Views 15156
Teem
Teem over 11 years ago
Dear All:
I am new to ocean script. I am using foreach loop to change the value of a variable, run the simulation and calculate the output which is a single value. Codes are like below
foreach(i ‘(1 3 5)
desVar(“variable” i)
run()
voutAt10ns=value(VT(“/vp”) 10n) ;one value for each condition
Now I want to plot output vs. input, i.e., Y axis is voutAt10ns and X axis is (1 3 5). Could anyone tell me how to do that?
Thank you very much.
  • MatthewT
    MatthewT over 11 years ago
    It is a workaround, but you can collect simulation results in the output file using "fprintf" command and then use spreadsheet to generate the desired plot.
    Or you could have used paramAnalysis() and paramRun() to do this and then plotting the value() expression would have done what you wanted directly.
