  3. Assura LVS run failing
  • Views 21135
w888ku
w888ku over 11 years ago
Hello all,
I am having a problem with the LVS run in my installation of Cadence Virtuoso. This is specific to my Cadence account at my institution. I am giving the contents from the log file for the LVS error below. Please let me know if anyone can offer some assistance on this matter. It is urgent and will be highly appreciated.
Best regards,
w888ku
Assura (R) Physical Verification Version av4.1:Production:dfII6.1.6:IC6.1.6.500.4
Release 4.1_USR4_HF16
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av4.1:Production:dfII6.1.6:IC6.1.6.500.4 08/29/2014 14:16 (sjfbm166) $
sub-version 4.1_USR4_HF16, integ signature 2014-08-29-1354
run on cycle1.eecs.ku.edu from /opt/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/assura on Fri Aug 7 09:20:58 2015
Starting /opt/cadence/ASSURA41//tools/assura/bin/aveng /home/wdanesh/Inverter.rsf -exec1 -LVS -cdslib /home/wdanesh/cds.lib
@(#)$CDS: aveng version av4.1:Production:dfII6.1.6:IC6.1.6.500.4 08/29/2014 14:16 (sjfbm166) $
run on cycle1.eecs.ku.edu from /opt/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/aveng on Fri Aug 7 09:20:58 2015
Summary Report: Inverter.sum
RSF : /home/wdanesh/Inverter.rsf
Library Name : Project
CDSLIB Path : "/home/wdanesh/cds.lib"
Cell Name : Inverter
View Name : layout
Rules File : /opt/IBM_PDK/cmrf7sf/V2.0.1.0AM/Assura/LVS/extract6.rul
Options : -exec1 -LVS -cdslib /home/wdanesh/cds.lib
Work Directory: .
Operating Mode: Legacy Mode is Off
avlck: INFO: Note that OpenAccess (OA) requires running the Configure phase.
avlck: See the "OpenAccess Installation and Configuration Guide" before
avlck: you complete the configuration step. This manual is included with
avlck: the Cadence product documentation.
avlck: ERROR: The command /opt/cadence/ASSURA41/share/oa/bin/sysname returned an error status:
unknown
Starting dfIIToVdb...
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
@(#)$CDS: dfIIToVdb version av4.1:Production:dfII6.1.6:IC6.1.6.500.4 08/29/2014 14:18 (sjfbm166) $
run on cycle1.eecs.ku.edu from /opt/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/dfIIToVdb on Fri Aug 7 09:20:58 2015
Loading IBM PDK cmrf7sf procedures...
IBM PDK cmrf7sf Device Status Table loaded.
*Error* eval: undefined function - hiGraphicMode
<<< Stack Trace >>>
hiGraphicMode()
(getd('dbGetDatabaseType) && (dbGetDatabaseType() == "OpenAccess") && (hiGraphicMode))
Compiling rules...
WARNING LVS Run detected.
Non-legacy mode has been disabled for this LVS run
unknown
Checking out license for Assura_LVS
Checking out license for Assura_DRC
Reading the design data...
Finished dfIIToVdb.
Building the VDB part 2 in background mode.
unknown
Building tables for LVS Preprocessing in background mode.
Starting /opt/cadence/ASSURA41/tools/assura/bin/vdbToCells . Inverter
Finished /opt/cadence/ASSURA41/tools/assura/bin/vdbToCells
Starting Nvn PreExtraction...
Starting /opt/cadence/ASSURA41/tools/assura/bin/nvn /home/wdanesh/Inverter.rsf -preExtract -exec1 -cdslib /home/wdanesh/cds.lib
@(#)$CDS: nvn version av4.1:Production:dfII6.1.6:IC6.1.6.500.4 08/29/2014 14:18 (sjfbm166) $
run on cycle1.eecs.ku.edu at Fri Aug 7 09:21:03 2015
INFO (AVLVSNN-10120) : '.nocase' command in binding file also switches on softSearchDeviceName(t) option to ensure, that compare rules are applied correctly.
Reading schematic network
inputting netlist /home/wdanesh/Inverter.netlist.lvs
*WARNING* *.PIN is not supported
Reading layout network
inputting network Inverter.ldb
WARNING (AVLVSNN-10035) : bindingFile/bind rule - layout cell 'symindp' is not found and
will be considered a dummy cell. The default binding for schematic cell 'symindp' will be broken.
WARNING (AVLVSNN-10035) : bindingFile/bind rule - layout cell 'indp' is not found and
will be considered a dummy cell. The default binding for schematic cell 'indp' will be broken.
WARNING (AVLVSNN-10035) : bindingFile/bind rule - layout cell 'inds' is not found and
will be considered a dummy cell. The default binding for schematic cell 'inds' will be broken.
inputting network Inverter.sdb
Preprocessing schematic network phase 1
*WARNING* genericDevice("ESDPSH_BASE") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("esdpsh_base") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("ESDNSH_BASE") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("esdnsh_base") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("ESDNDSX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("esdndsx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("TDNDSX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("tdndsx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("EFUSE") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("efuse") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("DINDPW") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("dindpw") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("ESDVPNPNW") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("esdvpnpnw") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("SINGLEWIREX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("singlewire") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("p5pcdcap50") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("PCDCAP50") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("pcdcap50") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("PCDCAP33") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("pcdcap33") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("PCDCAP") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("pcdcap") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("PCAP") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("pcap") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("DIFFMOSVARX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("DIFFMOSVAR") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("diffmosvarx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("diffmosvar") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("MOSVAR50X") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("mosvar50x") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("MOSVAR50") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("mosvar50") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("MOSVARX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("mosvarx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("MOSVAR") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("mosvar") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("INDX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("indx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("INDSX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("indsx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("INDS") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("inds") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("INDPX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("indpx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("INDP") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("indp") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("INDLINEX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("indlinex") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("INDLINE") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("indline") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("SYMINDPX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("symindpx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("SYMINDP") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("symindp") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("SYMINDX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("symindx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("SYMIND") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("symind") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("NFET50TW") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("nfet50tw") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("NFET33TW") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("nfet33tw") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("NFETTW") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("nfettw") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("psbd") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("vlnpn") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("jfetjc") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("diffhavar") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("IND") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("ind") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("COUPLEDWIRESX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("coupledwiresx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("COUPLEDWIRES") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("coupledwires") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("CORRPOINTX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("corrPointx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("CORRPOINT") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("corrPoint") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("DEVICEPAD") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("devicepad") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("BONDPADX") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("bondpadx") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("BONDPAD") - cell does not exist. This command will be ignored.
*WARNING* genericDevice("bondpad") - cell does not exist. This command will be ignored.
*WARNING* deleteCellPin - Unable to find cell 'NFET50TW'
*WARNING* deleteCellPin - Unable to find cell 'NFET33TW'
*WARNING* deleteCellPin - Unable to find cell 'NFETTW'
*WARNING* deleteCellPin - Unable to find cell 'nfet50tw'
*WARNING* deleteCellPin - Unable to find cell 'nfet33tw'
*WARNING* deleteCellPin - Unable to find cell 'nfettw'
Preprocessing layout network phase 1
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'bondpad' is not found and
will be considered a dummy cell. The default binding for layout cell 'bondpad(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'bondpadx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'devicepad' is not found and
will be considered a dummy cell. The default binding for layout cell 'devicepad(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'corrPoint' is not found and
will be considered a dummy cell. The default binding for layout cell 'corrPoint(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'corrPointx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'coupledwires' is not found and
will be considered a dummy cell. The default binding for layout cell 'coupledwires(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'coupledwiresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'dindpw' is not found and
will be considered a dummy cell. The default binding for layout cell 'dindpw(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diodenwx' is not found and
will be considered a dummy cell. The default binding for layout cell 'diodenwx(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diodenx' is not found and
will be considered a dummy cell. The default binding for layout cell 'diodenx(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diodepisx' is not found and
will be considered a dummy cell. The default binding for layout cell 'diodepisx(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diodepnw' is not found and
will be considered a dummy cell. The default binding for layout cell 'diodepnw(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diodepwpi' is not found and
will be considered a dummy cell. The default binding for layout cell 'diodepwpi(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'dipdnw' is not found and
will be considered a dummy cell. The default binding for layout cell 'dipdnw(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'divpnp' is not found and
will be considered a dummy cell. The default binding for layout cell 'divpnp(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'divpnpx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'dualmim' is not found and
will be considered a dummy cell. The default binding for layout cell 'dualmim(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'dualmimx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'dualmimhd' is not found and
will be considered a dummy cell. The default binding for layout cell 'dualmimhd(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'dualmimhdx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'efuse' is not found and
will be considered a dummy cell. The default binding for layout cell 'efuse(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'efusex' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdndsx' is not found and
will be considered a dummy cell. The default binding for layout cell 'esdndsx(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdndsxx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdvpnpnw' is not found and
will be considered a dummy cell. The default binding for layout cell 'esdvpnpnw(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdvpnpnwx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdndpi' is not found and
will be considered a dummy cell. The default binding for layout cell 'esdndpi(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdpnpi' is not found and
will be considered a dummy cell. The default binding for layout cell 'esdpnpi(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdnsh_base' is not found and
will be considered a dummy cell. The default binding for layout cell 'esdnsh_base(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'esdpsh_base' is not found and
will be considered a dummy cell. The default binding for layout cell 'esdpsh_base(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'havar' is not found and
will be considered a dummy cell. The default binding for layout cell 'havar(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'havarx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diffhavar' is not found and
will be considered a dummy cell. The default binding for layout cell 'diffhavar(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'ind' is not found and
will be considered a dummy cell. The default binding for layout cell 'ind(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'indx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'symind' is not found and
will be considered a dummy cell. The default binding for layout cell 'symind(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'symindx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'indline' is not found and
will be considered a dummy cell. The default binding for layout cell 'indline(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'indlinex' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'k1res' is not found and
will be considered a dummy cell. The default binding for layout cell 'k1res(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'k1resx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'lvsres' is not found and
will be considered a dummy cell. The default binding for layout cell 'lvsres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'lvsresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mim' is not found and
will be considered a dummy cell. The default binding for layout cell 'mim(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mimx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mimhd' is not found and
will be considered a dummy cell. The default binding for layout cell 'mimhd(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mimhdx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mimhk' is not found and
will be considered a dummy cell. The default binding for layout cell 'mimhk(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mimhkx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diffmosvar' is not found and
will be considered a dummy cell. The default binding for layout cell 'diffmosvar(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diffmosvarx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mosvar' is not found and
will be considered a dummy cell. The default binding for layout cell 'mosvar(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mosvarx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mosvar50' is not found and
will be considered a dummy cell. The default binding for layout cell 'mosvar50(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'mosvar50x' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'jfetjc' is not found and
will be considered a dummy cell. The default binding for layout cell 'jfetjc(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'vlnpn' is not found and
will be considered a dummy cell. The default binding for layout cell 'vlnpn(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfet' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfet(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfethv' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfethv(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfet33' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfet33(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfet50' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfet50(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfettw' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfettw(Generic)' will be broken.
will be considered a dummy cell. The default binding for layout cell 'nfettw4(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfet33tw' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfet33tw(Generic)' will be broken.
will be considered a dummy cell. The default binding for layout cell 'nfet33tw4(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfet50tw' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfet50tw(Generic)' will be broken.
will be considered a dummy cell. The default binding for layout cell 'nfet50tw4(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'opndres' is not found and
will be considered a dummy cell. The default binding for layout cell 'opndres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'opndresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'oppdres' is not found and
will be considered a dummy cell. The default binding for layout cell 'oppdres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'oppdresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'opppcres' is not found and
will be considered a dummy cell. The default binding for layout cell 'opppcres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'opppcresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'oprppres' is not found and
will be considered a dummy cell. The default binding for layout cell 'oprppres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'oprppresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'oprrpres' is not found and
will be considered a dummy cell. The default binding for layout cell 'oprrpres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'oprrpresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'rr_serpentine' is not found and
will be considered a dummy cell. The default binding for layout cell 'rr_serpentine(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'rr_serpentinex' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pcap' is not found and
will be considered a dummy cell. The default binding for layout cell 'pcap(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pcdcap' is not found and
will be considered a dummy cell. The default binding for layout cell 'pcdcap(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pcdcapx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pcdcap33' is not found and
will be considered a dummy cell. The default binding for layout cell 'pcdcap33(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pcdcap33x' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pcdcap50' is not found and
will be considered a dummy cell. The default binding for layout cell 'pcdcap50(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pcdcap50x' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfet' is not found and
will be considered a dummy cell. The default binding for layout cell 'pfet(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfetx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfet33' is not found and
will be considered a dummy cell. The default binding for layout cell 'pfet33(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfet33x' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfet50' is not found and
will be considered a dummy cell. The default binding for layout cell 'pfet50(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfet50x' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'p5pfet50' is not found and
will be considered a dummy cell. The default binding for layout cell 'p5pfet50(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'p5pfet50x' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfethv' is not found and
will be considered a dummy cell. The default binding for layout cell 'pfethv(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfethvx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sbd' is not found and
will be considered a dummy cell. The default binding for layout cell 'sbd(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sbdx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sbdnw' is not found and
will be considered a dummy cell. The default binding for layout cell 'sbdnw(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sbdnwx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'psbd' is not found and
will be considered a dummy cell. The default binding for layout cell 'psbd(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sblkndres' is not found and
will be considered a dummy cell. The default binding for layout cell 'sblkndres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sblkndresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sblkpdres' is not found and
will be considered a dummy cell. The default binding for layout cell 'sblkpdres(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'sblkpdresx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'singlewire' is not found and
will be considered a dummy cell. The default binding for layout cell 'singlewire(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'singlewirex' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'subc' is not found and
will be considered a dummy cell. The default binding for layout cell 'subc(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'subcx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'tdndsx' is not found and
will be considered a dummy cell. The default binding for layout cell 'tdndsx(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'tdndsxx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'tdpdnw' is not found and
will be considered a dummy cell. The default binding for layout cell 'tdpdnw(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'tdpdnwx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'vncap' is not found and
will be considered a dummy cell. The default binding for layout cell 'vncap(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'vncapx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'zvtnfet' is not found and
will be considered a dummy cell. The default binding for layout cell 'zvtnfet(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'zvtnfetx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'zvtnfet33' is not found and
will be considered a dummy cell. The default binding for layout cell 'zvtnfet33(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'zvtnfet33x' is not found and
Preprocessing schematic network phase 2
Preprocessing layout network phase 2
cpu=0.00m wall=0.02m mem=32.79mb
Finished /opt/cadence/ASSURA41/tools/assura/bin/nvn
*WARNING* '?expandCellToParent' list: No cell name match for psbd*
*WARNING* '?expandCellToParent' list: No cell name match for sbd*
*WARNING* '?expandCellToParent' list: No cell name match for corrPoint
*WARNING* '?expandCellToParent' list: No cell name match for coupledwire*
*WARNING* '?expandCellToParent' list: No cell name match for singlewire*
*WARNING* '?expandCellToParent' list: No cell name match for vncap*
*WARNING* '?expandCellToParent' list: No cell name match for esdndsx*
*WARNING* '?expandCellToParent' list: No cell name match for esdvpnpnw*
*WARNING* '?expandCellToParent' list: No cell name match for esdnfet*
*WARNING* '?expandCellToParent' list: No cell name match for k1res*
*WARNING* '?expandCellToParent' list: No cell name match for mosvar*
*WARNING* '?expandCellToParent' list: No cell name match for bondpad*
*WARNING* '?expandCellToParent' list: No cell name match for symind*
*WARNING* '?expandCellToParent' list: No cell name match for ind*
*WARNING* '?expandCellToParent' list: No cell name match for mimhk*
*WARNING* '?expandCellToParent' list: No cell name match for mim*
*WARNING* '?expandCellToParent' list: No cell name match for dualmim*
*WARNING* '?expandCellToParent' list: No cell name match for havar*
*WARNING* '?expandCellToParent' list: No cell name match for diffmosvar*
*WARNING* '?expandCellToParent' list: No cell name match for opn*
*WARNING* '?expandCellToParent' list: No cell name match for oppp*
*WARNING* '?expandCellToParent' list: No cell name match for oprr*
*WARNING* '?expandCellToParent' list: No cell name match for nwpc*
*WARNING* '?expandCellToParent' list: No cell name match for divpnp
*WARNING* '?expandCellToParent' list: No cell name match for dipdnw
*WARNING* '?expandCellToParent' list: No cell name match for zvtnfet*
*WARNING* '?expandCellToParent' list: No cell name match for efuse*
*WARNING* '?expandCellToParent' list: No cell name match for esdndpi*
*WARNING* '?expandCellToParent' list: No cell name match for esdpnpi*
*WARNING* '?expandCellToParent' list: No cell name match for jfetjc*
*WARNING* '?expandCellToParent' list: No cell name match for vlnpn*
*WARNING* '?expandCellToParent' list: No cell name match for rr_serpentine*
*WARNING* '?expandCellToParent' list: No cell name match for p5pfet50
*WARNING* '?expandCellToParent' list: No cell name match for esdnsh_base*
*WARNING* '?expandCellToParent' list: No cell name match for esdpsh_base*
*WARNING* '?expandCellToParent' list: No cell name match for devicepad*
*WARNING* '?expandCellToParent' list: No cell name match for p5pcdcap*
Building the VDB part 3 in background mode.
unknown
Finished building the VDB. VDB build times for main process:
cpu: 0.42 elap: 5 pf: 0 in: 0 out: 6680 virt: 0M phys: 480M
Running the Task Processor, 1 cells, 21341 steps...
Top Cell is 'Inverter layout Project'
Executing: bkgnd = geomBkgnd()
Executing: ns = geomAndNot(NS_drawing ti)
Executing: nw = geomAndNot(NW_drawing ti)
Executing: ca = geomOr(CA_drawing_net CABAR_drawing_net CA_bb)
Executing: ca_input = geomOr(ca)
Executing: m1_bb = geomAndNot(m1_bb m1_RES_bb)
Executing: m1 = geomOr(m1 m1_bb M1_pin)
Executing: v1 = geomOr(V1_drawing_net V1BAR_drawing V1_bb)
Executing: v1_input = geomOr(v1)
Executing: m2_bb = geomAndNot(m2_bb m2_RES_bb)
Executing: m2 = geomOr(m2 m2_bb M2_pin)
Executing: v2 = geomOr(V2_drawing_net V2BAR_drawing V2_bb)
Executing: v2_input = geomOr(v2)
Executing: m3_bb = geomAndNot(m3_bb m3_RES_bb)
Executing: m3 = geomOr(m3 m3_bb M3_pin)
Executing: v3 = geomOr(V3_drawing_net V3BAR_drawing V3_bb)
Executing: v3_input = geomOr(v3)
Executing: m4_bb = geomAndNot(m4_bb m4_RES_bb)
Executing: m4 = geomOr(m4 m4_bb M4_pin)
Executing: v4 = geomOr(V4_drawing_net V4BAR_drawing V4_bb)
Executing: v4_input = geomOr(v4)
Executing: mt_bb = geomAndNot(mt_bb mt_RES_bb)
Executing: mt = geomOr(mt mt_bb MT_pin)
Executing: FT_bb = geomAndNot(FT_bb qt_bb)
Executing: ft = geomOr(FT_drawing_net FT_bb)
Executing: ft_input = geomOr(ft)
Executing: bondPadFilter = geomSize(PAD_DEV -0.1)
Executing: wb_pad_dv = geomAnd(dv geomOr(bondPadFilter LVSDG6))
Executing: wb_pad_lv = geomAnd(lv geomOr(bondPadFilter LVSDG6))
Executing: am_bb = geomAndNot(am_bb am_RES_bb)
Executing: am = geomOr(am am_bb AM_pin)
Executing: bondPad = geomAnd(bondPadFilter am)
Executing: bondPad_via = geomAnd(am bondPad)
Executing: bondPad_top = geomOr(bondPad)
Executing: padOverDev = geomAnd(geomOutside(LVSDG6 bondPad) am)
Executing: padOverDev_top = geomOr(padOverDev)
Executing: padOverDev_via = geomAnd(am_padOverDev padOverDev)
Executing: wb_pad_dv_via = geomAnd(wb_pad_dv geomOr(bondPad padOverDev))
Executing: wb_pad_lv_via = geomAnd(wb_pad_lv geomOr(bondPad padOverDev))
Executing: pc = geomOr(pc geomAnd(pc PC_pin) pc_bb)
Executing: pc_input = geomOr(pc)
Executing: rx_input = geomOr(rx)
Executing: pc_ISO = geomOverlap(pc geomOr(ISODEV FLTGATE))
Executing: rx = geomAndNot(rx pc_ISO)
Executing: bp_not_bb = geomAndNot(bp bb)
Executing: pc_fill = geomOutside(geomInside(geomEnclose(pc rx) GRLOGIC) ca)
Executing: rx_fill = geomOutside(rx geomOr(ca pi))
Executing: rx = geomAndNot(rx geomOr(pc_fill))
Executing: rx = geomOr(geomOverlap(rx ca) geomOverlap(rx nw (keep > 1)))
Executing: ind_xy = geomAnd(ind_xy ind)
Executing: RF = geomSize(RF 0.25)
Executing: ESD_ALL = geomOr(ESD_DRC ESD_cdm)
Executing: errorLayer(geomOutside(geomAndNot(sblk op) ESD_ALL) "SBLK without OP")
Executing: op_temp = geomOutside(op sblk)
Executing: sblk = geomAnd(op sblk)
Executing: sblk_over_pc = geomOverlap(sblk pc)
Executing: sblk = geomAndNot(sblk geomSize(pc 0.01))
Executing: op = geomOr(op_temp)
Executing: ESD_nsnw = geomOverlap(geomOr(ns nw) ESD_DEV)
Executing: ESD_pdif = geomOverlap(geomOr(bp pd) ESD_DEV)
Executing: ESD_pdnw = geomOverlap(ESD_DEV geomGetRectangle(geomAnd(ESD_pdif ESD_nsnw)))
Executing: ESD_pdnw_all = geomOr(ESD_pdnw)
Executing: ESD_pdnw_diode = geomOutside(ESD_pdnw GRLOGIC)
Executing: ESD_pdnw_subc = geomOutside(geomOverlap(geomAnd(rx ESD_pdif) ESD_pdnw) ESD_nsnw)
Executing: ESD_pdnw_plus = geomOverlap(geomOverlap(geomAnd(rx ESD_pdif) ESD_pdnw) ESD_nsnw)
Executing: ESD_pdnw_minus = geomOverlap(geomAndNot(rx ESD_pdif) ESD_pdnw)
Executing: geomHoles(ESD_pdnw_minus)
Executing: ESD_pdnw_minus_term = geomOr(ESD_pdnw_minus geomSize(ESD_pdnw_minus_hole 0.1))
Executing: ESD_pdnw_minus_via = geomAnd(ESD_pdnw_minus_term ESD_pdnw_minus)
Executing: rx = geomAndNot(rx ESD_pdnw_plus)
Executing: VPNPnw = geomAnd(ESD_DEV geomEnclose(nw bp))
Executing: ESD_vpnp_pdif = geomOr(VPNPnw ESD_pdif)
Executing: ESD_ndsx = geomOutside(ESD_DEV VPNPnw)
Executing: ESD_ndsx_all = geomOr(ESD_ndsx)
Executing: ESD_ndsx_minus = geomInside(geomOutside(rx ESD_vpnp_pdif) ESD_DEV)
Executing: ESD_ndsx_minus = geomOr(geomOverlap(nw ESD_ndsx_minus) ESD_ndsx_minus)
Executing: ESD_ndsx_plus = geomOutside(ESD_pdif VPNPnw)
Executing: geomHoles(ESD_ndsx_plus)
Executing: ESD_ndsx_plus_term = geomOr(ESD_ndsx_plus geomSize(ESD_ndsx_plus_hole 0.1))
Executing: ESD_ndsx_plus_via = geomAnd(ESD_ndsx_plus_term ESD_ndsx_plus)
Executing: ESD_pdnw_pi = geomOverlap(ESD_pdnw pi)
Executing: ESD_pdnw = geomOutside(ESD_pdnw pi)
Executing: ESD_pdnw_diode = geomOutside(ESD_pdnw_diode pi)
Executing: ESD_ndsx_pi = geomOverlap(ESD_ndsx pi)
Executing: ESD_ndsx_GR_sized = geomOverlap(geomSize(geomAnd(geomOverlap(geomOutside(ESD_...
Executing: ESD_ndsx_GR = geomOutside(geomOverlap(geomOutside(ESD_ndsx pi) GRLOGIC) ESD_n...
Executing: ESD_ndsx = geomOutside(geomOutside(ESD_ndsx pi) GRLOGIC)
Executing: ESD_pdnw_diode_GR_sized = geomOverlap(geomSize(geomAnd(geomOverlap(ESD_pdnw G...
Executing: ESD_pdnw_diode_GR = geomOutside(geomOverlap(ESD_pdnw GRLOGIC) ESD_pdnw_diode_...
Executing: ESD_nw = geomOverlap(nw ESD_DEV)
Executing: nw = geomOutside(nw geomOr(ESD_pdnw ESD_ndsx))
Executing: ESD_ns = geomOverlap(ns ESD_DEV)
Executing: ns = geomOutside(ns geomOr(ESD_DEV ESD_ndsx))
Executing: recognized_device = geomOr(ESD_pdnw ESD_ndsx ESD_pdnw_pi ESD_ndsx_pi ESD_ndsx...
Executing: efuse = geomOr(pcFuse)
Executing: efuse_cath = geomOr(drc(geomButting(pc efuse) (area > 3)))
Executing: efuse_anod = geomOr(drc(geomButting(pc efuse) (area < 3)))
Executing: efuse_err1 = geomOutside(efuse bp)
errorLayer(efuse_err1 "efuse device without bp")
Executing: efuse_err2 = geomAnd(efuse geomOr(ns rx jd pi rn nw nr pr bb dg tg rr rp pd op))
errorLayer(efuse_err2 "efuse device touching ns,rx,jd,pi,rn,nw,nr,pr,bb,dg,tg,rr,rp,pd,op")
Executing: HAVAR = geomEnclose(ns geomOverlap(jd rx))
Executing: havar_err = geomAndNot(HAVAR bb)
errorLayer(havar_err "HAVAR device missing bb")
Executing: hvr_mul = geomOverlap(HAVAR multi)
Executing: hvr_dev = geomOr(HAVAR)
Executing: hvr_cath = geomAnd(HAVAR geomAnd(rx rn))
Executing: hvr_anod = geomAnd(HAVAR geomAndNot(rx rn))
Executing: hvr_dev_err = geomAnd(hvr_dev geomOr(pi nw nr pr dg pc rr rp pd op))
errorLayer(hvr_dev_err "HAVAR device touching pi,nw,nr,pr,dg,tg,pc,rr,rp,pd,op")
Executing: recognized_device = geomOr(recognized_device HAVAR)
Executing: diffhavar_dev = geomOverlap(HAVAR DiffMOSvar)
Executing: width_label_h_edge = geomSize(geomGetEdge(width_label coincident hvr_anod) 0.1)
Executing: width_label_dhvr = geomButting(width_label width_label_h_edge (keep == 3))
Executing: hvr_dev = geomOutside(hvr_dev DiffMOSvar)
Executing: var_rx = geomAnd(rx geomOr(hvr_dev diffhavar_dev))
Executing: rx = geomAndNot(rx geomOr(hvr_anod))
Executing: geomHoles(geomAndNot(pd recognized_device))
Executing: SBD = geomOutside(geomOutside(geomEnclose(geomAnd(SBD_in bb) geomAnd(rx pd_ho...
Executing: SBD_A = geomInside(geomStraddle(IBM_LayerCopy(rx) pd_hole) SBD)
Executing: SBD_C = geomAnd(geomAnd(rx rn) SBD)
Executing: pd_hole_sbd = geomAnd(pd_hole SBD_A)
Executing: width_label_s_edge = geomSize(geomGetEdge(width_label coincident pd_hole_sbd)...
Executing: width_label_sbd = geomButting(width_label width_label_s_edge (keep == 3))
Executing: sbd_err = geomOutside(SBD ns)
errorLayer(sbd_err "SBD device without NS")
Executing: sbd_err2 = geomStraddle(ns SBD)
errorLayer(sbd_err2 "NS straddling SBD device")
Executing: SBD_err3 = geomAnd(SBD geomOr(jd pi nw nr pr dg tg pc rr rp op))
errorLayer(SBD_err3 "SBD device touching jd,pi,nw,nr,pr,dg,tg,pc,rr,rp,op")
Executing: recognized_device = geomOr(recognized_device SBD)
Executing: rx = geomAndNot(rx geomOr(SBD_A))
Executing: SBDNW = geomOutside(geomOutside(geomInside(geomEnclose(geomEnclose(SCHKY bb) ...
Executing: SBDNW_A = geomInside(geomAnd(IBM_LayerCopy(rx) bb) SBDNW)
Executing: SBDNW_C = geomInside(geomAndNot(rx SBDNW_A) SBDNW)
Executing: width_label_snw_edge = geomSize(geomGetEdge(width_label coincident SBDNW_A) 0.1)
Executing: width_label_sbdnw = geomButting(width_label width_label_snw_edge (keep == 3))
Executing: sbdnw_err = geomAndNot(SBDNW nw)
errorLayer(sbdnw_err "SBDNW device must be covered by NW")
Executing: sbdnw_err3 = geomAnd(SBDNW geomOr(ns jd pi rn nr pr dg tg pc rr rp op))
errorLayer(sbdnw_err3 "SBDNW device touching ns,jd,pi,rn,nr,pr,dg,tg,pc,rr,rp,op")
Executing: recognized_device = geomOr(recognized_device SBDNW)
Executing: rx = geomAndNot(rx geomOr(SBDNW_A))
Executing: psbd_rev = geomGetTexted(SBD_in DEVICE_ID_TXT "PSBD-DEVICE")
Executing: PSBD = geomOutside(geomOutside(geomOverlap(geomEnclose(geomEnclose(geomEnclos...
Executing: PSBD_A = geomInside(geomAnd(IBM_LayerCopy(rx) pd) PSBD)
Executing: PSBD_C = geomInside(geomAndNot(rx PSBD_A) PSBD)
Executing: width_lbl_psbd_edge = geomSize(geomGetEdge(width_label coincident PSBD_C) 0.1)
Executing: width_label_psbd = geomButting(width_label width_lbl_psbd_edge (keep == 3))
Executing: psbd_err = geomAnd(PSBD geomOr(ns jd rn nr pr dg tg pc rr rp op))
errorLayer(psbd_err "PSBD device touching ns,jd,rn,nr,pr,dg,tg,pc,rr,rp,op")
Executing: psbd_err2 = geomOutside(PSBD bb)
errorLayer(psbd_err2 "PSBD device missing bb")
Executing: recognized_device = geomOr(recognized_device PSBD)
Executing: rx = geomAndNot(rx geomOr(PSBD_A PSBD_C))
Executing: DI_diode = geomOverlap(nw di)
Executing: DI_anode = geomOverlap(geomInside(IBM_LayerCopy(rx) di) DI_diode)
Executing: DI_cathode = geomAnd(geomOutside(rx di) DI_diode)
Executing: DI_FILTER = geomSize(DI_diode 0.94)
Executing: DI_vpnp_sharing_coll = geomSize(DI_diode 0.5)
Executing: DI_VPNP = geomOverlap(DI_vpnp_sharing_coll bperi)
Executing: DI_coll = geomOutside(geomOverlap(IBM_LayerCopy(rx) DI_VPNP) DI_diode)
Executing: DI_diode = geomOutside(DI_diode DI_VPNP)
Executing: DI_diode_err1 = geomOutside(DI_diode bp)
errorLayer(DI_diode_err1 "DI Diode device without bp")
Executing: DI_diode_err2 = geomAnd(DI_diode geomOr(ns jd pi rn nr pr bb dg tg pc rr rp p...
errorLayer(DI_diode_err2 "DI Diode device touching ns,jd,pi,rn,nr,pr,bb,dg,tg,pc,rr,rp,pd,op")
Executing: recognized_device = geomOr(recognized_device DI_FILTER DI_VPNP)
Executing: DIPI_diode1 = geomEnclose(pi DIPI)
Executing: DIPI_diode_pd = geomAnd(bp DIPI_diode1)
Executing: bp = geomAndNot(bp DIPI_diode_pd)
Executing: DIPI_diode = geomSize(DIPI_diode1 1.6)
Executing: DIPI_FILTER = geomSize(DIPI_diode1 2.1)
Executing: DIPI_cathode = geomOverlap(geomInside(IBM_LayerCopy(rx) DIPI) DIPI_diode)
Executing: DIPI_anode = geomOverlap(geomAnd(rx DIPI_diode_pd) DIPI_diode)
Executing: DIPI_iso_node = geomAnd(geomAnd(rx nw) DIPI_diode)
Executing: DIPI_subc = geomOverlap(geomAnd(rx bp) DIPI_diode)
Executing: DIPI_diode_err2 = geomAnd(DIPI_diode geomOr(ns jd rn nr pr bb dg rr rp pd op))
errorLayer(DIPI_diode_err2 "DIPI Diode device touching ns,jd,rn,nr,pr,bb,dg,rr,rp,pd,op")
Executing: DIPI_diode_err3 = geomAnd(DIPI geomOr(nw bp))
errorLayer(DIPI_diode_err3 "DIPI Diode device touching nw,bp")
Executing: recognized_device = geomOr(recognized_device DIPI_diode DIPI_FILTER)
Executing: pcap_dev = geomOutside(geomAnd(geomOverlap(pi geomOutside(geomAnd(pc rx) geom...
Executing: pcap_dev_pd = geomAnd(bp pcap_dev)
Executing: pcap_pc = geomOverlap(IBM_LayerCopy(pc) pcap_dev)
Executing: pcap_pdiff = geomOverlap(geomAnd(IBM_LayerCopy(rx) pcap_dev_pd) pcap_dev)
Executing: pcap_rxpc = geomAnd(pcap_pdiff pc)
Executing: pcap_rx = geomAndNot(pcap_pdiff pcap_rxpc)
Executing: pcap_gates = geomOverlap(geomAnd(IBM_LayerCopy(rx) IBM_LayerCopy(pc)) pcap_dev)
Executing: pcap_pc_length = geomSize(geomGetEdge(pcap_gates inside IBM_LayerCopy(pc)) -0...
Executing: pcap_rx_width = geomSize(geomGetEdge(pcap_gates inside IBM_LayerCopy(rx)) -0.05)
Executing: pcap_mul = geomOverlap(pcap_dev multi)
Executing: pcap_err = geomAnd(pcap_dev geomOr(ns jd rn nr pr bb dg rr rp pd op))
errorLayer(pcap_err "pcap device touching ns,jd,rn,nr,pr,bb,dg,rr,rp,pd,op")
Executing: pcap_err2 = geomAnd(pcap_dev tg)
errorLayer(pcap_err2 "pcap device touching tg")
Executing: pcap_pw = geomOverlap(geomAndNot(pi nw) pcap_dev)
Executing: rx = geomAndNot(rx pcap_rxpc)
Executing: nplus_in_pcap_pw = geomAnd(pcap_pw geomAndNot(rx bp))
errorLayer(nplus_in_pcap_pw "N+ diffusion in pcap pwell found")
Executing: recognized_device = geomOr(recognized_device pcap_dev)
Executing: vlnpn_rev = geomGetTexted(MOSvar DEVICE_ID_TXT "VLNPN-DEVICE")
Executing: vlnpn_dev = geomOutside(geomEnclose(bperi geomEnclose(pi geomEnclose(bipolar ...
Executing: ndiff_vlnpn = geomInside(geomOverlap(geomAndNot(rx bp) MOSvar) vlnpn_dev)
Executing: vlnpn_g = geomAndNot(geomAnd(pc ndiff_vlnpn) nw)
Executing: vlnpn_g_via = geomOr(vlnpn_g)
Executing: vlnpn_ce = geomButting(geomAndNot(geomAndNot(ndiff_vlnpn nw) pc) vlnpn_g)
Executing: vlnpn_c = geomOutside(vlnpn_ce drain_filter)
Executing: vlnpn_e = geomOverlap(vlnpn_ce drain_filter)
Executing: vlnpn_sub = geomOutside(geomOverlap(geomAnd(rx bp) vlnpn_dev) pi)
Executing: vlnpn_area = geomInside(geomAnd(pc rx) vlnpn_dev)
Executing: vlnpn_exl = geomSize(geomGetEdge(vlnpn_g butting vlnpn_e) -0.1)
Executing: vlnpn_err2 = geomAnd(vlnpn_dev geomOr(ns jd rn nr pr bb dg rr rp pd op))
errorLayer(vlnpn_err2 "vlnpn device touching ns,jd,rn,nr,pr,bb,dg,rr,rp,pd,op")
Executing: recognized_device = geomOr(recognized_device vlnpn_dev)
Executing: MOSVAR = geomOverlap(nw geomOutside(geomAnd(pc rx) geomOr(bp rn)))
Executing: mosvar_dev = geomOverlap(geomOverlap(MOSVAR geomAnd(pc rx)) MOSvar)
Executing: mosvar_pc = geomOverlap(IBM_LayerCopy(pc) mosvar_dev)
Executing: mosvar_nw = geomOverlap(IBM_LayerCopy(nw) mosvar_dev)
Executing: pc = geomAndNot(pc mosvar_pc)
Executing: mosvar_rx = geomAnd(geomAndNot(geomOverlap(IBM_LayerCopy(rx) mosvar_dev) pc) ...
Executing: mosvar_RX = geomOr(mosvar_rx)
Executing: mosvar_gates = geomOverlap(geomAnd(rx mosvar_pc) mosvar_dev)
Executing: mosvar_pc_length = geomSize(geomGetEdge(mosvar_gates inside mosvar_pc) -0.1)
Executing: mosvar_rx_width = geomSize(geomGetEdge(mosvar_gates inside rx) -0.05)
Executing: mosvar_mul = geomOverlap(mosvar_dev multi)
Executing: mosvar_err = geomAnd(mosvar_dev geomOr(dg))
errorLayer(mosvar_err "mosvar device touching dg")
Executing: recognized_device = geomOr(recognized_device mosvar_dev)
Executing: nw = geomAndNot(nw mosvar_nw)
Executing: mosvar50_dev = geomOverlap(mosvar_dev tg)
Executing: p5pcdcap50_d = geomOverlap(mosvar50_dev DECAP)
Executing: mosvar50_dev = geomOutside(mosvar50_dev DECAP)
Executing: p5pcdcap50_dev = geomGetTexted(p5pcdcap50_d DEVICE_ID_TXT "P5PCDCAP50-DEVICE")
Executing: mosvar_dev = geomOutside(mosvar_dev geomOr(tg))
Executing: diffmosvar_dev = geomOverlap(mosvar_dev DiffMOSvar)
Executing: mosvar_dev = geomOutside(mosvar_dev geomOr(DiffMOSvar))
Executing: ncap_dev = geomOutside(geomAnd(MOSVAR geomAnd(pc rx)) MOSvar)
Executing: ncap_pc = geomOverlap(IBM_LayerCopy(pc) ncap_dev)
Executing: ncap_nw = geomOverlap(IBM_LayerCopy(nw) ncap_dev)
Executing: ncap_rx = geomAnd(geomAndNot(geomOverlap(rx ncap_dev) geomOr(pc bp)) ncap_nw)
Executing: ncap_gates = geomOverlap(geomAnd(rx pc) ncap_dev)
Executing: decap_rx = geomAnd(geomOverlap(geomAnd(rx pc) ncap_dev) ncap_nw)
Executing: ncap_rx = geomOr(ncap_rx geomAnd(GRLOGIC decap_rx))
Executing: ndiff_in_ncap_nw = geomAnd(geomAndNot(geomOutside(rx ncap_dev) geomOr(pc bp))...
Executing: ncap_ndiff = geomOr(ncap_rx ndiff_in_ncap_nw)
Executing: pplus_in_ncap_nw = geomAnd(ncap_nw geomAnd(rx bp))
errorLayer(pplus_in_ncap_nw "P+ diffusion in ncap nwell found")
Executing: ncap_pc_length = geomSize(geomGetEdge(ncap_gates inside pc) -0.1)
Executing: ncap_rx_width = geomSize(geomGetEdge(ncap_gates inside rx) -0.1)
Executing: ncap_mul = geomOverlap(ncap_dev multi)
Executing: MOSVAR_err2 = geomAnd(MOSVAR geomOr(ns jd pi rn nr pr bp rr rp pd op))
errorLayer(MOSVAR_err2 "mosvar or ncap device touching ns,jd,pi,rn,nr,pr,bp,rr,rp,pd,op")
Executing: pc = geomAndNot(pc ncap_pc)
Executing: nw = geomAndNot(nw ncap_nw)
Executing: recognized_device = geomOr(recognized_device ncap_dev)
Executing: ncap33_dev = geomOverlap(ncap_dev dg)
Executing: ncap_dev = geomOutside(ncap_dev dg)
Executing: ncap50_dev = geomOverlap(ncap_dev tg)
Executing: ncap_dev = geomOutside(ncap_dev tg)
Executing: ncap_n1 = geomGetEdge(geomOr(mosvar_nw ncap_nw) inside rx)
Executing: ncap_ndo = geomSize(ncap_n1 0.01)
Executing: ncap_ndi = geomSize(ncap_n1 -0.01)
Executing: ncap_nd = geomOr(ncap_ndo ncap_ndi)
Executing: rx = geomAndNot(rx mosvar_rx)
Executing: rx = geomAndNot(rx geomOr(ncap_rx decap_rx))
Executing: JFET = geomOverlap(jc geomAnd(rx bp))
Executing: jfet_err = geomAndNot(JFET pi)
errorLayer(jfet_err "JFET device not over pi")
Executing: jfet_dev = geomOr(JFET)
Executing: jfet_dev_sized = geomSize(jfet_dev 2.0)
Executing: jfet_rx = geomOverlap(rx JFET)
Executing: jfet_gate = geomAnd(jfet_rx bp)
Executing: jfet_G = geomAnd(jfet_gate JFET)
Executing: jfet_sd = geomAndNot(jfet_rx bp)
Executing: jfet_drain = geomOverlap(jfet_sd drain_filter)
Executing: jfet_source = geomOutside(jfet_sd drain_filter)
Executing: width_lbl_jfet_edge = geomSize(geomGetEdge(width_label coincident jfet_sd) 0.1)
Executing: width_label_jfet = geomButting(width_label width_lbl_jfet_edge (keep >= 3))
Executing: width_label_jfet_sd = geomAnd(jfet_sd width_label_jfet)
Executing: jfet_dev_err = geomAnd(jfet_dev geomOr(ns jd rn nr pr bb dg tg pc rr rp pd op))
errorLayer(jfet_dev_err "JFET device touching ns,jd,rn,nr,pr,bb,dg,tg,pc,rr,rp,pd,op")
Executing: recognized_device = geomOr(recognized_device JFET)
Executing: butt_rx = geomGetEdge(bp inside rx)
Executing: butt_rxn = geomSize(butt_rx 0.1 edges)
Executing: butt_rxp = geomSize(butt_rx -0.1 edges)
Executing: butt_top = geomOr(butt_rxn butt_rxp)
Executing: ndiff = geomAndNot(rx bp)
Executing: nfet_gate = geomOutside(geomAndNot(geomAnd(pc ndiff) nw) recognized_device)
Executing: nfet_dev_polygon = geomGetPolygon(nfet_gate)
Executing: nfet_gate_gns = geomOverlap(sblk_over_pc nfet_gate)
Executing: nfet_dev_b = geomOutside(geomOr(nfet_dev_polygon) nr)
Executing: nfet_dev = geomOutside(nfet_gate geomOr(nfet_dev_b dg dgv tg ZVT nr))
Executing: nfet_dev_TG = geomAndNot(geomAnd(geomOutside(geomAndNot(nfet_gate nfet_dev_b)...
Executing: nfet_dev_MV = geomAndNot(geomAnd(geomAnd(geomOutside(geomAndNot(nfet_gate nfe...
Executing: nfet_dev_HV = geomAndNot(geomAnd(geomOutside(geomAndNot(nfet_gate nfet_dev_b)...
Executing: nfet_dev_HVT = geomAndNot(geomAnd(geomAndNot(nfet_gate nfet_dev_polygon) nr) ...
Executing: nfet_dev_HVT_b = geomAndNot(geomAnd(nfet_dev_polygon nr) geomOr(dg dgv))
Executing: nfzv_dev = geomOverlap(geomAndNot(nfet_gate geomOr(nfet_dev_polygon nfet_dev_...
Executing: nfzv_dev_HV = geomOverlap(geomAndNot(nfet_gate geomOr(nfet_dev_polygon nfet_d...
Executing: nfet_sd = geomButting(geomAndNot(geomAndNot(ndiff nw) geomOr(pc rn op sblk)) ...
Executing: nfet_fingers = geomInside(nfet_dev multi)
Executing: nfzv_fingers = geomInside(nfzv_dev multi)
Executing: nfzv_fingers_HV = geomInside(nfzv_dev_HV multi)
Executing: nfet_fingers_MV = geomInside(nfet_dev_MV multi)
Executing: nfet_fingers_TG = geomInside(nfet_dev_TG multi)
Executing: nfet_fingers_HV = geomInside(nfet_dev_HV multi)
Executing: nfet_fingers_HVT = geomInside(nfet_dev_HVT multi)
Executing: nfet_mul = geomStraddle(rx nfet_fingers)
Executing: nfzv_mul = geomStraddle(rx nfzv_fingers)
Executing: nfzv_mul_HV = geomStraddle(rx nfzv_fingers_HV)
Executing: nfet_mul_MV = geomStraddle(rx nfet_fingers_MV)
Executing: nfet_mul_HV = geomStraddle(rx nfet_fingers_HV)
Executing: nfet_mul_TG = geomStraddle(rx nfet_fingers_TG)
Executing: nfet_mul_HVT = geomStraddle(rx nfet_fingers_HVT)
Executing: nfet_dev = geomOutside(nfet_dev multi)
Executing: nfzv_dev = nfzv_dev = nfzv_dev = geomOutside(nfzv_dev multi)
Executing: nfzv_dev_HV = nfzv_dev_HV = nfzv_dev_HV = geomOutside(nfzv_dev_HV multi)
Executing: nfet_dev_TG = geomOutside(nfet_dev_TG multi)
Executing: nfet_dev_MV = geomOutside(nfet_dev_MV multi)
Executing: nfet_dev_HV = geomOutside(nfet_dev_HV multi)
Executing: nfet_dev_HVT = geomOutside(nfet_dev_HVT multi)
Executing: nfRF_dev_psp = geomOverlap(geomOverlap(rx geomOverlap(nfet_dev RF)) psp_model)
Executing: nfRF_mul_psp = geomOverlap(geomOverlap(rx geomOverlap(nfet_mul RF)) psp_model)
Executing: nfRF_dev_psp_MV = geomOverlap(geomOverlap(rx geomOverlap(nfet_dev_MV RF)) psp...
Executing: nfRF_mul_psp_MV = geomOverlap(geomOverlap(rx geomOverlap(nfet_mul_MV RF)) psp...
Executing: nfRF_dev_psp_HV = geomOverlap(geomOverlap(rx geomOverlap(nfet_dev_HV RF)) psp...
Executing: nfRF_mul_psp_HV = geomOverlap(geomOverlap(rx geomOverlap(nfet_mul_HV RF)) psp...
Executing: nfRF_dev = geomOutside(geomOverlap(rx geomOverlap(nfet_dev RF)) psp_model)
Executing: nfRF_mul = geomOutside(geomOverlap(rx geomOverlap(nfet_mul RF)) psp_model)
Executing: nfRF_dev_MV = geomOutside(geomOverlap(rx geomOverlap(nfet_dev_MV RF)) psp_model)
Executing: nfRF_mul_MV = geomOutside(geomOverlap(rx geomOverlap(nfet_mul_MV RF)) psp_model)
Executing: nfRF_dev_HV = geomOutside(geomOverlap(rx geomOverlap(nfet_dev_HV RF)) psp_model)
Executing: nfRF_mul_HV = geomOutside(geomOverlap(rx geomOverlap(nfet_mul_HV RF)) psp_model)
Executing: nfRF_dev_TG = geomOverlap(rx geomOverlap(nfet_dev_TG RF))
Executing: nfRF_mul_TG = geomOverlap(rx geomOverlap(nfet_mul_TG RF))
Executing: nfet_dev_psp_b = geomOverlap(geomOutside(nfet_dev_b RF) psp_model)
Executing: nfet_dev_psp = geomOverlap(geomOutside(nfet_dev RF) psp_model)
Executing: nfet_mul_psp = geomOverlap(geomOutside(nfet_mul RF) psp_model)
Executing: nfet_dev_psp_MV = geomOverlap(geomOutside(nfet_dev_MV RF) psp_model)
Executing: nfet_mul_psp_MV = geomOverlap(geomOutside(nfet_mul_MV RF) psp_model)
Executing: nfet_dev_psp_HV = geomOverlap(geomOutside(nfet_dev_HV RF) psp_model)
Executing: nfet_mul_psp_HV = geomOverlap(geomOutside(nfet_mul_HV RF) psp_model)
Executing: nfet_dev_b = geomOutside(geomOutside(nfet_dev_b RF) psp_model)
Executing: nfet_dev = geomOutside(geomOutside(nfet_dev RF) psp_model)
Executing: nfet_mul = geomOutside(geomOutside(nfet_mul RF) psp_model)
Executing: nfet_dev_MV = geomOutside(geomOutside(nfet_dev_MV RF) psp_model)
Executing: nfet_mul_MV = geomOutside(geomOutside(nfet_mul_MV RF) psp_model)
Executing: nfet_dev_HV = geomOutside(geomOutside(nfet_dev_HV RF) psp_model)
Executing: nfet_mul_HV = geomOutside(geomOutside(nfet_mul_HV RF) psp_model)
Executing: nfet_dev_HVT = nfet_dev_HVT = nfet_dev_HVT = geomOutside(nfet_dev_HVT RF)
Executing: nfet_dev_HVT_b = nfet_dev_HVT_b = nfet_dev_HVT_b = geomOutside(nfet_dev_HVT_b...
Executing: nfet_mul_TG = geomOutside(nfet_mul_TG RF)
Executing: nfet_dev_TG = geomOutside(nfet_dev_TG RF)
Executing: nfet_mul_HVT = geomOutside(nfet_mul_HVT RF)
Executing: nfeti_bottom_iso = geomSize(pi 1.0)
Executing: pwell_base = geomAndNot(pi geomOr(nw geomOr(DIPI_diode PSBD)))
Executing: pwell_ndpi = geomOverlap(pwell_base ESD_ndsx_pi)
Executing: pwell = geomAndNot(pwell_base pwell_ndpi)
Executing: pwell_diff = geomAnd(pwell geomOr(ESD_ndsx_plus geomAnd(rx bp)))
Executing: nfettw_all = geomOverlap(nfet_gate six_term)
Executing: nfeti_dev_psp = nfeti_dev_psp = nfeti_dev_psp = geomOverlap(nfet_dev_psp six_...
Executing: nfet6_dev_psp = nfet6_dev_psp = nfet6_dev_psp = geomEmpty()
Executing: nfeti_mul_psp = geomOverlap(nfet_mul_psp six_term)
Executing: nfet6_mul_psp = geomEmpty()
Executing: nfeti_dev_psp_MV = nfeti_dev_psp_MV = nfeti_dev_psp_MV = geomOverlap(nfet_dev...
Executing: nfet6_dev_psp_MV = nfet6_dev_psp_MV = nfet6_dev_psp_MV = geomEmpty()
Executing: nfeti_mul_psp_MV = geomOverlap(nfet_mul_psp_MV six_term)
Executing: nfet6_mul_psp_MV = geomEmpty()
Executing: nfeti_dev_psp_HV = nfeti_dev_psp_HV = nfeti_dev_psp_HV = geomOverlap(nfet_dev...
Executing: nfet6_dev_psp_HV = nfet6_dev_psp_HV = nfet6_dev_psp_HV = geomEmpty()
Executing: nfeti_mul_psp_HV = geomOverlap(nfet_mul_psp_HV six_term)
Executing: nfet6_mul_psp_HV = geomEmpty()
Executing: nfeti_dev_psp_b = nfeti_dev_psp_b = nfeti_dev_psp_b = geomOverlap(nfet_dev_ps...
Executing: nfet6_dev_psp_b = nfet6_dev_psp_b = nfet6_dev_psp_b = geomEmpty()
Executing: nfeti_dev = nfeti_dev = nfeti_dev = geomOverlap(nfet_dev six_term)
Executing: nfet6_dev = nfet6_dev = nfet6_dev = geomEmpty()
Executing: nfeti_mul = geomOverlap(nfet_mul six_term)
Executing: nfet6_mul = geomEmpty()
Executing: nfeti_dev_MV = nfeti_dev_MV = nfeti_dev_MV = geomOverlap(nfet_dev_MV six_term)
Executing: nfet6_dev_MV = nfet6_dev_MV = nfet6_dev_MV = geomEmpty()
Executing: nfeti_mul_MV = geomOverlap(nfet_mul_MV six_term)
Executing: nfet6_mul_MV = geomEmpty()
Executing: nfeti_dev_HV = nfeti_dev_HV = nfeti_dev_HV = geomOverlap(nfet_dev_HV six_term)
Executing: nfet6_dev_HV = nfet6_dev_HV = nfet6_dev_HV = geomEmpty()
Executing: nfeti_mul_HV = geomOverlap(nfet_mul_HV six_term)
Executing: nfet6_mul_HV = geomEmpty()
Executing: nfeti_dev_TG = nfeti_dev_TG = nfeti_dev_TG = geomOverlap(nfet_dev_TG six_term)
Executing: nfet6_dev_TG = nfet6_dev_TG = nfet6_dev_TG = geomEmpty()
Executing: nfeti_mul_TG = geomOverlap(nfet_mul_TG six_term)
Executing: nfet6_mul_TG = geomEmpty()
Executing: nfeti_dev_b = nfeti_dev_b = nfeti_dev_b = geomOverlap(nfet_dev_b six_term)
Executing: nfet6_dev_b = nfet6_dev_b = nfet6_dev_b = geomEmpty()
Executing: nfRFi_dev_psp = geomOverlap(nfRF_dev_psp six_term)
Executing: nfRF6_dev_psp = geomEmpty()
Executing: nfRFi_mul_psp = geomOverlap(nfRF_mul_psp six_term)
Executing: nfRF6_mul_psp = geomEmpty()
Executing: nfRFi_dev_psp_MV = geomOverlap(nfRF_dev_psp_MV six_term)
Executing: nfRF6_dev_psp_MV = geomEmpty()
Executing: nfRFi_mul_psp_MV = geomOverlap(nfRF_mul_psp_MV six_term)
Executing: nfRF6_mul_psp_MV = geomEmpty()
Executing: nfRFi_dev_psp_HV = geomOverlap(nfRF_dev_psp_HV six_term)
Executing: nfRF6_dev_psp_HV = geomEmpty()
Executing: nfRFi_mul_psp_HV = geomOverlap(nfRF_mul_psp_HV six_term)
Executing: nfRF6_mul_psp_HV = geomEmpty()
Executing: nfRFi_dev = geomOverlap(nfRF_dev six_term)
Executing: nfRF6_dev = geomEmpty()
Executing: nfRFi_mul = geomOverlap(nfRF_mul six_term)
Executing: nfRF6_mul = geomEmpty()
Executing: nfRFi_dev_MV = geomOverlap(nfRF_dev_MV six_term)
Executing: nfRF6_dev_MV = geomEmpty()
Executing: nfRFi_mul_MV = geomOverlap(nfRF_mul_MV six_term)
Executing: nfRF6_mul_MV = geomEmpty()
Executing: nfRFi_dev_HV = geomOverlap(nfRF_dev_HV six_term)
Executing: nfRF6_dev_HV = geomEmpty()
Executing: nfRFi_mul_HV = geomOverlap(nfRF_mul_HV six_term)
Executing: nfRF6_mul_HV = geomEmpty()
Executing: nfRFi_dev_TG = geomOverlap(nfRF_dev_TG six_term)
Executing: nfRF6_dev_TG = geomEmpty()
Executing: nfRFi_mul_TG = geomOverlap(nfRF_mul_TG six_term)
Executing: nfRF6_mul_TG = geomEmpty()
Executing: nfet_dev_psp_b = geomOutside(nfet_dev_psp_b geomOr(nfet6_dev_psp_b nfeti_dev_...
Executing: nfet_dev_b = geomOutside(nfet_dev_b geomOr(nfet6_dev_b nfeti_dev_b))
Executing: nfet_dev_psp = geomOutside(nfet_dev_psp geomOr(nfet6_dev_psp nfeti_dev_psp))
Executing: nfet_mul_psp = geomOutside(nfet_mul_psp geomOr(nfet6_mul_psp nfeti_mul_psp))
Executing: nfet_dev_psp_MV = geomOutside(nfet_dev_psp_MV geomOr(nfet6_dev_psp_MV nfeti_d...
Executing: nfet_mul_psp_MV = geomOutside(nfet_mul_psp_MV geomOr(nfet6_mul_psp_MV nfeti_m...
Executing: nfet_dev_psp_HV = geomOutside(nfet_dev_psp_HV geomOr(nfet6_dev_psp_HV nfeti_d...
Executing: nfet_mul_psp_HV = geomOutside(nfet_mul_psp_HV geomOr(nfet6_mul_psp_HV nfeti_m...
Executing: nfet_dev = geomOutside(nfet_dev geomOr(nfet6_dev nfeti_dev))
Executing: nfet_mul = geomOutside(nfet_mul geomOr(nfet6_mul nfeti_mul))
Executing: nfet_dev_MV = geomOutside(nfet_dev_MV geomOr(nfet6_dev_MV nfeti_dev_MV))
Executing: nfet_mul_MV = geomOutside(nfet_mul_MV geomOr(nfet6_mul_MV nfeti_mul_MV))
Executing: nfet_dev_HV = geomOutside(nfet_dev_HV geomOr(nfet6_dev_HV nfeti_dev_HV))
Executing: nfet_mul_HV = geomOutside(nfet_mul_HV geomOr(nfet6_mul_HV nfeti_mul_HV))
Executing: nfet_dev_TG = geomOutside(nfet_dev_TG geomOr(nfet6_dev_TG nfeti_dev_TG))
Executing: nfet_mul_TG = geomOutside(nfet_mul_TG geomOr(nfet6_mul_TG nfeti_mul_TG))
Executing: nfRF_dev_psp = geomOutside(nfRF_dev_psp geomOr(nfRF6_dev_psp nfRFi_dev_psp))
Executing: nfRF_mul_psp = geomOutside(nfRF_mul_psp geomOr(nfRF6_mul_psp nfRFi_mul_psp))
Executing: nfRF_dev_psp_MV = geomOutside(nfRF_dev_psp_MV geomOr(nfRF6_dev_psp_MV nfRFi_d...
Executing: nfRF_mul_psp_MV = geomOutside(nfRF_mul_psp_MV geomOr(nfRF6_mul_psp_MV nfRFi_m...
Executing: nfRF_dev_psp_HV = geomOutside(nfRF_dev_psp_HV geomOr(nfRF6_dev_psp_HV nfRFi_d...
Executing: nfRF_mul_psp_HV = geomOutside(nfRF_mul_psp_HV geomOr(nfRF6_mul_psp_HV nfRFi_m...
Executing: nfRF_dev = geomOutside(nfRF_dev geomOr(nfRF6_dev nfRFi_dev))
Executing: nfRF_mul = geomOutside(nfRF_mul geomOr(nfRF6_mul nfRFi_mul))
Executing: nfRF_dev_MV = geomOutside(nfRF_dev_MV geomOr(nfRF6_dev_MV nfRFi_dev_MV))
Executing: nfRF_mul_MV = geomOutside(nfRF_mul_MV geomOr(nfRF6_mul_MV nfRFi_mul_MV))
Executing: nfRF_dev_HV = geomOutside(nfRF_dev_HV geomOr(nfRF6_dev_HV nfRFi_dev_HV))
Executing: nfRF_mul_HV = geomOutside(nfRF_mul_HV geomOr(nfRF6_mul_HV nfRFi_mul_HV))
Executing: nfRF_dev_TG = geomOutside(nfRF_dev_TG geomOr(nfRF6_dev_TG nfRFi_dev_TG))
Executing: nfRF_mul_TG = geomOutside(nfRF_mul_TG geomOr(nfRF6_mul_TG nfRFi_mul_TG))
Executing: nfet_dpw_b = nfet_dpw_b = nfet_dpw_b = geomOverlap(nfet_dev_b pi)
Executing: nfet_dev_b = nfet_dev_b = nfet_dev_b = geomOutside(nfet_dev_b pi)
Executing: nfet_dpw_psp_b = nfet_dpw_psp_b = nfet_dpw_psp_b = geomOverlap(nfet_dev_psp_b...
Executing: nfet_dev_psp_b = nfet_dev_psp_b = nfet_dev_psp_b = geomOutside(nfet_dev_psp_b...
Executing: nfet_dpw = nfet_dpw = nfet_dpw = geomOverlap(nfet_dev pi)
Executing: nfet_dev = nfet_dev = nfet_dev = geomOutside(nfet_dev pi)
Executing: nfet_dpw_psp = nfet_dpw_psp = nfet_dpw_psp = geomOverlap(nfet_dev_psp pi)
Executing: nfet_dev_psp = nfet_dev_psp = nfet_dev_psp = geomOutside(nfet_dev_psp pi)
Executing: nfet_dpw_MV = nfet_dpw_MV = nfet_dpw_MV = geomOverlap(nfet_dev_MV pi)
Executing: nfet_dev_MV = nfet_dev_MV = nfet_dev_MV = geomOutside(nfet_dev_MV pi)
Executing: nfet_dpw_psp_MV = nfet_dpw_psp_MV = nfet_dpw_psp_MV = geomOverlap(nfet_dev_ps...
Executing: nfet_dev_psp_MV = nfet_dev_psp_MV = nfet_dev_psp_MV = geomOutside(nfet_dev_ps...
Executing: nfet_dpw_HV = nfet_dpw_HV = nfet_dpw_HV = geomOverlap(nfet_dev_HV pi)
Executing: nfet_dev_HV = nfet_dev_HV = nfet_dev_HV = geomOutside(nfet_dev_HV pi)
Executing: nfet_dpw_psp_HV = nfet_dpw_psp_HV = nfet_dpw_psp_HV = geomOverlap(nfet_dev_ps...
Executing: nfet_dev_psp_HV = nfet_dev_psp_HV = nfet_dev_psp_HV = geomOutside(nfet_dev_ps...
Executing: nfet_dpw_TG = nfet_dpw_TG = nfet_dpw_TG = geomOverlap(nfet_dev_TG pi)
Executing: nfet_dev_TG = nfet_dev_TG = nfet_dev_TG = geomOutside(nfet_dev_TG pi)
Executing: dual_poly_err = geomAnd(geomOutside(geomAndNot(geomStraddle(pc geomInside(geo...
errorLayer(dual_poly_err "Dual gate poly device without M1/CA connection")
Executing: dual_poly = geomInside(geomAnd(rx_input pc) dual_poly)
Executing: nfRF_drain = geomOverlap(geomAnd(nfet_sd RF) drain_filter)
Executing: nfRF_source = geomOutside(geomAnd(nfet_sd RF) drain_filter)
Executing: nfet_sd = geomOutside(nfet_sd RF)
Executing: RF_BULK = geomOverlap(RF nfet_gate)
Executing: ndiff = geomAndNot(ndiff pc)
Executing: res6n_bar = geomStraddle(ndiff geomOr(op sblk))
Executing: res6n_term = geomAndNot(res6n_bar geomOr(op sblk nfet_sd))
Executing: res6n_dev = geomAnd(res6n_bar op)
Executing: res6n_sblk = geomAnd(res6n_bar sblk)
Executing: res6n_err = geomAnd(geomOr(res6n_dev res6n_sblk) geomOr(ns nw nr pr))
errorLayer(res6n_err "N+ Diffused Resistor device touching ns,nw,nr,pr")
Executing: ndiff_dc_fet = geomOr(nfet_sd)
Executing: ndiff = geomAndNot(ndiff ndiff_dc_fet)
Executing: nfet_sd = geomOr(nfet_sd geomAnd(res6n_term geomOverlap(res6n_bar res6n_sblk)))
Executing: res6n_term = geomAndNot(res6n_term geomAnd(res6n_term geomOverlap(res6n_bar r...
Executing: ndiff = geomAndNot(ndiff res6n_bar)
Executing: ndiff_tie = geomAvoiding(geomAndNot(ndiff geomOr(nw ncap_nw mosvar_nw)) nfet_...
Executing: ntie_device = geomOverlap(ndiff_tie diode)
Executing: ntie_top = geomOr(ntie_device)
Executing: ndiff_tie = geomOutside(ndiff_tie ntie_device)
Executing: nwell_diff = geomAnd(ndiff nw)
Executing: nstap = geomAnd(geomAnd(geomAndNot(rx bp) rn) ns)
Executing: pdiff = geomAndNot(geomAnd(rx bp) geomOr(rn))
Executing: pfet_gate = geomOutside(geomAnd(geomAnd(pc pdiff) nw) di)
Executing: pfet_dev_polygon = geomGetPolygon(pfet_gate)
Executing: pfet_dev_b = geomOutside(geomOr(pfet_dev_polygon) pr)
Executing: pfet_dev = geomAndNot(geomAndNot(pfet_gate pfet_dev_b) geomOr(dg dgv tg pr sc...
Executing: pfet_dev_TG = geomAndNot(geomAnd(geomAndNot(pfet_gate pfet_dev_b) tg) geomOr(...
Executing: pfet_dev_SCG = geomAndNot(geomAnd(geomAnd(geomAndNot(pfet_gate pfet_dev_b) tg...
Executing: pfet_dev_MV = geomAndNot(geomAnd(geomAnd(geomAndNot(pfet_gate pfet_dev_b) dg)...
Executing: pfet_dev_HV = geomAndNot(geomAnd(geomAndNot(pfet_gate pfet_dev_b) dg) geomOr(...
Executing: pfet_dev_HVT = geomAndNot(geomAnd(geomAndNot(pfet_gate pfet_dev_polygon) pr) ...
Executing: pfet_dev_HVT_b = geomAndNot(geomAnd(pfet_dev_polygon pr) geomOr(dg dgv scgate))
Executing: pfet_sd = geomButting(geomAndNot(geomAnd(pdiff nw) geomOr(pc op sblk)) pfet_g...
Executing: pfet_fingers = geomInside(pfet_dev multi)
Executing: pfet_fingers_TG = geomInside(pfet_dev_TG multi)
Executing: pfet_fingers_SCG = geomInside(pfet_dev_SCG multi)
Executing: pfet_fingers_MV = geomInside(pfet_dev_MV multi)
Executing: pfet_fingers_HV = geomInside(pfet_dev_HV multi)
Executing: pfet_fingers_HVT = geomInside(pfet_dev_HVT multi)
Executing: pfet_mul = geomStraddle(rx pfet_fingers)
Executing: pfet_mul_TG = geomStraddle(rx pfet_fingers_TG)
Executing: pfet_mul_SCG = geomStraddle(rx pfet_fingers_SCG)
Executing: pfet_mul_MV = geomStraddle(rx pfet_fingers_MV)
Executing: pfet_mul_HV = geomStraddle(rx pfet_fingers_HV)
Executing: pfet_mul_HVT = geomStraddle(rx pfet_fingers_HVT)
Executing: pfet_dev = geomOutside(pfet_dev multi)
Executing: pfet_dev_TG = geomOutside(pfet_dev_TG multi)
Executing: pfet_dev_SCG = geomOutside(pfet_dev_SCG multi)
Executing: pfet_dev_MV = geomOutside(pfet_dev_MV multi)
Executing: pfet_dev_HV = geomOutside(pfet_dev_HV multi)
Executing: pfet_dev_HVT = geomOutside(pfet_dev_HVT multi)
Executing: pfRF_dev_psp = geomOverlap(geomOverlap(rx geomOverlap(pfet_dev RF)) psp_model)
Executing: pfRF_mul_psp = geomOverlap(geomOverlap(rx geomOverlap(pfet_mul RF)) psp_model)
Executing: pfRF_dev_psp_MV = geomOverlap(geomOverlap(rx geomOverlap(pfet_dev_MV RF)) psp...
Executing: pfRF_mul_psp_MV = geomOverlap(geomOverlap(rx geomOverlap(pfet_mul_MV RF)) psp...
Executing: pfRF_dev_psp_HV = geomOverlap(geomOverlap(rx geomOverlap(pfet_dev_HV RF)) psp...
Executing: pfRF_mul_psp_HV = geomOverlap(geomOverlap(rx geomOverlap(pfet_mul_HV RF)) psp...
Executing: pfRF_dev = geomOutside(geomOverlap(rx geomOverlap(pfet_dev RF)) psp_model)
Executing: pfRF_mul = geomOutside(geomOverlap(rx geomOverlap(pfet_mul RF)) psp_model)
Executing: pfRF_dev_MV = geomOutside(geomOverlap(rx geomOverlap(pfet_dev_MV RF)) psp_model)
Executing: pfRF_mul_MV = geomOutside(geomOverlap(rx geomOverlap(pfet_mul_MV RF)) psp_model)
Executing: pfRF_dev_HV = geomOutside(geomOverlap(rx geomOverlap(pfet_dev_HV RF)) psp_model)
Executing: pfRF_mul_HV = geomOutside(geomOverlap(rx geomOverlap(pfet_mul_HV RF)) psp_model)
Executing: pfRF_dev_TG = geomOverlap(rx geomOverlap(pfet_dev_TG RF))
Executing: pfRF_mul_TG = geomOverlap(rx geomOverlap(pfet_mul_TG RF))
Executing: pfRF_dev_SCG = geomOverlap(rx geomOverlap(pfet_dev_SCG RF))
Executing: pfRF_mul_SCG = geomOverlap(rx geomOverlap(pfet_mul_SCG RF))
Executing: pfet_dev_psp_b = pfet_dev_psp_b = pfet_dev_psp_b = geomOverlap(pfet_dev_b psp...
Executing: pfet_dev_b = pfet_dev_b = pfet_dev_b = geomOutside(pfet_dev_b psp_model)
Executing: pfet_dev_psp = pfet_dev_psp = pfet_dev_psp = geomOverlap(geomOutside(pfet_dev...
Executing: pfet_mul_psp = geomOverlap(geomOutside(pfet_mul RF) psp_model)
Executing: pfet_dev_psp_MV = pfet_dev_psp_MV = pfet_dev_psp_MV = geomOverlap(geomOutside...
Executing: pfet_mul_psp_MV = geomOverlap(geomOutside(pfet_mul_MV RF) psp_model)
Executing: pfet_dev_psp_HV = pfet_dev_psp_HV = pfet_dev_psp_HV = geomOverlap(geomOutside...
Executing: pfet_mul_psp_HV = geomOverlap(geomOutside(pfet_mul_HV RF) psp_model)
Executing: pfet_dev = pfet_dev = pfet_dev = geomOutside(geomOutside(pfet_dev RF) psp_model)
Executing: pfet_mul = geomOutside(geomOutside(pfet_mul RF) psp_model)
Executing: pfet_dev_MV = pfet_dev_MV = pfet_dev_MV = geomOutside(geomOutside(pfet_dev_MV...
Executing: pfet_mul_MV = geomOutside(geomOutside(pfet_mul_MV RF) psp_model)
Executing: pfet_dev_HV = pfet_dev_HV = pfet_dev_HV = geomOutside(geomOutside(pfet_dev_HV...
Executing: pfet_mul_HV = geomOutside(geomOutside(pfet_mul_HV RF) psp_model)
Executing: pfet_dev_HVT = pfet_dev_HVT = pfet_dev_HVT = geomOutside(pfet_dev_HVT RF)
Executing: pfet_dev_HVT_b = pfet_dev_HVT_b = pfet_dev_HVT_b = geomOutside(pfet_dev_HVT_b...
Executing: pfet_mul_HVT = geomOutside(pfet_mul_HVT RF)
Executing: pfet_dev_TG = pfet_dev_TG = pfet_dev_TG = geomOutside(pfet_dev_TG RF)
Executing: pfet_mul_TG = geomOutside(pfet_mul_TG RF)
Executing: pfet_dev_SCG = pfet_dev_SCG = pfet_dev_SCG = geomOutside(pfet_dev_SCG RF)
Executing: pfet_mul_SCG = geomOutside(pfet_mul_SCG RF)
Executing: pfRF_drain = geomOverlap(geomAnd(pfet_sd RF) drain_filter)
Executing: pfRF_source = geomOutside(geomAnd(pfet_sd RF) drain_filter)
Executing: pfet_sd = geomOutside(pfet_sd RF)
Executing: FET_DEV = geomOr(nfet_gate pfet_gate)
Executing: FET_err = geomAnd(FET_DEV geomOr(ns jd rn bb rr rp pd op))
errorLayer(FET_err "FET device touching ns,jd,rn,bb,rr,rp,pd,op")
Executing: pdiff = geomAndNot(pdiff pc)
Executing: res6p_bar = geomStraddle(pdiff geomOr(op sblk))
Executing: res6p_term = geomAndNot(res6p_bar geomOr(op sblk pfet_sd))
Executing: res6p_dev = geomAnd(res6p_bar op)
Executing: res6p_sblk = geomAnd(res6p_bar sblk)
Executing: pdiff = geomAndNot(pdiff res6p_bar)
Executing: diff_RES_dev = geomOr(res6n_dev res6p_dev res6n_sblk res6p_sblk)
Executing: diff_RES_err = geomOutside(geomAnd(diff_RES_dev geomOr(bb dg pc)) ESD_ALL)
errorLayer(diff_RES_err "Diffused Resistor device touching bb,dg,pc")
Executing: diff_RES_err2 = geomOutside(geomAnd(diff_RES_dev geomOr(ns jd rn pd rr rp nr ...
errorLayer(diff_RES_err2 "Diffused Resistor device touching ns,jd,rn,pd,rr,rp,nr,pr")
Executing: pdiff_dc_fet = geomOr(pfet_sd)
Executing: pdiff = geomAndNot(pdiff pdiff_dc_fet)
Executing: pfet_sd = geomOr(pfet_sd geomAnd(res6p_term geomOverlap(res6p_bar res6p_sblk)))
Executing: res6p_term = geomAndNot(res6p_term geomAnd(res6p_term geomOverlap(res6p_bar r...
Executing: nfetnsh_rev = geomGetTexted(ESD_ALL DEVICE_ID_TXT "ESDNSH_BASE-DEVICE")
Executing: esdnsh_nfet = geomOr(nfet6_dev nfet6_dev_MV nfet6_dev_HV nfet6_dev_TG nfeti_d...
Executing: esdnsh_dev = geomOverlap(geomOr(esdnsh_nfet geomButtOnly(nfet_sd nfet_gate) r...
Executing: esdnsh_gate = geomOverlap(nfet_gate esdnsh_dev)
Executing: esdnsh_drain = geomButtOnly(geomOverlap(nfet_sd drain_filter) esdnsh_gate)
Executing: esdnsh_source = geomButtOnly(geomOutside(nfet_sd drain_filter) esdnsh_gate)
Executing: pfetpsh_rev = geomGetTexted(ESD_ALL DEVICE_ID_TXT "ESDPSH_BASE-DEVICE")
Executing: esdpsh_pfet = geomOr(pfet_dev pfet_dev_MV pfet_dev_HV pfet_dev_TG)
Executing: esdpsh_dev = geomOverlap(geomOr(esdpsh_pfet geomButtOnly(pfet_sd pfet_gate) r...
Executing: esdpsh_gate = geomOverlap(pfet_gate esdpsh_dev)
Executing: esdpsh_drain = geomButtOnly(geomOverlap(pfet_sd drain_filter) esdpsh_gate)
Executing: esdpsh_source = geomButtOnly(geomOutside(pfet_sd drain_filter) esdpsh_gate)
Executing: esdnpsh_gate = geomOr(esdnsh_gate esdpsh_gate)
Executing: esdnpsh_drain = geomOr(esdnsh_drain esdpsh_drain)
Executing: esdnpsh_source = geomOr(esdnsh_source esdpsh_source)
Executing: esdnpsh_base = geomOr(esdnsh_dev esdpsh_dev)
Executing: esdnpsh_base50 = geomAnd(esdnpsh_base tg)
Executing: esdnpsh_base25 = geomAnd(geomAnd(esdnpsh_base dg) dgv)
Executing: esdnpsh_base33 = geomAndNot(geomAnd(esdnpsh_base dg) dgv)
Executing: esdnpsh_base = geomAndNot(esdnpsh_base geomOr(esdnpsh_base50 esdnpsh_base33 e...
Executing: ind_bb_term = geomOutside(geomOverlap(geomOr(tline ind symIND0) bb) m1)
Executing: bond_bb_term = geomOverlap(bondPadFilter bb)
Executing: ind_hr_term = geomOverlap(geomOr(tline ind symIND0) hr_gnd)
Executing: bond_hr_term = geomOverlap(bondPadFilter hr_gnd)
Executing: res6pc_bar = geomStraddle(pc op)
Executing: res6pc_term = geomAndNot(res6pc_bar op)
Executing: res6pc_dev = geomAnd(res6pc_bar op)
Executing: resistor_m = geomOverlap(geomOr(res6pc_dev res6n_dev res6p_dev) multi)
Executing: resistor_bb = geomOverlap(res6pc_dev bb)
Executing: resistor_op = geomOverlap(res6pc_dev op)
Executing: pc = geomAndNot(pc res6pc_bar)
Executing: poly_RES_err = geomAnd(res6pc_bar geomOr(ns jd rx rx_fill rn tg))
errorLayer(poly_RES_err "Polysilicon Resistor device touching ns,jd,rx,rn,tg")
Executing: poly_bp_err = geomAndNot(res6pc_dev geomOr(geomAndNot(bp bb) geomAnd(geomOr(r...
errorLayer(poly_bp_err "Polysilicon Resistor device not covered by P+ implant")
Executing: res6pc_err = geomAnd(res6pc_dev geomAnd(bb geomOr(pi nw nr pr)))
errorLayer(res6pc_err "Polysilicon Resistor device BB touching pi,nw,nr,pr")
Executing: res6pc_err2 = geomAnd(res6pc_dev geomAnd(geomOr(rr rp) geomOr(nr pr)))
errorLayer(res6pc_err2 "Polysilicon Resistor device RR or RP touching nr,pr")
Executing: rnw6pc_dev = geomOverlap(res6pc_dev nw)
Executing: res6pc_dev = geomOutside(res6pc_dev nw)
Executing: res_serp_one_pc = geomEnclose(geomAnd(rr res_hv) res6pc_dev (1 < ignore))
Executing: res_serpentine = geomOverlap(res6pc_dev res_serp_one_pc)
Executing: res6pc_corner = geomGetCorner(res6pc_dev angleMulti90 concave)
Executing: res6pc_growcorner = geomGrowCorner(res6pc_corner 0.05 inside)
Executing: res6pc_reshv = geomOverlap(res6pc_dev res6pc_growcorner)
Executing: res6pc_dev = geomOutside(res6pc_dev geomOr(res6pc_reshv geomAnd(rr res_hv)))
Executing: res6rr_dev = geomOverlap(res6pc_dev rr)
Executing: res6rp_dev = geomOverlap(res6pc_dev rp)
Executing: res6pc_dev = geomOutside(res6pc_dev geomOr(rr rp))
Executing: resnw_serpentine = geomOverlap(rnw6pc_dev geomAnd(rr res_hv))
Executing: rnw6pc_dev = geomOutside(rnw6pc_dev resnw_serpentine)
Executing: rnw6rr_dev = geomOverlap(rnw6pc_dev rr)
Executing: rnw6rp_dev = geomOverlap(rnw6pc_dev rp)
Executing: rnw6pc_dev = geomOutside(rnw6pc_dev geomOr(rr rp))
Executing: resbb_serpentine = geomAnd(res_serpentine bb)
Executing: ressub_serpentine = geomAndNot(res_serpentine resbb_serpentine)
Executing: pdiff_tie = geomAvoiding(geomAnd(pdiff nw) pfet_gate)
Executing: ptie_device = geomOverlap(pdiff_tie diode)
Executing: ptie_top = geomOr(ptie_device)
Executing: pdiff_tie = geomOutside(pdiff_tie ptie_device)
Executing: ca = geomAnd(ca geomAnd(m1 geomOr(pc_input rx_input)))
Executing: sub_diff_top1 = geomOutside(geomOverlap(geomAndNot(pdiff geomOr(ncap_nw nw DI...
Executing: sub_diff_exclude = geomOr(RF NOSUBC)
Executing: sub_diff = geomAndNot(sub_diff_top1 sub_diff_exclude)
Executing: SXCUT_pi = geomInside(SXCUT nfeti_bottom_iso)
Executing: SXCUT = geomAndNot(SXCUT SXCUT_pi)
Executing: sub_diff_grlogic = geomEmpty()
Executing: sub_dev = geomOr(sub_diff)
Executing: sub_diff = geomOutside(sub_diff sub_dev)
Executing: sub_diff_top = geomOr(sub_dev)
Executing: sub_diff_grlogic = geomAnd(sub_diff_grlogic GRLOGIC)
Executing: substrate = geomOr(geomAndNot(bkgnd geomSize(SXCUT 0.002)) SXCUT)
Executing: sub50 = geomXor(geomEmpty() LAYER)
Executing: sub1K = geomEmpty()
Executing: substrate_ptap = geomOverlap(substrate sub_diff)
Executing: substrate_text = geomOutside(substrate sub_diff)
Executing: subvia = geomOr(subterm)
Executing: sub_m1 = geomOverlap(m1 sub_diff_top)
Executing: dummy_via = geomAnd(sub_m1 IND_AC_WIRE)
Executing: ind_ac_via = geomAnd(geomOr(ind_bb_term ind_hr_term bond_bb_term bond_hr_term...
Executing: subs_sti = geomOr(substrate)
Executing: GateCon = geomOr(Gate)
Executing: corrPoint_dev_PD = geomAnd(corrPoint geomOr(pfet_sd pfRF_source pfRF_drain))
Executing: corrPoint_term_PD = geomOr(corrPoint_dev_PD)
Executing: corrPoint = geomAndNot(corrPoint corrPoint_dev_PD)
Executing: corrPoint_dev_ND = geomAnd(corrPoint geomOr(nfet_sd nfRF_source nfRF_drain))
Executing: corrPoint_term_ND = geomOr(corrPoint_dev_ND)
Executing: corrPoint = geomAndNot(corrPoint corrPoint_dev_ND)
Executing: corrPoint_dev_PC = geomAnd(corrPoint pc)
Executing: corrPoint_term_PC = geomAnd(corrPoint pc)
Executing: corrPoint = geomAndNot(corrPoint corrPoint_dev_PC)
Executing: corrPoint_dev_M1 = geomAnd(corrPoint m1)
Executing: corrPoint_term_M1 = geomAnd(corrPoint m1)
Executing: corrPoint = geomAndNot(corrPoint corrPoint_dev_M1)
Executing: corrPoint_dev_M2 = geomAnd(corrPoint m2)
Executing: corrPoint_term_M2 = geomAnd(corrPoint m2)
Executing: errorLayer(geomAndNot(am_RES am) "(AM res) not covered by mask AM")
Executing: errorLayer(geomAndNot(mt_RES mt) "(MT res) not covered by mask MT")
Executing: errorLayer(geomAndNot(m4_RES m4) "(M4 res) not covered by mask M4")
Executing: errorLayer(geomAndNot(m3_RES m3) "(M3 res) not covered by mask M3")
Executing: errorLayer(geomAndNot(m2_RES m2) "(M2 res) not covered by mask M2")
Executing: errorLayer(geomAndNot(m1_RES m1) "(M1 res) not covered by mask M1")
Executing: Edges_m1_RES = geomGetEdge(m1_RES inside m1)
Executing: Edges_inside_m1_RES = geomSize(Edges_m1_RES -0.004)
Executing: Edges_outside_m1_RES = geomSize(Edges_m1_RES 0.004)
Executing: Edges_m1_RES_Size = geomOr(Edges_inside_m1_RES Edges_outside_m1_RES)
Executing: m1_RES_grow = geomGrow(m1_RES 0 0 0.004 0.004)
Executing: m1_RES_reduced = geomAnd(Edges_m1_RES_Size m1_RES_grow)
Executing: m1_RES_min = geomInside(m1_RES_reduced m1_RES)
Executing: m1 = geomAndNot(m1 m1_RES_min)
Executing: rcxLayer(m1_RES_min)
Executing: Edges_m2_RES = geomGetEdge(m2_RES inside m2)
Executing: Edges_inside_m2_RES = geomSize(Edges_m2_RES -0.004)
Executing: Edges_outside_m2_RES = geomSize(Edges_m2_RES 0.004)
Executing: Edges_m2_RES_Size = geomOr(Edges_inside_m2_RES Edges_outside_m2_RES)
Executing: m2_RES_grow = geomGrow(m2_RES 0 0 0.004 0.004)
Executing: m2_RES_reduced = geomAnd(Edges_m2_RES_Size m2_RES_grow)
Executing: m2_RES_min = geomInside(m2_RES_reduced m2_RES)
Executing: m2 = geomAndNot(m2 m2_RES_min)
Executing: rcxLayer(m2_RES_min)
Executing: Edges_m3_RES = geomGetEdge(m3_RES inside m3)
Executing: Edges_inside_m3_RES = geomSize(Edges_m3_RES -0.004)
Executing: Edges_outside_m3_RES = geomSize(Edges_m3_RES 0.004)
Executing: Edges_m3_RES_Size = geomOr(Edges_inside_m3_RES Edges_outside_m3_RES)
Executing: m3_RES_grow = geomGrow(m3_RES 0 0 0.004 0.004)
Executing: m3_RES_reduced = geomAnd(Edges_m3_RES_Size m3_RES_grow)
Executing: m3_RES_min = geomInside(m3_RES_reduced m3_RES)
Executing: m3 = geomAndNot(m3 m3_RES_min)
Executing: rcxLayer(m3_RES_min)
Executing: Edges_m4_RES = geomGetEdge(m4_RES inside m4)
Executing: Edges_inside_m4_RES = geomSize(Edges_m4_RES -0.004)
Executing: Edges_outside_m4_RES = geomSize(Edges_m4_RES 0.004)
Executing: Edges_m4_RES_Size = geomOr(Edges_inside_m4_RES Edges_outside_m4_RES)
Executing: m4_RES_grow = geomGrow(m4_RES 0 0 0.004 0.004)
Executing: m4_RES_reduced = geomAnd(Edges_m4_RES_Size m4_RES_grow)
Executing: m4_RES_min = geomInside(m4_RES_reduced m4_RES)
Executing: m4 = geomAndNot(m4 m4_RES_min)
Executing: rcxLayer(m4_RES_min)
Executing: Edges_mt_RES = geomGetEdge(mt_RES inside mt)
Executing: Edges_inside_mt_RES = geomSize(Edges_mt_RES -0.004)
Executing: Edges_outside_mt_RES = geomSize(Edges_mt_RES 0.004)
Executing: Edges_mt_RES_Size = geomOr(Edges_inside_mt_RES Edges_outside_mt_RES)
Executing: mt_RES_grow = geomGrow(mt_RES 0 0 0.004 0.004)
Executing: mt_RES_reduced = geomAnd(Edges_mt_RES_Size mt_RES_grow)
Executing: mt_RES_min = geomInside(mt_RES_reduced mt_RES)
Executing: mt = geomAndNot(mt mt_RES_min)
Executing: rcxLayer(mt_RES_min)
Executing: Edges_am_RES = geomGetEdge(am_RES inside am)
Executing: Edges_inside_am_RES = geomSize(Edges_am_RES -0.004)
Executing: Edges_outside_am_RES = geomSize(Edges_am_RES 0.004)
Executing: Edges_am_RES_Size = geomOr(Edges_inside_am_RES Edges_outside_am_RES)
Executing: am_RES_grow = geomGrow(am_RES 0 0 0.004 0.004)
Executing: am_RES_reduced = geomAnd(Edges_am_RES_Size am_RES_grow)
Executing: am_RES_min = geomInside(am_RES_reduced am_RES)
Executing: am = geomAndNot(am am_RES_min)
Executing: rcxLayer(am_RES_min)
Executing: symIND = geomOverlap(ind symIND0)
Executing: ind = geomOutside(ind symIND)
Executing: tline = geomAndNot(tline geomOr(ind symIND))
Executing: am_trans = geomAnd(am tline)
Executing: errorLayer(geomAnd(am_trans amTerm) "Overlapping transmission lines - terminals must abut filters")
Executing: am_trans2 = geomAndNot(am_trans amTerm)
Executing: am_transmission = geomButting(am_trans2 amTerm (keep == 2))
Executing: am = geomAndNot(am am_transmission)
Executing: trans_in_am = geomGetTexted(amTerm am_text "in")
Executing: trans_out_am = geomGetTexted(amTerm am_text "out")
Executing: trans_in_mt = geomGetTexted(mtTerm mt_text "in")
Executing: trans_out_mt = geomGetTexted(mtTerm mt_text "out")
Executing: symind_in_am = geomGetTexted(amTerm am_text_symind "outpr")
Executing: symind_out_am = geomGetTexted(amTerm am_text_symind "outse")
Executing: symind_mid_m2 = geomGetTexted(m2Term m2_text "ct")
Executing: symind_mid_m4 = geomGetTexted(m4Term m4_text "ct")
Executing: symind_in = geomOr(symind_in_am)
Executing: symind_out = geomOr(symind_out_am)
Executing: All_in = geomOr(geomOr(trans_in_am trans_in_mt) symind_in)
Executing: All_out = geomOr(geomOr(trans_out_am trans_out_mt) symind_out)
Executing: symind_ct = geomOr(symind_mid_m2 symind_mid_m4)
Executing: symind_ct1 = geomOr(symind_mid_m2)
Executing: symind_ct2 = geomOr(symind_mid_m4)
Executing: ind_sym = geomOverlap(symIND symind_in)
Executing: dummy_ct = geomOutside(ind_sym symind_ct)
Executing: via_ct = geomOr(dummy_ct)
Executing: symind3 = geomAnd(geomAnd(geomOverlap(ind_sym symind_in (keep == 1)) geomOver...
Executing: symind2 = geomAnd(geomAnd(geomOverlap(ind_sym symind_in (keep == 1)) geomOver...
Executing: allSyminds = geomOr(symind3 symind2)
Executing: inductor2 = geomAnd(geomOverlap(ind All_in (keep == 1)) geomOverlap(ind All_o...
Executing: allInds = geomOr(inductor2 allSyminds)
Executing: ind_err2 = geomAnd(allInds geomOr(ns jd pi rn nw nr pr dg tg pc rr rp pd op))
errorLayer(ind_err2 "inductor device touching ns,jd,pi,rn,nw,nr,pr,dg,tg,pc,rr,rp,pd,op")
Executing: amTRan = geomOverlap(amTerm allInds)
Executing: mtTRan = geomOverlap(mtTerm allInds)
Executing: allInd_Mt = geomAnd(allInds mt)
Executing: am_intern = geomAnd(am allInds)
Executing: am = geomOr(geomAndNot(am allInds) amTRan)
Executing: mt_intern = geomOverlap(geomAnd(mt allInds) mtTRan)
Executing: mt_intern2 = geomOr(geomOverlap(mt_intern_all symind_ct) geomGetNonRectangle(...
Executing: mt_ind = geomInside(mt allInds)
Executing: mt = geomOr(geomOr(geomAndNot(mt allInds) mt_ind) mtTRan)
Executing: ft_ind = geomInside(ft allInds)
Executing: ft_intern = geomAnd(ft allInds)
Executing: ft = geomAndNot(ft allInds)
Executing: allInd_Mt_45 = geomSize(geomGetNon90(allInd_Mt) 0.1)
Executing: mt_BentArea = geomButting(mt allInd_Mt_45)
Executing: mt_XArea = geomOutside(geomAnd(mt_BentArea am_intern) ft_ind)
Executing: m2TRan = geomOverlap(m2Term allInds)
Executing: m4TRan = geomOverlap(m4Term allInds)
Executing: allInd_M3 = geomAnd(allInds m3)
Executing: allInd_M4 = geomAnd(allInds m4)
Executing: m3_ind = geomInside(m3 allInds)
Executing: m3 = geomOr(geomAndNot(m3 allInds) m3_ind)
Executing: m4_ind = geomInside(m4 allInds)
Executing: m4 = geomOr(geomOr(geomAndNot(m4 allInds) m4_ind) m4TRan)
Executing: allInd_M3_45 = geomSize(geomGetNon90(allInd_M3) 0.1)
Executing: allInd_M4_45 = geomSize(geomGetNon90(allInd_M4) 0.1)
Executing: m3_BentArea = geomButting(m3 allInd_M3_45)
Executing: m3_XArea = geomOutside(geomAnd(m3_BentArea am_intern) ft_ind)
Executing: m4_BentArea = geomButting(m4 allInd_M4_45)
Executing: m4_XArea = geomOutside(geomAnd(m4_BentArea am_intern) ft_ind)
Executing: errorLayer(geomAnd(geomOr(geomXor(m3_XArea mt_XArea) geomXor(m4_XArea mt_XArea)) ind_xov) "M3 and M4 inside enhanced Inductor model must have the same dimension as MT")
Executing: errorLayer(geomAndNot(geomOr(geomAnd(m3_XArea mt_XArea) geomAnd(m4_XArea mt_XArea)) ind_xov) "M3/M4 inside standard inductor model is not allowed")
Executing: v2_intern = geomAnd(v2 allInds)
Executing: v2 = geomAndNot(v2 v2_intern)
Executing: m3_intern = geomAnd(m3 allInds)
Executing: v3_intern = geomAnd(v3 allInds)
Executing: v3 = geomAndNot(v3 v3_intern)
Executing: m4_intern = geomAnd(m4 allInds)
Executing: v4_intern = geomAnd(v4 allInds)
Executing: v4 = geomAndNot(v4 v4_intern)
Executing: m3_v3_m4_NotConn_symind = geomOutside(geomOverlap(geomAnd(m3_intern m4_intern...
Executing: m4_v4_mt_NotConn_symind = geomOutside(geomOr(geomGetRectangle(geomAnd(m4_inte...
Executing: mt_ft_am_NotConn_ind = geomOutside(geomAnd(geomAndNot(mt_intern2 mtTerm) am_i...
Executing: mt_ft_am = geomOutside(geomAnd(mt_intern2 am_intern) ft_intern)
Executing: mt_ft_am_NotConn_symind = geomAndNot(mt_ft_am geomOr(geomGetRectangle(mt_ft_a...
Executing: m1_over_ind = geomAnd(m1 geomOr(symind3 symind2 inductor2))
Executing: m1_ind_groundplane = geomGetBBox(geomGetVertex(m1_over_ind (keep > 20)))
Executing: symind3_amam_m1 = geomOutside(geomOutside(geomOverlap(geomOverlap(geomOverlap...
Executing: symind3_amam_bb = geomOutside(geomOutside(geomOverlap(geomOverlap(geomOverlap...
Executing: symind3_amam_hr = geomOverlap(geomOutside(geomOutside(geomOverlap(geomOverlap...
Executing: symind2_amam_m1 = geomOutside(geomOutside(geomOverlap(geomOverlap(geomOverlap...
Executing: symind2_amam_bb = geomOutside(geomOutside(geomOverlap(geomOverlap(geomOverlap...
Executing: symind2_amam_hr = geomOverlap(geomOutside(geomOutside(geomOverlap(geomOverlap...
Executing: ind2_mtam_m1 = geomOutside(geomOutside(geomOverlap(geomOverlap(geomOverlap(in...
Executing: ind2_mtam_bb = geomOutside(geomOutside(geomOverlap(geomOverlap(geomOverlap(in...
Executing: ind2_mtam_hr = geomOverlap(geomOutside(geomOutside(geomOverlap(geomOverlap(in...
Executing: symind3_amam_err_3 = geomAnd(geomOr(symind3_amam_m1 symind3_amam_bb symind3_a...
errorLayer(symind3_amam_err_3 "Missing v3 vias on symind coils between m3 and m4")
Executing: symind3_amam_err_4 = geomAnd(geomOr(symind3_amam_m1 symind3_amam_bb symind3_a...
errorLayer(symind3_amam_err_4 "Missing v4 vias on symind coils between m4 and mt")
Executing: symind2_amam_err_3 = geomAnd(geomOr(symind2_amam_m1 symind2_amam_bb symind2_a...
errorLayer(symind2_amam_err_3 "Missing v3 vias on symind coils between m3 and m4")
Executing: symind2_amam_err_4 = geomAnd(geomOr(symind2_amam_m1 symind2_amam_bb symind2_a...
errorLayer(symind2_amam_err_4 "Missing v4 vias on symind coils between m4 and mt")
Executing: symind3_amam_err_T = geomAnd(geomOr(symind3_amam_m1 symind3_amam_bb symind3_a...
errorLayer(symind3_amam_err_T "Missing ft vias on symind coils between mt and am")
Executing: symind2_amam_err_T = geomAnd(geomOr(symind2_amam_m1 symind2_amam_bb symind2_a...
errorLayer(symind2_amam_err_T "Missing ft vias on symind coils between mt and am")
Executing: ind2_mtam_err_T = geomAnd(geomOr(ind2_mtam_m1 ind2_mtam_bb ind2_mtam_hr) mt_f...
errorLayer(ind2_mtam_err_T "Missing ft vias on ind coils between mt and am")
Executing: ind_space = geomInside(geomOr(drc(trans_out_am am_intern (sep < 5.2) opposite...
Executing: symind_space_s1 = geomInside(geomOr(drc(symind_out geomOr(mt am_intern) (sep ...
Executing: symind_space_no_s = geomButtOrCoin(symind_space_s1 symIND)
Executing: symind_space_s1 = geomAndNot(symind_space_s1 geomOr(am_intern symind_space_no...
Executing: symind_space_s2 = geomButtOnly(symind_space_s1 symind_out)
Executing: symind_space_cnr = geomGetCorner(symind_space_s2 manhattanOnly)
Executing: symind_space_corner = geomInside(geomGrowCorner(symind_space_cnr 0.1 manhatta...
Executing: symind_space_cont = geomOr(geomInside(drc(symind_space_corner (sep <= 25) opp...
Executing: symind_space_s = geomGetBBox(symind_space_cont)
Executing: Symind_edge_sp1 = geomSize(geomGetEdge(symind_space_s butting geomOr(symind_o...
Executing: Symind_edge_sp2 = geomSize(geomGetEdge(symind_space_s outside geomOr(symind_o...
Executing: Symind_edge_space = geomOutside(Symind_edge_sp2 Symind_edge_sp1)
Executing: am_am_intern = geomSize(geomGetEdge(am butting am_intern) 0.1)
Executing: am_sep_in_out = geomOr(drc(symind_in symind_out (sep <= 75) opposite parallel))
Executing: am_pin_err = geomAndNot(am_am_intern geomAnd(geomInside(am_sep_in_out symIND)...
errorLayer(am_pin_err "AM signal wire exiting symetrical inductor straddling metal coil outside the pin")
Executing: m4_butt_symind = geomSize(geomGetEdge(m4 butting symIND) 0.1)
Executing: ct_m4_pin_err = geomButtOrCoin(m4_butt_symind symind_ct)
errorLayer(ct_m4_pin_err "Center tap signal wire exiting symetrical inductor outside CT pin")
Executing: bondPad_PC = geomInside(bondPad pc)
Executing: bondPad_BB = geomAndNot(geomOverlap(bondPad bond_bb_term) bondPad_PC)
Executing: bondPad_HR = geomAndNot(geomAndNot(geomOverlap(bondPad bond_hr_term) bondPad_...
Executing: bond_dummy_gp = geomOr(bondPad_HR)
Executing: bond_dummy_via = geomOr(bond_dummy_gp)
Executing: VNCAP = geomAnd(VNCAP geomOr(VNCAP_M1 VNCAP_M2 VNCAP_M3 VNCAP_M4 VNCAP_MT))
Executing: VNCAP_new = geomSize(VNCAP -0.4)
Executing: vncap_gap = geomOr(geomAndNot(VNCAP_M1 m1) geomAndNot(VNCAP_M2 m2) geomAndNot...
Executing: nw_vncap = geomInside(VNCAP nw)
Executing: bb_vncap = geomInside(VNCAP bb)
Executing: nohr_vncap = geomAndNot(geomAndNot(geomInside(VNCAP nohr) nw_vncap) bb_vncap)
Executing: sub_vncap = geomAndNot(VNCAP geomOr(nw_vncap bb_vncap nohr_vncap))
Executing: vncap_edge = geomAndNot(VNCAP geomSize(VNCAP -0.01))
Executing: vncap_sides = geomSize(geomGetEdge(VNCAP) 0.01)
Executing: vncap_edge2 = geomButting(vncap_sides geomSize(geomGetEdge(VNCAP coincident v...
Executing: vncap_L_edge = geomSize(geomGetEdge(VNCAP butting vncap_edge2) -0.1)
Executing: vncap_topt = geomOr(VNCAP_MT)
Executing: vncap_top1 = geomOutside(VNCAP_M1 VNCAP_M2)
Executing: vncap_termt = geomAnd(geomAnd(vncap_topt mt) vncap_edge)
Executing: vncap_term1 = geomAnd(geomAnd(vncap_top1 m1) vncap_edge)
Executing: vncap_bot1 = geomOr(VNCAP_M1)
Executing: vncap_top4 = geomOutside(VNCAP_M4 VNCAP_MT)
Executing: vncap_top3 = geomOutside(VNCAP_M3 VNCAP_M4)
Executing: vncap_top2 = geomOutside(VNCAP_M2 VNCAP_M3)
Executing: vncap_bot4 = geomOutside(VNCAP_M4 VNCAP_M3)
Executing: vncap_bot3 = geomOutside(VNCAP_M3 VNCAP_M2)
Executing: vncap_bot2 = geomOutside(VNCAP_M2 VNCAP_M1)
Executing: vncap_bott = geomOutside(VNCAP_MT VNCAP_M4)
Executing: vncap_term2 = geomAnd(geomAnd(vncap_top2 m2) vncap_edge)
Executing: vncap_term3 = geomAnd(geomAnd(vncap_top3 m3) vncap_edge)
Executing: vncap_term4 = geomAnd(geomAnd(vncap_top4 m4) vncap_edge)
Executing: vncap_via1 = geomOr(vncap_term1)
Executing: vncap_viat = geomOr(vncap_termt)
Executing: vncap_via2 = geomOr(vncap_term2)
Executing: vncap_via3 = geomOr(vncap_term3)
Executing: vncap_via4 = geomOr(vncap_term4)
Executing: vncap_tnw1 = geomInside(vncap_top1 nw)
Executing: vncap_top1 = geomOutside(vncap_top1 vncap_tnw1)
Executing: vncap_tnwt = geomInside(vncap_topt nw)
Executing: vncap_topt = geomOutside(vncap_topt vncap_tnwt)
Executing: vncap_tnw2 = geomInside(vncap_top2 nw)
Executing: vncap_top2 = geomOutside(vncap_top2 vncap_tnw2)
Executing: vncap_tnw3 = geomInside(vncap_top3 nw)
Executing: vncap_top3 = geomOutside(vncap_top3 vncap_tnw3)
Executing: vncap_tnw4 = geomInside(vncap_top4 nw)
Executing: vncap_top4 = geomOutside(vncap_top4 vncap_tnw4)
Executing: transmission = geomAnd(transmission1 geomSize(drc(transmission1 ((0.28 < widt...
Executing: amTerm = geomOr(geomOutside(amTerm transmission) geomAnd(amTerm transmission))
Executing: mtTerm = geomOr(geomOutside(mtTerm transmission) geomAnd(mtTerm transmission))
Executing: m2Term = geomOr(geomOutside(m2Term transmission) geomAnd(m2Term transmission))
Executing: m3Term = geomOr(geomOutside(m3Term transmission) geomAnd(m3Term transmission))
Executing: m4Term = geomOr(geomOutside(m4Term transmission) geomAnd(m4Term transmission))
Executing: allPins = geomOr(geomOr(geomOr(geomOr(amTerm mtTerm) m4Term) m3Term) m2Term)
Executing: singleEnd2 = geomStraddle(transmission m2Term (keep == 2))
Executing: coupled2 = geomStraddle(transmission m2Term (keep == 4))
Executing: singleEnd3 = geomStraddle(transmission m3Term (keep == 2))
Executing: coupled3 = geomStraddle(transmission m3Term (keep == 4))
Executing: singleEnd4 = geomStraddle(transmission m4Term (keep == 2))
Executing: coupled4 = geomStraddle(transmission m4Term (keep == 4))
Executing: singleEndT = geomStraddle(transmission mtTerm (keep == 2))
Executing: coupledT = geomStraddle(transmission mtTerm (keep == 4))
Executing: singleEndA = geomStraddle(transmission amTerm (keep == 2))
Executing: coupledA = geomStraddle(transmission amTerm (keep == 4))
Executing: am_coupled = geomAnd(am coupledA)
Executing: am_single = geomAnd(am singleEndA)
Executing: am_shield = geomOverlap(geomAvoiding(geomOr(am_coupled am_single) amTerm) ft)
Executing: am_signal = geomOverlap(geomOr(am_coupled am_single) amTerm)
Executing: am = geomOr(geomAndNot(am am_signal) amTerm)
Executing: am_err = geomOr(geomCoincident(geomAndNot(am_signal amTerm) geomOr(coupledA s...
errorLayer(am_err "AM signal wire not exiting transmission line at port, shorted, or open")
Executing: trans_va_am = geomGetTexted(amTerm OUT_label "va")
Executing: trans_vb_am = geomGetTexted(amTerm OUT_label "vb")
Executing: trans_va1_am = geomGetTexted(amTerm OUT_label "va1")
Executing: trans_va2_am = geomGetTexted(amTerm OUT_label "va2")
Executing: trans_vb1_am = geomGetTexted(amTerm OUT_label "vb1")
Executing: trans_vb2_am = geomGetTexted(amTerm OUT_label "vb2")
Executing: m4_coupled = geomAnd(m4 coupled4)
Executing: m4_single = geomAnd(m4 singleEnd4)
Executing: m4_shield = geomOverlap(geomAvoiding(geomOr(m4_coupled m4_single) m4Term) v3)
Executing: m4_signal = geomOverlap(geomOr(m4_coupled m4_single) m4Term)
Executing: m4 = geomOr(geomAndNot(m4 m4_signal) m4Term)
Executing: m4_err = geomOr(geomCoincident(geomAndNot(m4_signal m4Term) geomOr(coupled4 s...
errorLayer(m4_err "M4 signal wire not exiting transmission line at port, shorted, or open")
Executing: trans_va_m4 = geomGetTexted(m4Term OUT_label "va")
Executing: trans_vb_m4 = geomGetTexted(m4Term OUT_label "vb")
Executing: trans_va1_m4 = geomGetTexted(m4Term OUT_label "va1")
Executing: trans_va2_m4 = geomGetTexted(m4Term OUT_label "va2")
Executing: trans_vb1_m4 = geomGetTexted(m4Term OUT_label "vb1")
Executing: trans_vb2_m4 = geomGetTexted(m4Term OUT_label "vb2")
Executing: mt_coupled = geomAnd(mt coupledT)
Executing: mt_single = geomAnd(mt singleEndT)
Executing: mt_signal = geomOverlap(geomOr(mt_coupled mt_single) mtTerm)
Executing: mt = geomOr(geomAndNot(mt mt_signal) mtTerm)
Executing: mt_err = geomOr(geomCoincident(geomAndNot(mt_signal mtTerm) geomOr(coupledT s...
errorLayer(mt_err "MT signal wire not exiting transmission line at port, shorted, or open")
Executing: mt_shield = geomOverlap(geomAvoiding(geomOr(mt_coupled mt_single) mtTerm) v4)
Executing: trans_va_mt = geomGetTexted(mtTerm OUT_label "va")
Executing: trans_vb_mt = geomGetTexted(mtTerm OUT_label "vb")
Executing: trans_va1_mt = geomGetTexted(mtTerm OUT_label "va1")
Executing: trans_va2_mt = geomGetTexted(mtTerm OUT_label "va2")
Executing: trans_vb1_mt = geomGetTexted(mtTerm OUT_label "vb1")
Executing: trans_vb2_mt = geomGetTexted(mtTerm OUT_label "vb2")
Executing: m3_coupled = geomAnd(m3 coupled3)
Executing: m3_single = geomAnd(m3 singleEnd3)
Executing: m3_shield = geomOverlap(geomAvoiding(geomOr(m3_coupled m3_single) m3Term) v2)
Executing: m3_signal = geomOverlap(geomOr(m3_coupled m3_single) m3Term)
Executing: m3 = geomOr(geomAndNot(m3 m3_signal) m3Term)
Executing: m3_err = geomOr(geomCoincident(geomAndNot(m3_signal m3Term) geomOr(coupled3 s...
errorLayer(m3_err "M3 signal wire not exiting transmission line at port, shorted, or open")
Executing: trans_va_m3 = geomGetTexted(m3Term OUT_label "va")
Executing: trans_vb_m3 = geomGetTexted(m3Term OUT_label "vb")
Executing: trans_va1_m3 = geomGetTexted(m3Term OUT_label "va1")
Executing: trans_va2_m3 = geomGetTexted(m3Term OUT_label "va2")
Executing: trans_vb1_m3 = geomGetTexted(m3Term OUT_label "vb1")
Executing: trans_vb2_m3 = geomGetTexted(m3Term OUT_label "vb2")
Executing: m2_coupled = geomAnd(m2 coupled2)
Executing: m2_single = geomAnd(m2 singleEnd2)
Executing: m2_shield = geomOverlap(geomAvoiding(geomOr(m2_coupled m2_single) m2Term) v1)
Executing: m2_signal = geomOverlap(geomOr(m2_coupled m2_single) m2Term)
Executing: m2 = geomOr(geomAndNot(m2 m2_signal) m2Term)
Executing: m2_err = geomOr(geomCoincident(geomAndNot(m2_signal m2Term) geomOr(coupled2 s...
errorLayer(m2_err "M2 signal wire not exiting transmission line at port, shorted, or open")
Executing: trans_va_m2 = geomGetTexted(m2Term OUT_label "va")
Executing: trans_vb_m2 = geomGetTexted(m2Term OUT_label "vb")
Executing: trans_va1_m2 = geomGetTexted(m2Term OUT_label "va1")
Executing: trans_va2_m2 = geomGetTexted(m2Term OUT_label "va2")
Executing: trans_vb1_m2 = geomGetTexted(m2Term OUT_label "vb1")
Executing: trans_vb2_m2 = geomGetTexted(m2Term OUT_label "vb2")
Executing: all_shield = geomOr(am_shield mt_shield m4_shield m3_shield m2_shield)
Executing: all_signal = geomOr(am_signal mt_signal m4_signal m3_signal m2_signal)
Executing: transmission_edges = geomSize(geomGetEdge(transmission over substrate) 0.01)
Executing: transmission_perim = geomAndNot(transmission geomSize(transmission -0.1))
Executing: coupledSpace = geomButting(geomGetRectangle(geomAndNot(geomAnd(transmission_p...
Executing: shieldSpace = geomButting(geomGetRectangle(geomAnd(transmission_perim drc(all...
Executing: signalWidth = geomAnd(transmission_perim allPins)
Executing: shield1 = geomButting(geomAnd(m1 transmission) transmission_edges (keep > 3))
Executing: trans_s1 = geomOr(shield1)
Executing: shield2 = geomButting(geomAnd(m2 transmission) transmission_edges (keep > 3))
Executing: trans_s2 = geomOr(shield2)
Executing: shield3 = geomButting(geomAnd(m3 transmission) transmission_edges (keep > 3))
Executing: trans_s3 = geomOr(shield3)
Executing: shield4 = geomButting(geomAnd(m4 transmission) transmission_edges (keep > 3))
Executing: trans_s4 = geomOr(shield4)
Executing: shieldT = geomButting(geomAnd(mt transmission) transmission_edges (keep > 3))
Executing: trans_sT = geomOr(shieldT)
Executing: amTran = geomOverlap(amTerm transmission)
Executing: mtTran = geomOverlap(mtTerm transmission)
Executing: m4Tran = geomOverlap(m4Term transmission)
Executing: m3Tran = geomOverlap(m3Term transmission)
Executing: m2Tran = geomOverlap(m2Term transmission)
Executing: mim_top = geomOverlap(geomAnd(qt am) ft)
Executing: dualtop = geomOverlap(geomAnd(ht am) ft)
Executing: qtblk = geomOr(qt)
Executing: MIM = geomOutside(qt ht)
Executing: width_label_m_edge = geomSize(geomGetEdge(width_label coincident MIM) 0.1)
Executing: width_label_mim = geomButting(width_label width_label_m_edge (keep == 3))
Executing: MIMHK = geomOverlap(MIM MIMHK)
Executing: MIM = geomAndNot(MIM MIMHK)
Executing: MIMnw_all = geomInside(MIM nw)
Executing: MIMnw = geomOr(MIMnw_all)
Executing: MIMpi_all = geomAndNot(geomInside(MIM pi) MIMnw)
Executing: MIMpi = geomOr(MIMpi_all)
Executing: MIMsx_all = geomAndNot(MIM geomOr(MIMnw MIMpi))
Executing: MIMsx = geomOr(MIMsx_all)
Executing: MIMhdnw = geomOverlap(MIMnw mimhd)
Executing: MIMnw = geomOutside(MIMnw mimhd)
Executing: MIMhdpi = geomOverlap(MIMpi mimhd)
Executing: MIMpi = geomOutside(MIMpi mimhd)
Executing: MIMhdsx = geomOverlap(MIMsx mimhd)
Executing: MIMsx = geomOutside(MIMsx mimhd)
Executing: MIMHKnw = geomInside(MIMHK nw)
Executing: MIMHKpi = geomAndNot(geomInside(MIMHK pi) MIMHKnw)
Executing: MIMHKpc = geomAndNot(geomInside(MIMHK pc) geomOr(MIMHKnw MIMHKpi))
Executing: MIMHKsx = geomAndNot(MIMHK geomOr(MIMHKnw MIMHKpi MIMHKpc))
Executing: DUALMIM = geomOr(ht)
Executing: width_label_d_edge = geomSize(geomGetEdge(width_label coincident DUALMIM) 0.1)
Executing: width_label_dmim = geomButting(width_label width_label_d_edge (keep == 3))
Executing: DUALMIMnw_all = geomInside(DUALMIM nw)
Executing: DUALMIMnw = geomOr(DUALMIMnw_all)
Executing: DUALMIMpi_all = geomAndNot(geomInside(DUALMIM pi) DUALMIMnw)
Executing: DUALMIMpi = geomOr(DUALMIMpi_all)
Executing: DUALMIMsx_all = geomAndNot(DUALMIM geomOr(DUALMIMnw DUALMIMpi))
Executing: DUALMIMsx = geomOr(DUALMIMsx_all)
Executing: DUALMIMhdnw = geomOverlap(DUALMIMnw mimhd)
Executing: DUALMIMnw = geomOutside(DUALMIMnw mimhd)
Executing: DUALMIMhdpi = geomOverlap(DUALMIMpi mimhd)
Executing: DUALMIMpi = geomOutside(DUALMIMpi mimhd)
Executing: DUALMIMhdsx = geomOverlap(DUALMIMsx mimhd)
Executing: DUALMIMsx = geomOutside(DUALMIMsx mimhd)
Executing: all_mim = geomOr(MIM MIMHK DUALMIM)
Executing: bb_mim = geomOutside(geomOutside(geomOutside(geomInside(all_mim bb) nw) pc) pi)
Executing: nw_mim = geomOutside(geomOutside(geomInside(all_mim nw) bb) pc)
Executing: pc_mim = geomOutside(geomOutside(geomInside(all_mim pc) bb) nw)
Executing: nohr_mim = geomAndNot(geomAndNot(geomInside(all_mim nohr) bb_mim) nw_mim)
Executing: sub_mim = geomAndNot(geomAndNot(geomAndNot(geomAndNot(all_mim bb_mim) nw_mim)...
Executing: dualmid = geomAnd(geomAndNot(qt ht) mt)
Executing: dualbot = geomAnd(qt mt)
Executing: mimVtop = geomAnd(mim_top ft)
Executing: mimVbot = geomAnd(mim_bot ft)
Executing: duaVtop = geomAnd(dualtop ft)
Executing: duaVmid = geomAnd(dualmid ft)
Executing: duaVbot = geomAnd(dualbot ft)
Executing: errorLayer(geomOutside(ht ft) "No FT via over HT")
Executing: errorLayer(geomOutside(qt ft) "No FT via over QT")
Executing: ft = geomAndNot(ft qt)
Executing: k1_via = geomSize(geomSize(geomAnd(v1 k1) 0.5) -0.5)
Executing: v1 = geomAndNot(v1 k1)
Executing: k1_term = geomOr(k1_via drc(k1 k1_via (enc < 1.6) opposite))
Executing: k1_dev = geomAndNot(k1 k1_term)
Executing: k1_dev = geomButting(k1_dev k1_via (keep > 1))
Executing: k1_dev_bb = geomInside(k1_dev bb)
Executing: k1_dev_sx = geomOutside(k1_dev bb)
Executing: k1_model = geomOverlap(k1 geomOr(m1 rx pc))
errorLayer(k1_model "MODEL concern - K1 resistor not totally over STI substrate")
Executing: sub_diff_RF = geomOutside(geomAnd(geomOverlap(geomAndNot(pdiff nw) geomOr(ca ...
Executing: RF_via = geomAnd(RF_BULK sub_diff_RF)
Executing: ca1 = geomAnd(ca geomOr(ntie_top ptie_top ESD_pdnw_subc))
Executing: ca2 = geomAnd(ca geomOr(nfRF_drain nfRF_source DI_anode DI_cathode DI_coll DI...
Executing: ca3 = geomAnd(ca geomOr(efuse_anod efuse_cath ESD_pdnw_plus ESD_ndsx_plus))
Executing: ca4 = geomAnd(ca geomOr(pc pfet_sd nfet_sd esdnsh_drain esdnsh_source esdpsh_...
Executing: ca5 = geomAnd(ca geomOr(res6pc_term pdiff_tie ndiff_tie res6n_term res6p_term))
Executing: ca6 = geomAnd(ca geomOr(sub_diff pwell_diff nwell_diff nstap sub_diff_top sub...
Executing: ca7 = geomAnd(ca geomOr(pfRF_drain pfRF_source SBD_A SBD_C SBDNW_A SBDNW_C))
Executing: ca8 = geomAnd(ca geomOr(mosvar_pc mosvar_rx hvr_cath hvr_anod))
Executing: ca9 = geomAnd(ca geomOr(ncap_pc ncap_rx ncap_ndiff ESD_pdnw_minus ESD_ndsx_mi...
Executing: ca10 = geomAnd(ca geomOr(pcap_pc pcap_rx jfet_gate jfet_source jfet_drain))
Executing: ca11 = geomAnd(ca geomOr(vlnpn_c vlnpn_e vlnpn_g vlnpn_sub PSBD_A PSBD_C))
Executing: nd_comx = geomAndNot(geomBkgnd() geomNot(nfet_sd))
Executing: pd_comx = geomAndNot(geomBkgnd() geomNot(pfet_sd))
Executing: nd_fet = geomButting(nd_comx nfet_gate)
Executing: pd_fet = geomButting(pd_comx pfet_gate)
Executing: nd_tie = geomSize(ndiff_tie -0.03)
Executing: nd_tie_via = geomOr(nd_tie)
Executing: pd_tie = geomSize(pdiff_tie -0.03)
Executing: pd_tie_via = geomOr(pd_tie)
Executing: nd_comp = geomAndNot(geomBkgnd() geomNot(geomAnd(nd_comx geomOr(drc(geomSize(...
Executing: pd_comp = geomAndNot(geomBkgnd() geomNot(geomAnd(pd_comx geomOr(drc(geomSize(...
Executing: nd_via = geomAnd(nfet_sd nd_comp)
Executing: pd_via = geomAnd(pfet_sd pd_comp)
Executing: ndRF_scx = geomAndNot(geomBkgnd() geomNot(nfRF_source))
Executing: ndRF_drx = geomAndNot(geomBkgnd() geomNot(nfRF_drain))
Executing: ndRF_fet_sc = geomButting(ndRF_scx nfet_gate)
Executing: ndRF_fet_dr = geomButting(ndRF_drx nfet_gate)
Executing: ndRF_comp_sc = geomAndNot(geomBkgnd() geomNot(geomAnd(ndRF_scx geomOr(drc(geo...
Executing: ndRF_comp_dr = geomAndNot(geomBkgnd() geomNot(geomAnd(ndRF_drx geomOr(drc(geo...
Executing: ndRF_via_sc = geomAnd(nfRF_source ndRF_comp_sc)
Executing: ndRF_via_dr = geomAnd(nfRF_drain ndRF_comp_dr)
Executing: pdRF_scx = geomAndNot(geomBkgnd() geomNot(pfRF_source))
Executing: pdRF_drx = geomAndNot(geomBkgnd() geomNot(pfRF_drain))
Executing: pdRF_fet_sc = geomButting(pdRF_scx pfet_gate)
Executing: pdRF_fet_dr = geomButting(pdRF_drx pfet_gate)
Executing: pdRF_comp_sc = geomAndNot(geomBkgnd() geomNot(geomAnd(pdRF_scx geomOr(drc(geo...
Executing: pdRF_comp_dr = geomAndNot(geomBkgnd() geomNot(geomAnd(pdRF_drx geomOr(drc(geo...
Executing: pdRF_via_sc = geomAnd(pfRF_source pdRF_comp_sc)
Executing: pdRF_via_dr = geomAnd(pfRF_drain pdRF_comp_dr)
Executing: npd_comp = geomOr(nd_comp pd_comp)
Executing: FET_drain = geomOr(pdRF_comp_dr ndRF_comp_dr)
Executing: FET_source = geomOr(pdRF_comp_sc ndRF_comp_sc)
Executing: m1LV = geomGetTexted(m1 LV_NET "low_voltage_net")
Executing: pcLV = geomGetTexted(pc LV_NET "low_voltage_net")
Executing: m1LVCon = geomOr(m1LV)
Executing: pcLVCon = geomOr(pcLV)
Executing: LVgate = geomAndNot(Gate geomOr(dg tg))
Executing: LVgateCon = geomOr(LVgate)
Executing: fetDiff = geomOr(ndRF_comp_sc ndRF_comp_dr pdRF_comp_dr pdRF_comp_sc nfet_sd ...
Executing: HVdiff = geomAnd(geomOr(fetDiff) geomOr(dg tg))
Executing: HVdiffCon = geomOr(HVdiff)
Executing: bondpad_rect = geomOverlap(geomGetRectangle(PAD_DEV) bondPad_PC)
Executing: bondpad_poly = geomOverlap(geomGetBBox(geomAndNot(PAD_DEV bondpad_rect)) bond...
Executing: All_bondpad = geomSize(geomOr(bondpad_rect bondpad_poly) 5.18)
Executing: bondpad_pc_model = geomOr(All_bondpad)
Executing: rcxLayer(bondpad_pc_model)
Executing: fet_pc_model = geomOr(geomSize(geomOutside(geomOr(nfet_gate pfet_gate) tg) 0....
Executing: rcxLayer(fet_pc_model)
Executing: psbd_m1_model = geomAnd(geomOverlap(m1 geomOr(PSBD_A PSBD_C)) MOSvar)
Executing: sbd_m1_model = geomAnd(m1 geomOr(geomSize(SBD -1.2) geomSize(SBDNW -0.6)))
Executing: dipdnw_m1_model = geomAnd(m1 DI_diode)
Executing: divpnp_m1_model = geomAnd(m1 DI_VPNP)
Executing: dindpw_m1_model = geomAnd(m1 DIPI_diode)
Executing: mosvar_pcap_pc_model = geomOr(pcap_pc mosvar_pc)
Executing: mosvar_pcap_m1_model = geomAnd(m1 MOSvar)
Executing: pcdcap_pc_model = geomAnd(pc geomSize(geomOr(ncap_dev ncap33_dev) 0.24))
Executing: pcdcap_m1_model = geomAnd(m1 ncap_rx)
Executing: havar_m1_model = geomAnd(m1 geomOr(geomSize(hvr_dev -0.56) geomSize(diffhavar...
Executing: esd_m1_model = geomAnd(m1 geomOr(ESD_ndsx ESD_ndsx_GR_sized ESD_ndsx_GR ESD_n...
Executing: wire_m1_model = geomSize(shield1 0.02)
Executing: vncap_m1_model = geomAnd(geomOr(vncap_tnw1 vncap_top1) vncap_bot1)
Executing: rcxLayer(vncap_m1_model)
Executing: wire_m2_model = geomSize(geomOr(shield1 shield2) 0.02)
Executing: vncap_m2_model = geomAnd(geomOr(vncap_tnw2 vncap_top2) vncap_bot2)
Executing: rcxLayer(vncap_m2_model)
Executing: vncap_m2m1_model = geomAnd(geomOr(vncap_tnw2 vncap_top2) vncap_bot1)
Executing: rcxLayer(vncap_m2m1_model)
Executing: wire_m3_model = geomSize(geomOr(shield1 shield2 shield3) 0.02)
Executing: vncap_m3_model = geomAnd(geomOr(vncap_tnw3 vncap_top3) vncap_bot3)
Executing: rcxLayer(vncap_m3_model)
Executing: vncap_m3m2_model = geomAnd(geomOr(vncap_tnw3 vncap_top3) vncap_bot2)
Executing: rcxLayer(vncap_m3m2_model)
Executing: vncap_m3m1_model = geomAnd(geomOr(vncap_tnw3 vncap_top3) vncap_bot1)
Executing: rcxLayer(vncap_m3m1_model)
Executing: wire_m4_model = geomSize(geomOr(shield1 shield2 shield3 shield4) 0.02)
Executing: vncap_m4_model = geomAnd(geomOr(vncap_tnw4 vncap_top4) vncap_bot4)
Executing: rcxLayer(vncap_m4_model)
Executing: vncap_m4m3_model = geomAnd(geomOr(vncap_tnw4 vncap_top4) vncap_bot3)
Executing: rcxLayer(vncap_m4m3_model)
Executing: vncap_m4m2_model = geomAnd(geomOr(vncap_tnw4 vncap_top4) vncap_bot2)
Executing: rcxLayer(vncap_m4m2_model)
Executing: vncap_m4m1_model = geomAnd(geomOr(vncap_tnw4 vncap_top4) vncap_bot1)
Executing: rcxLayer(vncap_m4m1_model)
Executing: wire_mt_model = geomSize(geomOr(shield1 shield2 shield3 shield4 shieldT) 0.02)
Executing: vncap_mt_model = geomAnd(geomOr(vncap_tnwt vncap_topt) vncap_bott)
Executing: rcxLayer(vncap_mt_model)
Executing: vncap_mtm4_model = geomAnd(geomOr(vncap_tnwt vncap_topt) vncap_bot4)
Executing: rcxLayer(vncap_mtm4_model)
Executing: vncap_mtm3_model = geomAnd(geomOr(vncap_tnwt vncap_topt) vncap_bot3)
Executing: rcxLayer(vncap_mtm3_model)
Executing: vncap_mtm2_model = geomAnd(geomOr(vncap_tnwt vncap_topt) vncap_bot2)
Executing: rcxLayer(vncap_mtm2_model)
Executing: vncap_mtm1_model = geomAnd(geomOr(vncap_tnwt vncap_topt) vncap_bot1)
Executing: rcxLayer(vncap_mtm1_model)
Executing: RfDevice_pc_model = geomAnd(geomButtOrOver(pc Gate) geomSize(RF 0.2))
Executing: rcxLayer(RfDevice_pc_model)
Executing: RfDevice_m1_model = geomAnd(m1 geomSize(RF 0.2))
Executing: rcxLayer(RfDevice_m1_model)
Executing: RfDevice_m2_model = geomAnd(geomOverlap(m2 geomAnd(v1 RfDevice_m1_model)) geo...
Executing: rcxLayer(RfDevice_m2_model)
Executing: vlnpn_pc_model = geomOverlap(pc vlnpn_g)
Executing: rcxLayer(vlnpn_pc_model)
Executing: vlnpn_m1_model = geomAnd(geomOverlap(m1 geomOr(ca4 ca6 ca7 ca11)) geomSize(vl...
Executing: rcxLayer(vlnpn_m1_model)
Executing: vlnpn_m2_model = geomAnd(geomOverlap(m2 geomAnd(v1 geomOr(vlnpn_c vlnpn_e))) ...
Executing: rcxLayer(vlnpn_m2_model)
Executing: jfet_m1_model = geomAnd(m1 geomOr(jfet_drain jfet_source jfet_gate))
Executing: rcxLayer(jfet_m1_model)
Executing: jfet_m2_model = geomAnd(m2 geomOr(jfet_drain jfet_source))
Executing: rcxLayer(jfet_m2_model)
Executing: pc_device_model = geomOr(fet_pc_model pcdcap_pc_model mosvar_pcap_pc_model vl...
Executing: pc_model = geomAnd(pc pc_device_model)
Executing: pc_resistive = geomAndNot(pc pc_model)
Executing: m1_device_model = geomOr(m1_ind_groundplane esd_m1_model havar_m1_model pcdca...
Executing: m1_model = geomAnd(m1 m1_device_model)
Executing: m1_resistive = geomAndNot(m1 m1_model)
Executing: m2_device_model = geomOr(vlnpn_m2_model RfDevice_m2_model ndiff_vlnpn jfet_m2...
Executing: m2_model = geomAnd(m2 m2_device_model)
Executing: m2_resistive = geomAndNot(m2 m2_model)
Executing: m3_device_blockage = geomOr(VNCAP_M3 wire_m3_model)
Executing: m3_model = geomAnd(m3 m3_device_blockage)
Executing: m3_resistive = geomAndNot(m3 m3_model)
Executing: m4_device_blockage = geomOr(VNCAP_M4 wire_m4_model)
Executing: m4_model = geomAnd(m4 m4_device_blockage)
Executing: m4_resistive = geomAndNot(m4 m4_model)
Executing: mt_device_model = geomOr(VNCAP_MT wire_mt_model geomSize(MIM 2.0) geomSize(MI...
Executing: mt_model = geomAnd(mt mt_device_model)
Executing: mt_resistive = geomAndNot(mt mt_model)
Executing: pc_columbus = geomOr(pc_model)
Executing: m1_columbus = geomOr(m1_model)
Executing: mt_columbus = geomOr(mt_model)
Executing: m2_columbus = geomOr(m2_model)
Executing: m3_columbus = geomOr(m3_model)
Executing: m4_columbus = geomOr(m4_model)
Executing: geomConnect((via vncap_via1 m1_model m1_resistive vncap_term1) (via vncap_via...
See the label report in "Inverter.erc" file for details.
Executing: geomHoles(nw)
Executing: nw_ring = geomButting(nw nw_hole)
Executing: NWbias_device = geomOr(pfet_gate VPNPnw ESD_nw DI_diode MOSVAR res6p_bar res6...
Executing: TWbias_device = geomOr(ntie_device nfettw_all pcap_dev DIPI_diode PSBD)
Executing: nw_ring = geomAndNot(nw_ring geomButting(nw_ring geomOverlap(nw_hole TWbias_d...
Executing: nw_ring = geomAndNot(nw_ring geomOverlap(nw_ring NWbias_device))
Executing: nw_ring = geomCat(nw_ring)
Executing: geomStamp(nw_ring nwell_diff multConnect "nw_StampErrorConnect" majority)
Executing: nw_StampErrorFloat = geomOutside(nw_ring nwell_diff)
errorLayer(nw_StampErrorFloat "nw_StampErrorFloat")
Executing: nw_StampErrorMult = geomOverlap(nw_ring nw_StampErrorConnect)
errorLayer(nw_StampErrorMult "nw_StampErrorMult")
Executing: nw = geomCat(nw)
Executing: geomStamp(nw nwell_diff multConnect "nw_StampErrorConnect" majority)
Executing: nw_StampErrorFloat = geomOutside(nw nwell_diff)
Executing: nw_StampErrorMult = geomOverlap(nw nw_StampErrorConnect)
Executing: ncap_nw = geomCat(ncap_nw)
Executing: geomStamp(ncap_nw ncap_ndiff multConnect "ncap_nw_StampErrorConnect" majority)
Executing: ncap_nw_StampErrorFloat = geomOutside(ncap_nw ncap_ndiff)
errorLayer(ncap_nw_StampErrorFloat "ncap_nw_StampErrorFloat")
Executing: ncap_nw_StampErrorMult = geomOverlap(ncap_nw ncap_nw_StampErrorConnect)
errorLayer(ncap_nw_StampErrorMult "ncap_nw_StampErrorMult")
Executing: well = geomCat(nw)
Executing: geomStamp(well nwell_diff multConnect "well_StampErrorConnect" majority)
Executing: well_StampErrorFloat = geomOutside(well nwell_diff)
errorLayer(well_StampErrorFloat "well_StampErrorFloat")
Executing: well_StampErrorMult = geomOverlap(well well_StampErrorConnect)
errorLayer(well_StampErrorMult "well_StampErrorMult")
Executing: nfeti_bottom_iso = geomCat(nfeti_bottom_iso)
Executing: geomStamp(nfeti_bottom_iso nw multConnect "pi_StampErrorConnect" majority)
Executing: pi_StampErrorFloat = geomOutside(nfeti_bottom_iso nw)
errorLayer(pi_StampErrorFloat "pi_StampErrorFloat")
Executing: pi_StampErrorMult = geomOverlap(nfeti_bottom_iso pi_StampErrorConnect)
errorLayer(pi_StampErrorMult "pi_StampErrorMult")
Executing: pwell = geomCat(pwell)
Executing: geomStamp(pwell pwell_diff multConnect "pwell_StampErrorConnect" majority)
Executing: pwell_StampErrorFloat = geomOutside(pwell pwell_diff)
errorLayer(pwell_StampErrorFloat "pwell_StampErrorFloat")
Executing: pwell_StampErrorMult = geomOverlap(pwell pwell_StampErrorConnect)
errorLayer(pwell_StampErrorMult "pwell_StampErrorMult")
Executing: ns = geomCat(ns)
Executing: geomStamp(ns nstap multConnect "ns_StampErrorConnect" majority)
Executing: ns_StampErrorFloat = geomOutside(ns nstap)
errorLayer(ns_StampErrorFloat "ns_StampErrorFloat")
Executing: ns_StampErrorMult = geomOverlap(ns ns_StampErrorConnect)
errorLayer(ns_StampErrorMult "ns_StampErrorMult")
Executing: geomStamp(substrate_ptap sub_diff multConnect "substrate_ptap_StampErrorCon" majority)
Executing: geomStamp(substrate substrate_ptap multConnect "substrate_StampErrorCon" majority)
Executing: geomStamp(subs_sti substrate multConnect "sub_sti_StampErrorCon" majority)
Executing: geomStamp(sub1K substrate multConnect majority)
Executing: geomStamp(sub50 substrate multConnect majority)
Executing: mixed_voltage_net = geomNodeRelate(LVgate HVdiff conn)
Executing: mixed_voltage_OK_M1 = geomNodeRelate(LVgate m1LV conn)
Executing: mixed_voltage_OK_PC = geomNodeRelate(LVgate pcLV conn)
Executing: mixed_voltage_net_err = geomAndNot(mixed_voltage_net geomOr(mixed_voltage_OK_...
errorLayer(mixed_voltage_net_err "Mixed voltage net found : 3V3 or 5V diffusion is connected to 1.8V gate")
Executing: geomPathCheck((layer sub_diff sub_diff_top) pwr "ptap connected to POWER net found !")
Executing: geomPathCheck((layer pwell_diff) pwr "pwtap connected to POWER net found !")
Executing: geomPathCheck((layer nw) gnd "nw connected to ground ")
Executing: geomPathCheck((layer pdiff_tie ptie_top) pwr "ptie connected to power ")
Executing: fwd_biased_ptie_err = geomOverlap(nw_to_ground ptie_to_power)
errorLayer(fwd_biased_ptie_err "forward biased ptie device found ! [tdpdnw/diodepnw] ")
Executing: geomPathCheck((layer pwell) pwr "pwell connected to power ")
Executing: geomPathCheck((layer ndiff_tie ntie_top) gnd "ntie connected to ground ")
Executing: fwd_biased_ntie_err = geomOverlap(pwell_to_power ntie_to_ground)
errorLayer(fwd_biased_ntie_err "forward biased ntie device found ! [tdndsx,tdndpw/diodenx,diodendpw] ")
Executing: geomPathCheck((layer nw_ring) noPwr "NW ring not connected to a power net found !")
Executing: end_fet_rx_edge = geomSize(geomButting(geomOr(nd_comx pd_comx) Gate (keep == ...
Executing: extractDevice("nfettw4" nfeti_dev (pc_model "G") (nfet_sd "S" "D") (pwell "B"...
Executing: extractDevice("nfettw4" nfeti_dev_psp (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: extractDevice("nfettw4" nfeti_dev_b (pc_model "G") (nfet_sd "S" "D") (pwell "...
Executing: extractDevice("nfettw4" nfeti_dev_psp_b (pc_model "G") (nfet_sd "S" "D") (pwe...
Executing: PSP_M = geomOverlap(dev_ID psp_model)
Executing: GNS_M = geomOverlap(dev_ID nfet_gate_gns)
Executing: saveProperty(dev_ID "rf" 0)
Executing: saveProperty(dev_ID "m" 1)
Executing: saveProperty(dev_ID "par" 1)
Executing: saveProperty(dev_ID "mSwitch" 0)
Executing: saveProperty(dev_ID "nf" 1)
Executing: saveProperty(dev_ID "blockParasiticsBetween" "PC sub")
Executing: saveProperty(nfeti_dev "tw" 1)
Executing: width = measureParameter(length (dev_ID coincident pc) 5e-07)
Executing: nameParameter(width "w")
Executing: nameParameter(width "wt")
Executing: area = measureParameter(area (dev_ID over rx) 1e-12)
Executing: length = calculateParameter((area / width))
Executing: nameParameter(length "l")
Executing: nc = measureParameter(figCount (dev_ID enclosing dual_poly))
Executing: gcon = calculateParameter((nc + 1.0 + (length - length)))
Executing: nameParameter(gcon "gcon")
Executing: psp_shape = measureParameter(figCount (dev_ID enclosing PSP_M))
Executing: psp = calculateParameter((psp_shape + (length - length)))
Executing: nameParameter(psp "psp")
Executing: nrd = calculateParameter((2.6e-07 / (width - 6e-08)))
Executing: gns_shape = measureParameter(figCount (dev_ID enclosing GNS_M))
Executing: gns = calculateParameter((gns_shape + (length - length)))
Executing: nameParameter(gns "gns")
Executing: nameParameter(nrd "nrd")
Executing: nameParameter(nrd "nrs")
Executing: sti = measureParameter(area (nfeti_dev over end_fet_rx_edge) 0.0001)
Executing: sti_stress = calculateParameter(((sti / width) + (length - length)))
Executing: nameParameter(sti_stress "stis")
Executing: saveProperty(nfeti_dev_psp "tw" 1)
Executing: saveProperty(nfeti_dev_psp "model" "nfetpsp")
Executing: sti = measureParameter(area (nfeti_dev_psp over end_fet_rx_edge) 0.0001)
Executing: saveProperty(nfeti_dev_b "tw" 1)
Executing: sti = measureParameter(area (nfeti_dev_b over end_fet_rx_edge) 0.0001)
Executing: nfet_bends = measureParameter(bends_all (nfeti_dev_b coincident pc))
Executing: nameParameter(nfet_bends "bentgate")
Executing: saveProperty(nfeti_dev_psp_b "tw" 1)
Executing: saveProperty(nfeti_dev_psp_b "model" "nfetpsp")
Executing: sti = measureParameter(area (nfeti_dev_psp_b over end_fet_rx_edge) 0.0001)
Executing: nfet_bends = measureParameter(bends_all (nfeti_dev_psp_b coincident pc))
Executing: extractDevice("nfettw" nfet6_dev (pc_model "G") (nfet_sd "S" "D") (pwell "B")...
Executing: extractDevice("nfettw" nfet6_dev_psp (pc_model "G") (nfet_sd "S" "D") (pwell ...
Executing: extractDevice("nfettw" nfet6_dev_b (pc_model "G") (nfet_sd "S" "D") (pwell "B...
Executing: extractDevice("nfettw" nfet6_dev_psp_b (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: sti = measureParameter(area (nfet6_dev over end_fet_rx_edge) 0.0001)
Executing: sti = measureParameter(area (nfet6_dev_psp over end_fet_rx_edge) 0.0001)
Executing: saveProperty(nfet6_dev_psp "model" "nfettwpsp")
Executing: sti = measureParameter(area (nfet6_dev_b over end_fet_rx_edge) 0.0001)
Executing: nfet_bends = measureParameter(bends_all (nfet6_dev_b coincident pc))
Executing: sti = measureParameter(area (nfet6_dev_psp_b over end_fet_rx_edge) 0.0001)
Executing: saveProperty(nfet6_dev_psp_b "model" "nfettwpsp")
Executing: nfet_bends = measureParameter(bends_all (nfet6_dev_psp_b coincident pc))
Executing: extractDevice("nfet33tw4" nfeti_dev_MV (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: extractDevice("nfet33tw4" nfeti_dev_psp_MV (pc_model "G") (nfet_sd "S" "D") (...
Executing: saveProperty(nfeti_dev_MV "tw" 1)
Executing: saveProperty(nfeti_dev_psp_MV "tw" 1)
Executing: saveProperty(nfeti_dev_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfet6_dev_MV (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: extractDevice("nfet33tw" nfet6_dev_psp_MV (pc_model "G") (nfet_sd "S" "D") (p...
Executing: saveProperty(nfet6_dev_psp_MV "model" "nfet33twpsp")
Executing: extractDevice("nfet33tw4" nfeti_dev_HV (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: extractDevice("nfet33tw4" nfeti_dev_psp_HV (pc_model "G") (nfet_sd "S" "D") (...
Executing: saveProperty(nfeti_dev_HV "tw" 1)
Executing: saveProperty(nfeti_dev_psp_HV "tw" 1)
Executing: saveProperty(nfeti_dev_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfet6_dev_HV (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: extractDevice("nfet33tw" nfet6_dev_psp_HV (pc_model "G") (nfet_sd "S" "D") (p...
Executing: saveProperty(nfet6_dev_psp_HV "model" "nfet33twpsp")
Executing: extractDevice("nfet50tw4" nfeti_dev_TG (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: saveProperty(nfeti_dev_TG "tw" 1)
Executing: extractDevice("nfet50tw" nfet6_dev_TG (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: extractDevice("nfet" nfet_dpw (pc_model "G") (nfet_sd "S" "D") (pwell "B") fl...
Executing: extractDevice("nfet" nfet_dev (pc_model "G") (nfet_sd "S" "D") (substrate "B"...
1 'nfet' created in cell 'Inverter layout Project'.
Executing: extractDevice("nfet" nfet_dpw_psp (pc_model "G") (nfet_sd "S" "D") (pwell "B"...
Executing: extractDevice("nfet" nfet_dev_psp (pc_model "G") (nfet_sd "S" "D") (substrate...
Executing: extractDevice("zvtnfet" nfzv_dev (pc_model "G") (nfet_sd "S" "D") (substrate ...
Executing: extractDevice("zvtnfet33" nfzv_dev_HV (pc_model "G") (nfet_sd "S" "D") (subst...
Executing: sti = measureParameter(area (nfet_dev over end_fet_rx_edge) 0.0001)
Executing: sti = measureParameter(area (nfet_dev_psp over end_fet_rx_edge) 0.0001)
Executing: saveProperty(nfet_dev_psp "model" "nfetpsp")
Executing: sti = measureParameter(area (nfet_dpw over end_fet_rx_edge) 0.0001)
Executing: sti = measureParameter(area (nfet_dpw_psp over end_fet_rx_edge) 0.0001)
Executing: saveProperty(nfet_dpw_psp "model" "nfetpsp")
Executing: extractDevice("nfet33" nfet_dpw_MV (pc_model "G") (nfet_sd "S" "D") (pwell "B...
Executing: extractDevice("nfet33" nfet_dev_MV (pc_model "G") (nfet_sd "S" "D") (substrat...
Executing: extractDevice("nfet33" nfet_dpw_psp_MV (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: extractDevice("nfet33" nfet_dev_psp_MV (pc_model "G") (nfet_sd "S" "D") (subs...
Executing: saveProperty(nfet_dpw_psp_MV "model" "nfet33psp")
Executing: saveProperty(nfet_dev_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33" nfet_dpw_HV (pc_model "G") (nfet_sd "S" "D") (pwell "B...
Executing: extractDevice("nfet33" nfet_dev_HV (pc_model "G") (nfet_sd "S" "D") (substrat...
Executing: extractDevice("nfet33" nfet_dpw_psp_HV (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: extractDevice("nfet33" nfet_dev_psp_HV (pc_model "G") (nfet_sd "S" "D") (subs...
Executing: saveProperty(nfet_dpw_psp_HV "model" "nfet33psp")
Executing: saveProperty(nfet_dev_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet50" nfet_dpw_TG (pc_model "G") (nfet_sd "S" "D") (pwell "B...
Executing: extractDevice("nfet50" nfet_dev_TG (pc_model "G") (nfet_sd "S" "D") (substrat...
Executing: extractDevice("nfethv" nfet_dev_HVT (pc_model "G") (nfet_sd "S" "D") (substra...
Executing: extractDevice("nfethv" nfet_dev_HVT_b (pc_model "G") (nfet_sd "S" "D") (subst...
Executing: nfet_bends = measureParameter(bends_all (nfet_dev_HVT_b coincident pc))
Executing: extractDevice("nfet" nfet_dpw_b (pc_model "G") (nfet_sd "S" "D") (pwell "B") ...
Executing: extractDevice("nfet" nfet_dev_b (pc_model "G") (nfet_sd "S" "D") (substrate "...
Executing: extractDevice("nfet" nfet_dpw_psp_b (pc_model "G") (nfet_sd "S" "D") (pwell "...
Executing: extractDevice("nfet" nfet_dev_psp_b (pc_model "G") (nfet_sd "S" "D") (substra...
Executing: nfet_bends = measureParameter(bends_all (nfet_dpw_b coincident pc))
Executing: sti = measureParameter(area (nfet_dpw_b over end_fet_rx_edge) 0.0001)
Executing: nfet_bends = measureParameter(bends_all (nfet_dpw_psp_b coincident pc))
Executing: sti = measureParameter(area (nfet_dpw_psp_b over end_fet_rx_edge) 0.0001)
Executing: saveProperty(nfet_dpw_psp_b "model" "nfetpsp")
Executing: nfet_bends = measureParameter(bends_all (nfet_dev_b coincident pc))
Executing: sti = measureParameter(area (nfet_dev_b over end_fet_rx_edge) 0.0001)
Executing: nfet_bends = measureParameter(bends_all (nfet_dev_psp_b coincident pc))
Executing: sti = measureParameter(area (nfet_dev_psp_b over end_fet_rx_edge) 0.0001)
Executing: saveProperty(nfet_dev_psp_b "model" "nfetpsp")
Executing: extractDevice("pfet" pfet_dev (pc_model "G") (pfet_sd "S" "D") (nw "B") flagM...
1 'pfet' created in cell 'Inverter layout Project'.
Executing: extractDevice("pfet" pfet_dev_psp (pc_model "G") (pfet_sd "S" "D") (nw "B") f...
Executing: saveProperty(pfet_dev_psp "model" "pfetpsp")
Executing: extractDevice("pfet33" pfet_dev_MV (pc_model "G") (pfet_sd "S" "D") (nw "B") ...
Executing: extractDevice("pfet33" pfet_dev_psp_MV (pc_model "G") (pfet_sd "S" "D") (nw "...
Executing: saveProperty(pfet_dev_psp_MV "model" "pfet33psp")
Executing: extractDevice("pfet33" pfet_dev_HV (pc_model "G") (pfet_sd "S" "D") (nw "B") ...
Executing: extractDevice("pfet33" pfet_dev_psp_HV (pc_model "G") (pfet_sd "S" "D") (nw "...
Executing: saveProperty(pfet_dev_psp_HV "model" "pfet33psp")
Executing: extractDevice("pfet50" pfet_dev_TG (pc_model "G") (pfet_sd "S" "D") (nw "B") ...
Executing: extractDevice("p5pfet50" pfet_dev_SCG (pc_model "G") (pfet_sd "S" "D") (nw "B...
Executing: extractDevice("pfethv" pfet_dev_HVT (pc_model "G") (pfet_sd "S" "D") (nw "B")...
Executing: extractDevice("pfethv" pfet_dev_HVT_b (pc_model "G") (pfet_sd "S" "D") (nw "B...
Executing: pfet_bends = measureParameter(bends_all (pfet_dev_HVT_b coincident pc))
Executing: nameParameter(pfet_bends "bentgate")
Executing: extractDevice("pfet" pfet_dev_b (pc_model "G") (pfet_sd "S" "D") (nw "B") fla...
Executing: extractDevice("pfet" pfet_dev_psp_b (pc_model "G") (pfet_sd "S" "D") (nw "B")...
Executing: pfet_bends = measureParameter(bends_all (pfet_dev_b coincident pc))
Executing: pfet_bends = measureParameter(bends_all (pfet_dev_psp_b coincident pc))
Executing: saveProperty(pfet_dev_psp_b "model" "pfetpsp")
Executing: extractDevice("nfettw4" nfeti_mul (pc_model "G") (nfet_sd "S" "D") (pwell "B"...
Executing: extractDevice("nfettw4" nfeti_mul_psp (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: DP = geomOverlap(dev_ID dual_poly)
Executing: wx = measureParameter(perimeter (dev_ID over Gate) 5e-07)
Executing: lx = measureParameter(length (dev_ID coincident Gate) 5e-07)
Executing: nf = measureParameter(figCount (dev_ID enclosing Gate))
Executing: nameParameter(nf "nf")
Executing: length = calculateParameter((lx / nf))
Executing: width = calculateParameter(((wx - lx) / nf))
Executing: fet_wt = calculateParameter((width * nf))
Executing: nameParameter(fet_wt "wt")
Executing: nfet_nc = measureParameter(figCount (dev_ID enclosing DP))
Executing: nfet_gcon = calculateParameter((nfet_nc + 1.0 + (lx - lx)))
Executing: nameParameter(nfet_gcon "gcon")
Executing: psp = calculateParameter((psp_shape + (lx - lx)))
Executing: saveProperty(dev_ID "mSwitch" 1)
Executing: n_peri = measureParameter(perimeter (dev_ID over npd_comp))
Executing: n_area = measureParameter(area (dev_ID over npd_comp))
Executing: nb_dx = measureParameter(figCount (dev_ID enclosing npd_comp))
Executing: nb_d = calculateParameter(floor((nb_dx / 2)))
Executing: nb_s = calculateParameter((nb_d + (fmod nb_dx 2)))
Executing: ad = calculateParameter(((((n_area * 1e-12) / nb_dx) * nb_d) / (nb_dx - 1)))
Executing: as = calculateParameter(((((n_area * 1e-12) / nb_dx) * nb_s) / (nb_dx - 1)))
Executing: pd = calculateParameter(((((n_peri * 1e-06) / nb_dx) * nb_d) / (nb_dx - 1)))
Executing: ps = calculateParameter(((((n_peri * 1e-06) / nb_dx) * nb_s) / (nb_dx - 1)))
Executing: nameParameter(ad "ad")
Executing: nameParameter(as "as")
Executing: nameParameter(pd "pd")
Executing: nameParameter(ps "ps")
Executing: saveProperty(nfeti_mul "tw" 1)
Executing: saveProperty(nfeti_mul "stis" 2)
Executing: saveProperty(nfeti_mul_psp "tw" 1)
Executing: saveProperty(nfeti_mul_psp "stis" 2)
Executing: saveProperty(nfeti_mul_psp "model" "nfetpsp")
Executing: extractDevice("nfettw" nfet6_mul (pc_model "G") (nfet_sd "S" "D") (pwell "B")...
Executing: extractDevice("nfettw" nfet6_mul_psp (pc_model "G") (nfet_sd "S" "D") (pwell ...
Executing: saveProperty(nfet6_mul "stis" 2)
Executing: saveProperty(nfet6_mul_psp "stis" 2)
Executing: saveProperty(nfet6_mul_psp "model" "nfettwpsp")
Executing: extractDevice("nfet33tw4" nfeti_mul_MV (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: extractDevice("nfet33tw4" nfeti_mul_psp_MV (pc_model "G") (nfet_sd "S" "D") (...
Executing: saveProperty(nfeti_mul_MV "tw" 1)
Executing: saveProperty(nfeti_mul_psp_MV "tw" 1)
Executing: saveProperty(nfeti_mul_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfet6_mul_MV (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: extractDevice("nfet33tw" nfet6_mul_psp_MV (pc_model "G") (nfet_sd "S" "D") (p...
Executing: saveProperty(nfet6_mul_psp_MV "model" "nfet33twpsp")
Executing: extractDevice("nfet33tw4" nfeti_mul_HV (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: extractDevice("nfet33tw4" nfeti_mul_psp_HV (pc_model "G") (nfet_sd "S" "D") (...
Executing: saveProperty(nfeti_mul_HV "tw" 1)
Executing: saveProperty(nfeti_mul_psp_HV "tw" 1)
Executing: saveProperty(nfeti_mul_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfet6_mul_HV (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: extractDevice("nfet33tw" nfet6_mul_psp_HV (pc_model "G") (nfet_sd "S" "D") (p...
Executing: saveProperty(nfet6_mul_psp_HV "model" "nfet33twpsp")
Executing: extractDevice("nfet50tw4" nfeti_mul_TG (pc_model "G") (nfet_sd "S" "D") (pwel...
Executing: saveProperty(nfeti_mul_TG "tw" 1)
Executing: extractDevice("nfet50tw" nfet6_mul_TG (pc_model "G") (nfet_sd "S" "D") (pwell...
Executing: extractDevice("nfet" nfet_mul (pc_model "G") (nfet_sd "S" "D") (pwell "B") fl...
extractDevice("nfet" nfet_mul (pc_model "G") (nfet_sd "S" "D") (substrate "B"...
Executing: extractDevice("nfet" nfet_mul_psp (pc_model "G") (nfet_sd "S" "D") (pwell "B"...
extractDevice("nfet" nfet_mul_psp (pc_model "G") (nfet_sd "S" "D") (substrate...
Executing: extractDevice("zvtnfet" nfzv_mul (pc_model "G") (nfet_sd "S" "D") (substrate ...
Executing: extractDevice("zvtnfet33" nfzv_mul_HV (pc_model "G") (nfet_sd "S" "D") (subst...
Executing: saveProperty(nfet_mul "stis" 2)
Executing: saveProperty(nfet_mul_psp "stis" 2)
Executing: saveProperty(nfet_mul_psp "model" "nfetpsp")
Executing: extractDevice("nfet33" nfet_mul_MV (pc_model "G") (nfet_sd "S" "D") (pwell "B...
extractDevice("nfet33" nfet_mul_MV (pc_model "G") (nfet_sd "S" "D") (substrat...
Executing: extractDevice("nfet33" nfet_mul_psp_MV (pc_model "G") (nfet_sd "S" "D") (pwel...
extractDevice("nfet33" nfet_mul_psp_MV (pc_model "G") (nfet_sd "S" "D") (subs...
Executing: saveProperty(nfet_mul_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33" nfet_mul_HV (pc_model "G") (nfet_sd "S" "D") (pwell "B...
extractDevice("nfet33" nfet_mul_HV (pc_model "G") (nfet_sd "S" "D") (substrat...
Executing: extractDevice("nfet33" nfet_mul_psp_HV (pc_model "G") (nfet_sd "S" "D") (pwel...
extractDevice("nfet33" nfet_mul_psp_HV (pc_model "G") (nfet_sd "S" "D") (subs...
Executing: saveProperty(nfet_mul_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet50" nfet_mul_TG (pc_model "G") (nfet_sd "S" "D") (pwell "B...
extractDevice("nfet50" nfet_mul_TG (pc_model "G") (nfet_sd "S" "D") (substrat...
Executing: extractDevice("nfethv" nfet_mul_HVT (pc_model "G") (nfet_sd "S" "D") (substra...
Executing: extractDevice("pfet" pfet_mul (pc_model "G") (pfet_sd "S" "D") (nw "B") flagM...
Executing: extractDevice("pfet" pfet_mul_psp (pc_model "G") (pfet_sd "S" "D") (nw "B") f...
Executing: saveProperty(pfet_mul_psp "model" "pfetpsp")
Executing: extractDevice("pfet33" pfet_mul_MV (pc_model "G") (pfet_sd "S" "D") (nw "B") ...
Executing: extractDevice("pfet33" pfet_mul_psp_MV (pc_model "G") (pfet_sd "S" "D") (nw "...
Executing: saveProperty(pfet_mul_psp_MV "model" "pfet33psp")
Executing: extractDevice("pfet33" pfet_mul_HV (pc_model "G") (pfet_sd "S" "D") (nw "B") ...
Executing: extractDevice("pfet33" pfet_mul_psp_HV (pc_model "G") (pfet_sd "S" "D") (nw "...
Executing: saveProperty(pfet_mul_psp_HV "model" "pfet33psp")
Executing: extractDevice("pfet50" pfet_mul_TG (pc_model "G") (pfet_sd "S" "D") (nw "B") ...
Executing: extractDevice("p5pfet50" pfet_mul_SCG (pc_model "G") (pfet_sd "S" "D") (nw "B...
Executing: extractDevice("pfethv" pfet_mul_HVT (pc_model "G") (pfet_sd "S" "D") (nw "B")...
Executing: extractDevice("nfettw4" nfRFi_dev (pc_model "G") (ndRF_comp_dr "D") (ndRF_com...
Executing: extractDevice("nfettw4" nfRFi_dev_psp (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: saveProperty(dev_ID "gns" 0)
Executing: saveProperty(dev_ID "rf" 1)
Executing: saveProperty(dev_ID "gcon" 2)
Executing: saveProperty(dev_ID "blockParasiticsBetween" "M2 sub")
Executing: s_fig = measureParameter(figCount (dev_ID enclosing FET_source))
Executing: d_fig = measureParameter(figCount (dev_ID enclosing FET_drain))
Executing: d_area = measureParameter(area (dev_ID over FET_drain))
Executing: s_area = measureParameter(area (dev_ID over FET_source))
Executing: d_peri = measureParameter(perimeter (dev_ID over FET_drain))
Executing: s_peri = measureParameter(perimeter (dev_ID over FET_source))
Executing: ad = calculateParameter(((d_area * 1e-12) / ((d_fig + s_fig) - 1)))
Executing: as = calculateParameter(((s_area * 1e-12) / ((d_fig + s_fig) - 1)))
Executing: pd = calculateParameter(((d_peri * 1e-06) / ((d_fig + s_fig) - 1)))
Executing: ps = calculateParameter(((s_peri * 1e-06) / ((d_fig + s_fig) - 1)))
Executing: saveProperty(dev_ID "blockParasiticsLPP" "OUTLINE rf")
Executing: saveProperty(nfRFi_dev "tw" 1)
Executing: saveProperty(nfRFi_dev "stis" 2)
Executing: saveProperty(nfRFi_dev_psp "tw" 1)
Executing: saveProperty(nfRFi_dev_psp "stis" 2)
Executing: saveProperty(nfRFi_dev_psp "model" "nfetpsp")
Executing: extractDevice("nfettw" nfRF6_dev (pc_model "G") (ndRF_comp_dr "D") (ndRF_comp...
Executing: extractDevice("nfettw" nfRF6_dev_psp (pc_model "G") (ndRF_comp_dr "D") (ndRF_...
Executing: saveProperty(nfRF6_dev "stis" 2)
Executing: saveProperty(nfRF6_dev_psp "stis" 2)
Executing: saveProperty(nfRF6_dev_psp "model" "nfettwpsp")
Executing: extractDevice("nfet33tw4" nfRFi_dev_MV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: extractDevice("nfet33tw4" nfRFi_dev_psp_MV (pc_model "G") (ndRF_comp_dr "D") ...
Executing: saveProperty(nfRFi_dev_MV "tw" 1)
Executing: saveProperty(nfRFi_dev_psp_MV "tw" 1)
Executing: saveProperty(nfRFi_dev_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfRF6_dev_MV (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: extractDevice("nfet33tw" nfRF6_dev_psp_MV (pc_model "G") (ndRF_comp_dr "D") (...
Executing: saveProperty(nfRF6_dev_psp_MV "model" "nfet33twpsp")
Executing: extractDevice("nfet33tw4" nfRFi_dev_HV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: extractDevice("nfet33tw4" nfRFi_dev_psp_HV (pc_model "G") (ndRF_comp_dr "D") ...
Executing: saveProperty(nfRFi_dev_HV "tw" 1)
Executing: saveProperty(nfRFi_dev_psp_HV "tw" 1)
Executing: saveProperty(nfRFi_dev_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfRF6_dev_HV (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: extractDevice("nfet33tw" nfRF6_dev_psp_HV (pc_model "G") (ndRF_comp_dr "D") (...
Executing: saveProperty(nfRF6_dev_psp_HV "model" "nfet33twpsp")
Executing: extractDevice("nfet50tw4" nfRFi_dev_TG (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: saveProperty(nfRFi_dev_TG "tw" 1)
Executing: extractDevice("nfet50tw" nfRF6_dev_TG (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: extractDevice("nfet" nfRF_dev (pc_model "G") (ndRF_comp_dr "D") (ndRF_comp_sc...
Executing: extractDevice("nfet" nfRF_dev_psp (pc_model "G") (ndRF_comp_dr "D") (ndRF_com...
Executing: saveProperty(nfRF_dev "stis" 2)
Executing: saveProperty(nfRF_dev_psp "stis" 2)
Executing: saveProperty(nfRF_dev_psp "model" "nfetpsp")
Executing: extractDevice("nfet33" nfRF_dev_MV (pc_model "G") (ndRF_comp_dr "D") (ndRF_co...
Executing: extractDevice("nfet33" nfRF_dev_psp_MV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: saveProperty(nfRF_dev_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33" nfRF_dev_HV (pc_model "G") (ndRF_comp_dr "D") (ndRF_co...
Executing: extractDevice("nfet33" nfRF_dev_psp_HV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: saveProperty(nfRF_dev_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet50" nfRF_dev_TG (pc_model "G") (ndRF_comp_dr "D") (ndRF_co...
Executing: extractDevice("pfet" pfRF_dev (pc_model "G") (pdRF_comp_dr "D") (pdRF_comp_sc...
Executing: extractDevice("pfet" pfRF_dev_psp (pc_model "G") (pdRF_comp_dr "D") (pdRF_com...
Executing: saveProperty(pfRF_dev_psp "model" "pfetpsp")
Executing: extractDevice("pfet33" pfRF_dev_MV (pc_model "G") (pdRF_comp_dr "D") (pdRF_co...
Executing: extractDevice("pfet33" pfRF_dev_psp_MV (pc_model "G") (pdRF_comp_dr "D") (pdR...
Executing: saveProperty(pfRF_dev_psp_MV "model" "pfet33psp")
Executing: extractDevice("pfet33" pfRF_dev_HV (pc_model "G") (pdRF_comp_dr "D") (pdRF_co...
Executing: extractDevice("pfet33" pfRF_dev_psp_HV (pc_model "G") (pdRF_comp_dr "D") (pdR...
Executing: saveProperty(pfRF_dev_psp_HV "model" "pfet33psp")
Executing: extractDevice("pfet50" pfRF_dev_TG (pc_model "G") (pdRF_comp_dr "D") (pdRF_co...
Executing: extractDevice("p5pfet50" pfRF_dev_SCG (pc_model "G") (pdRF_comp_dr "D") (pdRF...
Executing: extractDevice("nfettw4" nfRFi_mul (pc_model "G") (ndRF_comp_dr "D") (ndRF_com...
Executing: extractDevice("nfettw4" nfRFi_mul_psp (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: saveProperty(nfRFi_mul "tw" 1)
Executing: saveProperty(nfRFi_mul "stis" 2)
Executing: saveProperty(nfRFi_mul_psp "tw" 1)
Executing: saveProperty(nfRFi_mul_psp "stis" 2)
Executing: saveProperty(nfRFi_mul_psp "model" "nfetpsp")
Executing: extractDevice("nfettw" nfRF6_mul (pc_model "G") (ndRF_comp_dr "D") (ndRF_comp...
Executing: extractDevice("nfettw" nfRF6_mul_psp (pc_model "G") (ndRF_comp_dr "D") (ndRF_...
Executing: saveProperty(nfRF6_mul "stis" 2)
Executing: saveProperty(nfRF6_mul_psp "stis" 2)
Executing: saveProperty(nfRF6_mul_psp "model" "nfettwpsp")
Executing: extractDevice("nfet33tw4" nfRFi_mul_MV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: extractDevice("nfet33tw4" nfRFi_mul_psp_MV (pc_model "G") (ndRF_comp_dr "D") ...
Executing: saveProperty(nfRFi_mul_MV "tw" 1)
Executing: saveProperty(nfRFi_mul_psp_MV "tw" 1)
Executing: saveProperty(nfRFi_mul_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfRF6_mul_MV (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: extractDevice("nfet33tw" nfRF6_mul_psp_MV (pc_model "G") (ndRF_comp_dr "D") (...
Executing: saveProperty(nfRF6_mul_psp_MV "model" "nfet33twpsp")
Executing: extractDevice("nfet33tw4" nfRFi_mul_HV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: extractDevice("nfet33tw4" nfRFi_mul_psp_HV (pc_model "G") (ndRF_comp_dr "D") ...
Executing: saveProperty(nfRFi_mul_HV "tw" 1)
Executing: saveProperty(nfRFi_mul_psp_HV "tw" 1)
Executing: saveProperty(nfRFi_mul_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet33tw" nfRF6_mul_HV (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: extractDevice("nfet33tw" nfRF6_mul_psp_HV (pc_model "G") (ndRF_comp_dr "D") (...
Executing: saveProperty(nfRF6_mul_psp_HV "model" "nfet33twpsp")
Executing: extractDevice("nfet50tw4" nfRFi_mul_TG (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: saveProperty(nfRFi_mul_TG "tw" 1)
Executing: extractDevice("nfet50tw" nfRF6_mul_TG (pc_model "G") (ndRF_comp_dr "D") (ndRF...
Executing: extractDevice("nfet" nfRF_mul (pc_model "G") (ndRF_comp_dr "D") (ndRF_comp_sc...
Executing: extractDevice("nfet" nfRF_mul_psp (pc_model "G") (ndRF_comp_dr "D") (ndRF_com...
Executing: saveProperty(nfRF_mul "stis" 2)
Executing: saveProperty(nfRF_mul_psp "stis" 2)
Executing: saveProperty(nfRF_mul_psp "model" "nfetpsp")
Executing: extractDevice("nfet33" nfRF_mul_MV (pc_model "G") (ndRF_comp_dr "D") (ndRF_co...
Executing: extractDevice("nfet33" nfRF_mul_psp_MV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: saveProperty(nfRF_mul_psp_MV "model" "nfet33psp")
Executing: extractDevice("nfet33" nfRF_mul_HV (pc_model "G") (ndRF_comp_dr "D") (ndRF_co...
Executing: extractDevice("nfet33" nfRF_mul_psp_HV (pc_model "G") (ndRF_comp_dr "D") (ndR...
Executing: saveProperty(nfRF_mul_psp_HV "model" "nfet33psp")
Executing: extractDevice("nfet50" nfRF_mul_TG (pc_model "G") (ndRF_comp_dr "D") (ndRF_co...
Executing: extractDevice("pfet" pfRF_mul (pc_model "G") (pdRF_comp_dr "D") (pdRF_comp_sc...
Executing: extractDevice("pfet" pfRF_mul_psp (pc_model "G") (pdRF_comp_dr "D") (pdRF_com...
Executing: saveProperty(pfRF_mul_psp "model" "pfetpsp")
Executing: extractDevice("pfet33" pfRF_mul_MV (pc_model "G") (pdRF_comp_dr "D") (pdRF_co...
Executing: extractDevice("pfet33" pfRF_mul_psp_MV (pc_model "G") (pdRF_comp_dr "D") (pdR...
Executing: saveProperty(pfRF_mul_psp_MV "model" "pfet33psp")
Executing: extractDevice("pfet33" pfRF_mul_HV (pc_model "G") (pdRF_comp_dr "D") (pdRF_co...
Executing: extractDevice("pfet33" pfRF_mul_psp_HV (pc_model "G") (pdRF_comp_dr "D") (pdR...
Executing: saveProperty(pfRF_mul_psp_HV "model" "pfet33psp")
Executing: extractDevice("pfet50" pfRF_mul_TG (pc_model "G") (pdRF_comp_dr "D") (pdRF_co...
Executing: extractDevice("p5pfet50" pfRF_mul_SCG (pc_model "G") (pdRF_comp_dr "D") (pdRF...
Executing: attachParameter(Area ("as" "S") ("ad" "D") dev_ID shared)
Executing: attachParameter(Perim ("ps" "S") ("pd" "D") dev_ID shared)
Executing: extractDevice("havar" hvr_dev (hvr_cath "C") (hvr_anod "A") (substrate "BULK"...
Executing: extractDevice("diffhavar" diffhavar_dev (hvr_cath "C") (hvr_anod "AA" "AB") (...
Executing: saveProperty(hvr_dev "m" 1)
Executing: saveProperty(hvr_dev "c" -1)
Executing: saveProperty(hvr_dev "blockParasiticsBetween" "PC sub")
Executing: hvr_anodes = measureParameter(figCount (hvr_dev enclosing hvr_anod))
Executing: nameParameter(hvr_anodes "nastripes")
Executing: hvr_anode_width = measureParameter(area (hvr_dev over rx_label) 1e-05)
Executing: nameParameter(hvr_anode_width "rxw")
Executing: hvr_anode_area = measureParameter(area (hvr_dev over var_rx not_over rn) 1e-12)
Executing: hvr_rxl = calculateParameter((hvr_anode_area / hvr_anode_width / hvr_anodes))
Executing: nameParameter(hvr_rxl "rxl")
Executing: hvr_M = measureParameter(figCount (hvr_dev enclosing hvr_mul))
Executing: hvr_mSwitch = calculateParameter((hvr_M + (hvr_anode_area - hvr_anode_area)))
Executing: nameParameter(hvr_mSwitch "mSwitch")
Executing: cap = calculateParameter(((ca0 * (hvr_anode_width + dw) * (hvr_rxl + dl) * hv...
Executing: nameParameter(cap "cap")
Executing: saveProperty(diffhavar_dev "m" 1)
Executing: dhvr_mul = geomOverlap(diffhavar_dev multi)
Executing: dhvr_xrep = measureParameter(figCount (diffhavar_dev enclosing width_label_dh...
Executing: nameParameter(dhvr_xrep "nf")
Executing: dhvr_a_nber = measureParameter(figCount (diffhavar_dev enclosing hvr_anod))
Executing: nameParameter(dhvr_a_nber "number_of_anodes")
Executing: dhvr_yrep = calculateParameter((dhvr_a_nber / dhvr_xrep))
Executing: nameParameter(dhvr_yrep "yrep")
Executing: dhvr_l_area = measureParameter(area (diffhavar_dev over width_label_dhvr))
Executing: dhvr_length = calculateParameter(((dhvr_l_area / 0.1 / dhvr_xrep) * 1e-06))
Executing: nameParameter(dhvr_length "w")
Executing: dhvr_w_area = measureParameter(area (diffhavar_dev over hvr_anod))
Executing: dhvr_width = calculateParameter(((dhvr_w_area / dhvr_a_nber / (dhvr_length * ...
Executing: nameParameter(dhvr_width "l")
Executing: dhvr_m = measureParameter(figCount (diffhavar_dev enclosing dhvr_mul))
Executing: dhvr_mSwitch = calculateParameter((dhvr_m + (dhvr_length - dhvr_length)))
Executing: nameParameter(dhvr_mSwitch "mSwitch")
Executing: saveProperty(diffhavar_dev "blockParasiticsBetween" "M1 sub")
Executing: extractDevice("sbd" SBD (SBD_C "C") (SBD_A "A") (substrate "BULK") flagMalfor...
Executing: extractDevice("sbdnw" SBDNW (SBDNW_C "C") (SBDNW_A "A") (substrate "BULK") fl...
Executing: extractDevice("psbd" PSBD (PSBD_C "C") (PSBD_A "A") (nfeti_bottom_iso "TW") f...
Executing: saveProperty(SBD "m" 1)
Executing: saveProperty(SBD "par" 1)
Executing: sbd_mul = geomOverlap(SBD multi)
Executing: sbd_anodes = measureParameter(figCount (SBD enclosing SBD_A))
Executing: nameParameter(sbd_anodes "nf")
Executing: sbd_rxw = measureParameter(area (SBD over width_label_sbd) 1e-05)
Executing: sbd_rxw_width = calculateParameter((sbd_rxw / sbd_anodes))
Executing: nameParameter(sbd_rxw_width "w")
Executing: sbd_an_area = measureParameter(area (SBD over SBD_A not_over pd) 1e-12)
Executing: sbd_rxl = calculateParameter((sbd_an_area / sbd_rxw))
Executing: nameParameter(sbd_rxl "l")
Executing: sbd_M = measureParameter(figCount (SBD enclosing sbd_mul))
Executing: sbd_mSwitch = calculateParameter((sbd_M + (sbd_rxw - sbd_rxw)))
Executing: nameParameter(sbd_mSwitch "mSwitch")
Executing: saveProperty(SBD "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(SBDNW "m" 1)
Executing: saveProperty(SBDNW "par" 1)
Executing: sbdnw_mul = geomOverlap(SBDNW multi)
Executing: sbdnw_anodes = measureParameter(figCount (SBDNW enclosing SBDNW_A))
Executing: nameParameter(sbdnw_anodes "nf")
Executing: sbdnw_rxw = measureParameter(area (SBDNW over width_label_sbdnw) 1e-05)
Executing: sbdnw_rxw_width = calculateParameter((sbdnw_rxw / sbdnw_anodes))
Executing: nameParameter(sbdnw_rxw_width "w")
Executing: sbdnw_an_area = measureParameter(area (SBDNW over SBDNW_A not_over pd) 1e-12)
Executing: sbdnw_rxl = calculateParameter((sbdnw_an_area / sbdnw_rxw))
Executing: nameParameter(sbdnw_rxl "l")
Executing: sbdnw_M = measureParameter(figCount (SBDNW enclosing sbdnw_mul))
Executing: sbdnw_mSwitch = calculateParameter((sbdnw_M + (sbdnw_rxw - sbdnw_rxw)))
Executing: nameParameter(sbdnw_mSwitch "mSwitch")
Executing: saveProperty(SBDNW "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(PSBD "m" 1)
Executing: saveProperty(PSBD "par" 1)
Executing: psbd_mul = geomOverlap(PSBD multi)
Executing: psbd_cath = measureParameter(figCount (PSBD enclosing PSBD_C))
Executing: nameParameter(psbd_cath "nf")
Executing: psbd_rxw = measureParameter(area (PSBD over width_label_psbd) 1e-05)
Executing: psbd_rxw_width = calculateParameter((psbd_rxw / psbd_cath))
Executing: nameParameter(psbd_rxw_width "w")
Executing: psbd_ca_area = measureParameter(area (PSBD over PSBD_C) 1e-12)
Executing: psbd_rxl = calculateParameter((psbd_ca_area / psbd_rxw))
Executing: nameParameter(psbd_rxl "l")
Executing: psbd_M = measureParameter(figCount (PSBD enclosing psbd_mul))
Executing: psbd_mSwitch = calculateParameter((psbd_M + (psbd_rxw - psbd_rxw)))
Executing: nameParameter(psbd_mSwitch "mSwitch")
Executing: saveProperty(PSBD "blockParasiticsBetween" "M1 sub")
Executing: extractDevice("dipdnw" DI_diode (DI_anode "PLUS") (DI_cathode "SUB") flagMalf...
Executing: extractDevice("dindpw" DIPI_diode (DIPI_iso_node "tw") (DIPI_anode "pw") (DIP...
Executing: extractDevice("divpnp" DI_VPNP (DI_coll "SUB") (DI_cathode "NW") (DI_anode "P...
Executing: saveProperty(DI_diode "blockParasiticsBetween" "PC sub")
Executing: di_mul = geomOverlap(DI_diode multi)
Executing: di_anodes = measureParameter(figCount (DI_diode enclosing DI_anode))
Executing: nameParameter(di_anodes "nf")
Executing: di_width = measureParameter(area (DI_diode over rx_label) 1e-05)
Executing: nameParameter(di_width "w")
Executing: di_area = measureParameter(area (DI_diode over DI_anode))
Executing: di_length = calculateParameter(((di_area * 1e-12) / di_anodes / di_width))
Executing: nameParameter(di_length "l")
Executing: di_M = measureParameter(figCount (DI_diode enclosing di_mul))
Executing: di_mSwitch = calculateParameter((di_M + (di_width - di_width)))
Executing: nameParameter(di_mSwitch "mSwitch")
Executing: saveProperty(DI_diode "m" 1)
Executing: saveProperty(DI_diode "par" 1)
Executing: dindpw_mul = geomOverlap(DIPI_diode multi)
Executing: dipi_num_cath = measureParameter(figCount (DIPI_diode enclosing DIPI_cathode))
Executing: nameParameter(dipi_num_cath "nf")
Executing: dipi_width = measureParameter(area (DIPI_diode over rx_label) 1e-05)
Executing: nameParameter(dipi_width "w")
Executing: dipi_area = measureParameter(area (DIPI_diode over DIPI_cathode))
Executing: dipi_length = calculateParameter(((dipi_area * 1e-12) / dipi_num_cath / dipi_...
Executing: nameParameter(dipi_length "l")
Executing: dindpw_M = measureParameter(figCount (DIPI_diode enclosing dindpw_mul))
Executing: dindpw_mSwitch = calculateParameter((dindpw_M + (dipi_width - dipi_width)))
Executing: nameParameter(dindpw_mSwitch "mSwitch")
Executing: saveProperty(DIPI_diode "m" 1)
Executing: saveProperty(DIPI_diode "par" 1)
Executing: saveProperty(DI_VPNP "blockParasiticsBetween" "PC sub")
Executing: divpnp_mul = geomOverlap(DI_VPNP multi)
Executing: vpnp_emitters = measureParameter(figCount (DI_VPNP enclosing DI_anode))
Executing: nameParameter(vpnp_emitters "nf")
Executing: vpnp_width = measureParameter(area (DI_VPNP over rx_label) 1e-05)
Executing: nameParameter(vpnp_width "w")
Executing: vpnp_area = measureParameter(area (DI_VPNP over DI_anode))
Executing: vpnp_length = calculateParameter(((vpnp_area * 1e-12) / vpnp_emitters / vpnp_...
Executing: nameParameter(vpnp_length "l")
Executing: divpnp_M = measureParameter(figCount (DI_VPNP enclosing divpnp_mul))
Executing: divpnp_mSwitch = calculateParameter((divpnp_M + (vpnp_width - vpnp_width)))
Executing: nameParameter(divpnp_mSwitch "mSwitch")
Executing: saveProperty(DI_VPNP "m" 1)
Executing: saveProperty(DI_VPNP "par" 1)
Executing: extractDevice("pcdcap" ncap_dev (ncap_pc "G") (ncap_rx "D") (substrate "B") f...
Executing: extractDevice("pcdcap33" ncap33_dev (ncap_pc "G") (ncap_rx "D") (substrate "B...
Executing: extractDevice("pcdcap50" ncap50_dev (ncap_pc "G") (ncap_rx "D") (substrate "B...
Executing: ncap_gate = measureParameter(figCount (dev_ID enclosing ncap_gates))
Executing: nameParameter(ncap_gate "gates")
Executing: ncap_length1 = measureParameter(area (dev_ID over ncap_pc_length) 5e-06)
Executing: ncap_width1 = measureParameter(area (dev_ID over ncap_rx_width) 5e-06)
Executing: ncap_length = calculateParameter((ncap_length1 / ncap_gate))
Executing: ncap_width = calculateParameter((ncap_width1 / ncap_gate))
Executing: nameParameter(ncap_length "l")
Executing: nameParameter(ncap_width "w")
Executing: ncap_M = measureParameter(figCount (dev_ID enclosing ncap_mul))
Executing: ncap_mSwitch = calculateParameter((ncap_M + (ncap_length - ncap_length)))
Executing: nameParameter(ncap_mSwitch "mSwitch")
Executing: extractDevice("diffmosvar" diffmosvar_dev (mosvar_pc "GA" "GB") (mosvar_rx "D...
Executing: extractDevice("mosvar" mosvar_dev (mosvar_pc "G") (mosvar_rx "D") (substrate ...
Executing: extractDevice("mosvar50" mosvar50_dev (mosvar_pc "G") (mosvar_rx "D") (substr...
Executing: extractDevice("p5pcdcap50" p5pcdcap50_dev (mosvar_pc "G") (mosvar_rx "D") (su...
Executing: extractDevice("pcap" pcap_dev (pcap_pc "G") (pcap_rx "D") (nfeti_bottom_iso "...
Executing: dmosvar_nf = measureParameter(figCount (dev_ID enclosing mosvar_gates))
Executing: nameParameter(dmosvar_nf "nf")
Executing: dmosvar_length1 = measureParameter(area (dev_ID over mosvar_pc_length) 5e-06)
Executing: dmosvar_width1 = measureParameter(area (dev_ID over mosvar_rx_width) 1e-05)
Executing: dmosvar_length = calculateParameter((dmosvar_length1 / dmosvar_nf))
Executing: dmosvar_width = calculateParameter((dmosvar_width1 / dmosvar_nf))
Executing: nameParameter(dmosvar_length "l")
Executing: nameParameter(dmosvar_width "w")
Executing: dmos_M = measureParameter(figCount (dev_ID enclosing mosvar_mul))
Executing: dmos_mSwitch = calculateParameter((dmos_M + (dmosvar_length - dmosvar_length)))
Executing: nameParameter(dmos_mSwitch "mSwitch")
Executing: mosvar_gate = measureParameter(figCount (dev_ID enclosing mosvar_gates))
Executing: nameParameter(mosvar_gate "gates")
Executing: mosvar_length1 = measureParameter(area (dev_ID over mosvar_pc_length) 5e-06)
Executing: mosvar_width1 = measureParameter(area (dev_ID over mosvar_rx_width) 1e-05)
Executing: mosvar_length = calculateParameter((mosvar_length1 / mosvar_gate))
Executing: mosvar_width = calculateParameter((mosvar_width1 / mosvar_gate))
Executing: nameParameter(mosvar_length "l")
Executing: nameParameter(mosvar_width "w")
Executing: mosvar_yrep = measureParameter(figCount (dev_ID enclosing mosvar_RX))
Executing: nameParameter(mosvar_yrep "yrep")
Executing: mosvar_xrep = calculateParameter((mosvar_gate / mosvar_yrep))
Executing: nameParameter(mosvar_xrep "xrep")
Executing: mos_M = measureParameter(figCount (dev_ID enclosing mosvar_mul))
Executing: mos_mSwitch = calculateParameter((mos_M + (mosvar_length - mosvar_length)))
Executing: nameParameter(mos_mSwitch "mSwitch")
Executing: pcap_gate = measureParameter(figCount (dev_ID enclosing pcap_gates))
Executing: nameParameter(pcap_gate "gates")
Executing: pcap_length1 = measureParameter(area (dev_ID over pcap_pc_length) 1e-05)
Executing: pcap_width1 = measureParameter(area (dev_ID over pcap_rx_width) 1e-05)
Executing: pcap_length = calculateParameter((pcap_length1 / pcap_gate))
Executing: pcap_width = calculateParameter((pcap_width1 / pcap_gate))
Executing: nameParameter(pcap_length "l")
Executing: nameParameter(pcap_width "w")
Executing: pcap_yrep = measureParameter(figCount (dev_ID enclosing pcap_pdiff))
Executing: nameParameter(pcap_yrep "yrep")
Executing: pcap_xrep = calculateParameter((pcap_gate / pcap_yrep))
Executing: nameParameter(pcap_xrep "xrep")
Executing: mos_M = measureParameter(figCount (dev_ID enclosing pcap_mul))
Executing: mos_mSwitch = calculateParameter((mos_M + (pcap_length - pcap_length)))
Executing: vlnpn_c_good = geomNodeRelate(nfeti_bottom_iso vlnpn_c conn)
Executing: vlnpn_c_bad = geomAndNot(vlnpn_c vlnpn_c_good)
errorLayer(vlnpn_c_bad "vlnpn collector not connected to nw_ring")
Executing: extractDevice("vlnpn" vlnpn_dev (vlnpn_c "C") (vlnpn_e "E") (vlnpn_g "G") (pw...
Executing: vlnpn_mul = geomOverlap(vlnpn_dev multi)
Executing: nf = measureParameter(figCount (dev_ID enclosing vlnpn_e))
Executing: nameParameter(nf "nstripes")
Executing: vlnpn_width = measureParameter(area (dev_ID over vlnpn_exl) 5e-06)
Executing: exl = calculateParameter((vlnpn_width / nf))
Executing: vlnpn_a = measureParameter(area (dev_ID over vlnpn_area) 5e-13)
Executing: exw = calculateParameter((vlnpn_a / exl / nf))
Executing: nameParameter(exw "exw")
Executing: nameParameter(exl "exl")
Executing: nc = measureParameter(figCount (dev_ID enclosing DP))
Executing: gcon = calculateParameter((nc + 1.0 + (nf - nf)))
Executing: vlnpn_m = measureParameter(figCount (vlnpn_dev enclosing vlnpn_mul))
Executing: vlnpn_mSw = calculateParameter((vlnpn_m + (nf - nf)))
Executing: nameParameter(vlnpn_mSw "mSwitch")
Executing: saveProperty(dev_ID "blockParasiticsBetween" "M1 sub")
Executing: extractDevice("jfetjc" jfet_dev (jfet_drain "D") (jfet_source "S") (jfet_gate...
Executing: jfet_mul = geomOverlap(jfet_dev multi)
Executing: ax = measureParameter(area (dev_ID over jfet_sd) 1e-12)
Executing: lsd = measureParameter(area (dev_ID over width_label_jfet_sd) 1e-05)
Executing: width = calculateParameter((ax / lsd))
Executing: lx = measureParameter(length (dev_ID coincident jfet_G) 5e-07)
Executing: nf = measureParameter(figCount (dev_ID enclosing jfet_G))
Executing: wt = calculateParameter((width * nf))
Executing: nameParameter(wt "wt")
Executing: jfet_m = measureParameter(figCount (jfet_dev enclosing jfet_mul))
Executing: jfet_mSwitch = calculateParameter((jfet_m + (length - length)))
Executing: nameParameter(jfet_mSwitch "mSwitch")
Executing: extractDevice("rr_serpentine" res_serpentine (res6pc_term "D" "S") (substrate...
Executing: extractDevice("rr_serpentine" resnw_serpentine (res6pc_term "D" "S") (nw "G")...
Executing: corners = geomGetCorner(dev_ID angleMulti90 convex)
Executing: resHV7_edges = geomAvoiding(geomSize(geomGetEdge(dev_ID inside op) -0.01) cor...
Executing: op_filter = geomAndNot(op geomSize(pd 0.28))
Executing: rr_width = measureParameter(length (dev_ID coincident op) 5e-07)
Executing: corner_number = measureParameter(figCount (dev_ID enclosing corners))
Executing: stripes = calculateParameter((((corner_number - 4.0) / 2.0) + 1.0))
Executing: resHV7_length = measureParameter(length (dev_ID coincident resHV7_edges) 1e-06)
Executing: resHV7 = calculateParameter((resHV7_length / (stripes - 1.0)))
Executing: rr_area = measureParameter(area (dev_ID over op_filter) 1e-12)
Executing: corr_factor = calculateParameter((resHV7 * rr_width * (stripes - 1.0)))
Executing: rr_length = calculateParameter(((rr_area - corr_factor) / stripes / rr_width))
Executing: rr_L = calculateParameter((rr_length * 1000000.0))
Executing: rr_W = calculateParameter(((rr_width * 1000000.0) + dw))
Executing: res_r = calculateParameter((((rs * (((rr_L - (2.0 * rr_W)) * stripes) + (2 * ...
Executing: res_M = measureParameter(figCount (dev_ID enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (rr_width - rr_width)))
Executing: nameParameter(rr_width "w")
Executing: nameParameter(stripes "n")
Executing: nameParameter(rr_length "l")
Executing: nameParameter(res_r "r")
Executing: nameParameter(res_r "reff")
Executing: nameParameter(res_mSwitch "mSwitch")
Executing: saveProperty(dev_ID "s" 1)
Executing: saveProperty(dev_ID "pbar" 1)
Executing: serp_bb = measureParameter(figCount (res_serpentine enclosing resbb_serpentin...
Executing: serp_sub = measureParameter(figCount (res_serpentine enclosing ressub_serpent...
Executing: serp_bp = calculateParameter((serp_bb + serp_sub))
Executing: nameParameter(serp_bp "bp")
Executing: rsx_num = measureParameter(length (dev_ID coincident rsx_FE) 100.0)
Executing: rsx_perim = measureParameter(perimeter (dev_ID over rsx_FE) 100.0)
Executing: rsx_exp = calculateParameter(((rsx_perim - 20 - (2 * (rsx_num - 5))) / 2.0))
Executing: rsx_value = calculateParameter(((rsx_num - 5) * (power 10 rsx_exp)))
Executing: nameParameter(rsx_value "rsx")
Executing: saveProperty(resnw_serpentine "bp" 1)
Executing: extractDevice("opppcres" rnw6pc_dev (res6pc_term "D" "S") (nw "G") physical f...
Executing: res6pc_dev_pwell = extractDevice("opppcres" res6pc_dev (res6pc_term "D" "S") ...
res6pc_dev_subs = extractDevice("opppcres" res6pc_dev (res6pc_term "D" "S") (...
Executing: extractDevice("oprrpres" rnw6rr_dev (res6pc_term "D" "S") (nw "G") physical f...
Executing: res6rr_dev_pwell = extractDevice("oprrpres" res6rr_dev (res6pc_term "D" "S") ...
res6rr_dev_subs = extractDevice("oprrpres" res6rr_dev (res6pc_term "D" "S") (...
Executing: extractDevice("oprppres" rnw6rp_dev (res6pc_term "D" "S") (nw "G") physical f...
Executing: res6rp_dev_pwell = extractDevice("oprppres" res6rp_dev (res6pc_term "D" "S") ...
res6rp_dev_subs = extractDevice("oprppres" res6rp_dev (res6pc_term "D" "S") (...
Executing: saveProperty(rnw6pc_dev "m" 1)
Executing: saveProperty(rnw6pc_dev "par" 1)
Executing: saveProperty(rnw6pc_dev "s" 1)
Executing: saveProperty(rnw6pc_dev "pbar" 1)
Executing: saveProperty(rnw6pc_dev "bp" 1)
Executing: rnw6pc_width = measureParameter(length (rnw6pc_dev coincident op) 5e-07)
Executing: nameParameter(rnw6pc_width "w")
Executing: rnw6pc_bb = calculateParameter((rnw6pc_width - rnw6pc_width))
Executing: nameParameter(rnw6pc_bb "bb")
Executing: rnw6pc_length = measureParameter(length (rnw6pc_dev coincident res6pc_bar) 5e...
Executing: nameParameter(rnw6pc_length "l")
Executing: rnw6pc_res = calculateParameter((((2.0 * rend) + (rs * ((rnw6pc_length * 1000...
Executing: nameParameter(rnw6pc_res "r")
Executing: nameParameter(rnw6pc_res "reff")
Executing: res_M = measureParameter(figCount (rnw6pc_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (rnw6pc_length - rnw6pc_length)))
Executing: saveProperty(rnw6pc_dev "blockParasiticsBetween" "M1 sub")
Executing: res6pc_bb1 = measureParameter(figCount (res6pc_dev enclosing resistor_bb))
Executing: res6pc_bb2 = measureParameter(figCount (res6pc_dev enclosing resistor_op))
Executing: res6pc_bb = calculateParameter(((res6pc_bb2 * 3.0) - res6pc_bb1))
Executing: nameParameter(res6pc_bb "bp")
Executing: saveProperty(res6pc_dev "m" 1)
Executing: saveProperty(res6pc_dev "par" 1)
Executing: saveProperty(res6pc_dev "s" 1)
Executing: saveProperty(res6pc_dev "pbar" 1)
Executing: res6pc_width = measureParameter(length (res6pc_dev coincident op) 5e-07)
Executing: nameParameter(res6pc_width "w")
Executing: res6pc_length = measureParameter(length (res6pc_dev coincident res6pc_bar) 5e...
Executing: nameParameter(res6pc_length "l")
Executing: res6pc_res = calculateParameter((((2.0 * rend) + (rs * ((res6pc_length * 1000...
Executing: nameParameter(res6pc_res "r")
Executing: nameParameter(res6pc_res "reff")
Executing: res_M = measureParameter(figCount (res6pc_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (res6pc_length - res6pc_length)))
Executing: saveProperty(res6pc_dev "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(rnw6rr_dev "m" 1)
Executing: saveProperty(rnw6rr_dev "par" 1)
Executing: saveProperty(rnw6rr_dev "s" 1)
Executing: saveProperty(rnw6rr_dev "pbar" 1)
Executing: saveProperty(rnw6rr_dev "bp" 1)
Executing: rnw6rr_width = measureParameter(length (rnw6rr_dev coincident op) 5e-07)
Executing: nameParameter(rnw6rr_width "w")
Executing: rnw6rr_bb = calculateParameter((rnw6rr_width - rnw6rr_width))
Executing: nameParameter(rnw6rr_bb "bb")
Executing: rnw6rr_length = measureParameter(length (rnw6rr_dev coincident res6pc_bar) 5e...
Executing: nameParameter(rnw6rr_length "l")
Executing: rnw6rr_res = calculateParameter((((2.0 * rend) + (2.0 * rbn * lbn) + (rs * ((...
Executing: nameParameter(rnw6rr_res "r")
Executing: nameParameter(rnw6rr_res "reff")
Executing: res_M = measureParameter(figCount (rnw6rr_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (rnw6rr_length - rnw6rr_length)))
Executing: saveProperty(rnw6rr_dev "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(res6rr_dev "m" 1)
Executing: saveProperty(res6rr_dev "par" 1)
Executing: saveProperty(res6rr_dev "s" 1)
Executing: saveProperty(res6rr_dev "pbar" 1)
Executing: res6rr_width = measureParameter(length (res6rr_dev coincident op) 5e-07)
Executing: nameParameter(res6rr_width "w")
Executing: res6rr_length = measureParameter(length (res6rr_dev coincident res6pc_bar) 5e...
Executing: nameParameter(res6rr_length "l")
Executing: res6rr_res = calculateParameter((((2.0 * rend) + (2.0 * rbn * lbn) + (rs * ((...
Executing: nameParameter(res6rr_res "r")
Executing: nameParameter(res6rr_res "reff")
Executing: res_M = measureParameter(figCount (res6rr_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (res6rr_length - res6rr_length)))
Executing: res6rr_bb1 = measureParameter(figCount (res6rr_dev enclosing resistor_bb))
Executing: res6rr_bb2 = measureParameter(figCount (res6rr_dev enclosing resistor_op))
Executing: res6rr_bb = calculateParameter(((res6rr_bb2 * 3.0) - res6rr_bb1))
Executing: nameParameter(res6rr_bb "bp")
Executing: saveProperty(res6rr_dev "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(rnw6rp_dev "m" 1)
Executing: saveProperty(rnw6rp_dev "par" 1)
Executing: saveProperty(rnw6rp_dev "s" 1)
Executing: saveProperty(rnw6rp_dev "pbar" 1)
Executing: saveProperty(rnw6rp_dev "bp" 1)
Executing: rnw6rp_width = measureParameter(length (rnw6rp_dev coincident op) 5e-07)
Executing: nameParameter(rnw6rp_width "w")
Executing: rnw6rp_bb = calculateParameter((rnw6rp_width - rnw6rp_width))
Executing: nameParameter(rnw6rp_bb "bb")
Executing: rnw6rp_length = measureParameter(length (rnw6rp_dev coincident res6pc_bar) 5e...
Executing: nameParameter(rnw6rp_length "l")
Executing: rnw6rp_res = calculateParameter((((2.0 * rend) + (rs * ((rnw6rp_length * 1000...
Executing: nameParameter(rnw6rp_res "r")
Executing: nameParameter(rnw6rp_res "reff")
Executing: res_M = measureParameter(figCount (rnw6rp_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (rnw6rp_length - rnw6rp_length)))
Executing: saveProperty(rnw6rp_dev "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(res6rp_dev "m" 1)
Executing: saveProperty(res6rp_dev "par" 1)
Executing: saveProperty(res6rp_dev "s" 1)
Executing: saveProperty(res6rp_dev "pbar" 1)
Executing: res6rp_width = measureParameter(length (res6rp_dev coincident op) 5e-07)
Executing: nameParameter(res6rp_width "w")
Executing: res6rp_length = measureParameter(length (res6rp_dev coincident res6pc_bar) 5e...
Executing: nameParameter(res6rp_length "l")
Executing: res6rp_res = calculateParameter((((2.0 * rend) + (rs * ((res6rp_length * 1000...
Executing: nameParameter(res6rp_res "r")
Executing: nameParameter(res6rp_res "reff")
Executing: res_M = measureParameter(figCount (res6rp_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (res6rp_length - res6rp_length)))
Executing: res6rp_bb1 = measureParameter(figCount (res6rp_dev enclosing resistor_bb))
Executing: res6rp_bb2 = measureParameter(figCount (res6rp_dev enclosing resistor_op))
Executing: res6rp_bb = calculateParameter(((res6rp_bb2 * 3.0) - res6rp_bb1))
Executing: nameParameter(res6rp_bb "bp")
Executing: saveProperty(res6rp_dev "blockParasiticsBetween" "M1 sub")
Executing: res6n_dev_pwell = extractDevice("opndres" res6n_dev (res6n_term "D" "S") (pwe...
res6n_dev_subs = extractDevice("opndres" res6n_dev (res6n_term "D" "S") (subs...
Executing: extractDevice("oppdres" res6p_dev (res6p_term "D" "S") (nw "G") physical flag...
Executing: res6n_sblk_pwell = extractDevice("sblkndres" res6n_sblk (nfet_sd "S" "D") (pw...
res6n_sblk_subs = extractDevice("sblkndres" res6n_sblk (nfet_sd "S" "D") (sub...
Executing: extractDevice("sblkpdres" res6p_sblk (pfet_sd "S" "D") (nw "G") physical flag...
Executing: saveProperty(res6p_dev "m" 1)
Executing: saveProperty(res6p_dev "par" 1)
Executing: saveProperty(res6p_dev "s" 1)
Executing: saveProperty(res6p_dev "pbar" 1)
Executing: res6p_width = measureParameter(length (res6p_dev coincident op) 5e-07)
Executing: nameParameter(res6p_width "w")
Executing: res6p_length = measureParameter(length (res6p_dev coincident res6p_bar) 5e-07)
Executing: nameParameter(res6p_length "l")
Executing: res6p_res = calculateParameter((((2.0 * rend) + (rs * ((res6p_length * 100000...
Executing: nameParameter(res6p_res "r")
Executing: nameParameter(res6p_res "reff")
Executing: res_M = measureParameter(figCount (res6p_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (res6p_length - res6p_length)))
Executing: saveProperty(res6p_dev "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(res6p_sblk "m" 1)
Executing: saveProperty(res6p_sblk "s" 1)
Executing: saveProperty(res6p_sblk "pbar" 1)
Executing: sblk_M = geomOverlap(res6p_sblk multi)
Executing: res6p_width = measureParameter(length (res6p_sblk coincident sblk) 5e-07)
Executing: res6p_length = measureParameter(length (res6p_sblk coincident res6p_bar) 5e-07)
Executing: res6p_res = calculateParameter((((1.0 * rend) + (rs * ((res6p_length * 100000...
Executing: res_M = measureParameter(figCount (res6p_sblk enclosing sblk_M))
Executing: saveProperty(res6p_sblk "blockParasiticsBetween" "M1 sub")
Executing: saveProperty(res6n_dev "m" 1)
Executing: saveProperty(res6n_dev "par" 1)
Executing: saveProperty(res6n_dev "s" 1)
Executing: saveProperty(res6n_dev "pbar" 1)
Executing: res6n_width = measureParameter(length (res6n_dev coincident op) 5e-07)
Executing: nameParameter(res6n_width "w")
Executing: res6n_length = measureParameter(length (res6n_dev coincident res6n_bar) 5e-07)
Executing: nameParameter(res6n_length "l")
Executing: res6n_res = calculateParameter((((2.0 * rend) + (rs * ((res6n_length * 100000...
Executing: nameParameter(res6n_res "r")
Executing: nameParameter(res6n_res "reff")
Executing: res_M = measureParameter(figCount (res6n_dev enclosing resistor_m))
Executing: res_mSwitch = calculateParameter((res_M + (res6n_length - res6n_length)))
Executing: saveProperty(res6n_dev "blockParasiticsBetween" "M1 sub")
Executing: sblk_plus = geomAnd(res6n_sblk sblk_over_pc)
Executing: saveProperty(res6n_sblk "m" 1)
Executing: saveProperty(res6n_sblk "s" 1)
Executing: saveProperty(res6n_sblk "pbar" 1)
Executing: sblk_M = geomOverlap(res6n_sblk multi)
Executing: res6n_width = measureParameter(length (res6n_sblk coincident sblk) 5e-07)
Executing: length_plus = measureParameter(figCount (res6n_sblk enclosing sblk_plus) 1e-08)
Executing: res6n_length = measureParameter(length (res6n_sblk coincident res6n_bar) 5e-07)
Executing: length_sblk = calculateParameter((res6n_length + length_plus))
Executing: nameParameter(length_sblk "l")
Executing: res6n_res = calculateParameter((((1.0 * rend) + (rs * ((res6n_length * 100000...
Executing: res_M = measureParameter(figCount (res6n_sblk enclosing sblk_M))
Executing: saveProperty(res6n_sblk "blockParasiticsBetween" "M1 sub")
Executing: extractDevice("k1res" k1_dev_bb (k1_term "D" "S") (substrate "G") physical fl...
Executing: k1_dev_sx_pwell = extractDevice("k1res" k1_dev_sx (k1_term "D" "S") (pwell "G...
k1_dev_sx_subs = extractDevice("k1res" k1_dev_sx (k1_term "D" "S") (substrate...
Executing: saveProperty(k1_dev_bb "pbar" 1)
Executing: saveProperty(k1_dev_bb "s" 1)
Executing: saveProperty(k1_dev_bb "m" 1)
Executing: saveProperty(k1_dev_bb "par" 1)
Executing: k1_multi = geomOverlap(k1_dev_bb multi)
Executing: resk1_width = measureParameter(length (k1_dev_bb butting k1_term) 5e-07)
Executing: nameParameter(resk1_width "w")
Executing: resk1_length = measureParameter(length (k1_dev_bb coincident k1) 5e-07)
Executing: nameParameter(resk1_length "l")
Executing: resk1_R = calculateParameter((((rho * ((resk1_length * 1000000.0) + dl)) + (r...
Executing: nameParameter(resk1_R "r")
Executing: nameParameter(resk1_R "reff")
Executing: res_M = measureParameter(figCount (k1_dev_bb enclosing k1_multi))
Executing: res_mSwitch = calculateParameter((res_M + (resk1_length - resk1_length)))
Executing: saveProperty(k1_dev_sx "pbar" 1)
Executing: saveProperty(k1_dev_sx "s" 1)
Executing: saveProperty(k1_dev_sx "m" 1)
Executing: saveProperty(k1_dev_sx "par" 1)
Executing: k1_multi = geomOverlap(k1_dev_sx multi)
Executing: resk1_width = measureParameter(length (k1_dev_sx butting k1_term) 5e-07)
Executing: resk1_length = measureParameter(length (k1_dev_sx coincident k1) 5e-07)
Executing: res_M = measureParameter(figCount (k1_dev_sx enclosing k1_multi))
Executing: extractDevice("esdnsh_base" esdnsh_dev (esdnsh_drain "de") (pc_model "ge") (e...
Executing: extractDevice("esdpsh_base" esdpsh_dev (esdpsh_drain "de") (pc_model "ge") (e...
Executing: sblk_plus = geomAnd(dev_ID sblk_over_pc)
Executing: op_drain = geomAnd(geomButtOnly(sblk esdnpsh_drain) dev_ID)
Executing: op_source = geomAnd(geomButtOnly(sblk esdnpsh_source) dev_ID)
Executing: esdnsh_gate_area = measureParameter(area (dev_ID over esdnpsh_gate) 1e-12)
Executing: pc_length_size = measureParameter(length (dev_ID coincident esdnpsh_gate) 5e-07)
Executing: pc_length = calculateParameter((pc_length_size * 1.0))
Executing: pc_width = calculateParameter((esdnsh_gate_area / pc_length))
Executing: nf = measureParameter(figCount (dev_ID enclosing esdnpsh_gate))
Executing: length_plus = measureParameter(figCount (dev_ID enclosing sblk_plus) 1e-08)
Executing: op_drain_measure = measureParameter(length (dev_ID coincident op_drain) 1e-06)
Executing: op_drain_length = calculateParameter((((op_drain_measure - pc_width) / 2) + l...
Executing: op_source_measure = measureParameter(length (dev_ID coincident op_source) 1e-06)
Executing: op_source_length = calculateParameter((((op_source_measure - pc_width) / 2) +...
Executing: esdnpsh_50 = measureParameter(figCount (dev_ID enclosing esdnpsh_base50) 4.0)
Executing: esdnpsh_33 = measureParameter(figCount (dev_ID enclosing esdnpsh_base33) 3.0)
Executing: esdnpsh_25 = measureParameter(figCount (dev_ID enclosing esdnpsh_base25) 2.0)
Executing: esdnpsh_18 = measureParameter(figCount (dev_ID enclosing esdnpsh_base) 1.0)
Executing: esdnpsh_oxide = calculateParameter((esdnpsh_18 + esdnpsh_25 + esdnpsh_33 + es...
Executing: esdnpsh_gns = measureParameter(figCount (dev_ID enclosing sblk_plus))
Executing: gns_parm = calculateParameter((esdnpsh_gns + (nf - nf)))
Executing: rect_area = measureParameter(area (dev_ID over ESDNSH_wtesd) 1e-12)
Executing: number_of_devs = calculateParameter((rect_area / (1e-08 * 1e-08)))
Executing: total_w = calculateParameter((number_of_devs * pc_width))
Executing: nameParameter(pc_length "lesd")
Executing: nameParameter(pc_width "wesd")
Executing: nameParameter(total_w "wtesd")
Executing: nameParameter(op_drain_length "ldop")
Executing: nameParameter(op_source_length "lsop")
Executing: nameParameter(esdnpsh_oxide "esdoxide")
Executing: nameParameter(gns_parm "gns")
Executing: extractDevice("subc" sub_dev (sub_diff_top "SUBCON") (substrate "sub") flagMa...
1 'subc' created in cell 'Inverter layout Project'.
Executing: extractDevice("tdndsx" ntie_device (ntie_top "MINUS") (pwell "PLUS") flagMalf...
extractDevice("tdndsx" ntie_device (ntie_top "MINUS") (substrate "PLUS") flag...
Executing: extractDevice("tdpdnw" ptie_device (ptie_top "PLUS") (nw "MINUS") flagMalform...
Executing: subc_area = measureParameter(area (sub_dev) 1e-12)
Executing: nameParameter(subc_area "a")
Executing: subc_perimeter = measureParameter(perimeter (sub_dev) 1e-06)
Executing: nameParameter(subc_perimeter "p")
Executing: subc_area_4 = calculateParameter((subc_area * 4.0))
Executing: subc_perim_2 = calculateParameter((subc_perimeter / 2.0))
Executing: subc_length = calculateParameter(((subc_perim_2 + sqrt(abs(((subc_perim_2 * s...
Executing: nameParameter(subc_length "l")
Executing: subc_width = calculateParameter(((subc_perim_2 - sqrt(abs(((subc_perim_2 * su...
Executing: nameParameter(subc_width "w")
Executing: area = measureParameter(area (ntie_device) 1e-12)
Executing: nameParameter(area "area")
Executing: perimeter = measureParameter(perimeter (ntie_device) 1e-06)
Executing: nameParameter(perimeter "perim")
Executing: area = measureParameter(area (ptie_device) 1e-12)
Executing: perimeter = measureParameter(perimeter (ptie_device) 1e-06)
Executing: extractDevice("corrPoint" corrPoint_dev_M2 (corrPoint_term_M2 "cp") flagMalfo...
Executing: extractDevice("corrPoint" corrPoint_dev_PD (corrPoint_term_PD "cp") flagMalfo...
Executing: extractDevice("corrPoint" corrPoint_dev_ND (corrPoint_term_ND "cp") flagMalfo...
Executing: extractDevice("corrPoint" corrPoint_dev_PC (corrPoint_term_PC "cp") flagMalfo...
Executing: extractDevice("corrPoint" corrPoint_dev_M1 (corrPoint_term_M1 "cp") flagMalfo...
Executing: extractDevice("esdvpnpnw" ESD_pdnw_diode (ESD_pdnw_plus "pd") (ESD_pdnw_minus...
Executing: extractDevice("esdvpnpnw" ESD_pdnw_diode_GR_sized (ESD_pdnw_plus "pd") (ESD_p...
Executing: extractDevice("esdvpnpnw" ESD_pdnw_diode_GR (ESD_pdnw_plus "pd") (ESD_pdnw_mi...
Executing: extractDevice("esdndsx" ESD_ndsx (ESD_ndsx_plus_term "sx") (ESD_ndsx_minus "n...
Executing: extractDevice("esdndsx" ESD_ndsx_GR_sized (ESD_ndsx_plus_term "sx") (ESD_ndsx...
Executing: extractDevice("esdndsx" ESD_ndsx_GR (ESD_ndsx_plus_term "sx") (ESD_ndsx_minus...
Executing: extractDevice("esdpnpi" ESD_pdnw_pi (ESD_pdnw_plus "pd") (ESD_pdnw_minus_term...
Executing: extractDevice("esdndpi" ESD_ndsx_pi (ESD_ndsx_plus_term "pw") (ESD_ndsx_minus...
Executing: pdnw_NS = geomOverlap(ESD_pdnw_diode ESD_ns)
Executing: pdnw_fingers = measureParameter(figCount (ESD_pdnw_diode enclosing ESD_pdnw_p...
Executing: nameParameter(pdnw_fingers "nanod")
Executing: pdnw_perim = measureParameter(perimeter (ESD_pdnw_diode over ESD_pdnw_plus) 1...
Executing: nameParameter(pdnw_perim "perim")
Executing: pdnw_area = measureParameter(area (ESD_pdnw_diode over ESD_pdnw_plus) 1e-12)
Executing: nameParameter(pdnw_area "area")
Executing: pdnw_ns = measureParameter(figCount (ESD_pdnw_diode enclosing pdnw_NS))
Executing: pdnw_NS = calculateParameter(((pdnw_fingers - pdnw_fingers) + pdnw_ns))
Executing: nameParameter(pdnw_NS "ns")
Executing: saveProperty(ESD_pdnw_diode "blockParasiticsBetween" "M1 sub")
Executing: pdnw_NS = geomOverlap(ESD_pdnw_diode_GR_sized ESD_ns)
Executing: pdnw_fingers = measureParameter(figCount (ESD_pdnw_diode_GR_sized enclosing E...
Executing: pdnw_perim = measureParameter(perimeter (ESD_pdnw_diode_GR_sized over ESD_pdn...
Executing: pdnw_area = measureParameter(area (ESD_pdnw_diode_GR_sized over ESD_pdnw_plus...
Executing: pdnw_ns = measureParameter(figCount (ESD_pdnw_diode_GR_sized enclosing pdnw_NS))
Executing: saveProperty(ESD_pdnw_diode_GR_sized "blockParasiticsBetween" "M1 sub")
Executing: pdnw_NS = geomOverlap(ESD_pdnw_diode_GR ESD_ns)
Executing: pdnw_fingers = measureParameter(figCount (ESD_pdnw_diode_GR enclosing ESD_pdn...
Executing: pdnw_perim = measureParameter(perimeter (ESD_pdnw_diode_GR over ESD_pdnw_plus...
Executing: pdnw_area = measureParameter(area (ESD_pdnw_diode_GR over ESD_pdnw_plus) 1e-12)
Executing: pdnw_ns = measureParameter(figCount (ESD_pdnw_diode_GR enclosing pdnw_NS))
Executing: saveProperty(ESD_pdnw_diode_GR "blockParasiticsBetween" "M1 sub")
Executing: ndsx_NW = geomOverlap(ESD_ndsx ESD_nw)
Executing: ndsx_fingers = measureParameter(figCount (ESD_ndsx enclosing ESD_ndsx_minus))
Executing: nameParameter(ndsx_fingers "ncath")
Executing: ndsx_perim = measureParameter(perimeter (ESD_ndsx over ESD_ndsx_minus) 1e-06)
Executing: nameParameter(ndsx_perim "perim")
Executing: ndsx_area = measureParameter(area (ESD_ndsx over ESD_ndsx_minus) 1e-12)
Executing: nameParameter(ndsx_area "area")
Executing: ndsx_nw = measureParameter(figCount (ESD_ndsx enclosing ndsx_NW))
Executing: ndsx_NW = calculateParameter(((ndsx_fingers - ndsx_fingers) + ndsx_nw))
Executing: nameParameter(ndsx_NW "nw")
Executing: saveProperty(ESD_ndsx "blockParasiticsBetween" "M1 sub")
Executing: ndsx_NW = geomOverlap(ESD_ndsx_GR_sized ESD_nw)
Executing: ndsx_fingers = measureParameter(figCount (ESD_ndsx_GR_sized enclosing ESD_nds...
Executing: ndsx_perim = measureParameter(perimeter (ESD_ndsx_GR_sized over ESD_ndsx_minu...
Executing: ndsx_area = measureParameter(area (ESD_ndsx_GR_sized over ESD_ndsx_minus) 1e-12)
Executing: ndsx_nw = measureParameter(figCount (ESD_ndsx_GR_sized enclosing ndsx_NW))
Executing: saveProperty(ESD_ndsx_GR_sized "blockParasiticsBetween" "M1 sub")
Executing: ndsx_NW = geomOverlap(ESD_ndsx_GR ESD_nw)
Executing: ndsx_fingers = measureParameter(figCount (ESD_ndsx_GR enclosing ESD_ndsx_minus))
Executing: ndsx_perim = measureParameter(perimeter (ESD_ndsx_GR over ESD_ndsx_minus) 1e-06)
Executing: ndsx_area = measureParameter(area (ESD_ndsx_GR over ESD_ndsx_minus) 1e-12)
Executing: ndsx_nw = measureParameter(figCount (ESD_ndsx_GR enclosing ndsx_NW))
Executing: saveProperty(ESD_ndsx_GR "blockParasiticsBetween" "M1 sub")
Executing: pdnw_fingers = measureParameter(figCount (ESD_pdnw_pi enclosing ESD_pdnw_plus))
Executing: pdnw_perim = measureParameter(perimeter (ESD_pdnw_pi over ESD_pdnw_plus) 1e-06)
Executing: pdnw_area = measureParameter(area (ESD_pdnw_pi over ESD_pdnw_plus) 1e-12)
Executing: saveProperty(ESD_pdnw_pi "blockParasiticsBetween" "M1 sub")
Executing: ndsx_fingers = measureParameter(figCount (ESD_ndsx_pi enclosing ESD_ndsx_minus))
Executing: ndsx_perim = measureParameter(perimeter (ESD_ndsx_pi over ESD_ndsx_minus) 1e-06)
Executing: ndsx_area = measureParameter(area (ESD_ndsx_pi over ESD_ndsx_minus) 1e-12)
Executing: saveProperty(ESD_ndsx_pi "blockParasiticsBetween" "M1 sub")
Executing: extractDevice("mim" MIMpi (mim_top "D") (mim_bot "S") (pwell "G") flagMalform...
Executing: extractDevice("mim" MIMnw (mim_top "D") (mim_bot "S") (nw "G") flagMalformed ...
Executing: extractDevice("mim" MIMsx (mim_top "D") (mim_bot "S") (substrate "G") flagMal...
Executing: extractDevice("mimhd" MIMhdpi (mim_top "D") (mim_bot "S") (pwell "G") flagMal...
Executing: extractDevice("mimhd" MIMhdnw (mim_top "D") (mim_bot "S") (nw "G") flagMalfor...
Executing: extractDevice("mimhd" MIMhdsx (mim_top "D") (mim_bot "S") (substrate "G") fla...
Executing: mim_hds = geomAnd(dev_ID mimhd)
Executing: mim_multi = geomAnd(dev_ID multi_MIM)
Executing: saveProperty(dev_ID "m" 1)
Executing: saveProperty(dev_ID "par" 1)
Executing: saveProperty(dev_ID "est" 0)
Executing: mim_area = measureParameter(area (dev_ID) 1e-12)
Executing: mim_perim = measureParameter(perimeter (dev_ID) 1e-06)
Executing: mim_w = measureParameter(area (dev_ID over width_label_mim) 1e-05)
Executing: mim_l = calculateParameter((mim_area / mim_w))
Executing: mim_dw = calculateParameter((mim_w + mimDW))
Executing: mim_dl = calculateParameter((mim_l + mimDL))
Executing: mim_hdm = measureParameter(figCount (dev_ID enclosing mim_hds))
Executing: mim_hd = calculateParameter((mim_hdm + (mim_l - mim_l)))
Executing: mimCArea = calculateParameter(((mimCA * (1 - mim_hd)) + (mimCA_hd * mim_hd)))
Executing: mimCperim = calculateParameter(((mimCP * (1 - mim_hd)) + (mimCP_hd * mim_hd)))
Executing: mim_wl_inf_8 = calculateParameter(((minusp((min(mim_w mim_l) - 8e-06))) * mim...
Executing: mim_c_coeff = calculateParameter(((zerop(mim_wl_inf_8)) + mim_wl_inf_8))
Executing: mim_C_COEFF = calculateParameter(((mim_c_coeff * (1 - mim_hd)) + (mim_p_corre...
Executing: mim_c = calculateParameter(((mim_dw * mim_dl * mimCArea) + (2 * mim_C_COEFF *...
Executing: mim_m = measureParameter(figCount (dev_ID enclosing mim_multi))
Executing: mim_mSwitch = calculateParameter((mim_m + (mim_l - mim_l)))
Executing: mimL_ind_num1 = measureParameter(perimeter (dev_ID over INDL_ind_num) 10.0)
Executing: mimL_ind_num2 = measureParameter(length (dev_ID coincident INDL_ind_num) 20.0)
Executing: mimL_ind_exp = measureParameter(length (dev_ID coincident INDL_ind_exp) 20.0)
Executing: mimL_ind = calculateParameter(((mimL_ind_num2 + ((mimL_ind_num1 - mimL_ind_nu...
Executing: rsx_num = measureParameter(length (dev_ID coincident rsx_BE) 100.0)
Executing: rsx_perim = measureParameter(perimeter (dev_ID over rsx_BE) 100.0)
Executing: mim_bb = measureParameter(figCount (dev_ID enclosing bb_mim) 2.0)
Executing: mim_nw = measureParameter(figCount (dev_ID enclosing nw_mim) 1.0)
Executing: mim_sub = measureParameter(figCount (dev_ID enclosing sub_mim) 3.0)
Executing: mim_bp = calculateParameter((mim_bb + mim_nw + mim_sub))
Executing: nameParameter(mim_area "a")
Executing: nameParameter(mim_perim "p")
Executing: nameParameter(mim_w "w")
Executing: nameParameter(mim_l "l")
Executing: nameParameter(mim_hd "hd")
Executing: nameParameter(mim_c "c")
Executing: nameParameter(mim_c "ceff")
Executing: nameParameter(mim_mSwitch "mSwitch")
Executing: nameParameter(mimL_ind "setind")
Executing: nameParameter(mim_bp "bp")
Executing: saveProperty(dev_ID "blockParasiticsBetween" "AM MT")
Executing: saveProperty(dev_ID "nlev" "6")
Executing: extractDevice("mimhk" MIMHKpi (mim_top "D") (mim_bot "S") (pwell "G") flagMal...
Executing: extractDevice("mimhk" MIMHKnw (mim_top "D") (mim_bot "S") (nw "G") flagMalfor...
Executing: extractDevice("mimhk" MIMHKpc (mim_top "D") (mim_bot "S") (pc_resistive "G") ...
Executing: extractDevice("mimhk" MIMHKsx (mim_top "D") (mim_bot "S") (substrate "G") fla...
Executing: saveProperty(dev_ID "hik" 1)
Executing: mim_dw = calculateParameter((mim_w + mimhDW))
Executing: mim_dl = calculateParameter((mim_l + mimhDL))
Executing: mim_c = calculateParameter(((mim_dw * mim_dl * mimhCA) + (2 * mim_c_coeff * (...
Executing: mim_pc = measureParameter(figCount (dev_ID enclosing pc_mim) 7.0)
Executing: mim_bp = calculateParameter((mim_bb + mim_nw + mim_pc + mim_sub))
Executing: saveProperty(MIMHKnw "nw" 1)
Executing: saveProperty(MIMHKnw "lm" 1)
Executing: saveProperty(MIMHKpi "lm" 1)
Executing: saveProperty(MIMHKpc "lm" 1)
Executing: saveProperty(MIMHKsx "lm" 1)
Executing: extractDevice("dualmim" DUALMIMpi (dualmid "D") (dualbot "S") (pwell "G") fla...
Executing: extractDevice("dualmim" DUALMIMnw (dualmid "D") (dualbot "S") (nw "G") flagMa...
Executing: extractDevice("dualmim" DUALMIMsx (dualmid "D") (dualbot "S") (substrate "G")...
Executing: extractDevice("dualmimhd" DUALMIMhdpi (dualmid "D") (dualbot "S") (pwell "G")...
Executing: extractDevice("dualmimhd" DUALMIMhdnw (dualmid "D") (dualbot "S") (nw "G") fl...
Executing: extractDevice("dualmimhd" DUALMIMhdsx (dualmid "D") (dualbot "S") (substrate ...
Executing: mim_area = measureParameter(area (dev_ID over ht) 1e-12)
Executing: mim_perim = measureParameter(perimeter (dev_ID over ht) 1e-06)
Executing: mim_w = measureParameter(area (dev_ID over width_label_dmim) 1e-05)
Executing: mim_area_dwl = calculateParameter((mim_dw * mim_dl))
Executing: mim_perim_dw = calculateParameter((2 * (mim_dw + mim_dl)))
Executing: dmim_std_c = calculateParameter(((dmimCA * ((mim_area_dwl * 2.0) + (mim_dw * ...
Executing: dmim_hd_ca = calculateParameter((dmimCA_hd * ((mim_dw * mim_dl) + ((mim_dw + ...
Executing: dmim_hd_cp = calculateParameter((2 * dmimCP_hd * (mim_dw + mim_dl + dmim_HD_w...
Executing: dmim_hd_c = calculateParameter((dmim_hd_ca + dmim_hd_cp))
Executing: mim_c = calculateParameter(((dmim_std_c * (1 - mim_hd)) + (dmim_hd_c * mim_hd)))
Executing: saveProperty(MIMpi "lm" 1)
Executing: saveProperty(DUALMIMpi "lm" 1)
Executing: saveProperty(MIMnw "lm" 1)
Executing: saveProperty(DUALMIMnw "lm" 1)
Executing: saveProperty(MIMsx "lm" 1)
Executing: saveProperty(DUALMIMsx "lm" 1)
Executing: saveProperty(MIMhdpi "lm" 1)
Executing: saveProperty(DUALMIMhdpi "lm" 1)
Executing: saveProperty(MIMhdnw "lm" 1)
Executing: saveProperty(DUALMIMhdnw "lm" 1)
Executing: saveProperty(MIMhdsx "lm" 1)
Executing: saveProperty(DUALMIMhdsx "lm" 1)
Executing: vncap_top1_pwell = extractDevice("vncap" vncap_top1 (vncap_term1 "IN" "OUT") ...
vncap_top1_subs = extractDevice("vncap" vncap_top1 (vncap_term1 "IN" "OUT") (...
Executing: extractDevice("vncap" vncap_tnw1 (vncap_term1 "IN" "OUT") (nw "SUB") flagMalf...
Executing: vncap_topt_pwell = extractDevice("vncap" vncap_topt (vncap_termt "IN" "OUT") ...
vncap_topt_subs = extractDevice("vncap" vncap_topt (vncap_termt "IN" "OUT") (...
Executing: extractDevice("vncap" vncap_tnwt (vncap_termt "IN" "OUT") (nw "SUB") flagMalf...
Executing: vncap_top2_pwell = extractDevice("vncap" vncap_top2 (vncap_term2 "IN" "OUT") ...
vncap_top2_subs = extractDevice("vncap" vncap_top2 (vncap_term2 "IN" "OUT") (...
Executing: extractDevice("vncap" vncap_tnw2 (vncap_term2 "IN" "OUT") (nw "SUB") flagMalf...
Executing: vncap_top3_pwell = extractDevice("vncap" vncap_top3 (vncap_term3 "IN" "OUT") ...
vncap_top3_subs = extractDevice("vncap" vncap_top3 (vncap_term3 "IN" "OUT") (...
Executing: extractDevice("vncap" vncap_tnw3 (vncap_term3 "IN" "OUT") (nw "SUB") flagMalf...
Executing: vncap_top4_pwell = extractDevice("vncap" vncap_top4 (vncap_term4 "IN" "OUT") ...
vncap_top4_subs = extractDevice("vncap" vncap_top4 (vncap_term4 "IN" "OUT") (...
Executing: extractDevice("vncap" vncap_tnw4 (vncap_term4 "IN" "OUT") (nw "SUB") flagMalf...
Executing: vncap_multi1 = geomEnclose(multi dev_ID)
Executing: vncap_multi = geomAnd(dev_ID vncap_multi1)
Executing: saveProperty(dev_ID "lm" 1)
Executing: saveProperty(dev_ID "nlev" 6)
Executing: length = measureParameter(area (dev_ID over vncap_L_edge) 5e-06)
Executing: area = measureParameter(area (dev_ID) 1e-12)
Executing: width = calculateParameter((area / length))
Executing: vncapL_ind_num1 = measureParameter(perimeter (dev_ID over INDL_ind_num) 10.0)
Executing: vncapL_ind_num2 = measureParameter(length (dev_ID coincident INDL_ind_num) 20.0)
Executing: vncapL_ind_exp = measureParameter(length (dev_ID coincident INDL_ind_exp) 20.0)
Executing: vncapL_ind = calculateParameter(((vncapL_ind_num2 + ((vncapL_ind_num1 - vncap...
Executing: vncap_m = measureParameter(figCount (dev_ID enclosing vncap_multi))
Executing: vncap_mSwitch = calculateParameter((vncap_m + (length - length)))
Executing: vncap_nw = measureParameter(figCount (dev_ID enclosing nw_vncap) 1.0)
Executing: vncap_bb = measureParameter(figCount (dev_ID enclosing bb_vncap) 2.0)
Executing: rsx_num = measureParameter(length (dev_ID coincident rsx_vncap) 100.0)
Executing: rsx_perim = measureParameter(perimeter (dev_ID over rsx_vncap) 100.0)
Executing: vncap_sub = measureParameter(figCount (dev_ID enclosing sub_vncap) 3.0)
Executing: vncap_bp = calculateParameter((vncap_nw + vncap_bb + vncap_sub))
Executing: nameParameter(length "l")
Executing: nameParameter(width "w")
Executing: nameParameter(vncapL_ind "setind")
Executing: nameParameter(vncap_mSwitch "mSwitch")
Executing: nameParameter(vncap_bp "bp")
Executing: BL1 = measureParameter(figCount (dev_ID enclosing VNCAP_parm))
Executing: bl1 = calculateParameter(((length - length) + BL1))
Executing: nameParameter(bl1 "botlev")
Executing: TL1 = measureParameter(figCount (dev_ID enclosing VNCAP_count))
Executing: tl1 = calculateParameter(floor(((TL1 + bl1) - 1.0)))
Executing: nameParameter(tl1 "toplev")
Executing: saveProperty(dev_ID "blockParasiticsBetween2" "toplev2 botlev2 toplev botlev")
Executing: extractDevice("indline" am_transmission (am "out" "in") (ind_bb_term "BULK") ...
Executing: trans_width = measureParameter(length (am_transmission butting amTerm) 5e-07)
Executing: nameParameter(trans_width "w")
Executing: trans_area = measureParameter(area (am_transmission) 1e-12)
Executing: trans_length = calculateParameter((trans_area / trans_width))
Executing: nameParameter(trans_length "l")
Executing: saveProperty(am_transmission "blockParasiticsBetween" "AM sub")
Executing: saveProperty(am_transmission "grnd" -1)
Executing: indL_ind_num = measureParameter(area (am_transmission over INDL_ind_num))
Executing: indL_ind_exp = measureParameter(area (am_transmission over INDL_ind_exp))
Executing: indL_ind = calculateParameter((indL_ind_num / (power 10.0 indL_ind_exp)))
Executing: nameParameter(indL_ind "ind")
Executing: saveProperty(am_transmission "nlev" 6)
Executing: extractDevice("ind" ind2_mtam_m1 (trans_in_mt "in") (trans_out_am "out") (m1_...
Executing: extractDevice("ind" ind2_mtam_bb (trans_in_mt "in") (trans_out_am "out") (ind...
Executing: extractDevice("symind" symind3_amam_bb (symind_in "outpr") (symind_out "outse...
Executing: extractDevice("symind" symind3_amam_m1 (symind_in "outpr") (symind_out "outse...
Executing: extractDevice("symind" symind2_amam_bb (symind_in "outpr") (symind_out "outse...
Executing: extractDevice("symind" symind2_amam_m1 (symind_in "outpr") (symind_out "outse...
Executing: ind_rect = geomGetRectangle(ind_xy)
Executing: ind_poly = geomGetPolygon(ind_xy)
Executing: UNITY_1 = geomOr(DEV)
Executing: IND_M1 = geomOverlap(DEV m1)
Executing: IND_BB = geomOverlap(DEV ind_bb_term)
Executing: am_CUT = drc(geomAndNot(am_intern mtTerm) (area > 250.0))
Executing: am_Whole = geomGetVertex(am_CUT (keep > 19.0))
Executing: am_Part = geomSize(geomGetNon90(geomAndNot(am_CUT am_Whole)) -0.1)
Executing: width_DEV = measureParameter(length (DEV coincident PLUS) 1e-06)
Executing: WU = measureParameter(length (DEV coincident MINUS) 1e-06)
Executing: tempSPACE = measureParameter(area (DEV over ind_space) 1e-12)
Executing: SPACE = calculateParameter((tempSPACE / width_DEV))
Executing: PERIM_rect = measureParameter(perimeter (DEV over ind_rect))
Executing: IND_X_rect = calculateParameter((PERIM_rect / 4000000.0))
Executing: AREA_poly = measureParameter(area (DEV over ind_poly))
Executing: IND_X_poly = calculateParameter((floor((sqrt(AREA_poly) * 1.1)) * 1e-06))
Executing: IND_X = calculateParameter((IND_X_rect + IND_X_poly))
Executing: UNITY = measureParameter(figCount (DEV enclosing UNITY_1))
Executing: GRNDM1 = measureParameter(figCount (DEV enclosing IND_M1) -2.0)
Executing: GRNDBB = measureParameter(figCount (DEV enclosing IND_BB) -1.0)
Executing: GRNDHR = measureParameter(figCount (DEV enclosing ind_hr_term) -5.0)
Executing: GRND = calculateParameter(((UNITY - UNITY) + GRNDHR + GRNDBB + GRNDM1))
Executing: Whole = measureParameter(figCount (DEV enclosing am_Whole))
Executing: Partial = measureParameter(figCount (DEV enclosing am_Part))
Executing: TURNS = calculateParameter(((Partial / 8.0) + Whole))
Executing: nameParameter(TURNS "n")
Executing: nameParameter(width_DEV "w")
Executing: nameParameter(WU "wu")
Executing: nameParameter(SPACE "s")
Executing: nameParameter(IND_X "x")
Executing: nameParameter(GRND "grnd")
Executing: saveProperty(DEV "blockParasiticsBetween" "AM sub")
Executing: saveProperty(DEV "nlev" "6")
Executing: ind_rect = geomGetRectangle(DEV)
Executing: ind_poly = geomGetPolygon(DEV)
Executing: m1_plate = geomSize(geomSize(geomAndNot(geomAnd(m1 allInds) MIDDLE) -0.01) 0.01)
Executing: IND_M1 = geomOverlap(DEV m1_plate)
Executing: symind_center = geomGetBBox(DEV outputCenterMarker 1.0)
Executing: alternate_ct = geomAnd(MIDDLE symind_center)
Executing: Number_AM_internal = measureParameter(figCount (DEV enclosing am_intern))
Executing: TURNS = calculateParameter((Number_AM_internal / 1.0))
Executing: AREA_p = measureParameter(area (DEV over PLUS) 1e-12)
Executing: WIDTH_p = measureParameter(length (DEV coincident PLUS) 1e-06)
Executing: WIDTH_DEV = calculateParameter((AREA_p / WIDTH_p))
Executing: WUnderpass = measureParameter(length (DEV coincident MIDDLE) 1e-06)
Executing: tempSPACE = measureParameter(area (DEV over Symind_edge_space) 0.0001)
Executing: Number = measureParameter(figCount (DEV enclosing Symind_edge_space))
Executing: SPACE_P = calculateParameter((tempSPACE / max(Number 1)))
Executing: SPACE = calculateParameter((((zerop(SPACE_P)) * 5e-06) + SPACE_P))
Executing: ind_enh = measureParameter(figCount (DEV enclosing ind_xov))
Executing: ind_enhanced = calculateParameter((ind_enh + (TURNS - TURNS)))
Executing: altct = measureParameter(figCount (DEV enclosing alternate_ct))
Executing: wu = calculateParameter(if(((TURNS == 1.0) && (altct == 1.0)) then (WUnderpas...
Executing: nameParameter(WIDTH_DEV "w")
Executing: nameParameter(wu "wu")
Executing: nameParameter(ind_enhanced "xov")
Executing: nameParameter(altct "altct")
Executing: saveProperty(DEV "wu" "-1.0e-6")
Executing: GRNDBB = measureParameter(figCount (DEV enclosing ind_bb_term) -1.0)
Executing: extractDevice("devicepad" padOverDev (padOverDev_top "pad") flagMalformed (na...
Executing: saveProperty(padOverDev "c" 1e-15)
Executing: extractDevice("bondpad" bondPad_PC (bondPad_top "in") (pc_model "gp") (substr...
Executing: extractDevice("bondpad" bondPad_BB (bondPad_top "in") (bond_bb_term "gp") (su...
Executing: bondPad_rect = geomGetRectangle(bondPad_PC)
Executing: bondPad_poly = geomGetPolygon(bondPad_PC)
Executing: M4_nw = geomInside(bondPad_PC nw)
Executing: M4_pc = geomInside(bondPad_PC pc)
Executing: bondPad_a = measureParameter(area (bondPad_PC) 1e-12)
Executing: bondPad_p = measureParameter(perimeter (bondPad_PC) 1e-06)
Executing: bondPad_rect1 = measureParameter(figCount (bondPad_PC enclosing bondPad_rect))
Executing: bondPad_poly1 = measureParameter(figCount (bondPad_PC enclosing bondPad_poly))
Executing: bondPad_RorP = calculateParameter((bondPad_rect1 - bondPad_poly1))
Executing: bondPad_nw = measureParameter(figCount (bondPad_PC enclosing M4_nw))
Executing: bondPad_pc = measureParameter(figCount (bondPad_PC enclosing M4_pc))
Executing: bondPad_grnd = calculateParameter(((bondPad_nw * -3.0) + (bondPad_pc * -2.0)))
Executing: nameParameter(bondPad_a "area")
Executing: nameParameter(bondPad_p "perim")
Executing: nameParameter(bondPad_RorP "rect")
Executing: nameParameter(bondPad_grnd "grnd")
Executing: bondPbb_rect = geomGetRectangle(bondPad_BB)
Executing: bondPbb_poly = geomGetPolygon(bondPad_BB)
Executing: bondPbb_a = measureParameter(area (bondPad_BB over bond_bb_term) 1e-12)
Executing: bondPbb_p = measureParameter(perimeter (bondPad_BB over bond_bb_term) 1e-06)
Executing: bondPbb_rect1 = measureParameter(figCount (bondPad_BB enclosing bondPbb_rect))
Executing: bondPbb_poly1 = measureParameter(figCount (bondPad_BB enclosing bondPbb_poly))
Executing: bondPbb_RorP = calculateParameter((bondPbb_rect1 - bondPbb_poly1))
Executing: nameParameter(bondPbb_a "area")
Executing: nameParameter(bondPbb_p "perim")
Executing: nameParameter(bondPbb_RorP "rect")
Executing: saveProperty(bondPad_BB "grnd" -1.0)
Executing: saveProperty(bondPad_PC "blockParasiticsBetween" "AM sub")
Executing: saveProperty(bondPad_BB "blockParasiticsBetween" "AM sub")
Executing: saveProperty(bondPad_PC "nlev" "6")
Executing: saveProperty(bondPad_BB "nlev" "6")
Executing: extractDevice("efuse" efuse (efuse_anod "in") (efuse_cath "out") flagMalforme...
Executing: coupledA_shieldT = extractDevice("coupledwires" coupledA (trans_va1_am "va1")...
coupledA_shield4 = extractDevice("coupledwires" coupledA (trans_va1_am "va1")...
coupledA_shield3 = extractDevice("coupledwires" coupledA (trans_va1_am "va1")...
coupledA_shield2 = extractDevice("coupledwires" coupledA (trans_va1_am "va1")...
coupledA_shield1 = extractDevice("coupledwires" coupledA (trans_va1_am "va1")...
Executing: width = measureParameter(area (dev_ID over signalWidth) 2.5e-06)
Executing: area = measureParameter(area (dev_ID over signal) 5e-13)
Executing: length = calculateParameter(((area / width) + 4e-08))
Executing: dist = measureParameter(area (dev_ID over coupledSpace) 5e-06)
Executing: nameParameter(dist "d")
Executing: space1 = measureParameter(area (dev_ID over shieldSpace) 2.5e-06)
Executing: space = calculateParameter((space1 - (area - area)))
Executing: nameParameter(space "s")
Executing: Side = measureParameter(figCount (dev_ID enclosing shieldSpace) 0.25)
Executing: side = calculateParameter((Side - (area - area)))
Executing: nameParameter(side "shieldsads")
Executing: saveProperty(dev_ID "blockParasiticsBetween" "layerads overads")
Executing: UNITY = measureParameter(figCount (dev_ID enclosing signal) 0.5)
Executing: SEVEN = calculateParameter((UNITY * 7.0))
Executing: nameParameter(SEVEN "layerads")
Executing: am_couple_shield_m1 = measureParameter(figCount (coupledA enclosing shield1) ...
Executing: am_couple_shield_mt = measureParameter(figCount (coupledA enclosing shieldT) ...
Executing: am_couple_shield_m2 = measureParameter(figCount (coupledA enclosing shield2) ...
Executing: am_couple_shield_m3 = measureParameter(figCount (coupledA enclosing shield3) ...
Executing: am_couple_shield_m4 = measureParameter(figCount (coupledA enclosing shield4) ...
Executing: am_couple_shield = calculateParameter((am_couple_shield_mt + am_couple_shield...
Executing: nameParameter(am_couple_shield "overads")
Executing: saveProperty(coupledA "nlev" "6")
Executing: singleEndA_shieldT = extractDevice("singlewire" singleEndA (trans_va_am "va")...
singleEndA_shield4 = extractDevice("singlewire" singleEndA (trans_va_am "va")...
singleEndA_shield3 = extractDevice("singlewire" singleEndA (trans_va_am "va")...
singleEndA_shield2 = extractDevice("singlewire" singleEndA (trans_va_am "va")...
singleEndA_shield1 = extractDevice("singlewire" singleEndA (trans_va_am "va")...
Executing: width = measureParameter(area (dev_ID over signalWidth) 5e-06)
Executing: area = measureParameter(area (dev_ID over signal) 1e-12)
Executing: UNITY = measureParameter(figCount (dev_ID enclosing signal))
Executing: am_single_shield_m1 = measureParameter(figCount (singleEndA enclosing shield1...
Executing: am_single_shield_mt = measureParameter(figCount (singleEndA enclosing shieldT...
Executing: am_single_shield_m2 = measureParameter(figCount (singleEndA enclosing shield2...
Executing: am_single_shield_m3 = measureParameter(figCount (singleEndA enclosing shield3...
Executing: am_single_shield_m4 = measureParameter(figCount (singleEndA enclosing shield4...
Executing: am_single_shield = calculateParameter((am_single_shield_mt + am_single_shield...
Executing: nameParameter(am_single_shield "overads")
Executing: saveProperty(singleEndA "nlev" "6")
Executing: coupledT_shield4 = extractDevice("coupledwires" coupledT (trans_va1_mt "va1")...
coupledT_shield3 = extractDevice("coupledwires" coupledT (trans_va1_mt "va1")...
coupledT_shield2 = extractDevice("coupledwires" coupledT (trans_va1_mt "va1")...
coupledT_shield1 = extractDevice("coupledwires" coupledT (trans_va1_mt "va1")...
Executing: SIX = calculateParameter((UNITY * 6.0))
Executing: nameParameter(SIX "layerads")
Executing: mt_couple_shield_m1 = measureParameter(figCount (coupledT enclosing shield1) ...
Executing: mt_couple_shield_m2 = measureParameter(figCount (coupledT enclosing shield2) ...
Executing: mt_couple_shield_m3 = measureParameter(figCount (coupledT enclosing shield3) ...
Executing: mt_couple_shield_m4 = measureParameter(figCount (coupledT enclosing shield4) ...
Executing: mt_couple_shield = calculateParameter((mt_couple_shield_m4 + mt_couple_shield...
Executing: nameParameter(mt_couple_shield "overads")
Executing: saveProperty(coupledT "nlev" "6")
Executing: singleEndT_shield4 = extractDevice("singlewire" singleEndT (trans_va_mt "va")...
singleEndT_shield3 = extractDevice("singlewire" singleEndT (trans_va_mt "va")...
singleEndT_shield2 = extractDevice("singlewire" singleEndT (trans_va_mt "va")...
singleEndT_shield1 = extractDevice("singlewire" singleEndT (trans_va_mt "va")...
Executing: mt_single_shield_m1 = measureParameter(figCount (singleEndT enclosing shield1...
Executing: mt_single_shield_m2 = measureParameter(figCount (singleEndT enclosing shield2...
Executing: mt_single_shield_m3 = measureParameter(figCount (singleEndT enclosing shield3...
Executing: mt_single_shield_m4 = measureParameter(figCount (singleEndT enclosing shield4...
Executing: mt_single_shield = calculateParameter((mt_single_shield_m4 + mt_single_shield...
Executing: nameParameter(mt_single_shield "overads")
Executing: saveProperty(singleEndT "nlev" "6")
Executing: coupled4_shield3 = extractDevice("coupledwires" coupled4 (trans_va1_m4 "va1")...
coupled4_shield2 = extractDevice("coupledwires" coupled4 (trans_va1_m4 "va1")...
coupled4_shield1 = extractDevice("coupledwires" coupled4 (trans_va1_m4 "va1")...
Executing: FOUR = calculateParameter((UNITY * 4.0))
Executing: nameParameter(FOUR "layerads")
Executing: m4_couple_shield_m1 = measureParameter(figCount (coupled4 enclosing shield1) ...
Executing: m4_couple_shield_m2 = measureParameter(figCount (coupled4 enclosing shield2) ...
Executing: m4_couple_shield_m3 = measureParameter(figCount (coupled4 enclosing shield3) ...
Executing: m4_couple_shield = calculateParameter((m4_couple_shield_m3 + m4_couple_shield...
Executing: nameParameter(m4_couple_shield "overads")
Executing: saveProperty(coupled4 "nlev" "6")
Executing: singleEnd4_shield3 = extractDevice("singlewire" singleEnd4 (trans_va_m4 "va")...
singleEnd4_shield2 = extractDevice("singlewire" singleEnd4 (trans_va_m4 "va")...
singleEnd4_shield1 = extractDevice("singlewire" singleEnd4 (trans_va_m4 "va")...
Executing: m4_single_shield_m1 = measureParameter(figCount (singleEnd4 enclosing shield1...
Executing: m4_single_shield_m2 = measureParameter(figCount (singleEnd4 enclosing shield2...
Executing: m4_single_shield_m3 = measureParameter(figCount (singleEnd4 enclosing shield3...
Executing: m4_single_shield = calculateParameter((m4_single_shield_m3 + m4_single_shield...
Executing: nameParameter(m4_single_shield "overads")
Executing: saveProperty(singleEnd4 "nlev" "6")
Executing: coupled3_shield2 = extractDevice("coupledwires" coupled3 (trans_va1_m3 "va1")...
coupled3_shield1 = extractDevice("coupledwires" coupled3 (trans_va1_m3 "va1")...
Executing: THREE = calculateParameter((UNITY * 3.0))
Executing: nameParameter(THREE "layerads")
Executing: m3_couple_shield_m1 = measureParameter(figCount (coupled3 enclosing shield1) ...
Executing: m3_couple_shield_m2 = measureParameter(figCount (coupled3 enclosing shield2) ...
Executing: m3_couple_shield = calculateParameter((m3_couple_shield_m2 + m3_couple_shield...
Executing: nameParameter(m3_couple_shield "overads")
Executing: saveProperty(coupled3 "nlev" "6")
Executing: singleEnd3_shield2 = extractDevice("singlewire" singleEnd3 (trans_va_m3 "va")...
singleEnd3_shield1 = extractDevice("singlewire" singleEnd3 (trans_va_m3 "va")...
Executing: m3_single_shield_m2 = measureParameter(figCount (singleEnd3 enclosing shield2...
Executing: m3_single_shield_m1 = measureParameter(figCount (singleEnd3 enclosing shield1...
Executing: m3_single_shield = calculateParameter((m3_single_shield_m2 + m3_single_shield...
Executing: nameParameter(m3_single_shield "overads")
Executing: saveProperty(singleEnd3 "nlev" "6")
Executing: coupled2_shield1 = extractDevice("coupledwires" coupled2 (trans_va1_m2 "va1")...
Executing: TWO = calculateParameter((UNITY * 2.0))
Executing: nameParameter(TWO "layerads")
Executing: m2_couple_shield = measureParameter(figCount (coupled2 enclosing shield1) 1.0)
Executing: nameParameter(m2_couple_shield "overads")
Executing: saveProperty(coupled2 "nlev" "6")
Executing: singleEnd2_shield1 = extractDevice("singlewire" singleEnd2 (trans_va_m2 "va")...
Executing: m2_single_shield = measureParameter(figCount (singleEnd2 enclosing shield1) 1.0)
Executing: nameParameter(m2_single_shield "overads")
Executing: saveProperty(singleEnd2 "nlev" "6")
Executing: extractDevice("lvsres" m1_RES_min (m1_model "MINUS" "PLUS") physical (namePre...
extractDevice("lvsres" m1_RES_min (m1_resistive "MINUS" "PLUS") physical (nam...
extractDevice("lvsres" m1_RES_min (m1_resistive "MINUS") (m1_model "PLUS") ph...
Executing: extractDevice("lvsres" mt_RES_min (mt_model "MINUS" "PLUS") physical (namePre...
extractDevice("lvsres" mt_RES_min (mt_resistive "MINUS" "PLUS") physical (nam...
extractDevice("lvsres" mt_RES_min (mt_resistive "MINUS") (mt_model "PLUS") ph...
Executing: extractDevice("lvsres" m2_RES_min (m2_model "MINUS" "PLUS") physical (namePre...
extractDevice("lvsres" m2_RES_min (m2_resistive "MINUS" "PLUS") physical (nam...
extractDevice("lvsres" m2_RES_min (m2_resistive "MINUS") (m2_model "PLUS") ph...
Executing: extractDevice("lvsres" m3_RES_min (m3_model "MINUS" "PLUS") physical (namePre...
extractDevice("lvsres" m3_RES_min (m3_resistive "MINUS" "PLUS") physical (nam...
extractDevice("lvsres" m3_RES_min (m3_resistive "MINUS") (m3_model "PLUS") ph...
Executing: extractDevice("lvsres" m4_RES_min (m4_model "MINUS" "PLUS") physical (namePre...
extractDevice("lvsres" m4_RES_min (m4_resistive "MINUS" "PLUS") physical (nam...
extractDevice("lvsres" m4_RES_min (m4_resistive "MINUS") (m4_model "PLUS") ph...
Executing: extractDevice("lvsres" am_RES_min (am "MINUS" "PLUS") physical (namePrefix "R...
Executing: pwell_dev_exclude = geomOr(jfet_dev_sized pcap_dev vlnpn_dev DIPI_FILTER PSBD)
Executing: piwell_dev_exclude = geomOr(vlnpn_dev DIPI_FILTER)
Executing: excluded_dev = geomOr(ESD_pdnw_all ESD_ndsx_all vlnpn_dev DI_FILTER DIPI_FILT...
Executing: pdiode_dev = geomOutside(geomAnd(pd_tie nw) excluded_dev)
Executing: extractDevice("diodepnw" pdiode_dev (nw "MINUS") (pd_tie "PLUS") physical fla...
Executing: pdnw_atie = measureParameter(area (pdiode_dev over nw) 1e-12)
Executing: pdnw_ptie = measureParameter(length (pdiode_dev inside nw) 1e-06)
Executing: c_pdnw_area = calculateParameter((pdnw_atie * 8.5e-05))
Executing: c_pdnw_perim = calculateParameter((pdnw_ptie * 2.89e-10))
Executing: nameParameter(pdnw_atie "area")
Executing: nameParameter(pdnw_ptie "perim")
Executing: nameParameter(c_pdnw_area "c")
Executing: nameParameter(c_pdnw_perim "pcp")
Executing: ndiode_dev = geomAnd(geomOutside(geomAndNot(nd_tie geomOr(rn nw ncap_nw mosva...
Executing: extractDevice("diodenx" ndiode_dev (nd_tie "MINUS") (pwell "PLUS") physical f...
Executing: ndx_atie = measureParameter(area (ndiode_dev over pi) 1e-12)
Executing: ndx_ptie = measureParameter(length (ndiode_dev inside pi) 1e-06)
Executing: c_ndx_area = calculateParameter((ndx_atie * 8.5e-05))
Executing: c_ndx_perim = calculateParameter((ndx_ptie * 2.89e-10))
Executing: nameParameter(ndx_atie "area")
Executing: nameParameter(ndx_ptie "perim")
Executing: nameParameter(c_ndx_area "c")
Executing: nameParameter(c_ndx_perim "pcp")
Executing: ndiode_dev = geomOutside(geomAnd(geomAndNot(nd_tie geomOr(rn nw ncap_nw mosva...
Executing: extractDevice("diodenx" ndiode_dev (nd_tie "MINUS") (substrate "PLUS") physic...
Executing: ndx_atie = measureParameter(area (ndiode_dev over substrate) 1e-12)
Executing: ndx_ptie = measureParameter(length (ndiode_dev inside substrate) 1e-06)
Executing: nwdiode_dev1 = geomOutside(geomAnd(geomAndNot(nw excluded_dev) substrate) pi)
Executing: extractDevice("diodenwx" nwdiode_dev1 (nw "MINUS") (substrate "PLUS") physica...
1 'diodenwx' created in cell 'Inverter layout Project'.
Executing: nwx_area = measureParameter(area (nwdiode_dev1 over substrate) 1e-12)
Executing: nwx_down = measureParameter(perimeter (nwdiode_dev1 over substrate) 1e-06)
Executing: c_nwx_area = calculateParameter((nwx_area * 8.5e-05))
Executing: c_nwx_perim = calculateParameter((nwx_down * 2.89e-10))
Executing: nameParameter(nwx_area "area")
Executing: nameParameter(nwx_down "perim")
Executing: nameParameter(c_nwx_area "c")
Executing: nameParameter(c_nwx_perim "pcp")
Executing: nwdiode_dev = geomOverlap(geomAnd(geomAndNot(nw excluded_dev) substrate) pi)
Executing: NotOverNtub = geomOr(nfeti_bottom_iso)
Executing: extractDevice("diodenwx" nwdiode_dev (nw "MINUS") (substrate "PLUS") physical...
Executing: nwx_area = measureParameter(area (nwdiode_dev over substrate not_over NotOver...
Executing: nwx_down = measureParameter(perimeter (nwdiode_dev over substrate) 1e-06)
Executing: nwx_not = measureParameter(length (nwdiode_dev inside substrate inside NotOve...
Executing: nwx_perim = calculateParameter((nwx_down - nwx_not))
Executing: nameParameter(nwx_perim "perim")
Executing: pwell_dev = geomAndNot(geomAnd(pwell nfeti_bottom_iso) pwell_dev_exclude)
Executing: extractDevice("diodepwpi" pwell_dev (nfeti_bottom_iso "MINUS") (pwell "PLUS")...
Executing: ndx_atie = measureParameter(area (pwell_dev over nfeti_bottom_iso) 1e-12)
Executing: ndx_ptie = measureParameter(length (pwell_dev butting nw) 1e-06)
Executing: piwell_dev = geomAndNot(geomAnd(nfeti_bottom_iso substrate) piwell_dev_exclude)
Executing: extractDevice("diodepisx" piwell_dev (nfeti_bottom_iso "MINUS") (substrate "P...
Executing: ndx_atie = measureParameter(area (piwell_dev over substrate) 1e-12)
Executing: ndx_ptie = measureParameter(length (piwell_dev inside substrate) 1e-06)
Executing: saveDerived((RF ("OUTLINE" "rf") ext_view)
Executing: saveDerived((transmission1 ("OUTLINE" "TRANS") ext_view)
Executing: saveDerived((ind ("OUTLINE" "IND") ext_view)
Executing: saveRecognition(vncap_tnw1 "device")
Executing: saveRecognition(vncap_top1 "device")
Executing: saveRecognition(vncap_tnwt "device")
Executing: saveRecognition(vncap_topt "device")
Executing: saveRecognition(vncap_tnw2 "device")
Executing: saveRecognition(vncap_top2 "device")
Executing: saveRecognition(vncap_tnw3 "device")
Executing: saveRecognition(vncap_top3 "device")
Executing: saveRecognition(vncap_tnw4 "device")
Executing: saveRecognition(vncap_top4 "device")
Executing: saveRecognition(nfeti_dev_psp_b "device")
Executing: saveRecognition(nfeti_dev_psp "device")
Executing: saveRecognition(nfeti_dev_psp_MV "device")
Executing: saveRecognition(nfeti_dev_psp_HV "device")
Executing: saveRecognition(nfeti_dev "device")
Executing: saveRecognition(nfeti_dev_b "device")
Executing: saveRecognition(nfeti_dev_MV "device")
Executing: saveRecognition(nfeti_dev_HV "device")
Executing: saveRecognition(nfeti_dev_TG "device")
Executing: saveRecognition(nfeti_mul_psp "device")
Executing: saveRecognition(nfeti_mul_psp_MV "device")
Executing: saveRecognition(nfeti_mul_psp_HV "device")
Executing: saveRecognition(nfeti_mul "device")
Executing: saveRecognition(nfeti_mul_MV "device")
Executing: saveRecognition(nfeti_mul_HV "device")
Executing: saveRecognition(nfeti_mul_TG "device")
Executing: saveRecognition(nfet6_dev_psp_b "device")
Executing: saveRecognition(nfet6_dev_psp "device")
Executing: saveRecognition(nfet6_dev_psp_MV "device")
Executing: saveRecognition(nfet6_dev_psp_HV "device")
Executing: saveRecognition(nfet6_dev "device")
Executing: saveRecognition(nfet6_dev_b "device")
Executing: saveRecognition(nfet6_dev_MV "device")
Executing: saveRecognition(nfet6_dev_HV "device")
Executing: saveRecognition(nfet6_dev_TG "device")
Executing: saveRecognition(nfet6_mul_psp "device")
Executing: saveRecognition(nfet6_mul_psp_MV "device")
Executing: saveRecognition(nfet6_mul_psp_HV "device")
Executing: saveRecognition(nfet6_mul "device")
Executing: saveRecognition(nfet6_mul_MV "device")
Executing: saveRecognition(nfet6_mul_HV "device")
Executing: saveRecognition(nfet6_mul_TG "device")
Executing: saveRecognition(nfet_dpw_psp "device")
Executing: saveRecognition(nfet_dpw_psp_MV "device")
Executing: saveRecognition(nfet_dpw_psp_HV "device")
Executing: saveRecognition(nfet_dpw_psp_b "device")
Executing: saveRecognition(nfet_dpw "device")
Executing: saveRecognition(nfet_dpw_MV "device")
Executing: saveRecognition(nfet_dpw_HV "device")
Executing: saveRecognition(nfet_dpw_b "device")
Executing: saveRecognition(nfet_dpw_TG "device")
Executing: saveRecognition(nfet_dev_psp "device")
Executing: saveRecognition(nfet_dev_psp_MV "device")
Executing: saveRecognition(nfet_dev_psp_HV "device")
Executing: saveRecognition(nfet_dev_psp_b "device")
Executing: saveRecognition(nfet_dev "device")
Executing: saveRecognition(nfet_dev_MV "device")
Executing: saveRecognition(nfet_dev_HV "device")
Executing: saveRecognition(nfet_dev_b "device")
Executing: saveRecognition(nfet_dev_TG "device")
Executing: saveRecognition(nfet_dev_HVT "device")
Executing: saveRecognition(nfet_dev_HVT_b "device")
Executing: saveRecognition(nfet_mul_psp "device")
Executing: saveRecognition(nfet_mul_psp_MV "device")
Executing: saveRecognition(nfet_mul_psp_HV "device")
Executing: saveRecognition(nfet_mul "device")
Executing: saveRecognition(nfet_mul_MV "device")
Executing: saveRecognition(nfet_mul_HV "device")
Executing: saveRecognition(nfet_mul_TG "device")
Executing: saveRecognition(nfet_mul_HVT "device")
Executing: saveRecognition(nfzv_dev "device")
Executing: saveRecognition(nfzv_dev_HV "device")
Executing: saveRecognition(nfzv_mul "device")
Executing: saveRecognition(nfzv_mul_HV "device")
Executing: saveRecognition(nfRF_dev_psp "device")
Executing: saveRecognition(nfRF_dev_psp_MV "device")
Executing: saveRecognition(nfRF_dev_psp_HV "device")
Executing: saveRecognition(nfRF_dev "device")
Executing: saveRecognition(nfRF_dev_MV "device")
Executing: saveRecognition(nfRF_dev_HV "device")
Executing: saveRecognition(nfRF_mul_psp "device")
Executing: saveRecognition(nfRF_mul_psp_MV "device")
Executing: saveRecognition(nfRF_mul_psp_HV "device")
Executing: saveRecognition(nfRF_mul "device")
Executing: saveRecognition(nfRF_mul_MV "device")
Executing: saveRecognition(nfRF_mul_HV "device")
Executing: saveRecognition(nfRFi_dev_psp "device")
Executing: saveRecognition(nfRFi_dev_psp_MV "device")
Executing: saveRecognition(nfRFi_dev_psp_HV "device")
Executing: saveRecognition(nfRFi_dev "device")
Executing: saveRecognition(nfRFi_dev_MV "device")
Executing: saveRecognition(nfRFi_dev_HV "device")
Executing: saveRecognition(nfRFi_mul_psp "device")
Executing: saveRecognition(nfRFi_mul_psp_MV "device")
Executing: saveRecognition(nfRFi_mul_psp_HV "device")
Executing: saveRecognition(nfRFi_mul "device")
Executing: saveRecognition(nfRFi_mul_MV "device")
Executing: saveRecognition(nfRFi_mul_HV "device")
Executing: saveRecognition(nfRF6_dev_psp "device")
Executing: saveRecognition(nfRF6_dev_psp_MV "device")
Executing: saveRecognition(nfRF6_dev_psp_HV "device")
Executing: saveRecognition(nfRF6_dev "device")
Executing: saveRecognition(nfRF6_dev_MV "device")
Executing: saveRecognition(nfRF6_dev_HV "device")
Executing: saveRecognition(nfRF6_mul_psp "device")
Executing: saveRecognition(nfRF6_mul_psp_MV "device")
Executing: saveRecognition(nfRF6_mul_psp_HV "device")
Executing: saveRecognition(nfRF6_mul "device")
Executing: saveRecognition(nfRF6_mul_MV "device")
Executing: saveRecognition(nfRF6_mul_HV "device")
Executing: saveRecognition(nfRF_dev_TG "device")
Executing: saveRecognition(nfRF_mul_TG "device")
Executing: saveRecognition(nfRFi_dev_TG "device")
Executing: saveRecognition(nfRF6_dev_TG "device")
Executing: saveRecognition(nfRFi_mul_TG "device")
Executing: saveRecognition(nfRF6_mul_TG "device")
Executing: saveRecognition(pfet_dev_psp "device")
Executing: saveRecognition(pfet_dev_psp_MV "device")
Executing: saveRecognition(pfet_dev_psp_HV "device")
Executing: saveRecognition(pfet_dev_psp_b "device")
Executing: saveRecognition(pfet_dev "device")
Executing: saveRecognition(pfet_dev_MV "device")
Executing: saveRecognition(pfet_dev_TG "device")
Executing: saveRecognition(pfet_dev_SCG "device")
Executing: saveRecognition(pfet_dev_HV "device")
Executing: saveRecognition(pfet_dev_b "device")
Executing: saveRecognition(pfet_dev_HVT "device")
Executing: saveRecognition(pfet_dev_HVT_b "device")
Executing: saveRecognition(pfet_mul_psp "device")
Executing: saveRecognition(pfet_mul_psp_MV "device")
Executing: saveRecognition(pfet_mul_psp_HV "device")
Executing: saveRecognition(pfet_mul "device")
Executing: saveRecognition(pfet_mul_MV "device")
Executing: saveRecognition(pfet_mul_HV "device")
Executing: saveRecognition(pfet_mul_HVT "device")
Executing: saveRecognition(pfet_mul_TG "device")
Executing: saveRecognition(pfet_mul_SCG "device")
Executing: saveRecognition(pfRF_dev_psp "device")
Executing: saveRecognition(pfRF_dev_psp_MV "device")
Executing: saveRecognition(pfRF_dev_psp_HV "device")
Executing: saveRecognition(pfRF_dev "device")
Executing: saveRecognition(pfRF_dev_MV "device")
Executing: saveRecognition(pfRF_dev_HV "device")
Executing: saveRecognition(pfRF_mul_psp "device")
Executing: saveRecognition(pfRF_mul_psp_MV "device")
Executing: saveRecognition(pfRF_mul_psp_HV "device")
Executing: saveRecognition(pfRF_mul "device")
Executing: saveRecognition(pfRF_mul_MV "device")
Executing: saveRecognition(pfRF_mul_HV "device")
Executing: saveRecognition(pfRF_dev_TG "device")
Executing: saveRecognition(pfRF_mul_TG "device")
Executing: saveRecognition(pfRF_dev_SCG "device")
Executing: saveRecognition(pfRF_mul_SCG "device")
Executing: saveRecognition(efuse "device")
Executing: saveRecognition(DI_diode "device")
Executing: saveRecognition(DIPI_diode "device")
Executing: saveRecognition(DI_VPNP "device")
Executing: saveRecognition(hvr_dev "device")
Executing: saveRecognition(diffhavar_dev "device")
Executing: saveRecognition(ntie_device "device")
Executing: saveRecognition(ptie_device "device")
Executing: saveRecognition(mosvar_dev "device")
Executing: saveRecognition(mosvar50_dev "device")
Executing: saveRecognition(p5pcdcap50_dev "device")
Executing: saveRecognition(diffmosvar_dev "device")
Executing: saveRecognition(pcap_dev "device")
Executing: saveRecognition(ncap_dev "device")
Executing: saveRecognition(vlnpn_dev "device")
Executing: saveRecognition(ncap33_dev "device")
Executing: saveRecognition(ncap50_dev "device")
Executing: saveRecognition(jfet_dev "device")
Executing: saveRecognition(ESD_pdnw_diode "device")
Executing: saveRecognition(ESD_pdnw_diode_GR_sized "device")
Executing: saveRecognition(ESD_pdnw_diode_GR "device")
Executing: saveRecognition(ESD_ndsx "device")
Executing: saveRecognition(ESD_ndsx_GR_sized "device")
Executing: saveRecognition(ESD_ndsx_GR "device")
Executing: saveRecognition(ESD_ndsx_pi "device")
Executing: saveRecognition(ESD_pdnw_pi "device")
Executing: saveRecognition(esdnsh_dev "device")
Executing: saveRecognition(esdpsh_dev "device")
Executing: saveRecognition(SBD "device")
Executing: saveRecognition(SBDNW "device")
Executing: saveRecognition(PSBD "device")
Executing: saveRecognition(rnw6pc_dev "device")
Executing: saveRecognition(res6pc_dev "device")
Executing: saveRecognition(rnw6rr_dev "device")
Executing: saveRecognition(res6rr_dev "device")
Executing: saveRecognition(rnw6rp_dev "device")
Executing: saveRecognition(res6rp_dev "device")
Executing: saveRecognition(res6n_dev "device")
Executing: saveRecognition(res6p_dev "device")
Executing: saveRecognition(res6n_sblk "device")
Executing: saveRecognition(res6p_sblk "device")
Executing: saveRecognition(k1_dev_bb "device")
Executing: saveRecognition(k1_dev_sx "device")
Executing: saveRecognition(res_serpentine "device")
Executing: saveRecognition(resnw_serpentine "device")
Executing: saveRecognition(am_transmission "device")
Executing: saveRecognition(ind2_mtam_m1 "device")
Executing: saveRecognition(ind2_mtam_bb "device")
Executing: saveRecognition(symind3_amam_m1 "device")
Executing: saveRecognition(symind3_amam_bb "device")
Executing: saveRecognition(symind2_amam_m1 "device")
Executing: saveRecognition(symind2_amam_bb "device")
Executing: saveRecognition(coupledA "device")
Executing: saveRecognition(singleEndA "device")
Executing: saveRecognition(coupledT "device")
Executing: saveRecognition(singleEndT "device")
Executing: saveRecognition(coupled4 "device")
Executing: saveRecognition(singleEnd4 "device")
Executing: saveRecognition(coupled3 "device")
Executing: saveRecognition(singleEnd3 "device")
Executing: saveRecognition(coupled2 "device")
Executing: saveRecognition(singleEnd2 "device")
Executing: saveRecognition(MIMpi "device")
Executing: saveRecognition(MIMnw "device")
Executing: saveRecognition(MIMsx "device")
Executing: saveRecognition(MIMhdpi "device")
Executing: saveRecognition(MIMhdnw "device")
Executing: saveRecognition(MIMhdsx "device")
Executing: saveRecognition(MIMHKpi "device")
Executing: saveRecognition(MIMHKnw "device")
Executing: saveRecognition(MIMHKpc "device")
Executing: saveRecognition(MIMHKsx "device")
Executing: saveRecognition(DUALMIMpi "device")
Executing: saveRecognition(DUALMIMnw "device")
Executing: saveRecognition(DUALMIMsx "device")
Executing: saveRecognition(DUALMIMhdpi "device")
Executing: saveRecognition(DUALMIMhdnw "device")
Executing: saveRecognition(DUALMIMhdsx "device")
Executing: saveRecognition(bondPad_PC "device")
Executing: saveRecognition(bondPad_BB "device")
Executing: saveRecognition(padOverDev "device")
Executing: saveRecognition(sub_dev "device")
Executing: saveRecognition(corrPoint_dev_PD "device")
Executing: saveRecognition(corrPoint_dev_ND "device")
Executing: saveRecognition(corrPoint_dev_PC "device")
Executing: saveRecognition(corrPoint_dev_M1 "device")
Executing: saveRecognition(corrPoint_dev_M2 "device")
Executing: saveRecognition(m1_RES_min "device")
Executing: saveRecognition(m2_RES_min "device")
Executing: saveRecognition(m3_RES_min "device")
Executing: saveRecognition(m4_RES_min "device")
Executing: saveRecognition(mt_RES_min "device")
Executing: saveRecognition(am_RES_min "device")
Executing: saveRecognition(pdiode_dev "device")
Executing: saveRecognition(pwell_dev "device")
Executing: saveRecognition(piwell_dev "device")
Executing: saveRecognition(ndiode_dev "device")
Executing: saveRecognition(nwdiode_dev "device")
Executing: saveRecognition(nwdiode_dev1 "device")
Executing: errorLayer(geomOverlap(bkgnd chipedge) "###### SIX levels of metal M1-M2-M3-M4-MT-AM #####")
Executing: (saveInterconnect (padOverDev_top "AM") (SBDNW_A "RX") (SBDNW_C "RX") (SBD_A ...
Finished running rules. Task processor time in main process:
cpu: 2.70 elap: 3 pf: 0 in: 0 out: 0 virt: 0M phys: 10608M
No output post-processing: This is not a DRC run
Finished building the persistent database.
cpu: 0.01 elap: 0 pf: 0 in: 0 out: 0 virt: 0M phys: 13432M
***** aveng terminated normally *****
Finished /opt/cadence/ASSURA41//tools/assura/bin/aveng
Starting /opt/cadence/ASSURA41//tools/assura/bin/avrpt /home/wdanesh/Inverter.rsf
@(#)$CDS: avrpt version av4.1:Production:dfII6.1.6:IC6.1.6.500.4 08/29/2014 14:17 (sjfbm166) $
sub-version 4.1_USR4_HF16, integ signature 2014-08-29-1354
run on cycle1.eecs.ku.edu from /opt/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/avrpt on Fri Aug 7 09:21:07 2015
Creating Error Database 'Inverter'...
Reading VDB ...
avlck: INFO: Note that OpenAccess (OA) requires running the Configure phase.
avlck: See the "OpenAccess Installation and Configuration Guide" before
avlck: you complete the configuration step. This manual is included with
avlck: the Cadence product documentation.
avlck: ERROR: The command /opt/cadence/ASSURA41/share/oa/bin/sysname returned an error status:
unknown
Rule Message FlatCount RealCount
( 1) dataAuditErrors 0 0
( 2) SBLK without OP 0 0
( 3) efuse device without bp 0 0
( 4) efuse device touching ns,rx,jd,pi,rn,nw, 0 0
( 5) HAVAR device missing bb 0 0
( 6) HAVAR device touching pi,nw,nr,pr,dg,tg, 0 0
( 7) SBD device without NS 0 0
( 8) NS straddling SBD device 0 0
( 9) SBD device touching jd,pi,nw,nr,pr,dg,tg 0 0
( 10) SBDNW device must be covered by NW 0 0
( 11) SBDNW device touching ns,jd,pi,rn,nr,pr, 0 0
( 12) PSBD device touching ns,jd,rn,nr,pr,dg,t 0 0
( 13) PSBD device missing bb 0 0
( 14) DI Diode device without bp 0 0
( 15) DI Diode device touching ns,jd,pi,rn,nr, 0 0
( 16) DIPI Diode device touching ns,jd,rn,nr,p 0 0
( 17) DIPI Diode device touching nw,bp 0 0
( 18) pcap device touching ns,jd,rn,nr,pr,bb,d 0 0
( 19) pcap device touching tg 0 0
( 20) N+ diffusion in pcap pwell found 0 0
( 21) vlnpn device touching ns,jd,rn,nr,pr,bb, 0 0
( 22) mosvar device touching dg 0 0
( 23) P+ diffusion in ncap nwell found 0 0
( 24) mosvar or ncap device touching ns,jd,pi, 0 0
( 25) JFET device not over pi 0 0
( 26) JFET device touching ns,jd,rn,nr,pr,bb,d 0 0
( 27) Dual gate poly device without M1/CA conn 0 0
( 28) N+ Diffused Resistor device touching ns, 0 0
( 29) FET device touching ns,jd,rn,bb,rr,rp,pd 0 0
( 30) Diffused Resistor device touching bb,dg, 0 0
( 31) Diffused Resistor device touching ns,jd, 0 0
( 32) Polysilicon Resistor device touching ns, 0 0
( 33) Polysilicon Resistor device not covered 0 0
( 34) Polysilicon Resistor device BB touching 0 0
( 35) Polysilicon Resistor device RR or RP tou 0 0
( 36) (AM res) not covered by mask AM 0 0
( 37) (MT res) not covered by mask MT 0 0
( 38) (M4 res) not covered by mask M4 0 0
( 39) (M3 res) not covered by mask M3 0 0
( 40) (M2 res) not covered by mask M2 0 0
( 41) (M1 res) not covered by mask M1 0 0
( 42) Overlapping transmission lines - termina 0 0
( 43) inductor device touching ns,jd,pi,rn,nw, 0 0
( 44) M3 and M4 inside enhanced Inductor model 0 0
( 45) M3/M4 inside standard inductor model is 0 0
( 46) Missing v3 vias on symind coils between 0 0
( 47) Missing v4 vias on symind coils between 0 0
( 48) Missing v3 vias on symind coils between 0 0
( 49) Missing v4 vias on symind coils between 0 0
( 50) Missing ft vias on symind coils between 0 0
( 51) Missing ft vias on symind coils between 0 0
( 52) Missing ft vias on ind coils between mt 0 0
( 53) AM signal wire exiting symetrical induct 0 0
( 54) Center tap signal wire exiting symetrica 0 0
( 55) AM signal wire not exiting transmission 0 0
( 56) M4 signal wire not exiting transmission 0 0
( 57) MT signal wire not exiting transmission 0 0
( 58) M3 signal wire not exiting transmission 0 0
( 59) M2 signal wire not exiting transmission 0 0
( 60) No FT via over HT 0 0
( 61) No FT via over QT 0 0
( 62) MODEL concern - K1 resistor not totally 0 0
( 63) nw_StampErrorConnect 0 0
( 64) nw_StampErrorFloat 0 0
( 65) nw_StampErrorMult 0 0
( 66) nw_StampErrorConnect 0 0
( 67) nw_StampErrorFloat 0 0
( 68) nw_StampErrorMult 0 0
( 69) ncap_nw_StampErrorConnect 0 0
( 70) ncap_nw_StampErrorFloat 0 0
( 71) ncap_nw_StampErrorMult 0 0
( 72) well_StampErrorConnect 0 0
( 73) well_StampErrorFloat 0 0
( 74) well_StampErrorMult 0 0
( 75) pi_StampErrorConnect 0 0
( 76) pi_StampErrorFloat 0 0
( 77) pi_StampErrorMult 0 0
( 78) pwell_StampErrorConnect 0 0
( 79) pwell_StampErrorFloat 0 0
( 80) pwell_StampErrorMult 0 0
( 81) ns_StampErrorConnect 0 0
( 82) ns_StampErrorFloat 0 0
( 83) ns_StampErrorMult 0 0
( 84) substrate_ptap_StampErrorCon 0 0
( 85) substrate_StampErrorCon 0 0
( 86) sub_sti_StampErrorCon 0 0
( 87) sub1K_StampErrorConnect 0 0
( 88) sub50_StampErrorConnect 0 0
( 89) Mixed voltage net found : 3V3 or 5V diff 0 0
( 90) ptap connected to POWER net found ! 0 0
( 91) pwtap connected to POWER net found ! 0 0
( 92) forward biased ptie device found ! [tdpd 0 0
( 93) forward biased ntie device found ! [tdnd 0 0
( 94) NW ring not connected to a power net fou 0 0
( 95) vlnpn collector not connected to nw_ring 0 0
( 96) ###### SIX levels of metal M1-M2-M3-M4-M 0 0
( 97) malformed device nfeti_dev 0 0
( 98) malformed device nfeti_dev_psp 0 0
( 99) malformed device nfeti_dev_b 0 0
( 100) malformed device nfeti_dev_psp_b 0 0
( 101) malformed device nfet6_dev 0 0
( 102) malformed device nfet6_dev_psp 0 0
( 103) malformed device nfet6_dev_b 0 0
( 104) malformed device nfet6_dev_psp_b 0 0
( 105) malformed device nfeti_dev_MV 0 0
( 106) malformed device nfeti_dev_psp_MV 0 0
( 107) malformed device nfet6_dev_MV 0 0
( 108) malformed device nfet6_dev_psp_MV 0 0
( 109) malformed device nfeti_dev_HV 0 0
( 110) malformed device nfeti_dev_psp_HV 0 0
( 111) malformed device nfet6_dev_HV 0 0
( 112) malformed device nfet6_dev_psp_HV 0 0
( 113) malformed device nfeti_dev_TG 0 0
( 114) malformed device nfet6_dev_TG 0 0
( 115) malformed device nfet_dpw 0 0
( 116) malformed device nfet_dev 0 0
( 117) malformed device nfet_dpw_psp 0 0
( 118) malformed device nfet_dev_psp 0 0
( 119) malformed device nfzv_dev 0 0
( 120) malformed device nfzv_dev_HV 0 0
( 121) malformed device nfet_dpw_MV 0 0
( 122) malformed device nfet_dev_MV 0 0
( 123) malformed device nfet_dpw_psp_MV 0 0
( 124) malformed device nfet_dev_psp_MV 0 0
( 125) malformed device nfet_dpw_HV 0 0
( 126) malformed device nfet_dev_HV 0 0
( 127) malformed device nfet_dpw_psp_HV 0 0
( 128) malformed device nfet_dev_psp_HV 0 0
( 129) malformed device nfet_dpw_TG 0 0
( 130) malformed device nfet_dev_TG 0 0
( 131) malformed device nfet_dev_HVT 0 0
( 132) malformed device nfet_dev_HVT_b 0 0
( 133) malformed device nfet_dpw_b 0 0
( 134) malformed device nfet_dev_b 0 0
( 135) malformed device nfet_dpw_psp_b 0 0
( 136) malformed device nfet_dev_psp_b 0 0
( 137) malformed device pfet_dev 0 0
( 138) malformed device pfet_dev_psp 0 0
( 139) malformed device pfet_dev_MV 0 0
( 140) malformed device pfet_dev_psp_MV 0 0
( 141) malformed device pfet_dev_HV 0 0
( 142) malformed device pfet_dev_psp_HV 0 0
( 143) malformed device pfet_dev_TG 0 0
( 144) malformed device pfet_dev_SCG 0 0
( 145) malformed device pfet_dev_HVT 0 0
( 146) malformed device pfet_dev_HVT_b 0 0
( 147) malformed device pfet_dev_b 0 0
( 148) malformed device pfet_dev_psp_b 0 0
( 149) malformed device nfeti_mul 0 0
( 150) malformed device nfeti_mul_psp 0 0
( 151) malformed device nfet6_mul 0 0
( 152) malformed device nfet6_mul_psp 0 0
( 153) malformed device nfeti_mul_MV 0 0
( 154) malformed device nfeti_mul_psp_MV 0 0
( 155) malformed device nfet6_mul_MV 0 0
( 156) malformed device nfet6_mul_psp_MV 0 0
( 157) malformed device nfeti_mul_HV 0 0
( 158) malformed device nfeti_mul_psp_HV 0 0
( 159) malformed device nfet6_mul_HV 0 0
( 160) malformed device nfet6_mul_psp_HV 0 0
( 161) malformed device nfeti_mul_TG 0 0
( 162) malformed device nfet6_mul_TG 0 0
( 163) malformed device nfet_mul 0 0
( 164) malformed device nfet_mul_psp 0 0
( 165) malformed device nfzv_mul 0 0
( 166) malformed device nfzv_mul_HV 0 0
( 167) malformed device nfet_mul_MV 0 0
( 168) malformed device nfet_mul_psp_MV 0 0
( 169) malformed device nfet_mul_HV 0 0
( 170) malformed device nfet_mul_psp_HV 0 0
( 171) malformed device nfet_mul_TG 0 0
( 172) malformed device nfet_mul_HVT 0 0
( 173) malformed device pfet_mul 0 0
( 174) malformed device pfet_mul_psp 0 0
( 175) malformed device pfet_mul_MV 0 0
( 176) malformed device pfet_mul_psp_MV 0 0
( 177) malformed device pfet_mul_HV 0 0
( 178) malformed device pfet_mul_psp_HV 0 0
( 179) malformed device pfet_mul_TG 0 0
( 180) malformed device pfet_mul_SCG 0 0
( 181) malformed device pfet_mul_HVT 0 0
( 182) malformed device nfRFi_dev 0 0
( 183) malformed device nfRFi_dev_psp 0 0
( 184) malformed device nfRF6_dev 0 0
( 185) malformed device nfRF6_dev_psp 0 0
( 186) malformed device nfRFi_dev_MV 0 0
( 187) malformed device nfRFi_dev_psp_MV 0 0
( 188) malformed device nfRF6_dev_MV 0 0
( 189) malformed device nfRF6_dev_psp_MV 0 0
( 190) malformed device nfRFi_dev_HV 0 0
( 191) malformed device nfRFi_dev_psp_HV 0 0
( 192) malformed device nfRF6_dev_HV 0 0
( 193) malformed device nfRF6_dev_psp_HV 0 0
( 194) malformed device nfRFi_dev_TG 0 0
( 195) malformed device nfRF6_dev_TG 0 0
( 196) malformed device nfRF_dev 0 0
( 197) malformed device nfRF_dev_psp 0 0
( 198) malformed device nfRF_dev_MV 0 0
( 199) malformed device nfRF_dev_psp_MV 0 0
( 200) malformed device nfRF_dev_HV 0 0
( 201) malformed device nfRF_dev_psp_HV 0 0
( 202) malformed device nfRF_dev_TG 0 0
( 203) malformed device pfRF_dev 0 0
( 204) malformed device pfRF_dev_psp 0 0
( 205) malformed device pfRF_dev_MV 0 0
( 206) malformed device pfRF_dev_psp_MV 0 0
( 207) malformed device pfRF_dev_HV 0 0
( 208) malformed device pfRF_dev_psp_HV 0 0
( 209) malformed device pfRF_dev_TG 0 0
( 210) malformed device pfRF_dev_SCG 0 0
( 211) malformed device nfRFi_mul 0 0
( 212) malformed device nfRFi_mul_psp 0 0
( 213) malformed device nfRF6_mul 0 0
( 214) malformed device nfRF6_mul_psp 0 0
( 215) malformed device nfRFi_mul_MV 0 0
( 216) malformed device nfRFi_mul_psp_MV 0 0
( 217) malformed device nfRF6_mul_MV 0 0
( 218) malformed device nfRF6_mul_psp_MV 0 0
( 219) malformed device nfRFi_mul_HV 0 0
( 220) malformed device nfRFi_mul_psp_HV 0 0
( 221) malformed device nfRF6_mul_HV 0 0
( 222) malformed device nfRF6_mul_psp_HV 0 0
( 223) malformed device nfRFi_mul_TG 0 0
( 224) malformed device nfRF6_mul_TG 0 0
( 225) malformed device nfRF_mul 0 0
( 226) malformed device nfRF_mul_psp 0 0
( 227) malformed device nfRF_mul_MV 0 0
( 228) malformed device nfRF_mul_psp_MV 0 0
( 229) malformed device nfRF_mul_HV 0 0
( 230) malformed device nfRF_mul_psp_HV 0 0
( 231) malformed device nfRF_mul_TG 0 0
( 232) malformed device pfRF_mul 0 0
( 233) malformed device pfRF_mul_psp 0 0
( 234) malformed device pfRF_mul_MV 0 0
( 235) malformed device pfRF_mul_psp_MV 0 0
( 236) malformed device pfRF_mul_HV 0 0
( 237) malformed device pfRF_mul_psp_HV 0 0
( 238) malformed device pfRF_mul_TG 0 0
( 239) malformed device pfRF_mul_SCG 0 0
( 240) malformed device hvr_dev 0 0
( 241) malformed device diffhavar_dev 0 0
( 242) malformed device SBD 0 0
( 243) malformed device SBDNW 0 0
( 244) malformed device PSBD 0 0
( 245) malformed device DI_diode 0 0
( 246) malformed device DIPI_diode 0 0
( 247) malformed device DI_VPNP 0 0
( 248) malformed device ncap_dev 0 0
( 249) malformed device ncap33_dev 0 0
( 250) malformed device ncap50_dev 0 0
( 251) malformed device diffmosvar_dev 0 0
( 252) malformed device mosvar_dev 0 0
( 253) malformed device mosvar50_dev 0 0
( 254) malformed device p5pcdcap50_dev 0 0
( 255) malformed device vlnpn_dev 0 0
( 256) malformed device jfet_dev 0 0
( 257) malformed device res_serpentine 0 0
( 258) malformed device resnw_serpentine 0 0
( 259) malformed device rnw6pc_dev 0 0
( 260) malformed device res6pc_dev 0 0
( 261) malformed device rnw6rr_dev 0 0
( 262) malformed device res6rr_dev 0 0
( 263) malformed device rnw6rp_dev 0 0
( 264) malformed device res6rp_dev 0 0
( 265) malformed device res6n_dev 0 0
( 266) malformed device res6p_dev 0 0
( 267) malformed device res6n_sblk 0 0
( 268) malformed device res6p_sblk 0 0
( 269) malformed device k1_dev_bb 0 0
( 270) malformed device k1_dev_sx 0 0
( 271) malformed device esdnsh_dev 0 0
( 272) malformed device esdpsh_dev 0 0
( 273) malformed device sub_dev 0 0
( 274) malformed device ntie_device 0 0
( 275) malformed device ptie_device 0 0
( 276) malformed device corrPoint_dev_M2 0 0
( 277) malformed device corrPoint_dev_PD 0 0
( 278) malformed device corrPoint_dev_ND 0 0
( 279) malformed device corrPoint_dev_PC 0 0
( 280) malformed device corrPoint_dev_M1 0 0
( 281) malformed device ESD_pdnw_diode 0 0
( 282) malformed device ESD_pdnw_diode_GR_sized 0 0
( 283) malformed device ESD_pdnw_diode_GR 0 0
( 284) malformed device ESD_ndsx 0 0
( 285) malformed device ESD_ndsx_GR_sized 0 0
( 286) malformed device ESD_ndsx_GR 0 0
( 287) malformed device MIMpi 0 0
( 288) malformed device MIMnw 0 0
( 289) malformed device MIMsx 0 0
( 290) malformed device MIMhdpi 0 0
( 291) malformed device MIMhdnw 0 0
( 292) malformed device MIMhdsx 0 0
( 293) malformed device MIMHKpi 0 0
( 294) malformed device MIMHKnw 0 0
( 295) malformed device MIMHKpc 0 0
( 296) malformed device MIMHKsx 0 0
( 297) malformed device DUALMIMpi 0 0
( 298) malformed device DUALMIMnw 0 0
( 299) malformed device DUALMIMsx 0 0
( 300) malformed device DUALMIMhdpi 0 0
( 301) malformed device DUALMIMhdnw 0 0
( 302) malformed device DUALMIMhdsx 0 0
( 303) malformed device vncap_top1 0 0
( 304) malformed device vncap_tnw1 0 0
( 305) malformed device vncap_topt 0 0
( 306) malformed device vncap_tnwt 0 0
( 307) malformed device vncap_top2 0 0
( 308) malformed device vncap_tnw2 0 0
( 309) malformed device vncap_top3 0 0
( 310) malformed device vncap_tnw3 0 0
( 311) malformed device vncap_top4 0 0
( 312) malformed device vncap_tnw4 0 0
( 313) malformed device am_transmission 0 0
( 314) malformed device ind2_mtam_m1 0 0
( 315) malformed device ind2_mtam_bb 0 0
( 316) malformed device symind3_amam_bb 0 0
( 317) malformed device symind3_amam_m1 0 0
( 318) malformed device symind2_amam_bb 0 0
( 319) malformed device symind2_amam_m1 0 0
( 320) malformed device padOverDev 0 0
( 321) malformed device bondPad_PC 0 0
( 322) malformed device bondPad_BB 0 0
( 323) malformed device efuse 0 0
( 324) malformed device coupledA 0 0
( 325) malformed device singleEndA 0 0
( 326) malformed device coupledT 0 0
( 327) malformed device singleEndT 0 0
( 328) malformed device coupled4 0 0
( 329) malformed device singleEnd4 0 0
( 330) malformed device coupled3 0 0
( 331) malformed device singleEnd3 0 0
( 332) malformed device coupled2 0 0
( 333) malformed device singleEnd2 0 0
( 334) malformed device pdiode_dev 0 0
( 335) malformed device ndiode_dev 0 0
( 336) malformed device ndiode_dev 0 0
( 337) malformed device nwdiode_dev1 0 0
( 338) malformed device nwdiode_dev 0 0
( 339) malformed device pwell_dev 0 0
( 340) malformed device piwell_dev 0 0
( 341) unstable device for piwell_dev_Device_31 0 0
( 343) unstable device for pwell_dev_Device_318 0 0
( 345) unstable device for nwdiode_dev_Device_3 0 0
( 347) unstable device for nwdiode_dev1_Device_ 0 0
( 349) unstable device for ndiode_dev_Device_31 0 0
( 351) unstable device for ndiode_dev_Device_31 0 0
( 353) unstable device for pdiode_dev_Device_31 0 0
( 355) unstable device for am_RES_min_Device_31 0 0
( 357) unstable device for m4_RES_min_Device_31 0 0
( 359) unstable device for m4_RES_min_Device_30 0 0
( 361) unstable device for m3_RES_min_Device_30 0 0
( 363) unstable device for m3_RES_min_Device_30 0 0
( 365) unstable device for m2_RES_min_Device_30 0 0
( 367) unstable device for m2_RES_min_Device_30 0 0
( 369) unstable device for mt_RES_min_Device_30 0 0
( 371) unstable device for mt_RES_min_Device_30 0 0
( 373) unstable device for m1_RES_min_Device_29 0 0
( 375) unstable device for m1_RES_min_Device_29 0 0
( 377) unstable device for singleEnd2_shield1 0 0
( 379) unstable device for coupled2_shield1 0 0
( 381) unstable device for singleEnd3_shield2 0 0
( 383) unstable device for singleEnd3_shield1 0 0
( 385) unstable device for coupled3_shield2 0 0
( 387) unstable device for coupled3_shield1 0 0
( 389) unstable device for singleEnd4_shield3 0 0
( 391) unstable device for singleEnd4_shield2 0 0
( 393) unstable device for singleEnd4_shield1 0 0
( 395) unstable device for coupled4_shield3 0 0
( 397) unstable device for coupled4_shield2 0 0
( 399) unstable device for coupled4_shield1 0 0
( 401) unstable device for singleEndT_shield4 0 0
( 403) unstable device for singleEndT_shield3 0 0
( 405) unstable device for singleEndT_shield2 0 0
( 407) unstable device for singleEndT_shield1 0 0
( 409) unstable device for coupledT_shield4 0 0
( 411) unstable device for coupledT_shield3 0 0
( 413) unstable device for coupledT_shield2 0 0
( 415) unstable device for coupledT_shield1 0 0
( 417) unstable device for singleEndA_shieldT 0 0
( 419) unstable device for singleEndA_shield4 0 0
( 421) unstable device for singleEndA_shield3 0 0
( 423) unstable device for singleEndA_shield2 0 0
( 425) unstable device for singleEndA_shield1 0 0
( 427) unstable device for coupledA_shieldT 0 0
( 429) unstable device for coupledA_shield4 0 0
( 431) unstable device for coupledA_shield3 0 0
( 433) unstable device for coupledA_shield2 0 0
( 435) unstable device for coupledA_shield1 0 0
( 437) unstable device for efuse_Device_266 0 0
( 439) unstable device for bondPad_BB_Device_26 0 0
( 441) unstable device for bondPad_PC_Device_26 0 0
( 443) unstable device for padOverDev_Device_26 0 0
( 445) unstable device for symind2_amam_m1_Devi 0 0
( 447) unstable device for symind2_amam_bb_Devi 0 0
( 449) unstable device for symind3_amam_m1_Devi 0 0
( 451) unstable device for symind3_amam_m1_Devi 0 0
( 453) unstable device for symind3_amam_bb_Devi 0 0
( 455) unstable device for symind3_amam_bb_Devi 0 0
( 457) unstable device for ind2_mtam_bb_Device_ 0 0
( 459) unstable device for ind2_mtam_m1_Device_ 0 0
( 461) unstable device for am_transmission_Devi 0 0
( 463) unstable device for vncap_tnw4_Device_25 0 0
( 465) unstable device for vncap_top4_pwell 0 0
( 467) unstable device for vncap_top4_subs 0 0
( 469) unstable device for vncap_tnw3_Device_25 0 0
( 471) unstable device for vncap_top3_pwell 0 0
( 473) unstable device for vncap_top3_subs 0 0
( 475) unstable device for vncap_tnw2_Device_24 0 0
( 477) unstable device for vncap_top2_pwell 0 0
( 479) unstable device for vncap_top2_subs 0 0
( 481) unstable device for vncap_tnwt_Device_24 0 0
( 483) unstable device for vncap_topt_pwell 0 0
( 485) unstable device for vncap_topt_subs 0 0
( 487) unstable device for vncap_tnw1_Device_24 0 0
( 489) unstable device for vncap_top1_pwell 0 0
( 491) unstable device for vncap_top1_subs 0 0
( 493) unstable device for DUALMIMhdsx_Device_2 0 0
( 495) unstable device for DUALMIMhdnw_Device_2 0 0
( 497) unstable device for DUALMIMhdpi_Device_2 0 0
( 499) unstable device for DUALMIMsx_Device_235 0 0
( 501) unstable device for DUALMIMnw_Device_234 0 0
( 503) unstable device for DUALMIMpi_Device_233 0 0
( 505) unstable device for MIMHKsx_Device_232 0 0
( 507) unstable device for MIMHKpc_Device_231 0 0
( 509) unstable device for MIMHKnw_Device_230 0 0
( 511) unstable device for MIMHKpi_Device_229 0 0
( 513) unstable device for MIMhdsx_Device_228 0 0
( 515) unstable device for MIMhdnw_Device_227 0 0
( 517) unstable device for MIMhdpi_Device_226 0 0
( 519) unstable device for MIMsx_Device_225 0 0
( 521) unstable device for MIMnw_Device_224 0 0
( 523) unstable device for MIMpi_Device_223 0 0
( 525) unstable device for ESD_ndsx_pi_Device_2 0 0
( 527) unstable device for ESD_pdnw_pi_Device_2 0 0
( 529) unstable device for ESD_ndsx_GR_Device_2 0 0
( 531) unstable device for ESD_ndsx_GR_sized_De 0 0
( 533) unstable device for ESD_ndsx_Device_218 0 0
( 535) unstable device for ESD_pdnw_diode_GR_De 0 0
( 537) unstable device for ESD_pdnw_diode_GR_si 0 0
( 539) unstable device for ESD_pdnw_diode_Devic 0 0
( 541) unstable device for corrPoint_dev_M1_Dev 0 0
( 543) unstable device for corrPoint_dev_PC_Dev 0 0
( 545) unstable device for corrPoint_dev_ND_Dev 0 0
( 547) unstable device for corrPoint_dev_PD_Dev 0 0
( 549) unstable device for corrPoint_dev_M2_Dev 0 0
( 551) unstable device for ptie_device_Device_2 0 0
( 553) unstable device for ntie_device_Device_2 0 0
( 555) unstable device for ntie_device_Device_2 0 0
( 557) unstable device for sub_dev_Device_206 0 0
( 559) unstable device for esdpsh_dev_Device_20 0 0
( 561) unstable device for esdnsh_dev_Device_20 0 0
( 563) unstable device for esdnsh_dev_Device_20 0 0
( 565) unstable device for k1_dev_sx_pwell 0 0
( 567) unstable device for k1_dev_sx_subs 0 0
( 569) unstable device for k1_dev_bb_Device_200 0 0
( 571) unstable device for res6p_sblk_Device_19 0 0
( 573) unstable device for res6n_sblk_pwell 0 0
( 575) unstable device for res6n_sblk_subs 0 0
( 577) unstable device for res6p_dev_Device_196 0 0
( 579) unstable device for res6n_dev_pwell 0 0
( 581) unstable device for res6n_dev_subs 0 0
( 583) unstable device for res6rp_dev_pwell 0 0
( 585) unstable device for res6rp_dev_subs 0 0
( 587) unstable device for rnw6rp_dev_Device_19 0 0
( 589) unstable device for res6rr_dev_pwell 0 0
( 591) unstable device for res6rr_dev_subs 0 0
( 593) unstable device for rnw6rr_dev_Device_18 0 0
( 595) unstable device for res6pc_dev_pwell 0 0
( 597) unstable device for res6pc_dev_subs 0 0
( 599) unstable device for rnw6pc_dev_Device_18 0 0
( 601) unstable device for resnw_serpentine_Dev 0 0
( 603) unstable device for res_serpentine_Devic 0 0
( 605) unstable device for jfet_dev_Device_182 0 0
( 607) unstable device for vlnpn_dev_Device_181 0 0
( 609) unstable device for pcap_dev_Device_180 0 0
( 611) unstable device for p5pcdcap50_dev_Devic 0 0
( 613) unstable device for mosvar50_dev_Device_ 0 0
( 615) unstable device for mosvar_dev_Device_17 0 0
( 617) unstable device for diffmosvar_dev_Devic 0 0
( 619) unstable device for ncap50_dev_Device_17 0 0
( 621) unstable device for ncap33_dev_Device_17 0 0
( 623) unstable device for ncap_dev_Device_173 0 0
( 625) unstable device for DI_VPNP_Device_172 0 0
( 627) unstable device for DIPI_diode_Device_17 0 0
( 629) unstable device for DI_diode_Device_170 0 0
( 631) unstable device for PSBD_Device_169 0 0
( 633) unstable device for SBDNW_Device_168 0 0
( 635) unstable device for SBD_Device_167 0 0
( 637) unstable device for diffhavar_dev_Device 0 0
( 639) unstable device for hvr_dev_Device_165 0 0
( 641) unstable device for pfRF_mul_SCG_Device_ 0 0
( 643) unstable device for pfRF_mul_TG_Device_1 0 0
( 645) unstable device for pfRF_mul_psp_HV_Devi 0 0
( 647) unstable device for pfRF_mul_HV_Device_1 0 0
( 649) unstable device for pfRF_mul_psp_MV_Devi 0 0
( 651) unstable device for pfRF_mul_MV_Device_1 0 0
( 653) unstable device for pfRF_mul_psp_Device_ 0 0
( 655) unstable device for pfRF_mul_Device_157 0 0
( 657) unstable device for nfRF_mul_TG_Device_1 0 0
( 659) unstable device for nfRF_mul_TG_Device_1 0 0
( 661) unstable device for nfRF_mul_psp_HV_Devi 0 0
( 663) unstable device for nfRF_mul_psp_HV_Devi 0 0
( 665) unstable device for nfRF_mul_HV_Device_1 0 0
( 667) unstable device for nfRF_mul_HV_Device_1 0 0
( 669) unstable device for nfRF_mul_psp_MV_Devi 0 0
( 671) unstable device for nfRF_mul_psp_MV_Devi 0 0
( 673) unstable device for nfRF_mul_MV_Device_1 0 0
( 675) unstable device for nfRF_mul_MV_Device_1 0 0
( 677) unstable device for nfRF_mul_psp_Device_ 0 0
( 679) unstable device for nfRF_mul_psp_Device_ 0 0
( 681) unstable device for nfRF_mul_Device_143 0 0
( 683) unstable device for nfRF_mul_Device_144 0 0
( 685) unstable device for nfRF6_mul_TG_Device_ 0 0
( 687) unstable device for nfRFi_mul_TG_Device_ 0 0
( 689) unstable device for nfRF6_mul_psp_HV_Dev 0 0
( 691) unstable device for nfRF6_mul_HV_Device_ 0 0
( 693) unstable device for nfRFi_mul_psp_HV_Dev 0 0
( 695) unstable device for nfRFi_mul_HV_Device_ 0 0
( 697) unstable device for nfRF6_mul_psp_MV_Dev 0 0
( 699) unstable device for nfRF6_mul_MV_Device_ 0 0
( 701) unstable device for nfRFi_mul_psp_MV_Dev 0 0
( 703) unstable device for nfRFi_mul_MV_Device_ 0 0
( 705) unstable device for nfRF6_mul_psp_Device 0 0
( 707) unstable device for nfRF6_mul_Device_131 0 0
( 709) unstable device for nfRFi_mul_psp_Device 0 0
( 711) unstable device for nfRFi_mul_Device_129 0 0
( 713) unstable device for pfRF_dev_SCG_Device_ 0 0
( 715) unstable device for pfRF_dev_TG_Device_1 0 0
( 717) unstable device for pfRF_dev_psp_HV_Devi 0 0
( 719) unstable device for pfRF_dev_HV_Device_1 0 0
( 721) unstable device for pfRF_dev_psp_MV_Devi 0 0
( 723) unstable device for pfRF_dev_MV_Device_1 0 0
( 725) unstable device for pfRF_dev_psp_Device_ 0 0
( 727) unstable device for pfRF_dev_Device_121 0 0
( 729) unstable device for nfRF_dev_TG_Device_1 0 0
( 731) unstable device for nfRF_dev_TG_Device_1 0 0
( 733) unstable device for nfRF_dev_psp_HV_Devi 0 0
( 735) unstable device for nfRF_dev_psp_HV_Devi 0 0
( 737) unstable device for nfRF_dev_HV_Device_1 0 0
( 739) unstable device for nfRF_dev_HV_Device_1 0 0
( 741) unstable device for nfRF_dev_psp_MV_Devi 0 0
( 743) unstable device for nfRF_dev_psp_MV_Devi 0 0
( 745) unstable device for nfRF_dev_MV_Device_1 0 0
( 747) unstable device for nfRF_dev_MV_Device_1 0 0
( 749) unstable device for nfRF_dev_psp_Device_ 0 0
( 751) unstable device for nfRF_dev_psp_Device_ 0 0
( 753) unstable device for nfRF_dev_Device_107 0 0
( 755) unstable device for nfRF_dev_Device_108 0 0
( 757) unstable device for nfRF6_dev_TG_Device_ 0 0
( 759) unstable device for nfRFi_dev_TG_Device_ 0 0
( 761) unstable device for nfRF6_dev_psp_HV_Dev 0 0
( 763) unstable device for nfRF6_dev_HV_Device_ 0 0
( 765) unstable device for nfRFi_dev_psp_HV_Dev 0 0
( 767) unstable device for nfRFi_dev_HV_Device_ 0 0
( 769) unstable device for nfRF6_dev_psp_MV_Dev 0 0
( 771) unstable device for nfRF6_dev_MV_Device_ 0 0
( 773) unstable device for nfRFi_dev_psp_MV_Dev 0 0
( 775) unstable device for nfRFi_dev_MV_Device_ 0 0
( 777) unstable device for nfRF6_dev_psp_Device 0 0
( 779) unstable device for nfRF6_dev_Device_95 0 0
( 781) unstable device for nfRFi_dev_psp_Device 0 0
( 783) unstable device for nfRFi_dev_Device_93 0 0
( 785) unstable device for pfet_mul_HVT_Device_ 0 0
( 787) unstable device for pfet_mul_SCG_Device_ 0 0
( 789) unstable device for pfet_mul_TG_Device_9 0 0
( 791) unstable device for pfet_mul_psp_HV_Devi 0 0
( 793) unstable device for pfet_mul_HV_Device_8 0 0
( 795) unstable device for pfet_mul_psp_MV_Devi 0 0
( 797) unstable device for pfet_mul_MV_Device_8 0 0
( 799) unstable device for pfet_mul_psp_Device_ 0 0
( 801) unstable device for pfet_mul_Device_84 0 0
( 803) unstable device for nfet_mul_HVT_Device_ 0 0
( 805) unstable device for nfet_mul_TG_Device_8 0 0
( 807) unstable device for nfet_mul_TG_Device_8 0 0
( 809) unstable device for nfet_mul_psp_HV_Devi 0 0
( 811) unstable device for nfet_mul_psp_HV_Devi 0 0
( 813) unstable device for nfet_mul_HV_Device_7 0 0
( 815) unstable device for nfet_mul_HV_Device_7 0 0
( 817) unstable device for nfet_mul_psp_MV_Devi 0 0
( 819) unstable device for nfet_mul_psp_MV_Devi 0 0
( 821) unstable device for nfet_mul_MV_Device_7 0 0
( 823) unstable device for nfet_mul_MV_Device_7 0 0
( 825) unstable device for nfzv_mul_HV_Device_7 0 0
( 827) unstable device for nfzv_mul_Device_71 0 0
( 829) unstable device for nfet_mul_psp_Device_ 0 0
( 831) unstable device for nfet_mul_psp_Device_ 0 0
( 833) unstable device for nfet_mul_Device_67 0 0
( 835) unstable device for nfet_mul_Device_68 0 0
( 837) unstable device for nfet6_mul_TG_Device_ 0 0
( 839) unstable device for nfeti_mul_TG_Device_ 0 0
( 841) unstable device for nfet6_mul_psp_HV_Dev 0 0
( 843) unstable device for nfet6_mul_HV_Device_ 0 0
( 845) unstable device for nfeti_mul_psp_HV_Dev 0 0
( 847) unstable device for nfeti_mul_HV_Device_ 0 0
( 849) unstable device for nfet6_mul_psp_MV_Dev 0 0
( 851) unstable device for nfet6_mul_MV_Device_ 0 0
( 853) unstable device for nfeti_mul_psp_MV_Dev 0 0
( 855) unstable device for nfeti_mul_MV_Device_ 0 0
( 857) unstable device for nfet6_mul_psp_Device 0 0
( 859) unstable device for nfet6_mul_Device_55 0 0
( 861) unstable device for nfeti_mul_psp_Device 0 0
( 863) unstable device for nfeti_mul_Device_53 0 0
( 865) unstable device for pfet_dev_psp_b_Devic 0 0
( 867) unstable device for pfet_dev_b_Device_51 0 0
( 869) unstable device for pfet_dev_HVT_b_Devic 0 0
( 871) unstable device for pfet_dev_HVT_Device_ 0 0
( 873) unstable device for pfet_dev_SCG_Device_ 0 0
( 875) unstable device for pfet_dev_TG_Device_4 0 0
( 877) unstable device for pfet_dev_psp_HV_Devi 0 0
( 879) unstable device for pfet_dev_HV_Device_4 0 0
( 881) unstable device for pfet_dev_psp_MV_Devi 0 0
( 883) unstable device for pfet_dev_MV_Device_4 0 0
( 885) unstable device for pfet_dev_psp_Device_ 0 0
( 887) unstable device for pfet_dev_Device_41 0 0
( 889) unstable device for nfet_dev_psp_b_Devic 0 0
( 891) unstable device for nfet_dpw_psp_b_Devic 0 0
( 893) unstable device for nfet_dev_b_Device_38 0 0
( 895) unstable device for nfet_dpw_b_Device_37 0 0
( 897) unstable device for nfet_dev_HVT_b_Devic 0 0
( 899) unstable device for nfet_dev_HVT_Device_ 0 0
( 901) unstable device for nfet_dev_TG_Device_3 0 0
( 903) unstable device for nfet_dpw_TG_Device_3 0 0
( 905) unstable device for nfet_dev_psp_HV_Devi 0 0
( 907) unstable device for nfet_dpw_psp_HV_Devi 0 0
( 909) unstable device for nfet_dev_HV_Device_3 0 0
( 911) unstable device for nfet_dpw_HV_Device_2 0 0
( 913) unstable device for nfet_dev_psp_MV_Devi 0 0
( 915) unstable device for nfet_dpw_psp_MV_Devi 0 0
( 917) unstable device for nfet_dev_MV_Device_2 0 0
( 919) unstable device for nfet_dpw_MV_Device_2 0 0
( 921) unstable device for nfzv_dev_HV_Device_2 0 0
( 923) unstable device for nfzv_dev_Device_23 0 0
( 925) unstable device for nfet_dev_psp_Device_ 0 0
( 927) unstable device for nfet_dpw_psp_Device_ 0 0
( 929) unstable device for nfet_dev_Device_20 0 0
( 931) unstable device for nfet_dpw_Device_19 0 0
( 933) unstable device for nfet6_dev_TG_Device_ 0 0
( 935) unstable device for nfeti_dev_TG_Device_ 0 0
( 937) unstable device for nfet6_dev_psp_HV_Dev 0 0
( 939) unstable device for nfet6_dev_HV_Device_ 0 0
( 941) unstable device for nfeti_dev_psp_HV_Dev 0 0
( 943) unstable device for nfeti_dev_HV_Device_ 0 0
( 945) unstable device for nfet6_dev_psp_MV_Dev 0 0
( 947) unstable device for nfet6_dev_MV_Device_ 0 0
( 949) unstable device for nfeti_dev_psp_MV_Dev 0 0
( 951) unstable device for nfeti_dev_MV_Device_ 0 0
( 953) unstable device for nfet6_dev_psp_b_Devi 0 0
( 955) unstable device for nfet6_dev_b_Device_7 0 0
( 957) unstable device for nfet6_dev_psp_Device 0 0
( 959) unstable device for nfet6_dev_Device_5 0 0
( 961) unstable device for nfeti_dev_psp_b_Devi 0 0
( 963) unstable device for nfeti_dev_b_Device_3 0 0
( 965) unstable device for nfeti_dev_psp_Device 0 0
( 967) unstable device for nfeti_dev_Device_1 0 0
Total errors: 0 0
Finished creating Error Database ...
Writing Report into ./Inverter.err ...
avrpt cpu sec: 0.18 elapsed: 0 virtual: 76M
Finished /opt/cadence/ASSURA41//tools/assura/bin/avrpt
Starting /opt/cadence/ASSURA41//tools/assura/bin/avcallproc /home/wdanesh/Inverter.rsf -exec1 -LVS -cdslib /home/wdanesh/cds.lib
Finished /opt/cadence/ASSURA41//tools/assura/bin/avcallproc
Starting /opt/cadence/ASSURA41//tools/assura/bin/avnx /home/wdanesh/Inverter.rsf -exec1 -LVS -cdslib /home/wdanesh/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
Checking out license for Assura_LVS
@(#)$CDS: avnx version av4.1:Production:dfII6.1.6:IC6.1.6.500.4 08/29/2014 14:16 (sjfbm166) $
run on cycle1.eecs.ku.edu from /opt/cadence/ASSURA41/tools.lnx86/assura/bin/32bit/avnx on Fri Aug 7 09:21:08 2015
avnx started...
unknown
cpu: 0.39 elap: 0 pf: 0 in: 0 out: 16 virt: 0M phys: 16M
Run time = 0.00 seconds
CPU time = 0.44 seconds
End of Summary Report
cpu: 0.01 elap: 0 pf: 0 in: 0 out: 0 virt: 0M phys: 13640M
***** avnx terminated normally *****
Finished /opt/cadence/ASSURA41//tools/assura/bin/avnx
Starting /opt/cadence/ASSURA41//tools/assura/bin/nvn /home/wdanesh/Inverter.rsf -postExtract -exec1 -cdslib /home/wdanesh/cds.lib
@(#)$CDS: nvn version av4.1:Production:dfII6.1.6:IC6.1.6.500.4 08/29/2014 14:18 (sjfbm166) $
run on cycle1.eecs.ku.edu at Fri Aug 7 09:21:09 2015
INFO (AVLVSNN-10120) : '.nocase' command in binding file also switches on softSearchDeviceName(t) option to ensure, that compare rules are applied correctly.
Reading schematic network
Reading layout network
inputting network Inverter.ldb
Preprocessing schematic network phase 1
*WARNING* deleteCellPin - Unable to find cell 'NFET50TW'
*WARNING* deleteCellPin - Unable to find cell 'NFET33TW'
*WARNING* deleteCellPin - Unable to find cell 'NFETTW'
*WARNING* deleteCellPin - Unable to find cell 'nfet50tw'
*WARNING* deleteCellPin - Unable to find cell 'nfet33tw'
*WARNING* deleteCellPin - Unable to find cell 'nfettw'
Preprocessing layout network phase 1
WARNING (AVLVSNN-10050) : capDevice - cell 'vncap' not found.
WARNING (AVLVSNN-10050) : capDevice - cell 'dualmimhd' not found.
WARNING (AVLVSNN-10050) : capDevice - cell 'dualmim' not found.
WARNING (AVLVSNN-10050) : capDevice - cell 'mimhk' not found.
WARNING (AVLVSNN-10050) : capDevice - cell 'mimhd' not found.
WARNING (AVLVSNN-10050) : capDevice - cell 'mim' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'subcx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'sblkpdresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'sblkpdres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'sblkndresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'sblkndres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'rr_serpentinex' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'rr_serpentine' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'oprrpresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'oprrpres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'oprppresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'oprppres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'opppcresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'opppcres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'oppdresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'oppdres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'opndresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'opndres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'lvsresx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'lvsres' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'k1resx' not found.
WARNING (AVLVSNN-10050) : resDevice - cell 'k1res' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'zvtnfet33x' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'zvtnfet33' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'zvtnfetx' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'zvtnfet' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'p5pfet50x' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'p5pfet50' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'pfethvx' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'pfethv' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'pfet50x' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'pfet50' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'pfet33x' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'pfet33' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'pfetx' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'nfethvx' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'nfethv' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'nfet50x' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'nfet50' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'nfet33x' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'nfet33' not found.
WARNING (AVLVSNN-10050) : mosDevice - cell 'nfetx' not found.
WARNING (AVLVSNN-10050) : bjtDevice - cell 'divpnp' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'tdpdnw' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'dipdnw' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'psbd' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'sbdnw' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'sbd' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'havar' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'esdpnpi' not found.
WARNING (AVLVSNN-10050) : dioDevice - cell 'esdndpi' not found.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'diodenwx' is not found and
will be considered a dummy cell. The default binding for layout cell 'diodenwx(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'nfet' is not found and
will be considered a dummy cell. The default binding for layout cell 'nfet(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfet' is not found and
will be considered a dummy cell. The default binding for layout cell 'pfet(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'pfetx' is not found and
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'subc' is not found and
will be considered a dummy cell. The default binding for layout cell 'subc(Generic)' will be broken.
WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'subcx' is not found and
Preprocessing schematic network phase 2
Preprocessing layout network phase 2
*ERROR* Device 'nfet(MOS)' on Layout is unbound to any Schematic device.
*ERROR* Device 'pfet(MOS)' on Layout is unbound to any Schematic device.
*ERROR* Device 'subc(RES)' on Layout is unbound to any Schematic device.
*ERROR* UnBound devices found.
Info: All devices must be bound or filtered for comparision to be run.
Exiting nvn.
***** nvn fork terminated abnormally *****
*WARNING* nvn exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
  • Quek
    Quek over 10 years ago
    Hi Wafi Danesh
    Assura reported the following errors at the end of the log file:
    The above errors mean that you have extra devices in the layout. You can force LVS to complete by using "abortOnUnboundDevices" avCompareRules cmd in the LVS form.
    Best regards
    Quek
  • w888ku
    w888ku over 10 years ago
    Thank you very much Quek for the reply! My LVS is working now. But, a new query has come up regarding the CDL netlist for the LVS. I am simulating digital CMOS circuits and before performing the LVS I have to prepare the CDL netlist. I want to choose digital for the netlist creation, however, when I do that, the LVS gives the errors as I mentioned in the post previously. But when I choose analog, the LVS runs without error. My question is, then should I continue with the analog netlist for my digital simulations or is there a way to change the that. Any help would be appreciated. Thanks in advance
    Whether you use digital or analog netlisting mode is not really anything to do with whether your circuit is analog or digital. It's more to do with which flow the design kit is set up for.
    Historically there were two different flows in the Cadence IC tools, from 20-25 years or so back. One was more digital-centric, and one more analog-centric. Because of their different heritages, they had different ways of describing how each component should be netlisted. The digital flow used properties on the stopping view and "NLP" expressions, whereas the analog flow used CDF to describe the information about the components and how they should be netlisted.
    Most design kits nowadays are analog-centric, and even if you are using the design kit for digital transistor level circuitry, the chances are you'd use the analog-centriic flow and netlisters.
    So it sounds whether you should use the analog netlister. Typically the only place you'd choose is for CDL netlisting (and for Diva LVS too, but most likely you're not using that).
  • w888ku
    Thank you very much for the clarification Andrew! Best regards, Wafi
