  3. Import cdl netlis
  • Views 16446
Import cdl netlis
masa071
masa071 over 11 years ago
I try to import CDL netlist (standard cell) in cadence IC6.
file->import->spice (netlist =language CDL)
However  there are following error and I can't import the file.
spiceIn:  error while loading shared libraries: libdbm.so2: wrong ELF class: ELFCLASS32 ERROR (SPICEIN_GUI-25))
Do you know that how I can to import cdl file?
  • theopaone
    theopaone over 11 years ago
    This one you probably want to call in to Cadence support. This usually means that you are trying to use a 32 bit shared object file with a 64 bit compiled function.
    This is where I got some insight:
    http://www.linuxquestions.org/questions/programming-9/wrong-elf-class-elfclass32-857222/
