  3. measurements with transient sim with temp as a dynamic ...
  • Views 15681
measurements with transient sim with temp as a dynamic parameter
vamshiky
vamshiky over 11 years ago
I have a simple opamp setup with a single sine input and wish to plot output pk-pk variation with temperature swept min to max with 1degC step. (in tran sim)
Instead of doing 100s of sims for every 1degC, I have planned to use dyn parameter for temp and use in single tran run,
but confused about how to measure the output pk-pk wrt temp after the run is done, as the peak-peak calculator function only gives over complete time window and need to clip for every temp step.?
Please help me in this regard.
Thank,
Vamshi
  • vamshiky
    In otherwords I need a calculator function which takes a transient voltage waveforms and plots the peak-peak every cycle as a function of time.
    Not sure this is quite what you want but you may be able to adapt it to your needs (it finds the local peaks and returns them as a waveform):
    /* abGetPeakList.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 19, 2005
    Modified   Jun 06, 2011
    By         A.D.Beckett
    Example:
    peaks=abGetPeakList(myWaveObj 'minimum)
    abWritePeakListToFile(peaks "peaks.out")
    Also has a function which returns a waveform of the peaks:
    plot(abPeakDetect(v("/out" ?result 'tran) "maximum"))
    SCCS Info: @(#) abGetPeakList.il 06/06/11.14:21:52 1.3
    *                   abGetPeakList(waveform maximum)                   *
    *       Given a waveform object, and a second argument which is       *
    * t, "max", "maximum", 'max, 'maximum or nil, "min", "minimum", 'min, *
    *       or 'minimum, return a list of x-y pairs for the peaks.        *
    procedure(abGetPeakList(waveform maximum)
        let((xVec yVec len previous delta previousDelta current output)
            xVec=drGetWaveformXVec(waveform)
            yVec=drGetWaveformYVec(waveform)
            len=drVectorLength(xVec)
            ; Iterate over points in waveform
            for(index 0 sub1(len)
                current=drGetElem(yVec index)
                when(previous
                    delta=current-previous
                    ; Check to see if previous point was a peak, and if so
                    ; add it to the output list
                    when(
                        case(maximum
                            ((nil min minimum "min" "minimum")
                                delta>=0 &&
                                (!previousDelta || previousDelta<=0)
                            (;(t max maximum "max" "maximum")
                             t
                                delta<=0 &&
                                (!previousDelta || previousDelta>=0)
                            ) ; case
                        output=tconc(output
                            list(drGetElem(xVec sub1(index)) previous)
                            ) ; tconc
                        ) ; when
                previousDelta=delta
                previous=current
                ) ; for
            ; Return list of x-y points
            car(output)
            ) ; let
        ) ; procedure
    *               abWritePeakListToFile(peakList fileName)               *
    * Given the result of abGetPeakList, write the data to a tab-separated *
    *                                file.                                 *
    procedure(abWritePeakListToFile(peakList fileName)
        let((prt)
            prt=outfile(fileName)
            if(prt then
                foreach(peak peakList
                    fprintf(prt "%13g\t%13g\n" car(peak) cadr(peak))
                    ) ; foreach
                close(prt)
            else
                error("Could not open file %L for writing\n" fileName)
                ) ; if
            ) ; let
        ) ; procedure
    *                  abPeakDetect(waveform maximum)                   *
    *   Function to return a waveform of the peaks in a waveform. The   *
    * second argument must be min, minimum, max or maximum (as a string *
    *                           or a symbol).                           *
    procedure(abPeakDetect(waveform maximum)
        cond(
            (drIsWaveform(waveform)
                let((peaks x y xVec yVec)
                    peaks=abGetPeakList(waveform maximum)
                    x=mapcar('car peaks)
                    y=mapcar('cadr peaks)
                    xVec=drCreateVec('double x)
                    yVec=drCreateVec('double y)
                    xVec~>units=drGetWaveformXVec(waveform)~>units
                    xVec~>name=drGetWaveformXVec(waveform)~>name
                    yVec~>units=drGetWaveformYVec(waveform)~>units
                    yVec~>name=drGetWaveformYVec(waveform)~>name
                    drCreateWaveform(xVec yVec)
            (famIsFamily(waveform)
                famMap('abPeakDetect waveform maximum)
            (t
                error("abPeakDetect: Cannot handle %L\n" waveform)
