  3. Noise file - vsource
  • Views 3633
analogy
analogy over 11 years ago
While trying to add noisefile in vsource from analogLib, I encountered the following error :
Error found by spectre during circuit read-in.
    ERROR (SFE-874): "input.scs" 14: Unexpected hierarchical name "noise.txt". Expected end of file or end of line.
I am even attaching a noise file (click here) I generated.It's a tab delimited file.I suspect the error lies with format of file.Is it ?
Thanks.
Edit: hierachical name ? Checked for EOL in file format , there is no end of line error (based on my understanding).
  • Tawna
    Tawna over 11 years ago
    Hi Analogy,
    Just a quick note
    Please check out this article on Cadence Online Support:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20256770
    Also, check the  Spectre RF User Guide .   It has information on noisefiles for the port.  Much of the port parameters also apply to the vsource.
    best regards,
    Tawna
