  3. Ultrasim Error for Stitching
  • Views 14708
Cuong Truong
Cuong Truong over 11 years ago
Hi everyone,
Could you help me a problem for Stitching in Ultrasim?
I build a testbench using SPICE: ideal netlist and SPF netlist.
After running simulation, I got the logfile with message: UltraSim completed successfully.
However, there are many errors: "node not found" exist in spf report (.spfrpt).
I checked the hierachical patterns between two netlists but it was not a reason.
Could you help me to solve that problems?
The problem was solved.
    Please contact customer support for this. I think it will be quite hard to debug without seeing the data and the precise messages.
  • Cuong Truong
    Thanks for your response.
