  3. ADE L simulation problems with stimulus file
  • Views 15526
orgconfuzion
orgconfuzion over 10 years ago
Hello, I have some problem with layout simulation with extracted parameters. ADE L doesn't recognize stimulus file for
layout simulation, in schematic simulation everything works ok. I have this error message:
ERROR (SFE-868): "input.scs" 2548: Unable to open input file '(there is file directory)'
thank you on help
Regards
Pavle.
    Not really enough information to go on - but the most likely situation is that the file can't be opened! Check the path reported in the spectre error message, and check that the permissions are correct that you can read it (on the machine where the simulation is running).
    If you can't get to the bottom of it this way, talking to customer support is probably your best bet because we'd need to understand more about the precise nature of the problem - and going back and forth via the forums is not going to be very efficient.
