  3. SpiceIn "subtype" User Property
  • Views 1816
garobe
garobe over 10 years ago
I found another thread with a similar problem, but it ended without a real solution (link is below), so I'm hoping to see if there have been any updates regarding it.  I have successfully created schematics from a CDL netlist, but can't get the SpiceIn tool to stop creating a User Property called "subtype."  In one particular case, it creates the "subtype" User Property and assigns a local value of "NFET."  This appears to be causing a problem in ADE as Spectre is looking for an "NFET" subtype when only an "nfet" exists.
If I could either have SpiceIn not create the subtype User Property, or change it so that the local value is not capitalized, I believe things should start working again, though I'm not certain.  I am not terribly familiar with Skill, so I'm hoping there is a solution that involves setting up SpiceIn correctly rather than hacking schematics...
Gideon
community.cadence.com/.../18414
  • Quek
    Quek over 10 years ago
    Hi Gideon
    Would you please try adding "model cdlModel" as one of the parameters to be mapped during spiceIn? I used this to prevent spiceIn from overwriting the value of the original "model" CDF parameter from the device.
    Best regards
    Quek
